Dead Touareg Challenge
DicknNancy
C?ID=25580
Hi All.
We picked up a summer project. It's an early 2004 V10 Touareg that the PO was just completely overwhelmed with and just wanted the car gone. I'ts led a rough life and for the past year or so was a resident at the local towing yard.
Interior footwells were soaked from the well known plugged front cowl drains being plugged. That has now been addressed and all is dry.
When we got it, the engine ran and the transmission was unlocked so it could be put in the service bay.
I did an initial scan on it before any work was performed and it is messed up although it seems no communication from the ABS module is a common theme in many of the modules.
I've pulled apart the left side carpet to access the main wiring bundle and resoldered the different factory spliced wires that are known to get wet and corroded.
I've unplugged re plugged in the ABS module, checked all the fuses, and charged up both batteries. Now, the engine runs but the transmission is locked.
I see the KESSY errors and have a plan to pull that and get the MOFSETs and resistors replaced.
Beyond the KESSY fixes, I'm not sure where to start with the repairs at this point. The engine runs but the transmission is locked in park.
I've posted the current scan below and welcome any suggestions.
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGGH77L64D060732   Mileage: 217170km-134943miles
   Part No SW: 070 997 016 R    HW: 028 101 172 9
   Component: V10 5,0L EDCG000AGMª2813
   Revision: 5KO3        Serial number: VWZ3Z0D7152879
   Coding: 0060575
   Shop #: WSC 02326 444 54085
   VCID: 2952138183392102AA-50E6
18057 - Powertrain Data Bus
            P1649 - 000 - Missing Message from ABS Controller
                    RPM: 630 /min
                    Torque: 110.6 Nm
                    Speed: 3.6 km/h
                    Voltage: 13.98 V
                    Bin. Bits: 00001111
                    Torque: 308.1 Nm
17911 - Load Signal from Alternator Term. DF
            P1503 - 000 - Implausible Signal
                    RPM: 588 /min
                    Torque: 102.7 Nm
                    Speed: 3.6 km/h
                    Voltage: 13.98 V
                    Bin. Bits: 00001111
                    (no units): 1.0
18253 - Please check DTC Memory of Steering Electronics (J527)
            P1845 - 000 -  - Intermittent
                    RPM: 693 /min
                    Torque: 94.8 Nm
                    Voltage: 11.86 V
                    Bin. Bits: 00001111
                    Bin. Bits: 00001111
Readiness: 1 1 1 0 1
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No: 09D 927 750 BB
   Component: AL 600 6Q           0467
   Coding: 0004153
   Shop #: WSC 31414 000 00000
   VCID: 6FE63D997D5D0F3234-50E6
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 137 C    HW: 7L0 909 137 C
   Component: 2G Kessy            6850
   Revision: 00H22072    Serial number: VWZ3Z0D7152879
   Coding: 0147688
   Shop #: WSC 02651 444 83466
   VCID: 336EF1E951F56BD210-50E6
                    Fault Frequency: 14
                    Reset counter: 2
                    Time: 04:18:26
00955 - Key 1
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Fault Frequency: 0
                    Reset counter: 241
                    Date: 2064.00.00
                    Time: 00:00:14
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
                    Fault Frequency: 0
                    Reset counter: 244
                    Date: 2064.00.00
                    Time: 00:00:14
00183 - Interior Access/Start Authorization Antenna 1 (R138)
                    Fault Frequency: 0
                    Reset counter: 43
                    Date: 2064.00.00
                    Time: 00:00:14
                    Fault Frequency: 14
                    Reset counter: 38
                    Date: 2064.00.00
                    Time: 00:00:14
                    Fault Status: 01101101
                    Fault Frequency: 0
                    Reset counter: 2
                    Date: 2064.00.00
                    Time: 00:00:14
Address 06: Seat Mem. Pass        Labels: None
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77F605F9050D47F2EC-50E6
00457 - Control Module for Network (J519)
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 H
   Component: CLIMAtronic R/L   X 3716
