I have tried to get VCDS-mobile to work with my Hex-Net Pro.
I have a problem, described below, with ASAM data download failing.
1. At home network via USB-cable at windows 10 laptop, updating, after clearing RODs with VCDS-Mobile:
VCDS Interface Config V2.248
Downloading DS Update
Getting 530k
Download Finished
Unpacking DS Update
Update completed Successfully
Recheck for updates -> You are up to date.
So, this step seems to go smoothly.
2. At car, Golf R Variant DSG 2019 (post-wltp model):
- Hex-net in Infrastructure mode (Green light), connected to the car.
Starting Autoscan is followed with a warning message about missing ASAM data, and that it can be downloaded after the scan.
After the scan completes, I press Download update. (The saved autoscan log is below).
VCDS-Mobile ASAM Update -> Updating ASAM dataset: 0% Step 1/3 Downloading update 6/1001 KB, Status: Downloaded: 6KB
The only way forward is to press “Cancel the update”.
It always gets stuck at downloading 6KB of ASAM Data, whatever I do. The total amount to be downloaded has changed, however (e.g. to 264KB when starting the “Check for updates” again after cancelling), but it again stops the download immediately at 6KB. I have waited for over 30 minutes, and it does not progress. The Internet connection works fine, and is not slow otherwise.
I have tried “Clear RODs” in VCDS Mobile several times and “Clear Dataset cache” but it has no effect on the end result, always stuck on 6KB’s downloaded (the total amount to be downloaded varies, as said before).
CB: 0.4505
FW:0.256
CFB: 0.10
BL: 0.28
DS: 60000057
How to proceed?
Best regards,
Jukka-Pekka L.
Getting 530k
Download Finished
Unpacking DS Update
Wed,Jun,05,2019,02:02:59
VCDS Mobile 0.4505.0.4
VIN: WVWZZZAUZKP549473
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 36 39 3C 42 44
47 4B 52 5F 75 A5 A9 D6 D7
29-Left Light -- Status: Malfunction 0010
75-Telematics -- Status: Not registered 0001
Address 01: Engine (DNUE J623) Labels: 8V-01.lbl
Part No SW: 8V0 906 259 R HW: 06K 907 425 J
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 092540122466050B3000
Shop #: WSC 00028 028 00071
ASAM Dataset: EV_ECM20TFS0208V0906259R 001002
ROD: N/A
VCID: 4FE1E03FCA09A4B28808F1-801A
No ASAM data for: "EV_ECM20TFS0208V0906259R"
No fault codes found.
Address 02: Auto Trans (J743) Labels: 0G-02.clb
Part No SW: 0GC 300 014 B HW: 0GC 927 711 H
Component: GSG DQ381 H06 2403
Revision: 00H06V08
ROD: N/A
VCID: 240B7F93F30F77EA057A16-8071
No ASAM data for: "EV_TCMDQ381061"
Address 03: ABS Brakes (J104) Labels: 5Q-03.clb
Part No SW: 5Q0 614 517 EF HW: 5Q0 614 517 BP
Component: ESC H35 0107
Revision: 00000000
Coding: 04FA6BA150242175477B070760C66920D60A84E2E0069677384250F8D2A84B0B0000000012121212B835351919323200
Shop #: WSC 00028 028 00069
ROD: N/A
VCID: 79B57EE7240DDA0206ACAF-802C
No ASAM data for: "EV_Brake1UDSContiMK100IPB"
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000
Coding: 132C0C0723
ASAM Dataset: EV_KessyHellaMQBAB 004046
ROD: N/A
VCID: 43C9DC0F164150D21CB07D-8016
No ASAM data for: "EV_KessyHellaMQBAB"
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0202002420041001110500420010102A
ROD: N/A
VCID: 6D9D5AB7604576A29A542B-8038
No ASAM data for: "EV_ACClimaBHBVW37X"
Subsystem 1 -
Subsystem 2 -
Subsystem 3 -
Address 09: Cent. Elect. (J519) Labels: 5Q-09.clb
Part No SW: 5Q0 937 086 BQ HW: 5Q0 937 086 BQ
Component: BCM PQ37BOSCH 036 0265
Revision: --------
ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
ROD: N/A
VCID: 8A57B12BF1EB419A9F7668-80DF
