Passat B7 new PDC retrofit hiccup
siLc
Tallinn, Estonia
C?ID=330192
I did a Discover Media PQ retrofit for a colleague's 2012 Passat B7 using my former Discover Media PQ unit. The standard package of this retrofit is a newer parking aid module 1K8919472C, newer highline reversing camera module 7N0907441B (and camera) and a newer CAN gateway 7N0907530BL. Everything was working fine. The radio played fine, reversing camera displayed a picture and the camera lines moved as they should but one weird thing popped up and didn't want to go away - when stationary and shifting from R to P, the PDC doesn't turn off. You have to press the appropriate button for it to turn off. When driving ahead 20km/h+, PDC turns off as it should. Any ideas on this? Perhaps this is caused by an incompatible parameterization of the PDC module? It reportedly came out of a 2015+ Sharan.
I did this retrofit in stages. First the DM itself, the PDC module and this behaviour didn't show. Second I fitted the newer camera module and CAN, then this behaviour showed.
Also, I had Traffic Sign Recognition enabled on my car but this car doesn't have the Lane Assist camera for it to work. I unticked the appropriate bits in DM coding and went over the adaptations but this fault returned after clearing. DM admap is below...
The following autoscan is somewhat out-of-date as I was able to code the PDC module so it doesn't miss the trailer and RCTA modules. Also the CAN fault in clocks isn't actual anymore.
Saturday,25,May,2019,11:52:21:46309
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
Dealer/Shop Name:
Workshop Code: 123 12345 098765
VIN: WVWZZZ3CZCE149555   License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 3C 42 44 46 47 4C 4F 52
          53 55 5F 61 62 6C 72
VIN: WVWZZZ3CZCE149555   Mileage: 335550km-208501miles
Address 01: Engine (J623-CFGB)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 NT    HW: 03L 907 309 AE
   Component: R4 2,0L EDC   H27 2473
   Revision: 41H27---    Serial number: 00000000000000
   Coding: 001D0012046401080000
   Shop #: WSC 00015 115 00000
   ASAM Dataset: EV_ECM20TDI01103L906018NT 003004
   ROD: EV_ECM20TDI01103L906018NC.rod
   VCID: 094F609449B20C1FC93-805C
   Part No SW: 02E 300 057 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3113
   Revision: 05551213    Serial number: 00001203121663
   Shop #: WSC 05311 000 00000
   VCID: 24111120C2D0B177DA5-8070
   Part No SW: 3AA 614 109 AJ    HW: 3AA 614 109 AJ
   Component: J104   C2 450M VE84 0023
   Revision: --H07---    Serial number: 00000005472483
   Coding: 0122300
   VCID: 75B71C6439CA78FFBDB-8020
   Part No SW: 3AA 907 044 F    HW: 3AA 907 044 F
   Component: Climatronic   H03 0404
   Revision: 00001K01
   Coding: 0011004803
   VCID: 3333E27C7BBE26CF53F-8066
Address 09: Cent. Elect. (J519)       Labels:. User\3AA-937-087.lbl
   Part No SW: 3AA 937 087 H    HW: 3AA 937 087 H
   Component: BCM PQ47 H+   421 0464
   Revision: BC421001
   Coding: 0008000000000000001C0080740029F423D50088672D8760E480C7240041
   Shop #: WSC 05311 123 08193
   VCID: 3FDBBE4C4776F2AFA77-806A
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 21021  10  0603
   Coding: 00B795
   Component: RLS 170312 05  54  0403
   Coding: 024D2A
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331626405049
   Coding: 0021151011
   Shop #: WSC 12345 123 98765
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: 372BD66C6FC6CAEF6F7-8062
13632272 - Databus
          [Steuergerät für Anhängererkennung-J345 - mGate_Komf_1.GK1_Sta_Anhaen - kein Signal/keine Kommunikation]
