2015 Volkswagen Golf GTI - engine rpm max 3000rpm
obdserwis-pl
Poland
C?ID=364454
I have problem with cutoff engine rpms to 3000.
After short ride, gauges shows 'Engine max 3000rpm' and EPC light turn on
After ignition off, and turn on again problem sometimes losts.
This is Golf GTI 2.0 TSI engine
Thursday,30,May,2019,16:29:22:02777
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4437.4
VIN: 3VW4T7AUXFM061894   License Plate:
Mileage: 150998km-93825mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 47 52 5F 75 A9
VIN: 3VW4T7AUXFM061894   Mileage: 150998km-93825miles
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0105
   Revision: --H13---
   Coding: 091D00124424002F1000
   Shop #: WSC 46809 001 1048576
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001007
   ROD: EV_ECM20TFS0205G0906259A_VW37.rod
   VCID: 2C1408C64701EE2A51-8078
15255 - Secondary Air Injection System Valve (N112)
          P0413 00 [096] - Open Circuit
                    Mileage: 150998 km
                    Date: 2019.02.20
                    Time: 22:57:37
                    Engine speed: 1041.25 /min
                    Normed load value: 17.3 %
                    Coolant temperature: 28 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 14.042 V
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 32 s
                    MAP_MES_SAE: 51 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 16.015625 %
                    FUP_H_SAE: 5890.0 kPa
15188 - Oil Pressure Switch
          P164B 00 [044] - Malfunction
                    Mileage: 150997 km
                    Date: 2019.02.15
                    Time: 06:07:07
                    Engine speed: 799.50 /min
                    Normed load value: 10.2 %
                    Coolant temperature: 107 °C
                    Intake air temperature: 65 °C
                    Voltage terminal 30: 13.984 V
                    STATE_LS_SAE[1]: OL_INTR
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 36 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.968 V
                    FAC_TPS_1_SAE: 13.671875 %
                    FUP_H_SAE: 4970.0 kPa
Readiness: 1010 0101
   Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4511
   Revision: 03253104    Serial number: TFK01411040813
   Shop #: WSC 00066 790 00202
   ROD: EV_TCMDQ250021.rod
   VCID: 291AF1D248F3FB02AA-807C
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Revision: 00000000    Serial number: 53184000002376
   Coding: 01FA6BA13426096D007F020981C72980D62C9000408194B400430050C005
   VCID: 47DE576AFEA72D725C-8012
   Revision: 00021000    Serial number: 0349864043
   Coding: 030C0C
   Shop #: WSC 01383 790 50316
   VCID: 3A383E9EBD55409AD3-806E
65813 - Supply voltage
                    Fault Frequency: 48
                    Reset counter: 2
                    Mileage: 150938 km
                    Date: 2018.09.02
                    Time: 17:09:49
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 00020014200100000005004012111400
   VCID: 42C8467ED585085A8B-8016
   Air quality sensor:
328198 - Position Sensor for Right Temperature Flap Motor
          B1095 11 [008] - Short to Ground
                    Reset counter: 248
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 01:19:33
                    Voltage terminal 30: 13.8 V
                    Outside air temperature: 5.0 °C
                    Interior temperature: 20.3 °C
                    Right temperature flap: actual value: 197
                    Right temperature flap: actual value: 82.0 %
                    Right temperature flap: specified value: 196
262914 - Refrigerant Pressure
          B10AB F0 [008] - Too Low
                    Reset counter: 1
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 13:27:53
                    Outside air temperature: 16.0 °C
                    Engine speed: 0 /min
                    Temperature after evaporator: 15.0 °C
                    System run time-Terminal 15 on: 6 s
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [008] -  -
                    Reset counter: 4
                    Mileage: 150997 km
                    Date: 2019.02.15
                    Time: 05:58:25
                    Voltage terminal 30: 13.3 V
                    Compressor shut-off requirement: Shut-off of engine control module via CAN (T > 15 sec.)
