2016 A6 Enable Automatic front Parking Distance Sensors (PDC)?
nhdoc
C?ID=98855
I have been searching for a tweak to enable automatic activation of the front parking sensors on my 2016 A6. I found some tips online already but none seem to work with my car. (the one involving bit 1 of byte 37 of controller 9 doesn't seem to work). I have posted an autoscan to show what version of the various modules my car has. Any help would be appreciated.
Sunday,02,June,2019,10:39:52:28013
VCDS Version: 19.6.0.2
VIN: WAUFMAFC2GN006348   License Plate:
Mileage: 16424km-10205mi   Repair Order:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 36 3B 3C 42 44 46 52 53
          55 5F 62 6C 72 85 8B 8E 8F 90 AC
VIN: WAUFMAFC2GN006348   Mileage: 16424km-10205miles
Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 AA    HW: 4G0 907 401 E
   Component: 3.0TDI FSA    H14 0010
   Revision: 58H14---
   Coding: 0A2A4012056601050000
   Shop #: WSC 23321 002 1048576
   ASAM Dataset: EV_ECM30TDI0114G0907401AA 002009
   ROD: EV_ECM30TDI0114G0907401AA_002.rod
   VCID: 62CB88777522DC5FE7-8036
10577 - MIL Request Signal Active (Check TCM for errors too!)
          P1624 00 [032] - -
                    Mileage: 16327 km
                    Date: 2019.05.31
                    Time: 14:31:29
                    Engine speed: 0.00 /min
                    Coolant temperature: 62 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 14.320 V
                    Engine status: COENG_READY
   Part No SW: 4G0 927 158 AQ    HW: 0BK 927 156 AM
   Component: 0BK 30TDIUSA  H19 1006
   Revision: --H19---
   VCID: 7DF1DB0BEC9C03A7FA-8028
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 47A79649E2E569921B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3F8D6103A610D1B7A8-806A
   Part No SW: 4H0 907 064 FR    HW: 4H0 907 064 ER
   Component: BCM2 2.0      H36 0560
   Coding: 0DA86F4E000000000000
   VCID: 7EF3DC07E99A18BFE3-802A
   Serial number: 3215000012586005
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 4G0 820 043 CG    HW: 4G0 820 043 CG
   Component: KLIMA 2 ZONEN H14 0112
   Serial number: 02021500110437
   Coding: 368131184D0000
   ASAM Dataset: EV_AirCondiBasisUDS 003009
   ROD: EV_AirCondiBasisUDS_003.rod
   VCID: 66C39467990AA07F0B-8032
   Part No SW: 4H0 907 063 DM    HW: 4H0 907 063 AM
   Component: BCM1 2.0      H20 0311
   Revision: 21020001    Serial number: 00000992625402
   Coding: 01050011043C9FE2C100488780003800CF9CD208AE08022180000494F10015020060002D0B0000
   VCID: 76E3C427C1AA50FFBB-8022
   Component: WWS57X 150114  H37 0080
   Serial number:         150120075429
   Coding: 0045F7
   Serial number: 23685819
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
   Component: E1 - LDS  H07 0044
   Serial number: 28 01 2015  00000177
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01DC6AC9
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA120043000011412668
   Coding: 020300
   Subsystem 6 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: 2278CD87000000000001
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0053
   Coding: 7E01010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002014
   VCID: 2959DF5B48944F07E6-807C
95232 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 189
                    Mileage: 16327 km
                    Date: 2019.05.31
                    Time: 14:31:30
                    Control Module temperature: 37 °C
                    Voltage terminal 15: 14.350 V
95488 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 189
                    Mileage: 16327 km
                    Date: 2019.05.31
                    Time: 14:31:30
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G0001UX63
   Coding: 303331343135303334354A55304C34473053
   VCID: 34673E2F9F5602EF45-8060
   Component: BF-Gewichtss.  H11 0046
   Serial number: 6940000Y140001A62W0N
   Serial number: 3575HRB40672UMTMEOJ$
   Serial number: 3585HRB400K52SLE8OC%
   Serial number: 3515JRB4010533VUQPO8
   Serial number: 3525JRB405N350J8OH6E
   Serial number: 3554VRB4065358DCC9H8
   Serial number: 3564VRB4065358DCE9A4
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372OAS00039
   Coding: 0004FC
   VCID: 387F0A1F8B3EE68F69-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 15 12 2014  E0052147
   Part No SW: 4G8 920 986 C    HW: 4G8 920 986 C
   Component: TDieUsaAccNv  H07 0043
   Revision: 03001036    Serial number: 658290115596013
   Coding: 0FCE0A040F51D705020000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 387F0A1F833EE68F69-806C
   Part No SW: 4G8 907 468     HW: 4G8 907 468
   Revision: --------    Serial number: 00000001712949
   Coding: C0CD078110
   VCID: 75E1C32BD4AC5BE7B2-8020
   Serial number: 5444165603
   Voltage stabilizer:
   Serial number: 1411160000000000015F
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   VCID: 7CF7D60FFF860AAFCD-8028
   Revision: AA000000    Serial number: 00000134147856
   VCID: 77FDC923C6A029F7A0-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA8208XFBS
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 36630427892A10FF7B-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H06 0060
   Serial number: 0359056246
   Coding: 040211