                    Reset counter: 172
                    Mileage: 335550 km
                    Date: 2019.05.25
                    Time: 11:47:54
13639168 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01 - kein Signal / keine Kommunikation]
                    Reset counter: 172
                    Mileage: 335550 km
                    Date: 2019.05.25
                    Time: 10:25:22
Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
   Part No SW: 3AA 907 567 A    HW: 3AA 907 567
   Component: AC201  RDW A    036 0170
   Revision: 00036000    Serial number: 00000000540740
   Coding: 0010000
   Shop #: WSC 05311 000 08193
   VCID: 3829D5506E58C59766D-806C
   Part No SW: 5N0 959 655 T    HW: 5N0 959 655 T
   Component: J234__11R VW10 HI   2118
   Revision: 24017000    Serial number: 003LDP5MB9AX
   Coding: 0012626
   VCID: 4EC59388FCDC6B275C1-801A
   Subsystem 1 - Serial number: 6332MTS680270602
   Subsystem 2 - Serial number: 6342MTS640730592
   Subsystem 3 - Serial number: 6351HTS6E2OGMAKR
   Subsystem 4 - Serial number: 6361HTS6R1AHMAKR
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C9 953 501 BM    HW: 5K0 953 569 T
   Revision: FF010040    Serial number: 20120322300300
   Coding: 3992A50001
   VCID: 75B71C64354A78FFBDB-8020
   Coding: E30000
   Part No SW: 3AA 920 880 C    HW: 3AA 920 880 C
   Component: KOMBI         H03 0408
   Coding: 161F01
   Shop #: WSC 05311 115 08193
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
          U0056 00 [008] - Performance
          [Datenbus Kombi/Fahrwerk: keine Kommunikation]
                    Reset counter: 172
10486016 - Control module
          B2001 00 [009] - Incorrect software version
          [BAP: Steuergerät falsche Softwareversion]
                    Reset counter: 132
                    Mileage: 335550 km
                    Date: 2019.05.25
                    Time: 10:29:48
   Part No SW: 7N0 907 530 BL    HW: 1K0 907 951
   Component: J533  Gateway H41 1682
   Revision:   H41       Serial number: 100112F1002116
   Coding: 462006
   VCID: 7BA30A5C13EE2E8FCBF-802E
   Part No SW: 3AA 959 799 A    HW: 3AA 959 799 A
   Component:    IMMO         083 0402
   Revision: 00083000    Serial number: VWZCZ000000000
   VCID: 46D5ABA814ACA367E41-8012
   Part No SW: 3AA 907 566 B    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0040
   Revision: 00H02000    Serial number: 6PZ 010 316-08
   Coding: 0000172
   Subsystem 1 - Part No: 3AA 907 568 B
   Component: J0770_SWA_Slave_H02 0040
   Subsystem 2 - Serial number: 6PZ 010 316-28
   Subsystem 3 - Serial number: 5F07.03.1200H020003C730455ÿ
   Subsystem 4 - Serial number: 730455ÿ
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0004585626
   Coding: 0200FF
   Shop #: WSC 05311 115 00000
   VCID: 3537DC6475CA38FF7DB-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 703     HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0407
   Serial number: 00000002803340
   Coding: 0000D8
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.311 1002
   Revision: 1AH03734    Serial number: 00120720345801
   Coding: 0000258
   VCID: 3C21C9405A60E9B7825-8068
Address 46: Central Conv.        Labels:. User\3C0-959-799-46.lbl
   Component: 02 KESSY PQ47   083 0346
   Coding: 0191020052C30E76340494157E004FCE705801030434B8
   Component: Neigungssensor  004 0611
   Subsystem 4 - Component:       ViP n.mounted
   Part No SW: 5K0 035 456 C    HW: 5K0 035 456 C
   Component: KonzernAmp 8K H07 0202