1048836 - Blower Output Reduction due to Energy Management
          B10CE 00 [008] -  -
                    Reset counter: 3
                    Mileage: 150964 km
                    Date: 2019.02.13
                    Time: 00:01:47
                    Voltage terminal 30: 12.4 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 0
                    CAN input signal(s) status-Back-up light: OFF
          B10CD 00 [008] -  -
                    Reset counter: 2
                    Mileage: 150938 km
                    Date: 2018.09.11
                    Time: 00:09:02
                    Voltage terminal 30: 10.6 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
   Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
   Revision: --------    Serial number: 86580412140847
   Coding: 00111846404182E969E44000001407201800000000000000000000000000
   Shop #: WSC 00066 790 00228
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4AD86E5EEDB5D01A43-801E
   Component: WWS    141129  043 0581
   Serial number:         150105060939
   Component: RLHS  037 0059
   Serial number: S3Y14M12D09H08M33S03
   Coding: 00A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H02 0003
   Serial number: 0000FST000062X500000
   Coding: 181801
13 Faults Found:
131330 - Supply voltage
          [VersorgungsspannungSpannung zu niedrig]
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 01:19:05
          U1400 00 [008] - -
                    Reset counter: 2
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 01:14:42
6666 - Bulb for Low Beam Headlamp Left
          B1217 15 [009] - Open or Short to Plus
                    Fault Frequency: 62
                    Reset counter: 220
                    Mileage: 139582 km
                    Date: 2018.04.09
                    Time: 10:42:28
5130 - Bulb for Front Left Turn Signal
          B11E8 15 [008] - Open or Short to Plus
                    Reset counter: 250
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 00:00:14
5386 - Bulb for Front Right Turn Signal
          B11EA 15 [008] - Open or Short to Plus
                    Reset counter: 253
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 00:00:14
17162 - Bulb for Left DRL and Parking Lamp
          B12EA 15 [008] - Open or Short to Plus
                    Reset counter: 250
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 00:00:39
17418 - Bulb for Right DRL and Parking Lamp
          B12EB 15 [008] - Open or Short to Plus
                    Reset counter: 250
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 00:00:39
17674 - Bulb for Front Left Side Marker Lamp
          B12BA 15 [009] - Open or Short to Plus
                    Reset counter: 22
                    Mileage: 138991 km
                    Date: 2018.04.05
                    Time: 02:15:48
17927 - Bulb for Front Right Side Marker Lamp
          B12BB 11 [008] - Short to Ground
                    Reset counter: 245
                    Mileage: 150938 km
                    Date: 2018.09.11
                    Time: 00:08:07
17930 - Bulb for Front Right Side Marker Lamp
          B12BB 15 [008] - Open or Short to Plus
                    Reset counter: 252
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 00:10:10
939524 - No Communications with Humidity Sensor
          U10F5 00 [008] - -
          [Geber für Luftfeuchtigkeitkeine Kommunikation]
                    Reset counter: 241
                    Mileage: 150820 km
                    Date: 2018.07.17
                    Time: 10:10:52
722449 - Control Module for Power Sunroof
          B13C6 F0 [008] - Function Aborted
                    Reset counter: 2
                    Mileage: 150964 km
                    Date: 2019.02.12
                    Reset counter: 6
                    Mileage: 150964 km
                    Date: 2019.01.16
                    Time: 01:54:44
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM01EG7G
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 51EA793200E3E3C202-8004
   Occupant Detection:
   Serial number: IBH0000J14000232ZF0+
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 002 410 14
   Serial number: 35700000000EA941711J
   Subsystem 3 - Part No SW: -----------    HW: 480 002 410 14
   Serial number: 35800000000418947118
   Subsystem 4 - Part No SW: -----------    HW: 480 402 210 14
   Serial number: 3510002A91811BA2301P
   Subsystem 5 - Part No SW: -----------    HW: 480 402 210 14
   Serial number: 3520002A518166A5B16$
   Subsystem 6 - Part No SW: -----------    HW: 480 401 910 14
   Serial number: 3550002B518166B5736%
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 910 14
   Serial number: 3560002B718166B1C1B6
          B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                    Fault Frequency: 39
                    Reset counter: 250
                    Mileage: 150938 km
                    Date: 2018.07.18
                    Time: 03:36:05
          B10B4 00 [008] - Function Restriction due to Undervoltage
          [Bladder Mat: functional restriction because of low voltage]
