Hello
I changed the abs module and bleeded the brakes but i need the abs code. Thanks
Here is a autoscan
Here is a autoscan
Monday,27,May,2019,18:13:44:50280
VCDS Version: 18.9.1.0 (x64) HEX-NET CB: 0.4436.4
VIN: WVWZZZ1KZ9W411195 License Plate:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZ9W411195 Mileage: 193840km-120446miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 AH HW: 03L 906 022 G
Component: R4 2.0l TDI 0000AG 9977
Revision: 13H01--- Serial number:
Coding: 0000078
Shop #: WSC 00046 000 00000
VCID: EB969FF3CA41181298-80BE
049441 - No Communication with ABS Brake Control Module
U0121 - 000 - - Intermittent
Mileage: 193816 km
Date: 2013.10.16
Time: 11:47:08
Temperature: 18.9°C
Voltage: 12.39 V
Bin. Bits: 00000000
Torque: 93.0 Nm
Temperature: 38.7°C
050197 - Implausible Data Received from ABS Control Module
U0415 - 000 - - Intermittent
Mileage: 193840 km
Date: 2013.10.17
Time: 08:43:41
RPM: 3427 /min
Speed: 31.0 km/h
Load: 38.4 %
Voltage: 13.60 V
Bin. Bits: 00000100
Bin. Bits: 00000000
(no units): 0.0
005000 - Control Module Malfunction - DBW Throttle Monitoring
P1388 - 000 - - Intermittent
Mileage: 193816 km
Date: 2013.10.16
Time: 11:47:16
RPM: 1794 /min
Speed: 4.0 km/h
Voltage: 13.60 V
Voltage: 2.052 V
Voltage: 0.988 V
Torque: 410.0 Nm
Bin. Bits: 0000000
Fault Frequency: 167
Mileage: 193816 km
Date: 2013.10.16
Time: 11:47:16
RPM: 1886 /min
Speed: 4.0 km/h
Load: 41.6 %
Bin. Bits: 0000000
Inj. Quantity: 0.0 mg/str
Hex Value: 0xFF00
Hex Value: 0xFF01
009258 - Exhaust Gas Temperature Sensor; B1 S3
P242A - 000 - Malfunction - Intermittent
Mileage: 193840 km
Date: 2013.10.17
Time: 12:59:32
RPM: 115 /min
Voltage: 12.08 V
Temperature: 26.1°C
Temperature: 18.0°C
Temperature: 930.0°C
009326 - Exhaust Gas Temperature Sensor 4 Bank 1
P246E - 000 - Electrical Malfunction - Intermittent
Mileage: 193840 km
Date: 2013.10.17
Time: 12:59:32
RPM: 115 /min
Voltage: 12.08 V
Temperature: 26.1°C
Temperature: 18.0°C
Readiness: 0 1 0 0 0
Part No SW: 02E 300 052 HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1977
Revision: 04843012 Serial number: 00000809170964
Shop #: WSC 21377 123 87419
VCID: D1EA2D1B482DD2C282-8084
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Shop #: WSC 00028 028 00001
VCID: F8BCB0BF4B17A38A65-80AC
02085 - Incorrect Control Module Installed
Reset counter: 38
Date: 2013.10.17
Time: 17:59:06
Count: 16387
Count: 20992
Count: 204
Count: 48128
Count: 7936
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Reset counter: 38
Mileage: 193842 km
Date: 2013.10.17
Time: 17:59:01
Count: 16387
Count: 12800
Count: 39
Count: 48128
Count: 256
Count: 7936
Reset counter: 253
Mileage: 193842 km
Date: 2013.10.17
Time: 17:59:09
Count: 16391
Count: 195
Count: 46848
Count: 256
Count: 7936
Fault Status: 01100101
Reset counter: 253
Mileage: 193842 km
Date: 2013.10.17
Time: 17:59:01
Count: 16387
Count: 12800
Count: 279
Count: 48128
Count: 256
Count: 7936
Reset counter: 253
Mileage: 193842 km
Date: 2013.10.17
Time: 17:59:01
Count: 16387
Count: 12800
Count: 295
Count: 48128
Count: 256
Count: 7936
Reset counter: 253
Mileage: 193842 km
Date: 2013.10.17
Time: 17:59:01
Count: 16387
Count: 12800
Count: 270
Count: 48128
Count: 256
Count: 7936
Part No SW: 5K0 907 044 AK HW: 5K0 907 044 AK
Component: Climatronic 130 0303
Coding: 0000000000
ASAM Dataset: EV_Climatronic A01001
VCID: F4A4848F5F7FC7EA49-80A0
9481988 - Air Quality Sensor
B10AF 04 [009] - Internal System Fault
Fault Frequency: 14
Reset counter: 253
Mileage: 193840 km
Date: 2019.05.27
Time: 15:06:13