   Revision: --------    Serial number: EAA086A0009398
   ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
   ROD: EV_AudioVerst8KanalBNO2.rod
   VCID: 2A0DFF18AC746707E09-807E
   Component: EZE_2         H41 1682
   Coding: 00000008
   VCID: 6FBB2E0C5796422F777-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0004586703
   Coding: 0200FE
   ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
   VCID: 3635DB6868CC33E7741-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 704     HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0407
   Serial number: 00000002805260
   Coding: 0000D8
   Revision:   H19       Serial number: 00000000064936
   Coding: 0022167
   VCID: 3635DB68644C33E7741-8062
   Component: AFS-ECU       H04 0111
   Coding: 029200000B000200
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   Subsystem 1 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H04 0012
   Coding: 230000
   Subsystem 2 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H04 0012
   Coding: 230000
   Part No SW: 5C0 035 680 B    HW: 5C0 035 680 B
   Component: MU-S-N-ER     H20 0252
   Serial number: VWZAZ2R0221946
   Coding: 02740401AA00000011110003000908001F0100C4002001000C
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 20191D30DA48AD57BED-8074
   Subsystem 1 - Part No SW: 5NA 919 866 R    HW: -----------
   Component: ECE AS 19/20  --- 1115
7201 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 132
                    Mileage: 335550 km
                    Date: 2019.05.25
                    Time: 11:20:39
                    Voltage terminal 30: 11.9 V
                    BAP-BAP_Function_ID: 02
   Component: Batt.regelung H41 1682
   Coding: 030F1859
   VCID: 71BF287441A254DF613-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900436783
   Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Component: VW428 RVC Mid H04 0040
   Coding: 012408012201000300
   ASAM Dataset: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAVW428.rod
   VCID: 3039ED708AA81DD72ED-8064
End----------(Elapsed Time: 01:47, VBatt start/end: 12.0V/12.1V)-----------
I managed to find PDC coding after completing stage 1 (when P disengaged PDC):
                Address 10: Park/Steer Assist       Labels: 5Q0-919-294.clb
Control Module Part Number: 1K8 919 472 C    HW: 5Q0 919 294 A
  Component and/or Version: PARKHILFE 8K  H03 0480
           Software Coding: 0071155011
            Work Shop Code: WSC 00020 999 00000
              ASAM Dataset: EV_EPHVA18VW364GP00 001007 (VW46)
13639168 - Databus
                    Reset counter: 207
                    Mileage: 333059 km
                    Date: 2019.05.04
                    Time: 12:16:59
	SW:5C0-035-680-B			HW:5C0-035-680-B	---		Information	Electr.
	Component:MU-S-N-ER					H20	252	Coding:02740401AA00000011110003000908001F0100C4002001000C
	EV_MUStd4CTSAT,001022,EV_MUStd4CTSAT_VW36.rod
	Saturday,25,May,2019,12:05:03:46309
	VCDS	Version:	Release	18.9.1	(x64)		Data	version:	20190114	DS296.0
IDE00001-Production	mode,00	0	0	0,3
IDE00346-Summertime-automatic,none	0,1
IDE00758-Base	volume	of	telephone,50	%,1
IDE00759-Base	volume	of	speech	output,50	%,1
IDE00760-Microphone	sensitivity,0	dB,1
IDE00769-Number	1	for	Info	call,5E	7	A1	80	0	68	55	97	42	63	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	0,23
IDE00770-Number	1	for	roadside	assistance,5E	7	A1	80	0	98	37	87	24	F3	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	0,23
IDE00820-ENG117828-Activating	and	deactivating	all	development	messages-Infotainment_CAN_Messages,OFF	0,1
