2015 A3 8v - Coolant system
tclark18
C?ID=371550
New to this forum and I love it! New user with vcds and what a great tool. Anyway, 3 weeks ago had fault before i got this Hex-v2 for Coolant flow low / temp.
I cleared thinking hoping just a fluke. 1 week later came back and like a knucklehead i cleared agin and brought to Audi since I still have about 1 month left on warranty. I have 34k miles. I just plugged in my vcds and did a scan, Oh well, code found again but did not trip the check engine light. Please see my scan and
point me in right direction?... I have read about leaking thermostat water pump housings but see no visible leaks anywhere. I am familiar with the plastic that VW uses because I had a jetta that leaked twice from the coolant manifold. Thanks for any advice. LOVE this forum and everything about Ross - Tech!
Monday,03,June,2019,18:56:33:07665
VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
VIN: WAUBFGFF9F1139426   License Plate:
Mileage: 55519km-34497mi   Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 3C 42 44 52 55 5F 6C BB BC
VIN: WAUBFGFF9F1139426   Mileage: 55519km-34497miles
Address 01: Engine (J623-CNTC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0006
   Revision: --H13---
   Coding: 0A1D00324426000F2000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001008
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C01055BE68AE877469-8078
16987 - Insufficient Engine Cooling / Coolant Flow
          P00B7 00 [096] - -
                    Mileage: 55260 km
                    Date: 2019.05.30
                    Time: 17:51:31
                    Engine speed: 0.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 108 °C
                    Intake air temperature: 47 °C
                    Voltage terminal 30: 12.519 V
                    Unlearning counter according OBD: 34
                    Engine: operating status: ES
                    Engine temp. management actuator: raw value: 3715
                    Engine temperature management actuator: stop open: 133
                    Engine temperature management actuator: after-run stop: 3969
                    RVC_SP: 234.69 °
                    RVC_AV: 238.14 °
                    RVCPWM: 33.081 %
   Part No SW: 0D9 300 012 K    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4515
   Revision: 05853104    Serial number: TFK01504020715
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1E65DF93A0360AE7D8D-804A
   Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
   Component: ESC           H42 0610
   Revision: 00000000    Serial number: 61105000002093
   Coding: 13FF6A9234230A75017B030281C929C8562C5080C08194B4024100588208
   ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
   VCID: 48C959CB52322457421-801C
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 186
                    Mileage: 27774 km
                    Date: 2017.09.29
                    Time: 15:48:57
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000628663
   Coding: 03000014010000000000000000001400
   VCID: 33331E273BB4B78F073-8066
   Serial number: D12804A7000000000001
   Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
   Component: BCM MQBAB MNA H18 0137
   Serial number: 01011510000419
   Coding: 04141A46C04122F541C04004511007000000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 79AFEC0F59588DDF8DF-802C
   Component: WWS371 150415  042 0585
   Serial number:         150422013203
   Coding: 0A47F7
   Serial number: 23908855
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 12 02 2015  00001544
   Serial number: 00000000000032291052
   Sun Roof:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST00090EM900000
   Coding: 101F00
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39391510500909
   Coding: 0030150011
   VCID: 42DD4BE3740E0E079C5-8016
   Serial number: 003GCR01V1FK
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47CB5AF75F2C2B2F4BB-8012
   Belt Pretensioner left:
   Serial number: 34178311B21041540228
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34178312B21041540464
   Coding: 333135
   Occupant Detection:
   Serial number: 6940000Y150001BBWY0J
   Coding: 303139
   Subsystem 4 - Part No SW: -----------    HW: 480 001 604 15
   Serial number: 357000000003F314E31G
   Subsystem 5 - Part No SW: -----------    HW: 480 001 604 15
   Serial number: 358000000001F314E31F
   Subsystem 6 - Part No SW: -----------    HW: 480 401 304 15
   Serial number: 3510002A519EFF5383BO
   Subsystem 7 - Part No SW: -----------    HW: 480 401 604 15
   Serial number: 3520002991A87864226+
   Subsystem 8 - Part No SW: -----------    HW: 480 400 902 15
   Serial number: 35500029D196FF52F2CX
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 400 902 15
   Serial number: 35600029F196FF54330F
   Part No SW: 8V0 953 521 CB    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 22041508490633
   Coding: A018
   ROD: EV_SMLSKLOMQB_010_AU37.rod
   VCID: 7CA1F51B566AB8F7969-8028
   Part No SW: 8V0 920 971 D    HW: 8V0 920 971 D
