Solved: [Skoda Fabia RS Tdi] Steering angle sensor (ERROR: Group 001 Not Available)
herwan
Reunion
C?ID=94950
Edit; As of 7/22/2019 this is solved. Please see post #13 for the details.
Hi,
i have a Skoda Fabia TDi RS 130Ch (2006-6y2) and i have an issue with VCDS. When i try to do a [Basic Settings] on VCDS to reset my Steering Angle Sensor (G85) in "group 001" i have this error : ERROR: Group 001 Not Available
When i clear all error code (AutoScan, see below) error is erased but when i'm going in the calculator [03-ABS Brake] default is here again.
I have try to see in the Skoda Fabia section, but nothing available.
I have try this method (Polo) but Group 001 is not available...
My question is : why i don't have "Group 001" and how to reset (basic settings) the steering angle sensor (g85) ?
Do you have an idea ?
Best,
Tuesday,04,June,2019,19:02:33:02394
VCDS Version: 18.9.1.0
VIN: TMBWU26Y864598346   License Plate:
Mileage: 161640km-100438mi   Repair Order:
Chassis Type: 6Y (6Y - Skoda Fabia (1996 > 2008))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: TMBWU26Y864598346   Mileage: 161640km-100438miles
Address 01: Engine        Labels: 038-906-019-ASZ.lbl
   Part No: 038 906 019 NJ
   Component: 1,9l R4 EDC G000SG  7331
   Coding: 00102
   Shop #: WSC 13765
   VCID: 6CD931C21C82AD2A11-4AE6
   TMBWU26Y864598346     SKZ7Z0F3549163
17911 - Load Signal from Alternator Term. DF
            P1503 - 35-10 - Implausible Signal - Intermittent
Readiness: 0 0 1 1 1
Address 03: ABS Brakes        Labels: 6R0-907-37x-ESP80.clb
   Part No SW: 6Q0 907 379 AQ    HW: 6Q0 907 379 AQ
   Component: ESP 8.0 front   H04 0002
   Coding: 0000296
   Shop #: WSC 13765 000 00000
   VCID: 0C1951426C420D2AB1-5120
   Subsystem 1 - Part No: 6Q0 907 379 AQ
No Faults Found
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 6Y0 820 045
   Component: Klimaanlage        X0840
   VCID: 72E52FBA3EA67BDADB-513C
            07-00 - Signal too Low
Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 0000 BN-SG.         1S34
   Coding: 25738
   Shop #: WSC 13765
   VCID: 3C79C1822C62FDAAC1-5120
   Part No: 1C0 909 605 K
   Component: 01 AIRBAG VW51 08   0008
   Coding: 12337
   Shop #: WSC 13765
   VCID: 2C59F1C2DC026D2A51-513C
Address 17: Instruments        Labels: 6Y0-920-xx0-17.lbl
   Part No: 6Y0 920 842 S
   Component: KOMBI+WEGFAHRSP VDO V03
   Coding: 28101
   Shop #: WSC 13765
   VCID: 4B9B925E79CC4A1278-5120
01304 - Radio
            49-00 - No Communications
   Part No: 6N0 909 901
   Component: 003C GATEWAY CAN    1S34
   Coding: 00014
   Shop #: WSC 13765
   VCID: 70E125B230AA49CA2D-513C
   Part No: 6Q0 423 156 AF
   Component: LenkhilfeKYO        V957
   Coding: 10120
   Shop #: WSC 13765
   VCID: 73EB2ABE41BC72D2D0-513C
Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
   Part No: 6Q0 959 433 E
   Component: 5Z Komfortgerát     0002
   Coding: 00019
   Shop #: WSC 13765
   VCID: 3D7FCC863778F4A2F6-4B00
End-------------------------(Elapsed Time: 03:22)--------------------------
Tuesday,04,June,2019,19:03:40:02394
Control Module Part Number:
  Component and/or Version:
           Software Coding:
            Work Shop Code:
                      VCID: 55AF7426BF080CE2DE-513C
                    Fault Status: 01100101
                    Reset counter: 33
                    Mileage: 161642 km
18265 - Load Signal
            P1857 - 000 - Error Message from ECU
                    Reset counter: 33
                    Mileage: 161642 km
Yes, I think the Basic Setting should be available in Group 001.
Does your steering angle sensor work correctly? Check in Measuring Blocks, group 005, field 1. Move the steering wheel. The value should change. With the front wheels pointed straight ahead and the steering wheel centered, it should read no more than +/- 1.5 (or maybe 2.5) degrees.
PS: Please Get Verified. I think you are in category 2 of that post.
herwan
Reunion
C?ID=94950
Hi,
in Measuring Blocks (Group 005, field 1), i have the position of sterring wheel (0.0° when the wheels pointed straight and + or - xxx° when i move the Steering wheel).
it's strange... it's not present in Basic Settings (Group 001).
NEtech
Denmark
C?ID=56995
You did as described, Secure Access etc. ?
herwan
Reunion
C?ID=94950
Hi,
I have change the "steering wheel sensor" by a new and always nothing in Group 001 : ERROR: Group 001 Not Available.
Nobody have an ideas ?
United States
The only thing I see that may explain your issues is a communication problem. For instance, the scan showed
No Faults Found
or a communication error occurred​
.. and the DTC log was missing the part number, etc:
Software Coding:
Work Shop Code:​
I would try using another PC if you happen to have one.
You may also want to make sure the live G85 readings are close to each other when the steering wheel is at the extreme left and right stop. So, if the steering angle reads -430° in one direction it should read close to + 430° in the opposite direction.
PS: After you Get Verified we can move this thread to the Car Repair Support sub-forum so it will receive more views.
herwan
Reunion
C?ID=94950
No Faults Found
Software Coding:
Work Shop Code:​
I get verified first (data has been sent to Ross-Tech) and try another PC this week-end.
Thanks for help.
United States
Thanks for help.
Thanks. I switched your account status to Verified VCDS User and I'll move this thread to the Car Repair section.
herwan
Reunion
C?ID=94950
Hi, I was able to join the "group 001" with a new PC (the procedure worked perfectly).
By contrast, the ESP warning light comes on after a 10-minute drive, I will check the wiring near the alternator as shown on several topics.
herwan
Reunion
C?ID=94950
Hi, after investigations, I had a wire cut near the starter as shown in the picture.
After doing the repair / welding, the tests are conclusive. The ESP indicator will not light up after 10 minutes as before.
Everything is back in order and operational.