IDE00820-ENG117829-Activating	and	deactivating	all	development	messages-MIB_CAN_Messages,OFF	0,1
IDE00845-Wheel	circ.,0	mm,2
IDE02121-CD	eject	button,Enabled	0,1
IDE02122-Developer	mode,activated	0,1
IDE02330-Number	2	for	Info	call,5E	8	91	94	81	20	68	55	97	42	63	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	0,23
IDE02331-Number	2	for	roadside	assistance,5E	6	91	94	81	60	11	21	31	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	0,23
IDE02332-Deactivate	production	mode,0	0,3
IDE02476-MAS03001-Electrical	test	of	loudspeakers-Mode,automatic	0,49
IDE02476-ENG117360-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000	Hz,49
IDE02476-ENG117361-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,36	0,49
IDE02476-ENG117378-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000	Hz,49
IDE02476-ENG117379-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,36	0,49
IDE02476-ENG117380-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000	Hz,49
IDE02476-ENG117381-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,36	0,49
IDE02476-ENG117382-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000	Hz,49
IDE02476-ENG117383-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,36	0,49
IDE02476-ENG117384-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000	Hz,49
IDE02476-ENG117385-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,36	0,49
IDE02476-ENG117386-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000	Hz,49
IDE02476-ENG117387-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,36	0,49
IDE02476-ENG117388-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000	Hz,49
IDE02476-ENG117389-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,36	0,49
IDE02476-ENG117390-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000	Hz,49
IDE02476-ENG117391-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,36	0,49
IDE02476-ENG117362-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000	Hz,49
IDE02476-ENG117363-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,36	0,49
IDE02476-ENG117364-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000	Hz,49
IDE02476-ENG117365-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,36	0,49
IDE02476-ENG117366-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000	Hz,49
IDE02476-ENG117367-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,36	0,49
IDE02476-ENG117368-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000	Hz,49
IDE02476-ENG117369-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,36	0,49
IDE02476-ENG117370-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000	Hz,49
IDE02476-ENG117371-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,36	0,49
IDE02476-ENG117372-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000	Hz,49
IDE02476-ENG117373-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,36	0,49
IDE02476-ENG117374-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000	Hz,49
IDE02476-ENG117375-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,36	0,49
IDE02476-ENG117376-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000	Hz,49
IDE02476-ENG117377-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,36	0,49
IDE02502-Confirmation	of	installation	change,30	E7	0,2
IDE02607-Wheel	pulse,0	0,2
IDE02699-Number	1	for	roadside	assistance,5E	2	A1	11	F2	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	0,23
IDE02701-Number	1	(roaming)	for	roadside	assistance,5E	2	A1	11	F2	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	0,23
IDE04331-Selection	of	release	codes	for	a	SWaP	function,FF	FF	FF	FF	0,4