   Component: KOMBI         H02 4292
   Coding: 0BF418092B88D7050200E8001800000000000000
   VCID: 3E253F1300F66AE7F8D-806A
   Revision: --------    Serial number: 18041510801065
   Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72BDDB23042EFE87CC5-8026
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 14 04 2015  C0040578
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00010.03.15
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   VCID: 46D557F358263227B0D-8012
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Serial number: 0363732741
   Coding: 030211
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 3829290B22D254D7321-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0080
   Serial number: 0365753967
   Coding: 030211
   Part No SW: 5Q0 959 393 D    HW: 5Q0 959 393 B
   Serial number: 030415BD311549
   Coding: 00100F204000048000000002
   VCID: 40D941EB7A021C178A1-8014
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 43D34EE76B14070F973-8016
   Part No SW: 5Q0 959 392 D    HW: 5Q0 959 392 B
   Serial number: 250315BCP07028
   Coding: 001007204000048000000002
   VCID: 3FDB421707FC63EFF3B-806A
   Coding: 012A000101000000
   VCID: 75B7E03F7540E9BFE97-8020
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-HGH1.clb
   Part No SW: 8V0 035 047 B    HW: 8V0 035 047 B
   Component: MU-H-NS-US    H43 0394
   Serial number: A052D0FB006165
   Coding: 01730102FF0A000021220001041A00002F000105010001047E
   ROD: EV_MUHig6C3HBAS_AU37.rod
   Subsystem 1 - Part No SW: V03 959 800 SS    HW: -----------
   Component: NAR 2015  --- 0035
   Component: DU High  H49 0014
   Serial number: AUZ8Z9FY202YX9
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 K    HW: 8V0 919 614 K
   Component: ControlUnit_H  H81 0816
   Serial number: C1000030011500030427
   Compact Disc Database:
   Component: Gracenote  --- 3006
0009 - Antenna for Satellite Radio
          B10F4 13 [008] - Open Circuit
                    Reset counter: 56
                    Mileage: 32924 km
                    Date: 2018.05.03
                    Time: 15:53:21
                    Voltage terminal 30: 14.0 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Reception quality: No_signal
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE.rod
   VCID: 3039112BCAA28C977A1-8064
   Part No SW: 5Q0 959 395 D    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0028
   Serial number: 310315BCT12779
   Coding: 000007204000048000000002
   Component: TSG HBFS      020 0028
   Serial number: 310315CCU0499A
End----------(Elapsed Time: 01:35, VBatt start/end: 12.3V/12.3V)-----------
NostraJackAss
Emission standard0GTEmission standard SULEV
Welcome to the VCDS forum OP!
JPPSG!
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Under useful life warranty!
Vehicle Identification No.WAUBFGFF9F1139426
ModelAudi A3 saloon
Quattro 2.0
A3
Date of production05.05.2015
Model year2015
Sales type8VS58L
Engine CodeCNTC
Transmission CodeQSN
Has coolant pump been revised yet?
The warranty on an SULEV is 15/150K you been misinformed!
https://forums.ross-tech.com/showth...uot-JPPSG-quot&p=156577&viewfull=1#post156577
OP: Please post the OBD2 data in VCDS MODES 1,3,7 & 9.........
tclark18
C?ID=371550
My gut tells me no on the coolant pump being revised but I don't know. I purchased the car 5 1/2 months ago from dealer and "car fax" was clean. How do I verify if it is new or not?.....PS..OP?
NostraJackAss
Have you contacted NHTSA and Audi customer care?
OP = Original Poster
Please post the OBD2 data as aforementioned.
RTFB the TSB or TPI....
https://erwin.audiusa.com/erwin/showHome.do
Did you JPPSG yet?
Run along now, go verify and come back with hard data!
tclark18
C?ID=371550
PSS....What you're saying is that my coolant pump falls under the CAA emissions?
tclark18
C?ID=371550
Run along now?, Im not a child....Really, just trying to learn......Guess Ill try to look elsewhere.
NostraJackAss
If a P-code will light up the MIL & the MIL is responsible for informing of CAA failures than isn't it under useful life warranty?
If the engine ran too hot or too cold would it effect SMOG, indeed it would?
Effectively you are new & like a child in a manner of speaking and part of the learning process is following directions and doing home work when asked.
I should of warned you while my methods of being the local yokel asshole are in fact self evident, you should realize that I am trying to help you help yourself.
Did I not answer your questions or point you to where you could scholastically achieve them?
tclark18
C?ID=371550
Your name handle fits you like a glove!....While i was a child I was told no question is a dumb question. That was 45 yrs ago.
With that being said I understand about the warranty now. I assumed that is what you meant. I will contact customer care. Again, I can take the beatings if in the long run I learn as much as I can.......
NostraJackAss
Indeed you will, smart answer & I like it!
Welcome
:p
Seriously JPPSG!
Verify latest part number for coolant pump, it's not like they catch on fire, right?