Part No SW: 1K0 937 084 HW: 1K0 937 084
Component: BCM PQ35 B 020 0358
Revision: 00020000
Coding: 40180A3A98251AC040080080540000E445510088636D8D60648000000000
VCID: EB969FF30A41181298-80BE
Component: Wischer 03100 21 0501
Coding: 009795
Component: RLS 011008 05 54 0402
Coding: 0330AD
00984 - Left Tail Light (M4)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 16
Reset counter: 253
Mileage: 193840 km
Date: 2013.10.17
Time: 15:12:60
Voltage: 13.70 V
Term 50 Off
02389 - Release Signal Transmission; Position P/N
Reset counter: 38
Mileage: 193842 km
Date: 2013.10.17
Time: 17:54:54
Voltage: 13.05 V
Term 50 Off
01502 - Bulb for Rear Fog; Left (L46)
Fault Status: 01101100
Reset counter: 253
Mileage: 193843 km
Date: 2013.10.17
Time: 18:11:40
Voltage: 12.55 V
Term 50 Off
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5K0 919 475 HW: 5K0 919 475
Component: PARKHILFE 8K H07 0002
Revision: -------- Serial number: 60630822100702
Coding: 100101
VCID: F3A687935271C0D250-80A6
Part No SW: 5K0 959 655 HW: 5K0 959 655
Component: AirbagVW10 020 0507
Serial number: 003C2D03X57Z
Coding: 00003135
ASAM Dataset: EV_AirbaVW10SMEVW360 A01003
ROD: EV_AirbaVW10SMEVW360.rod
VCID: F7BEB3834E09ACF26C-80A2
Component: S.Sens.Fahr.V U01 ----
Serial number: 0B491043ZZZZZZZZZZZZ
Component: S.Sens.Beif.V U01 ----
Serial number: 750C5542ZZZZZZZZZZZZ
Serial number: 38031059ZZZZZZZZZZZZ
Serial number: 26291010ZZZZZZZZZZZZ
9440026 - Driver's side; side-airbag igniter
B100B 1A [137] - Resistance Too Low
Mileage: 193840 km
Date: 2019.05.27
Time: 15:06:15
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CE HW: 1K0 953 549 CE
Component: J0527 055 0111
Coding: 0001802
VCID: F7BEB3838609ACF26C-80A2
Subsystem 1 - Part No: 3C8 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H2ÿ 0021
Coding: 00000227
Part No SW: 5K0 920 870 CX HW: 5K0 920 870 CX
Component: KOMBI H21 0030
Coding: 170F00
Shop #: WSC 21377 123 179808
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
VCID: 8542C94B04E5CE626E-80D0
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 011008F1000834
Coding: EDA07F060006020002
VCID: B522798BDC859EE2BE-80E0
Mileage: 193841 km
Date: 2013.10.17
Time: 17:41:02
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H21 0030
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
ROD: EV_Immo_UDS_VDD_RM09.rod
Part No SW: 1K0 959 701 AN HW: 1K0 959 701 AN
Component: Tuer-SG 008 2015
Coding: 0004278
VCID: FAB8AAB7B51BB19A13-80AE
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
Shop #: WSC 01324 785 00200
VCID: AA185AF7053BC11A23-80FE
Fault Status: 00101101
Reset counter: 48
Mileage: 193842 km
Date: 2013.10.17
Time: 17:59:01
Voltage: 13.50 V
DU
Temperature: 41.0°C
RPM: 781 /min
Part No SW: 1K0 959 702 AN HW: 1K0 959 702 AN
Coding: 0004534
VCID: FBB6AFB3BA21889208-80AE
Part No SW: 3AD 035 190 HW: 3AD 035 190
Component: RCD510USBRVC 001 0003
Revision: -----001 Serial number: VWZ4Z3N8062098
Coding: 01000464040010
Shop #: WSC 00079 790 00000
VCID: EA989AF705BB011AE3-80BE
Reset counter: 253
Mileage: 193840 km
Date: 2013.10.17
Time: 15:16:03
Part No SW: 1K0 959 703 AL HW: 1K0 959 703 AL
Component: Tuer-SG 007 2009
Coding: 0000144
Shop #: WSC 01357 011 1012552
Part No SW: 1K0 959 704 AL HW: 1K0 959 704 AL
Coding: 0000144
Address 77: Telephone Labels: 3C0-035-730.lbl
Part No SW: 3C8 035 730 HW: 3C8 035 730
Component: Telefon 2800
Revision: 00012000 Serial number: 0000000113585
Coding: 0020145
VCID: E08CF8DF33874B4A3D-80B4
End----------(Elapsed Time: 01:18, VBatt start/end: 12.6V/12.6V)-----------