IDE04550-Bluetooth:	Sniff	mode,OFF	0,1
IDE05111-Fee-based	traffic	information	(TMC),15	0,2
IDE05113-Infotainment	Recorder,activated	0,1
IDE08814-IDE04033-Navigation	receiver	GNSS	configuration-Compass,OFF	0,1
IDE08814-MAS01570-Navigation	receiver	GNSS	configuration-Default,On	0,1
IDE08814-MAS02614-Navigation	receiver	GNSS	configuration-GPS,OFF	0,1
IDE08814-MAS07828-Navigation	receiver	GNSS	configuration-Galileo,OFF	0,1
IDE08814-MAS07829-Navigation	receiver	GNSS	configuration-Glonass,OFF	0,1
IDE08814-ENG142047-Navigation	receiver	GNSS	configuration-external_gps_1,OFF	0,1
IDE08814-ENG142048-Navigation	receiver	GNSS	configuration-external_gps_2,OFF	0,1
IDE10221-MAS00839-Audio	Management	Input	Gain	Generation	2-TV	Tuner,-128	0,4
IDE10221-MAS00846-Audio	Management	Input	Gain	Generation	2-Satellite	radio,5	0,4
IDE10221-MAS01984-Audio	Management	Input	Gain	Generation	2-Radio	(FM),4	0,4
IDE10221-MAS01985-Audio	Management	Input	Gain	Generation	2-Radio	(AM),7	0,4
IDE10221-MAS01986-Audio	Management	Input	Gain	Generation	2-Digital	radio	(DAB),4	0,4
IDE10221-ENG125854-Audio	Management	Input	Gain	Generation	2-Exbox_DMB,-128	0,4
IDE10221-ENG117430-Audio	Management	Input	Gain	Generation	2-HFP,-128	0,4
IDE10221-ENG125846-Audio	Management	Input	Gain	Generation	2-Media_Airplay,-128	0,4
IDE10221-ENG125837-Audio	Management	Input	Gain	Generation	2-Media_AUX_Adapter,-128	0,4
IDE10221-ENG125836-Audio	Management	Input	Gain	Generation	2-Media_AUXIN,-128	0,4
IDE10221-ENG125843-Audio	Management	Input	Gain	Generation	2-Media_Bluray,-128	0,4
IDE10221-ENG125841-Audio	Management	Input	Gain	Generation	2-Media_BTDevice,-128	0,4
IDE10221-ENG125838-Audio	Management	Input	Gain	Generation	2-Media_CDA,0	0,4
IDE10221-ENG125848-Audio	Management	Input	Gain	Generation	2-Media_Cloud,-128	0,4
IDE10221-ENG125839-Audio	Management	Input	Gain	Generation	2-Media_DVD,-128	0,4
IDE10221-ENG125844-Audio	Management	Input	Gain	Generation	2-Media_HDMI,-128	0,4
IDE10221-ENG125840-Audio	Management	Input	Gain	Generation	2-Media_MFP,0	0,4
IDE10221-ENG125847-Audio	Management	Input	Gain	Generation	2-Media_UPNP,-128	0,4
IDE10221-ENG125855-Audio	Management	Input	Gain	Generation	2-Mirrorlink,-128	0,4
IDE10221-ENG125859-Audio	Management	Input	Gain	Generation	2-Phone_Ringer_MFP,-128	0,4
IDE10221-ENG125860-Audio	Management	Input	Gain	Generation	2-Phone_Ringer_OB,-128	0,4
IDE10221-ENG125858-Audio	Management	Input	Gain	Generation	2-Phone_Voice,-128	0,4
IDE10221-ENG125842-Audio	Management	Input	Gain	Generation	2-TA_Tuner_FM,7	0,4
IDE10221-ENG125850-Audio	Management	Input	Gain	Generation	2-Tone_Beep,-128	0,4
IDE10221-ENG125853-Audio	Management	Input	Gain	Generation	2-Tone_Messaging,-128	0,4
IDE10221-ENG125852-Audio	Management	Input	Gain	Generation	2-Tone_Touchscreen,-128	0,4
IDE10221-ENG125851-Audio	Management	Input	Gain	Generation	2-Tone_Warning,-128	0,4
IDE10221-ENG125856-Audio	Management	Input	Gain	Generation	2-TTS_Nav,-128	0,4
IDE10221-ENG125857-Audio	Management	Input	Gain	Generation	2-TTS_SDS,-128	0,4
IDE10221-ENG125845-Audio	Management	Input	Gain	Generation	2-Tuner_Online,-128	0,4
IDE10221-ENG125849-Audio	Management	Input	Gain	Generation	2-Tuner_Personal,-128	0,4
IDE10221-ENG125835-Audio	Management	Input	Gain	Generation	2-Tuner_TI,-128	0,4
IDE10221-ENG125861-Audio	Management	Input	Gain	Generation	2-TV_AV_IN,-128	0,4
IDE10480-MAS10741-Interface	for	external	media:	activation-Connection	1,activated	0,4
IDE10480-MAS10742-Interface	for	external	media:	activation-Connection	2,not	activated	0,4