No ASAM data for: "EV_BodyContrModul1UDSBosc"
Subsystem 1 - Part No SW: 5G1-955-119-A Labels: 5Qx-955-119-V1.clb
Component: WWS 181130043 0551
Serial Number: 181213162931
Coding: 0E4DFD
Subsystem 2 - Part No SW: 5Q0-955-547-B Labels: 5Q0-955-547.clb
Component: RLHS 052 0107
Serial Number: SAY19M01D17H01M07S34
Coding: 00A8EE
Subsystem 3 - Part No SW: 5Q0-951-172
Serial Number: 000000000ZY183300JM1
Subsystem 4 - Part No SW: 5Q0-951-605-A
Serial Number: 00000000000046218922
Subsystem 5 - Part No SW: 5G0-959-591-A
Component: J245 PS22.409H04 0005
Serial Number: 0000FST0028MNFY00000
Coding: 191900
Subsystem 6 - Part No SW: 5G0-959-591-A
Component: J394 PS22.409H04 0005
Serial Number: 0000FST0028MNDW00000
Coding: 191900
Subsystem 7 -
Subsystem 8 - Part No SW: 5Q1-953-521-M
Component: Lenks.Modul H03 0170
Serial Number: 0100110120190C202314
Address 10: Park/Steer Assist (J446) Labels: 5Q-10.lbl
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Component: PDC 8 Kanal
Coding: 0471155811
ASAM Dataset: EV_EPHVA18AU3700000 009039
ROD: N/A
VCID: 4CDBF7333B1F9FAAEDEADE-8019
No ASAM data for: "EV_EPHVA18AU3700000"
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Coding: 330067C15DFFC728949C810580400600000000000000000004
ROD: N/A
VCID: 44CBDF13134F57EA25BA76-8011
No ASAM data for: "EV_ACCBOSCHVW416"
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Shop #: WSC 00000 000
ROD: N/A
VCID: 3833BBE35F87030AB922F2-806D
No ASAM data for: "EV_DRCONTITEMIC"
Part No SW: 5Q0 959 655 BT HW: 5Q0 959 655 BT
Component: AirbagVW21 007 0403
Shop #: WSC 00028 028 00057
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
ROD: N/A
VCID: 9369AC4FA6A180526CD0CD-80C6
No ASAM data for: "EV_AirbaVW20SMEVW37X"
Subsystem 1 - Part No SW: 5G0-980-945-B
Component: BeltPretRevFLH37 0350
Serial Number: 34169667E17011940669
Coding: 333135
Subsystem 2 - Part No SW: 5G0-980-946-B
Component: BeltPretRevFRH37 0350
Serial Number: 34169668E17011920719
Coding: 333135
Subsystem 3 - Part No SW: --------------
Component: SideSensor_Df001 0887
Serial Number: 357000000003D314D73J
Subsystem 4 - Part No SW: --------------
Component: SideSensor_Pf001 0887
Serial Number: 35800000000EC885D63
Subsystem 5 - Part No SW: --------------
Component: SideSensor_Dr004 6149
Serial Number: 3510001262B805C3D2A+
Subsystem 6 - Part No SW: --------------
Component: SideSensor_Pr004 6149
Serial Number: 35200012E2B7227334B-
Part No SW: 5G1 920 791 B HW: 5G1 920 791 B
Component: KOMBI 403 4191
Coding: 07AD601B7F8C000801887B0B5401000880000000
ROD: N/A
VCID: 2B1994AF9ED1B892C4A045-807E
No ASAM data for: "EV_DashBoardVDDMQBAB"
Address 19: CAN Gateway (J533) Labels: 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Coding: 030100047F085900FB00827E9C0F00010001070000000000000000000000
ROD: N/A
VCID: 6E9F5DBB6D438DBAA35E24-803B
No ASAM data for: "EV_GatewNF"
Subsystem 1 - Component: 1-01-09-01-04
Subsystem 2 - Part No SW: 5G0-959-442-AE Labels: 3C8-959-537.clb
Component: E221__MFL-DC1H11 0052
Serial Number: 29180003056140019017
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0-915-181-K
Component: J367-BDMHellaH10 9070
Serial Number: 1073529304
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Coding: 0001
ROD: N/A
No ASAM data for: "EV_AllWheelContrHA1VW37X"
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevo
ROD: N/A
VCID: 47D1C81F22797CF2C0D889-8012
No ASAM data for: "EV_LCMLeftHELLAAU736"
000033 - ROD - Unknown faultcode
Address 2B: Steer. Col. Lock (J764) Labels: None
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Coding: 0800000000000000