                    Reset counter: 2
                    Mileage: 150964 km
                    Date: 2019.02.14
                    Time: 21:03:18
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20141103500490
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 044480668F11C66AF9-8050
114178 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung -unterer Grenzwert unterschritten>]
                    Reset counter: 2
                    Mileage: 150964 km
                    Date: 2019.02.12
                    Time: 00:00:05
                    Ubat 30 Voltage: 6.00 V
                    Ignition State: OFF
                    Terminal 15: 5.20 V
136194 - Supply voltage
          [Versorgungsspannung -unterer Grenzwert unterschritten>]
                    Reset counter: 2
                    Mileage: 150964 km
                    Date: 2019.02.12
                    Time: 00:00:05
                    Ignition State: OFF
                    Terminal 15: 5.20 V
   Part No SW: 5G1 920 856     HW: 5G1 920 856
   Component: KOMBI         342 4270
   Coding: 0BAD091A2180CF0502086A001000000000000000
   VCID: 6B96CBDA828F291218-803E
13635840 - Supply voltage
          [Versorgungsspannung - unterer Grenzwert unterschritten Versorgungsspannung Spannung dauerhaft zu niedrig]
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 01:17:51
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 05121410000139
   Coding: 0101000820085900EF0002281C0F00000001050000000000000000000000
   ROD: EV_GatewConti_011_VW37.rod
   VCID: 71AAD9B2A0A3C3C222-8024
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0101
   Serial number: 27140002607290054435
   Coding: 280000
1282 - Supply voltage
          [Versorgungsspannung - unterer Grenzwert unterschritten]
                    Reset counter: 2
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 01:17:08
                    Supply voltage: Terminal 30: 8.4 V
                    Terminal 15: On
8782090 - Cruise Control Switch
          B1154 96 [008] - Component internal failure
                    Reset counter: 231
                    Mileage: 144961 km
                    Date: 2018.06.04
                    Time: 16:54:02
                    Supply voltage: Terminal 30: 13.5 V
                    Terminal 15: On
   Revision: 00000000    Serial number: 14000318772004
   Coding: 5D00000000000000
   Shop #: WSC 00066 790 07027
   ROD: EV_ELVMarquMQB.rod
   VCID: 342410A69F31B6EA09-8060
          [Under voltage (continued)]
                    Reset counter: 2
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 01:23:05
                    ELV State: 04
                    Information Clamps: 77 60
                    CoCo State: A0 01
                    WFS State: 17 06
                    Vehicle speed: 0.00 km/h
                    Voltage: 47
                    AD-Value H-bridge: 23
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 00
          U1400 00 [008] - -
          [Under voltage (temporary)]
                    Reset counter: 2
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 01:15:01
                    ELV State: 04
                    CoCo State: A0 01
                    WFS State: 17 06
                    Voltage: 4C
                    AD-Value H-bridge: 25
                    CAN signals: 00
1048844 - Ignition Starter Switch
          B11D7 29 [008] - Signal Implausible
                    Fault Frequency: 15
                    Reset counter: 250
                    Mileage: 150938 km
                    Date: 2018.09.11
                    Time: 00:01:23
                    ELV State: 02
                    Information Clamps: 00 08
                    CoCo State: E0 01
                    WFS State: 00 06
                    Vehicle speed: 655.34 km/h
                    Voltage: 6D
                    AD-Value H-bridge: 34
                    Clamp15 flip flop: SSTx: button contacts: 09
                    CAN signals: 05
13637378 - Databus
          [Errorvalue ESP_Wegimpulse]
                    Reset counter: 242
                    Mileage: 150938 km
                    Date: 2018.07.18
                    Time: 03:35:48
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 1F 06
                    Vehicle speed: 121.37 km/h
                    Voltage: 77
                    AD-Value H-bridge: 3A
                    CAN signals: 04
   Serial number: 031214060503S9
   Coding: 003E13200000040000000000
   VCID: 40CC4C76DB891A4A9D-8014
   Serial number: 00000000000000424978
   Coding: 011000
65548 - Supply voltage
                    Reset counter: 2
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 01:18:59
65604 - Door Warning Lamp
          B1326 01 [009] - Electrical Failure
                    Fault Frequency: 211
                    Reset counter: 207
                    Mileage: 139044 km
                    Date: 2018.04.05
                    Time: 14:36:14
589827 - Window Regulator; Rear Driver Side
          B131F 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 220
                    Mileage: 150950 km
                    Date: 2019.01.12