IDE10480-MAS10743-Interface	for	external	media:	activation-Connection	3,not	activated	0,4
IDE10480-MAS10744-Interface	for	external	media:	activation-Connection	4,not	activated	0,4
IDE10604-Menu	entries	for	mobile	online	services,activated	0,1
IDE11122-Country	identification:	country	of	sale	HMI,DE	0,2
IDE11502-ENG127601-Locked	menu	contents-FB_CAR_0,non_blocked	0,21
IDE11502-ENG127602-Locked	menu	contents-FB_CAR_1,non_blocked	0,21
IDE11502-ENG127611-Locked	menu	contents-FB_CAR_10,non_blocked	0,21
IDE11502-ENG127612-Locked	menu	contents-FB_CAR_11,non_blocked	0,21
IDE11502-ENG127613-Locked	menu	contents-FB_CAR_12,non_blocked	0,21
IDE11502-ENG127614-Locked	menu	contents-FB_CAR_13,non_blocked	0,21
IDE11502-ENG127615-Locked	menu	contents-FB_CAR_14,non_blocked	0,21
IDE11502-ENG127616-Locked	menu	contents-FB_CAR_15,non_blocked	0,21
IDE11502-ENG127617-Locked	menu	contents-FB_CAR_16,non_blocked	0,21
IDE11502-ENG127618-Locked	menu	contents-FB_CAR_17,non_blocked	0,21
IDE11502-ENG127619-Locked	menu	contents-FB_CAR_18,non_blocked	0,21
IDE11502-ENG127620-Locked	menu	contents-FB_CAR_19,non_blocked	0,21
IDE11502-ENG127603-Locked	menu	contents-FB_CAR_2,non_blocked	0,21
IDE11502-ENG127621-Locked	menu	contents-FB_CAR_20,non_blocked	0,21
IDE11502-ENG127622-Locked	menu	contents-FB_CAR_21,non_blocked	0,21
IDE11502-ENG127623-Locked	menu	contents-FB_CAR_22,non_blocked	0,21
IDE11502-ENG127624-Locked	menu	contents-FB_CAR_23,non_blocked	0,21
IDE11502-ENG127604-Locked	menu	contents-FB_CAR_3,non_blocked	0,21
IDE11502-ENG127605-Locked	menu	contents-FB_CAR_4,non_blocked	0,21
IDE11502-ENG127606-Locked	menu	contents-FB_CAR_5,non_blocked	0,21
IDE11502-ENG127607-Locked	menu	contents-FB_CAR_6,non_blocked	0,21
IDE11502-ENG127608-Locked	menu	contents-FB_CAR_7,non_blocked	0,21
IDE11502-ENG127609-Locked	menu	contents-FB_CAR_8,non_blocked	0,21
IDE11502-ENG127610-Locked	menu	contents-FB_CAR_9,non_blocked	0,21
IDE11502-ENG127521-Locked	menu	contents-FB_MEDIA_0,non_blocked	0,21
IDE11502-ENG127522-Locked	menu	contents-FB_MEDIA_1,non_blocked	0,21
IDE11502-ENG127531-Locked	menu	contents-FB_MEDIA_10,non_blocked	0,21
IDE11502-ENG127532-Locked	menu	contents-FB_MEDIA_11,non_blocked	0,21
IDE11502-ENG127533-Locked	menu	contents-FB_MEDIA_12,non_blocked	0,21
IDE11502-ENG127534-Locked	menu	contents-FB_MEDIA_13,non_blocked	0,21
IDE11502-ENG127535-Locked	menu	contents-FB_MEDIA_14,non_blocked	0,21
IDE11502-ENG127536-Locked	menu	contents-FB_MEDIA_15,non_blocked	0,21
IDE11502-ENG127537-Locked	menu	contents-FB_MEDIA_16,non_blocked	0,21
IDE11502-ENG127538-Locked	menu	contents-FB_MEDIA_17,non_blocked	0,21
IDE11502-ENG127539-Locked	menu	contents-FB_MEDIA_18,non_blocked	0,21
IDE11502-ENG127540-Locked	menu	contents-FB_MEDIA_19,non_blocked	0,21
IDE11502-ENG127523-Locked	menu	contents-FB_MEDIA_2,non_blocked	0,21
IDE11502-ENG127541-Locked	menu	contents-FB_MEDIA_20,non_blocked	0,21
IDE11502-ENG127542-Locked	menu	contents-FB_MEDIA_21,non_blocked	0,21
IDE11502-ENG127543-Locked	menu	contents-FB_MEDIA_22,non_blocked	0,21
IDE11502-ENG127544-Locked	menu	contents-FB_MEDIA_23,non_blocked	0,21
IDE11502-ENG127524-Locked	menu	contents-FB_MEDIA_3,non_blocked	0,21
IDE11502-ENG127525-Locked	menu	contents-FB_MEDIA_4,non_blocked	0,21
IDE11502-ENG127526-Locked	menu	contents-FB_MEDIA_5,non_blocked	0,21
IDE11502-ENG127527-Locked	menu	contents-FB_MEDIA_6,non_blocked	0,21
IDE11502-ENG127528-Locked	menu	contents-FB_MEDIA_7,non_blocked	0,21
IDE11502-ENG127529-Locked	menu	contents-FB_MEDIA_8,non_blocked	0,21
IDE11502-ENG127530-Locked	menu	contents-FB_MEDIA_9,non_blocked	0,21