   Coding: 0021030
   VCID: 356ACFF15F8175E23E-50E6
01596 - Motor for Outside/Recirculated Air Flap (V154)
            000 -  -
00229 - Refrigerant Pressure
Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 L
   Component:                     2702
   Coding: 0086494
   Shop #: WSC 02326 444 57416
   VCID: 458ABF310F61E562AE-50C8
   Subsystem 1 - Part No: 7L6 937 049 L
   Component:                     2702
No Faults Found
Address 11: Engine II        Labels: None
   Component: V10 5,0L EDCG000AGSª2813
   Coding: 0060575
   Part No: 3D0 909 601 C
   Component: 05 Airbag 8.4E++H01 0352
   Revision: BB36963     Serial number: 00008441
   Coding: 0012341
   VCID: 234E01A9E115FB52E0-50E6
   Subsystem 1 - Part No: 7L0 959 339 B
   Component: BF-Gewichtsens. 005 0006
                    Date: 2063.15.31
                    Time: 31:60:00
                    Date: 2063.15.31
                    Time: 31:60:00
                    Reset counter: 39
                    Date: 2063.15.31
                    Time: 31:60:00
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 D
   Component: Lenksäulenmodul     3301
   Coding: 0000032
   VCID: 4084AE251043C04A9D-50E6
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 980 P
   Component: KOMBIINSTRUMENT RB4 2935
   Coding: 0007231
   Shop #: WSC 02326 444 83476
01335 - Drivers Seat/Mirror Position Control Module (J543)
Address 18: Aux. Heat        Labels: 7L6-819-008.clb
   Part No: 7L6 819 008 B
   Component: Standheizung  E1MAC 0235
   Coding: 0000030
00664 - Fuel gauge
01126 - Engine Speed Signal
01408 - Under-Voltage Shut-Off (fixed Value)
   Part No: 6N0 909 901
   Coding: 0000006
   Shop #: WSC 02326 444 53518
   VCID: 70E43EE5606310CA2D-50E6
01302 - Control Module for Telematic (J499)
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879
   Component: JCI PathPoint       1700
   VCID: 040C623544DB1C6AF9-50E6
00926 - Terminal 30
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F06EDD92D3D7FB2A4-50E6
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  X012
   Coding: 0000003
   VCID: 66C858BD52A7CE7A47-5120
00492 - Body Pitch Angle from Level Control Module
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 H
   Component: LUFTFDR.-CDC- 3C3P1 3099
   Coding: 0015521
   Shop #: WSC 02326 444 58767
   VCID: 3874C6C54893888A25-5102
Address 39: Right Light        Labels: 3D0-909-158.lbl
   Part No: 3D0 909 158
   Component: EVG GDL+AutoLWR(r)  X012
   Coding: 0000003
   VCID: 67D655B955ADD7727C-50E6
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L0 959 933 C
   Component: B0 HSG              0102
   Coding: 0000085
   Shop #: WSC 26030 444 85857
   VCID: 3C7CDAD57CABA4AAC1-4AB4
   Subsystem 1 - Part No: 7L0 959 933 C
   Subsystem 2 - Part No: 7L0 959 701 B
   Component: Tuersteuergeraet FS 0201
   Subsystem 3 - Part No: 7L0 959 702 B
   Component: Tuersteuergeraet BF 0201
   Subsystem 4 - Part No: 7L0 959 703 B
   Component: Tuersteuergeraet HL 0201
   Subsystem 5 - Part No: 7L0 959 704 B
   Component: Tuersteuergeraet HR 0201
No Faults Found
Address 68: Wiper Electr.        Labels: 7L0-955-119-V1.clb
   Part No: 7L0 955 119 F
   Component: Front Wiper         2416
   Coding: 0000004
   Shop #: WSC 31414 000 376832
   VCID: 3776C5F9458D87F22C-50E6
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
   Component: ANHAENGERELEKTRONIK 8854
   Coding: 0000002
   VCID: 3874C6C54893888A25-50E6
16347 - Control Module - EEPROM Error
            014 - Defective
02579 - Trailer; Left Brake Lamps (M65)
02580 - Trailer; Right Brake Lamps (M66)
Address 6E: Ctrl Head Roof        Labels: None
   Part No: 7L6 919 044 L
   Component: DACHDISPLAY         0538
   Revision: 00800538    Serial number: 2009268.07
   VCID: 4084AE251043C04A9D-50C8
Address 75: Telematics        Labels: 3D0-035-617.lbl
   Part No SW: 3D0 035 617 B    HW: 3D0 035 617 B
   Component: Telematik NAR1      0104
   Coding: 0076510
   Shop #: WSC 02326 444 00852
   VCID: 1F460D59CD7DDFB2C4-50E6
01304 - Radio
Address 76: Park Assist        Labels: None
   Part No: 7L0 919 283 E
   Component: 0E Einparkhilfe     0907
End-------------------------(Elapsed Time: 10:02)--------------------------
DrPeter
16.4905° S, 151.7375° W
- Are you saying the transmission selector lever does not move or are you saying the selector moves, but the transmission is still in park?