                    Time: 01:42:49
589829 - Window Regulator; Rear Driver side
          B131F F5 [008] - Supply Voltage too Low
                    Fault Frequency: 20
                    Reset counter: 2
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 01:21:30
589830 - Window Regulator; Rear Driver side
          B131F F4 [008] - Supply Voltage too High
                    Reset counter: 2
                    Mileage: 150964 km
                    Date: 2019.02.13
                    Time: 00:01:24
589839 - Window Regulator Motor; Front Driver Side
          B1321 02 [008] - Signal Failure
                    Reset counter: 2
                    Mileage: 150964 km
                    Date: 2019.02.12
                    Time: 00:14:46
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 8102
   VCID: 373E27AA8E475DF22C-8062
Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H40 0060
   Serial number: VWZ8Z1EC401V8B8
   Coding: 22000000AAAAAA0000
   ASAM Dataset: EV_AMPMst11CALPI 001006
   ROD: EV_AMPMst11CALPI.rod
   VCID: 6386A3FA6A5F6152A0-8036
0565 - Loudspeaker 1 in Double-Subwoofer
          B130C 13 [008] - Open Circuit
                    Reset counter: 245
                    Mileage: 150938 km
                    Date: 2018.09.11
                    Time: 00:02:14
0570 - Loudspeaker 2 in Double-Subwoofer
          B130D 13 [008] - Open Circuit
                    Reset counter: 245
                    Mileage: 150938 km
                    Date: 2018.09.11
                    Time: 00:02:14
          U1101 00 [008] - Active
          [Anti-theft protection - component protection active (0xEA6100)]
                    Reset counter: 250
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 01:43:58
   Serial number: 281114060500CK
   VCID: 3FCE4F8AA67765B2E4-806A
   Serial number: 00000000000000363754
   Coding: 091000
                    Reset counter: 2
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 01:18:43
589843 - Window Regulator; Front Passenger Side
          B1320 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 213
                    Mileage: 150950 km
                    Date: 2019.01.12
                    Time: 01:42:49
589845 - Window Regulator; Front Passenger side
          B1320 F5 [008] - Supply Voltage too Low
                    Fault Frequency: 19
                    Reset counter: 2
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 01:21:06
589846 - Window Regulator; Front Passenger side
          B1320 F4 [008] - Supply Voltage too High
                    Reset counter: 2
                    Mileage: 150964 km
                    Date: 2019.02.13
                    Time: 00:01:24
   Part No SW: 5G0 035 876     HW: 5G0 035 876
   Component: MU-S-NS-US    014 0645
   Serial number: V7B01911143974
   Coding: 027300010000000021110002001800001F0203340100010546
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 699AB1D288733B026A-803C
   Subsystem 1 - Part No SW: 5G0 919 605 K    HW: 5G0 919 605 K
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9PS600DGL
   Subsystem 2 - Part No SW: 5G0 919 866 S    HW: -----------
   Component:  NAR 2015  --- 0022
          U1400 00 [008] - -
          [Function restriction due to insufficient voltage - lower limit value not reached]
                    Fault Frequency: 51
                    Reset counter: 2
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 01:17:57
                    Voltage terminal 30: 8.3 V
6669 - Optical Data Bus for Digital Sound System
          U10CC 00 [008] - Intermittent Disruption
          [Optical data bus: sporadic open circuit in sound]
                    Reset counter: 4
                    Mileage: 150979 km
                    Date: 2019.02.15
                    Time: 05:30:59
                    Temperature of MOST transceiver-max.value: -50 °C
                    Temperature of MOST transceiver-min.value: -19 °C
                    Temperature of MOST transceiver-Current: 41 °C
7219 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 2
                    Mileage: 150964 km
                    Date: 2019.02.13
                    Time: 00:38:15
                    Voltage terminal 30: 11.5 V
   Component: OCULowMQBUS   007 0564
   Shop #: WSC 00066 790 00122
   ROD: EV_OCULowMQB.rod
   VCID: 43C6437ACA9F015280-8016
          [supply voltage lower limit exceeded]
                    Reset counter: 250
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 01:11:06
          U1400 00 [008] - -
          [restriction due to undervoltage]
                    Reset counter: 2
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 01:06:07
   Component: SAS-GEN 2     H06 0014
   Serial number: 140925202932
0002 - Supply voltage
          [Versorgungsspannung - unterer Grenzwert unterschritten--> Versorgungsspannung Spannung dauerhaft zu niedrig]
                    Reset counter: 250
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 01:13:44
0004 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung--> funktionelle Einschränkungen aufgrund vorübergehender Unterspannung in der Versorgung.]
