AUDI TT 8N 2001 (non bose) - TELEPHONE
napostolidis
GR
C?ID=330266
Hi
I have an Audi TT 8N (non Bose) but with handsfree preparation, not the bluetooth one but the wired one.. (yeah that one with the old cradle for Nokia/Motorola etc....).
The problem is that every time i just connect the Nokia phone (without being on a call) , radio mutes and not responding when i press buttons etc and i cannot even a call no sound.... and i only see "TELEFON" on headunit and DIS on clusters.
I think it should work as follows... keep it connected and when receives a call, then mutes the radio and hear from speakers (which one should it be i don't know..)
I also notice that on coding there is not reference regarding Telephone setting apart from Bose system which i don't have :/
Any help please?
http://wiki.ross-tech.com/wiki/index.php/Audi_Radio_Generation_I#Coding
napostolidis
GR
C?ID=330266
Wednesday,27,March,2019,00:11:36:60191
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
VIN: TRUZZZ8NZ11045966   License Plate: EYA9900
Mileage: 181540km-112803mi   Repair Order:
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
VIN: TRUZZZ8NZ11045966   Mileage: 181540km-112803miles
Address 01: Engine        Labels: 06A-906-032-BAM.lbl
   Part No: 8N0 906 018 H
   Component: 1.8L R4/5VT     G   0004
   Coding: 10710
   VCID: 3635DB65F159CC47741-513D
   TRUZZZ8NZ11045966     AUZ5Z0A4212029
Readiness: 0110 0101
Address 03: ABS Brakes        Labels: 8N0-907-379-MK20-E.clb
   Part No: 8N0 907 379 E
   Component: ESP     20    CAN  V005
   Coding: 18446
   Shop #: WSC 01236
   VCID: 3E25C345D9690407AC1-4B01
Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
   Part No: 8N0 820 043 A
   Component: TT-KLIMAVOLLAUTOMAT D03
   Coding: 00040
   Shop #: WSC 01236
   VCID: 2809051D2BEDAAB7F6D-2581
Address 15: Airbags        Labels: 8N8-909-601.lbl
   Part No: 8N8 909 601
   Component: Airbag Front+Seite 2008
   Coding: 10102
   Shop #: WSC 01236
   VCID: 77AB1661B6D3F54FAF7-513D
Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
   Part No: 8N1 920 880 H
   Component: KOMBI+WEGFAHRS. M73 D56
   Coding: 05044
   Shop #: WSC 01020
   VCID: 3A2DCF55C5412827909-4B01
            49-00 - No Communications
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 B
   Component: HALDEX LSC  ECC     0006
   VCID: 1F1B1EC17EA36D0F877-4B01
No Faults Found
Address 35: Centr. Locks        Labels:. 8Nx-962-267.lbl
   Part No: 8N8 962 267
   Component: Zentralverrieg.,DWA D05
   Coding: 06730
   Shop #: WSC 01236
   VCID: 7EA5034599E9C407EC1-4F0D
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8N8 951 177 A
   Component: Innenraumueberw.    D09
   Coding: 00001
   VCID: 3D27C449D46F1F1FB5B-5119
Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
   Part No: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D004
   Coding: 00010
   Shop #: WSC 01236
   VCID: 65974C291C7F77DF0DB-5161
            35-00 -  -
            35-00 -  -
Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
   Part No: 4B0 035 186 D
   Component:  Radio             0001
   Coding: 00007
   Shop #: WSC 00040
   VCID: 211F183948D75BFFB13-4B01
End----------(Elapsed Time: 02:44, VBatt start/end: 13.3V/13.1V)-----------
napostolidis
GR
C?ID=330266
any help please?
Gone But Not Forgotten
Those old radios are a POS, the buttons wear cosmetically and mechanically/electronically and replacements with new BT settings are far better with nice filters & advisable ultimately because cheaper!
Clean install like this and folding mechanism.
https://www.youtube.com/watch?v=973ZdEWPkrg
napostolidis
GR
C?ID=330266
i think i would not be able to press the alert button if something urgent :)
i've thought about this solution but not my cup of tea, thank you vm
Jef
HQ
With the radio, MVB group 004.4 shows the telephone mute status. My guess is the phone cradle is messed up and when you dock a phone, to goes to mute when it shouldn't.
<Toggle Jack mode = ON>
<Toggle Jack mode = OFF>
I suspect Jack is on the right path in that you have a hardware failure.
:D
Yeah me too until the RNS and OEM radios just became too much trouble for cost when seeing the bling bling for peanuts + additional functions, I had to see if it was bullshit!
I installed a 7 inch touch screen with WIFI & NAV + BT + DVD player I never watch other than to see that it worked when I installed it about a year ago and even the other day I smiled when my wiper fluid was deliberately used up because I wanted to install fresh when I got home and the dam info screen popped up with a diagnostic screen telling me I had an MMI I didn't even realize now in an ALH Jetta.
.....no drilling holes and SAT + antenna read right inside dash & multi-function on CAN talks to everything.
I would say it shouldn't be dismissed!
napostolidis
GR
C?ID=330266
Thanks.
Sorry, confused, does the MVB group 004.4 show the telephone mute status or the intake air temperature?
napostolidis
GR
C?ID=330266
long time....
MVB 004.4
Amplifier Output: 0
Telephone: Telephone
Telephone Mute Status: OFF
Jef
HQ
So if I understand this correctly, 4 years, 2 months and 12 days onward, you still have the same phone that gets cradled?
Does the Mute Status ever change as you mess with the phone? I'll check back in here on November 4, 2027. :p
napostolidis
GR
C?ID=330266
Hehe not really… but I would like to have it solved once :)
Regarding mute status havent really checked with phone connected
napostolidis
GR
C?ID=330266
may i ask please, what coding should i use for stereo? i dont have Bose and i have phone preparation wiring (this bulky cradle between the seats)
Coding​
  • 00?xx: Speakers
    • 0 = Sound System (No passive Speakers)
    • 1 = 1 passive Speaker (Front Left for Bose Sound System with Telephone)
    • 2 = 2 passive Speakers (Front) and 2 active Speakers (Rear)
    • 5 = 2 passive Speakers (Front) and no active Speakers (Rear)
  • 00x?x: Sound System Correction
    • 0 = No Sound System (No Correction)
    • 1 = Sound System (Bose)
  • 00xx?: Configuration
    • +1 = Active/Remote Supplied Antenna
    • +2 = CD-Changer
    • +4 = Secondary Display (Board Computer/Navigation)