If the selector lever does not move, check the brake light switch (In the [02-Auto Trans], Measuring Value Block group 011, field 1) and the Selector lever lock solenoid -N110, (MVB-011, field 2).
If the selector moves, check the transmission shift linkage, cable, selector, etc. Check MVB-001, field 4 for the gear selection value.
Hope this helps,
drpeter
DicknNancy
C?ID=25580
The former...
" the transmission selector lever does not move"
Thanks for the suggestion. I'll check that out.
DrPeter
The former...
- Cool, let us know what you find, this way if someone has a similar issues this post could help.
drpeter
DicknNancy
C?ID=25580
Will do. I'm now laid up for a bit recovering from a broken ankle so it will be a few weekends before I get back to it.
DicknNancy
C?ID=25580
Recovering from surgery last week to fix this broken ankle so I'm not quite up to crawling around the car testing stuff just yet (maybe a little this weekend?) but I have been spending time going over the different scans I did pre-fracture and reading wiring diagrams trying to understand how all the components are related/connected.
In looking back over the scans, it allowed me to take a step back and review the history as I know it.
1. Car has had long time electrical issues and changed hands at least three times.
2. It was running albeit with numerous errors and problems, for the immediate PO.
3. When we looked at it the PO had it towed from the tow yard to her house after having it sit outside through an Idaho winter under a tree. Our VAGCOM was not with us.
4. It was stone cold dead when we first tried to start it and had to give it a jump to get it running. Once running, the engine sounded fine and appeared to be charging as it should. After 15 minutes at an idle, it was able to restart on its own.
5. At that time while many electrical components did not work including things like the odometer, Kessey related items, wipers, etc. and it had multiple MFI indicators lit up, it did shift out of park and we were able to drive it into the trailer.
6. After unloading it from the trailer we were still able to get it started and moving under it's own power. I did the first auto scan at that time. I tried to clear each code and did a rescan.
7. It was wet inside from the plugged up plenum drains and I think we now have everything dried up.
8. I did pull up the main harness to investigate the troublesome splices but I'll say, all looked OK but I did add some solder to each.
I noted the missing/intermittent ABS control module signal was the common failure mentioned in nearly all the erroring other components so I started there by checking all 6 fuses in that circuit (all tested fine). I also did enough disassembly to be able to unplug for 5 minutes or so, the ABS control module plug, reconnect it and rescan. The rescan now showed the ABS control module was finally communicating with the other modules and I was able to clear several of the codes to get down to 4-5 minor ones I expected (AC unit discharged, light out, etc.). YAY!!!
I pulled the car into the garage bay and stopped for the evening. I've kept the car on a charger due to the known KESSEY antenna failure error.
Here's the scan where I left off feeling like things were headed the right direction
   Coding: 0060575
18005 - Powertrain Databus
            P1597 - 000 - Missing Message from Level Control System (J197)
                    RPM: 630 /min
                    Torque: 79.0 Nm
                    Speed: 3.6 km/h
                    Voltage: 13.91 V
                    Bin. Bits: 00001100
                    Torque: 347.6 Nm
                    Torque: 0.0 Nm
18034 - Powertrain Data Bus
            P1626 - 000 - Missing Message from TCU
                    RPM: 630 /min
                    Torque: 79.0 Nm
                    Speed: 3.6 km/h
                    Voltage: 13.91 V
                    Bin. Bits: 00001100
                    Bin. Bits: 10000100
                    RPM: 630 /min
                    Torque: 79.0 Nm
                    Speed: 3.6 km/h
                    Voltage: 13.91 V
                    Bin. Bits: 00001100
                    Torque: 347.6 Nm
18053 - Powertrain Data Bus
            P1645 - 000 - Missing Message from AWD Controller
                    RPM: 630 /min
                    Torque: 79.0 Nm
                    Speed: 3.6 km/h
                    Voltage: 13.91 V
                    Bin. Bits: 00001100
                    Torque: 347.6 Nm
                    Torque: 0.0 Nm
Readiness: 0 0 1 1 1
   Coding: 0147688
   VCID: 336EF1E951F56BD210-50C8
                    Fault Frequency: 0