                    Reset counter: 250
                    Mileage: 150938 km
                    Date: 2019.01.11
                    Time: 01:13:44
End----------(Elapsed Time: 01:41, VBatt start/end: 12.3V/12.3V)-----------
NostraJackAss
Or Lower O-Rings never been chnage at oil filter, and car loosing oil pressure . This is most stupid filter kit VW ever made , that not supply 2 lower O-rings. You have to buy complete rod which is almost $10.
I agree Marin........INDEED!
Jetta/Jack: I had to take a look because I have never changed these O-rings (I hadn't thought it necessary). Notwithstanding the note in the manual (see the diagram below) - the O-rings look like they can be easily separated from the rod (and simply replaced from bits in my O-ring box). Is there anything special about these O-rings and how often do you recommend changing them?
rrador
Canada
C?ID=68027
You have a code for oil pressure switch so car is in limp mode. Either something wrong with press switch or you have low oil pess. I would start with checking the switch as the code says switch malfunction
NostraJackAss
Don,
Don't you think when the filter is changed I change the rod with oring set?
This is why it's good to change oil more frequently, bifurcate turbo from sump and use regular oil for engine, huh?
Jack: you replace the rod and the o rings EVERY filter change - wow? I guess that's the difference between us (well......... that and opposable thumbs - I don't have them)!!;)
darkchina811
ITALY
C?ID=333184
of course O-rings are replaced at every filter change. here in Europe all you need is to buy a MANN filter, new O-rings come together in the box.
golfi_vend
Tartu, Estonia
C?ID=195131
NostraJackAss
Don,
I don't remove the oil filter each time oil is changed and change the oil more frequent than the OEM interval.
Than rely on chemistry observation of what I sample for fuel and large sump particulates.
When I drain oil, my drain wok is spotless for FOD & I even go as far as to screen it and coffee filter it for refraction light and magnifier mirror inspection of TBD FOD!
Fuel content contamination seems to be the biggest enemy and if not caught in time the motor is a "blow by" garbage can!
When I do change the filter I cut it open with a pipe cutter for FOD inspection.
If particulates are in the filter, you are fucked!
Best to keep an eye on sump!
Don,
Jack: I fully suspect that we have different views about these practices - but as I often say to those who have a different opinion to me - "you are entitled to be wrong" (just joking)!!!;).
I'm not a professional like you and others here - but for me, what folk believe is necessary for routine maintenance is largely a matter of their appetite for risk (purely as it applies to vehicles, of course). And as such (and IMO), there are a range of views which are all (mostly) legitimate. I'm a moderate risk taker and I tend to rely on the manufacturer's protocol for planned servicing - nothing more.
Until now, I had thought that I had understood the OEM protocol, but clearly my understanding has been greatly exaggerated - I have never changed the rod and lower o-rings! As penance and to assuage Catholic guilt, I must now go to the naughty corner with the maintenance manual in hand for remedial training!
PS: Does European Parts Emporium make house calls for routine maintenance work (down here in the very deep south)? And, given the disastrous exchange rate of our Pacific Peso - can I afford you?
NostraJackAss
One day I may indeed pay a visit to the prison colony in the deep South and than New Zealand on my way to Neu Swabia to do VAG service.
Sometimes I'm wrong, just not on the aforementioned subject or experience in volume proves I'm right.
Better living through chemistry!