ROD: N/A
VCID: 312586C7BCFDD242FEFC87-8064
No ASAM data for: "EV_ELVMarqMQBA0"
Address 36: Seat Mem. Drvr (J810) Labels: None
Part No SW: 5Q0 959 760 C HW: 5Q0 959 760 C
Component: Sitzmemory H09 0024
Coding: 0010000000000500018280808080000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002022
ROD: N/A
VCID: 3D3DAAF770A526226A743B-8068
No ASAM data for: "EV_SeatMemorDriveSide"
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
ROD: N/A
No ASAM data for: "EV_LCMRightHELLAAU736"
Address 3C: Lane Change (J1086) Labels: 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Coding: 02011103
ROD: N/A
No ASAM data for: "EV_HREntryHella"
Address 42: Door Elect, Driver (J386) Labels: 5Q-42.clb
Part No SW: 5Q4 959 593 F HW: 5Q4 959 593 F
Component: TSG FS 006 0246
Coding: 001F1220D200048000001000
ROD: N/A
VCID: 48D3CB232F67738AC9C282-801D
No ASAM data for: "EV_DCU2DriveSideMAXHCONT"
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 911F0000
ROD: N/A
VCID: 3C3BA7F36BBF2F2A5D4A0E-8069
No ASAM data for: "EV_SteerAssisMQB"
Address 47: Sound System (J525) Labels: 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001
Coding: 12000000008AAA8A000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
ROD: N/A
VCID: 2E1F9DBBADC3CDBAE3DE64-807B
No ASAM data for: "EV_AMPMst11CGen2ALPI"
Address 4B: Multifunc. Module (J745) Labels: None
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Coding: 00000005090019D206204F01020000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: N/A
VCID: 352DB2D74895FE62A204D3-8060
No ASAM data for: "EV_MultiModulContiVW48X"
Address 52: Door Elect, Pass. (J387) Labels: 5Q-52.clb
Part No SW: 5Q4 959 592 F HW: 5Q4 959 592 F
Component: TSG BFS 006 0246
Coding: 001F1020DE00048000001000
ROD: N/A
No ASAM data for: "EV_DCU2PasseSideMAXHCONT"
Address 5F: Information Electr. (J794) Labels: 5N-5f.clb
Part No SW: 5NA 035 043 D HW: 5NA 035 043
Component: MU-H-N-EU H55 1367
Coding: 02731201000000004111000200080A231F0107F4012004009E
ROD: N/A
VCID: 3731B8DF52990C72B038F9-8062
No ASAM data for: "EV_MUHig4CGen2HBAS"
Subsystem 1 - Part No SW: 5G6-919-606
Component: ABT_High-2 H52 9130
Serial Number: VWZ6ZJW0211258
Subsystem 2 - Part No SW: V03-959-806-FL
Component: ECE 2019 --- 0175
Serial Number: --------------------
Subsystem 3 - Part No SW: V03-959-800-EG
Component: Gracenote2 --- 1017
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
Component: OCULowMQBLGE H19 0825
Revision: --------
Coding: 02730201EA42380D3F1CBE020045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004049
ROD: N/A
No ASAM data for: "EV_OCULowMQBLGE"
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 0272
Coding: 0003070200000401002623548150A90098000E300040
ROD: N/A
No ASAM data for: "EV_MFKBoschMQBB"
Address A9: Struct. Borne Sound (J869) Labels: 5G-a9.lbl
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
ROD: N/A
VCID: 2F2180BFAAC9C4B2E8C891-807A
No ASAM data for: "EV_SoundActuaGen2AU64X"
Address D6: Light Ctrl Left 2 (A31) Labels: None
Part No SW: 7P5 941 572 AG HW: 7P5 941 572 A
Component: LED1L H07 0008
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: N/A
VCID: 80439303C7D70BCAC1121A-80D5
No ASAM data for: "EV_LEDMinMaxL_KEBODAVW481"
Address D7: Light Ctrl Right 2 (A27) Labels: None
Component: LED1R H07 0008
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: N/A
No ASAM data for: "EV_LEDMinMaxR_KEBODAVW481"
End--(Elapsed Time: 03:09, VBatt start/end: 12.4/12.3 Vign: 0.0)-
CB: 0.4505
FW:0.256
CFB: 0.10
BL: 0.28
DS: 60000057
How to proceed?
Best regards,
Jukka-Pekka L.