                    Reset counter: 9
                    Date: 2064.00.00
                    Time: 00:00:14
                    Fault Frequency: 0
                    Reset counter: 9
                    Date: 2064.00.00
                    Time: 00:00:14
                    Fault Frequency: 0
                    Reset counter: 9
                    Date: 2064.00.00
                    Time: 00:00:14
00576 - Terminal 15
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 0
                    Reset counter: 9
                    Date: 2064.00.00
                    Time: 00:00:14
   Coding: 0021030
            010 - Open or Short to Plus
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Component:                     2702
   Coding: 0086494
   VCID: 458ABF310F61E562AE-5102
   Coding: 0060575
   Coding: 0012341
   VCID: 234E01A9E115FB52E0-50C8
                    Date: 2063.15.31
                    Time: 31:60:00
   Coding: 0000032
   Coding: 0007231
   VCID: 458ABF310F61E562AE-50E6
01310 - Level Control System Control Module (J197)
02053 - Control Module for Transfer Case (J646)
   Coding: 0000030
   Coding: 0000006
   VCID: 70E43EE5606310CA2D-5102
   Coding: 0000085
   VCID: 3C7CDAD57CABA4AAC1-FFFE
   Subsystem 1 - Part No: 7L0 959 701 B
   Subsystem 2 - Part No: 7L0 959 702 B
   Subsystem 3 - Part No: 7L0 959 703 B
   Subsystem 4 - Part No: 7L0 959 704 B
   Coding: 0000004
   Coding: 0000002
   VCID: 3874C6C54893888A25-50C8
            014 - Defective
00576 - Terminal 15
   Coding: 0076510
01304 - Radio
End-------------------------(Elapsed Time: 09:56)--------------------------
Scroll ahead to a week later and hubby (Dick) goes to pull the car out of the garage to move it, and low and behold it will not shift out of park now.
The night before the ankle injury I scanned it again and the ABS error is back along with the other errors in other modules from the missing ABS communication just like before, only now the darn thing won't allow me to get it out of park.
   Coding: 0060575
                    RPM: 630 /min
                    Torque: 110.6 Nm
                    Speed: 3.6 km/h
                    Voltage: 13.98 V
                    Bin. Bits: 00001111
                    Torque: 308.1 Nm
                    RPM: 588 /min
                    Torque: 102.7 Nm
                    Speed: 3.6 km/h
                    Voltage: 13.98 V
                    Bin. Bits: 00001111
                    (no units): 1.0
                    RPM: 693 /min
                    Torque: 94.8 Nm
                    Voltage: 11.86 V
                    Bin. Bits: 00001111
                    Bin. Bits: 00001111
   Coding: 0004153
   Coding: 0147688
                    Fault Frequency: 14
                    Reset counter: 2
                    Time: 04:18:26
00955 - Key 1
                    Fault Frequency: 0
                    Reset counter: 241
                    Date: 2064.00.00
                    Time: 00:00:14
                    Fault Frequency: 0
                    Reset counter: 244
                    Date: 2064.00.00
                    Time: 00:00:14
                    Fault Frequency: 0
                    Reset counter: 43
                    Date: 2064.00.00
                    Time: 00:00:14
                    Fault Frequency: 14
                    Reset counter: 38
                    Date: 2064.00.00
                    Time: 00:00:14
                    Fault Frequency: 0
                    Reset counter: 2
                    Date: 2064.00.00
                    Time: 00:00:14
   Coding: 0021030
            000 -  -
   Component:                     2702
   Coding: 0086494
   Component:                     2702
No Faults Found
   Coding: 0060575
   Coding: 0012341
                    Date: 2063.15.31
                    Time: 31:60:00
                    Date: 2063.15.31
                    Time: 31:60:00
                    Reset counter: 39
                    Date: 2063.15.31
                    Time: 31:60:00
   Coding: 0000032
   Coding: 0007231
   Coding: 0000030
00664 - Fuel gauge
   Coding: 0000006
00926 - Terminal 30
   Coding: 0000003
   Coding: 0015521
   Coding: 0000003
   Coding: 0000085
No Faults Found
   Coding: 0000004
   Coding: 0000002
            014 - Defective
   Coding: 0076510
01304 - Radio
So, I'm sort of doing a brain dump here to see if any of it's history and behavior is familiar, and to see if there may be any other diagnostic things I can research from the couch with my foot in the air.
I'll go back over and test the suggestions already presented as soon as I can.
Thanks again, all.
Nancy