   VCID: 39790F1BB834FF8796-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H06 0060
   Serial number: 0359088761
   Coding: 040211
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F17015E00628002000013
   VCID: 458173EBCCCC8B67E2-8010
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0003377794
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   VCID: 33653D339A5805D75C-8066
   Revision: 00002001    Serial number: 0358681020
   Coding: 0106063A00FA408580A0080402070E470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000269788
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST00043AQ700000
   Coding: 101F02
   Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93423586
   Component: TSG BF        H03 0507
   Coding: 011F17015E00628002000002
   VCID: 468374E7F1CA807FEB-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001347417
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D512B4B7C7C53270A-8078
   Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0081
   Coding: 04FA021122600400
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 025 E    HW: 4G1 035 025
   Component: MU-H-LNS-US   040 1062
   Serial number: A278B0FB005061
   Coding: 01750102FF0A000013220001041A00102F0006E5F17001047E
   Shop #: WSC 50909 003 1048576
   VCID: 204FC27F3BAE8E4FB1-8074
   Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
   Component: NAR 2017/2018  --- 0060
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9EY800GBH
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349OAR0003Y
   Compact Disc Database:
   Component: Gracenote2  --- 3006
          B11CF 53 [009] - Deactivated
                    Reset counter: 149
                    Mileage: 16327 km
                    Date: 2019.05.31
                    Time: 14:43:20
                    Voltage terminal 30: 14.8 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Component: TSG HL        H03 0507
   Coding: 010F17004000628002000002
   VCID: 49997FDBE0D46F0706-801C
   Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
   Component: TopView       H07 0330
   Revision: 11001001    Serial number: 82330JF0199421
   Coding: 0211000001010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
   VCID: 2E532C47717A283F33-807A
   Component: TSG HR        H03 0507
   Component: DPC-SG        H27 0081
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C57264F47665A2F1D-8078
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E01010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
   VCID: 275DD9635E807977F0-8072
          U1113 00 [008] - -
                    Reset counter: 189
                    Mileage: 16327 km
                    Date: 2019.05.31
                    Time: 14:31:30
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 14.364 V
                    Velocity_vehicle_reference: -0.00 m/s
          U1113 00 [008] - -
                    Reset counter: 189
                    Mileage: 16327 km
                    Date: 2019.05.31
                    Time: 14:31:30
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000622601157
   Coding: 04C1B8180111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 3169373B604437C72E-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 326B383765420CDF57-8066
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 143280778
   ROD: EV_RDCMA00100_008.rod
End-------------------------(Elapsed Time: 06:45)--------------------------
siLc
Tallinn, Estonia
C?ID=330192
On the A6 C7.5 the factory PDC is its own seperate module, not integrated into the BCM1 (module 09). But where is your PDC (module 10) ?
nhdoc
C?ID=98855
I show no module 10 installed on my car, as you can see. The only thing I can think of is the North American version may be a different configuration from the ROW.
I have full parking sensors as well as front, back and top cameras and everything works as designed...just wanted the sensors to come on automatically like they do in my other cars and in the post 2016 Audis.
wuplur
C?ID=247333
In 2016 the PDC is integrated in 09 unless you have parallel park then it’s in 10. I have the same vehicle and would love to get this activated also.
siLc
Tallinn, Estonia
C?ID=330192
Thanks for the clarification. Didn't see that nuance in Elsa.
PQ platform VW-s got the PDC automatic activation in 2015 but these are always seperate module 10. One could simply retrofit the newer module but this doesn't seem the case with the C7.5.
hadez16
C?ID=289891
Not possible.
nhdoc
C?ID=98855
From what I have been able to find online Audi enabled automatic front PDC in MY 2017 in some models (the Q saw it roll into mid year production) and the A4 sometime after that but on both of those models the earlier versions could be tweaked to work using this:
Enable Automatic PDC Front
[09 – Central Elect.] [Coding - 07]
Select Long Coding Helper
Select Byte 37
Check Bit 1
Exit Long Coding Helper
Click Do It
I tried using VCDS to change bit 1 of byte 37 to 1 from 0 but it didn't seem to change anything on my car. The one thing I didn't try was rebooting the MMI after I made the change so I might try that and see if it works. My guess is the answer is somewhere in controller 9. It is just a matter of finding which bit it is.
