DQ200 BASIC SETTING OF TRASMISSION ISSUE
Daniele
Italy
C?ID=368452
Hello everyone. I am an owner of GOLF TGI DSG 7, which start has trasmission problem very early 10000 km.:banghead:
I feel the trasmission change very soon, the engine always labouring at low rpm, a very bad response of the engine when pushing accelerator pedal.
These problems start very likely, after a bodyshop mechanich reparation, where the battery was probabily disconnected.
I lost hope in VW service, so I decided try to do adaptation by my self with a rosstech HEX V2 bought recently.
TBA was perform succesfully and now I can feel the car better.
Then an IDE 02903 [basic setting of trasmission] was selected from the scroll menu; initially the screen, shown "RUNNING" but after some minutes and some normal noise of trasmission, the "UNKNOW" message appear (with ignition ON, engine OFF), made me very concerned.
This procedure appear different from what I aspected, expecially comparing with the one on the following link: wiki-ross tech at this link http://wiki.ross-tech.com/wiki/index.php/7-Speed_Direct_Shift_Gearbox_(DSG/0AM),
So here I don't need to set any group, eg.60 etc...
No fault codes are stored and the car seems work quite well, but always with not the best response of the engne when pressing accelerator pedal.
I found somebody who post the following procedure:
"Engine idle speed, do not press accelerator pedal
Parking brake and foot brake applied during the entire procedure. This can be confirmed using Advanced Measuring Values:
* IDE02713 Brake Light Switch
* IDE02714 Brake test switch
0D9 - DQ250 MQB - Basic Settings Procedure:
[Select]
[02- Auto Trans]
[Basic Settings-04]
Select [Basic settings of transmission]
[Show Measuring Data] and select:
* IDE00021 Engine speed
* IDE00322 Status of basic setting
* IDE00024 Transmission fluid temperature
[Go!]
- During the basic setting procedure, there may be some loud gear shifting noises from the transmission, this is normal."
In my situation , with idle engine the "UNKNOW" message is shown again and adaptation does not start: I don't know if procedure was succesfully or not, is there a more update guide please??
Many tanks!
Daniele
Italy
C?ID=368452
I hope this is the scan required
Tuesday,04,June,2019,22:20:41:51758
VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZJP121418   Mileage: 28884km-17947miles
Address 01: Engine (J623-CPWA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 ER    HW: 04E 907 309 E
   Component: R4 1.4l CSI   H16 5823
   Revision: WIH16---
   Coding: 01250032236405082000
   Shop #: WSC 30054 264 00000
   ASAM Dataset: EV_ECM14CSI01104E906016ER 002003
   ROD: EV_ECM14CSI01104E906016EH.rod
   VCID: 76B5E77AC84B9F57E0D-8022
   CAN Converter 01:
   Part No SW: 0CW 300 041 N    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1605
   Revision: 00005008    Serial number: CU501802195161
   Shop #: WSC 00028 028 00066
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 40D941A2DA0F61E78A1-8014
   Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
   Component: ESC           H25 0523
   Revision: 00000000    Serial number: 60668000003493
   Coding: 01FA6AA12422216D477B060160CB2580562484E26006A4733822F078C202430B00000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 03538EAE8B99BAFFD73-8056
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 00020004200110011005000000101022
   VCID: 6D87C816BD1D5C8F117-8038
   Air quality sensor:
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001806503990
   ROD: EV_BCMBOSCH_018.rod
   VCID: 08499982B2BF99A7821-805C
   Component: WWS    180210  043 0551
   Serial number:         180218230320
   Component: RLHS  047 0105
   Serial number: S8Y18M03D08H09M42S06
   Coding: 00A8DD
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418018053
   Coding: 0471051811
   VCID: 4BC3668EE349B2BF6F3-801E
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 3300670111FFC728949C810580400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E253F5AA0FB1717F8D-806A
   Part No SW: 5Q0 959 655 BH    HW: 5Q0 959 655 BH
   Component: AirbagVW21    005 0336
   Serial number: 003VVR3YZFV
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00063
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 074B9ABEBFA196DF8BB-8052
   Subsystem 1 - Part No SW: -----------    HW: 480 000 103 18
   Serial number: 35700000000755C81C2O
   Subsystem 2 - Part No SW: -----------    HW: 480 000 103 18
   Serial number: 35800000000E0C393C2S
   Subsystem 3 - Part No SW: -----------    HW: 480 400 903 18
   Serial number: 3510001AD298CB0286EJ
   Subsystem 4 - Part No SW: -----------    HW: 480 400 903 18
   Serial number: 3520001C1294E953E7FK
   Subsystem 5 - Part No SW: -----------    HW: 480 400 303 18
   Serial number: 3550001C32929722E460
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 08031820240175
   Coding: 0410
   VCID: 025D8BAA9483B3F7DC5-8056
   Part No SW: 5G1 920 752 C    HW: 5G1 920 752 C
   Component: KOMBI         302 0310
   Coding: 07A42A082780000801882A011401000080000000
   Shop #: WSC 00028 028 00070
   VCID: 290FFC06497580AFBDF-807C
   Component: GW MQB High   518 5323
   Serial number: 24021810803755
   Coding: 030100047F085708FA0002481C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 3829294282DF2927321-806C
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29180000271310098061
   Coding: 2CFFFF
   Serial number: 0494257004
   Serial number: 0000306993038
   Coding: 003A03208000020000001000
   Shop #: WSC 00028 028 00231
   VCID: 47CB5ABEFF2156DF4BB-8012
   Serial number: 00000000000008307055
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 011F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B3DE6EDB398A7FC73-8026
   Serial number: 0000306159747
   Coding: 003A01208E00020000801000
   VCID: 46D557BAF82B4FD7B0D-8012
   Serial number: 00000000000008298091
   Coding: 090000
   Part No SW: 3Q0 035 824 C    HW: 3Q0 035 824 C
   Component: MU-S--ER      722 0867
   Coding: 02731000FF0000005111000100080A001F0500C40120050003
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2D0708167D9D9C8F517-8078
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZJV0636662
End----------(Elapsed Time: 01:18, VBatt start/end: 12.4V/12.3V)-----------
many thanks
Daniele
Italy
C?ID=368452
Solved the problem of basic setting of trasmission.
adv. measuring block select:
-basic setting sequence index (this is essential)
-status of basic setting
-satus of basic setting data
[GO] basic setting of transmission
wait until in the basic setting sequence index appear number 4, and then turn the engine ON
after a couple of minutes and some noise, the live data should diplay now:
-basic setting sequence index: [254]
-status of basic setting: [16]
-satus of basic setting data: [VALID]
...and info: [FINISHED CORRECTLY] finally is dislayed.
This procedure work fine with me, and gears switch are much smoother but the pedal accelerator still has a bad response (only in Drive mode).
Maybe a software problem? I have found this link very interesting seem matching with my issue:http://www.tvsengineering.nl/en/gearbox/dsg/dq200.html
Nitnesvakes
Kosovo
Hey when a want to do the basic setting it gives me the message to enter three numbers.does anybody known which numbers
South Molton, UK
It would be a lot easier to answer your question when you post a full unedited VCDS Auto-Scan so we know what car you have, what TCU is fitted, etc.
Jdobbins
Been waiting over a year for this guide lol. Knew it would come eventually. I had the dreaded unknown too and eventually gave up. Only issue was sometimes I lost drive and if I didn’t know about the holding gas pedal to the floor trick the car would have been off to dealers. I’m still reluctant to try this. Has anyone done a video or maybe plan to ?