Einst there was a boo boo.....
https://static.nhtsa.gov/odi/rcl/2018/RIONL-18V229-5195.pdf
This notice applies to your vehicle: NHTSA: 18V229IMPORTANT!Information about Safety Recall 19N4 – After Run Coolant PumpTHIS RECALL REPAIR IS NOT YET AVAILABLE. We will send another letter as soon as therecall work can be completed on your vehicle.As an interim measure, please contact your Audi dealer immediately to have SafetyRecall 19M1 performed.This notice is sent to you in accordance with the National Traffic and Motor Vehicle Safety Act.Audi has decided that a defect, which relates to motor vehicle safety, exists in certain 2013-2017model year Audi vehicles equipped with a 2.0L TFSI gasoline engine. Our records show that youare the owner of a vehicle affected by this action. At this time, the recall repair is not yetavailable; however we anticipate being able to begin recall repairs in late 2018.Recall Description: In certain vehicles equipped with a 2.0L TFSI gasoline engine, the electriccoolant pump may experience a short circuit and/or overheat. A short circuit or overheating withinthe electric coolant pump may lead to a fire resulting in vehicle or other property damage.What You Need to Do: Have Safety Recall 19M1 performed on your vehicle immediately.The software installed for FREE under Safety Recall 19M1 will turn off the electriccoolant pump if the pump becomes blocked with debris, and will alert you if this happensby turning on the Electronic Power Control lamp (EPC). This can help reduce the risk ofthe pump overheating and possibly causing a fire. Please schedule this important, FREErecall with your authorized Audi dealer without delay. Contact your Audi dealer without delay if the EPC light comes on.After Safety Recall 19M1 is completed, an illuminated EPC light can mean that thecoolant pump in your vehicle is blocked. For FREE, your dealer will diagnose the reasonfor the EPC light and also replace the coolant pump for FREE if necessary. Until Safety Recall 19N4 has been completed on your vehicle, Audi recommendsparking your vehicle outdoors as a precaution. Contact your dealer or Audi if you have any concerns about your vehicle.Your authorized Audi dealer knows your vehicle best, and has the tools and informationnecessary to address your vehicle concerns. If you should have any questions about thiscommunication, please contact Audi Customer Experience at 1-800-253-2834 or via our“Contact Us” page at www.audiusa.com.
NostraJackAss
Revision: --H13---
P00B7 00 [096] - -
Mileage: 55260 km
Date: 2019.05.30
Time: 17:51:31
RVC_SP: 234.69 °
RVC_AV: 238.14 °
RVCPWM: 33.081 %
OP: Isn't the ability to see DTC's with VCDS & as proof of a fault, with date and time stamp, oh such a glorious means of documentation for court or to inform an agency when needed?
CAA is fun stuff huh?
FOR EACH PENNY DENIED OR INCURRED, LET ME CAST & THERE BE INVERSE A BILLION PENNIES FOLD
tclark18
C?ID=371550
Jackass..YOU ARE THE MAN....This is the beginning of a long tumultuous relationship!
tclark18
C?ID=371550
Thank You for real....
NostraJackAss
Kind of hard to deny the VCDS legal instrument powerful implications from commencing & with a mere purported auto-scan, huh? :rolleyes:
Post the OBD2 data please OP!
FOD could be lurking!
FOD GIVE BEFORE IT HURTS!
NostraJackASS Has Asked the Right Questions?
tclark18
C?ID=371550
Please, don't shoot me, but i thought I did.....I loaded an auto scan...That not OBD2 data?
Here it comes, hit me.
tclark18
C?ID=371550
Crap....I wanted to post that I found what you meant before u replied..LOL..I will send data......Love love love learning!....
NostraJackAss
Hurry...... it's almost milk time and graham crackers!
tclark18
C?ID=371550
Monday,03,June,2019,22:03:18:07665
VCDS Release 19.6.0 (x64): Generic OBD2
Mode 1:Read Data
05:Engine coolant temperature 102 °C 102 °C
tclark18
C?ID=371550
Monday,03,June,2019,22:05:12:07665
Mode 07: Pending emission related fault codes
Address 7E8: No fault code found.
Address 7E9: No fault code found.
Monday,03,June,2019,22:05:47:07665
Mode 03: Emission related fault codes
Monday,03,June,2019,22:06:19:07665
Monday,03,June,2019,22:06:57:07665
Type 02 - VIN : WAUBFGFF9F1139426 (Address E8)
Type 04 - Calibration ID : 5G0259A 0006AXBK (Address E8)
Type 04 - Calibration ID : 0D9300012K 4515 (Address E9)
Type 06 - Calibration Verification Number : DA544777 (Address E8)
Type 06 - Calibration Verification Number : 0000E245 (Address E9)
Type 08 - In-use performance tracking :
OBD Monitoring Conditions Encountered count : 1565
Ignition cycle count : 5928
Catalyst monitor bank 1 : 1268 / 1565
Catalyst monitor bank 2 : 0 / 0
O2 Sensor monitor bank 1 : 1520 / 1565
O2 Sensor monitor bank 2 : 0 / 0
EGR-VVT monitor : 358 / 604
AIR monitor : 1322 / 435
EVAP monitor : 179 / 307
Secondary O2 Sensor monitor bank 1 : 927 / 1565
Secondary O2 Sensor monitor bank 2 : 0 / 0
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
Monday,03,June,2019,22:07:31:07665
Mode 10: Permanent Fault Codes