IDE11502-ENG127625-Locked	menu	contents-FB_MISC_0,non_blocked	0,21
IDE11502-ENG127626-Locked	menu	contents-FB_MISC_1,non_blocked	0,21
IDE11502-ENG127635-Locked	menu	contents-FB_MISC_10,non_blocked	0,21
IDE11502-ENG127636-Locked	menu	contents-FB_MISC_11,non_blocked	0,21
IDE11502-ENG127637-Locked	menu	contents-FB_MISC_12,non_blocked	0,21
IDE11502-ENG127638-Locked	menu	contents-FB_MISC_13,non_blocked	0,21
IDE11502-ENG127639-Locked	menu	contents-FB_MISC_14,non_blocked	0,21
IDE11502-ENG127640-Locked	menu	contents-FB_MISC_15,non_blocked	0,21
IDE11502-ENG127641-Locked	menu	contents-FB_MISC_16,non_blocked	0,21
IDE11502-ENG127642-Locked	menu	contents-FB_MISC_17,non_blocked	0,21
IDE11502-ENG127643-Locked	menu	contents-FB_MISC_18,non_blocked	0,21
IDE11502-ENG127644-Locked	menu	contents-FB_MISC_19,non_blocked	0,21
IDE11502-ENG127627-Locked	menu	contents-FB_MISC_2,non_blocked	0,21
IDE11502-ENG127645-Locked	menu	contents-FB_MISC_20,non_blocked	0,21
IDE11502-ENG127646-Locked	menu	contents-FB_MISC_21,non_blocked	0,21
IDE11502-ENG127647-Locked	menu	contents-FB_MISC_22,non_blocked	0,21
IDE11502-ENG127648-Locked	menu	contents-FB_MISC_23,non_blocked	0,21
IDE11502-ENG127649-Locked	menu	contents-FB_MISC_24,non_blocked	0,21
IDE11502-ENG127650-Locked	menu	contents-FB_MISC_25,non_blocked	0,21
IDE11502-ENG127651-Locked	menu	contents-FB_MISC_26,non_blocked	0,21
IDE11502-ENG127652-Locked	menu	contents-FB_MISC_27,non_blocked	0,21
IDE11502-ENG127653-Locked	menu	contents-FB_MISC_28,non_blocked	0,21
IDE11502-ENG127654-Locked	menu	contents-FB_MISC_29,non_blocked	0,21
IDE11502-ENG127628-Locked	menu	contents-FB_MISC_3,non_blocked	0,21
IDE11502-ENG127655-Locked	menu	contents-FB_MISC_30,non_blocked	0,21
IDE11502-ENG127656-Locked	menu	contents-FB_MISC_31,non_blocked	0,21
IDE11502-ENG127657-Locked	menu	contents-FB_MISC_32,non_blocked	0,21
IDE11502-ENG127658-Locked	menu	contents-FB_MISC_33,non_blocked	0,21
IDE11502-ENG127659-Locked	menu	contents-FB_MISC_34,non_blocked	0,21
IDE11502-ENG127660-Locked	menu	contents-FB_MISC_35,non_blocked	0,21
IDE11502-ENG127661-Locked	menu	contents-FB_MISC_36,non_blocked	0,21
IDE11502-ENG127662-Locked	menu	contents-FB_MISC_37,non_blocked	0,21
IDE11502-ENG127663-Locked	menu	contents-FB_MISC_38,non_blocked	0,21
IDE11502-ENG127664-Locked	menu	contents-FB_MISC_39,non_blocked	0,21
IDE11502-ENG127629-Locked	menu	contents-FB_MISC_4,non_blocked	0,21
IDE11502-ENG127665-Locked	menu	contents-FB_MISC_40,non_blocked	0,21
IDE11502-ENG127666-Locked	menu	contents-FB_MISC_41,non_blocked	0,21
IDE11502-ENG127667-Locked	menu	contents-FB_MISC_42,non_blocked	0,21
IDE11502-ENG127668-Locked	menu	contents-FB_MISC_43,non_blocked	0,21
IDE11502-ENG127669-Locked	menu	contents-FB_MISC_44,non_blocked	0,21
IDE11502-ENG127670-Locked	menu	contents-FB_MISC_45,non_blocked	0,21
IDE11502-ENG127671-Locked	menu	contents-FB_MISC_46,non_blocked	0,21
IDE11502-ENG127672-Locked	menu	contents-FB_MISC_47,non_blocked	0,21
IDE11502-ENG127630-Locked	menu	contents-FB_MISC_5,non_blocked	0,21
IDE11502-ENG127631-Locked	menu	contents-FB_MISC_6,non_blocked	0,21
IDE11502-ENG127632-Locked	menu	contents-FB_MISC_7,non_blocked	0,21
IDE11502-ENG127633-Locked	menu	contents-FB_MISC_8,non_blocked	0,21
IDE11502-ENG127634-Locked	menu	contents-FB_MISC_9,non_blocked	0,21
IDE11502-ENG127561-Locked	menu	contents-FB_NAV_0,non_blocked	0,21
IDE11502-ENG127562-Locked	menu	contents-FB_NAV_1,non_blocked	0,21
IDE11502-ENG127571-Locked	menu	contents-FB_NAV_10,non_blocked	0,21
IDE11502-ENG127572-Locked	menu	contents-FB_NAV_11,non_blocked	0,21
IDE11502-ENG127573-Locked	menu	contents-FB_NAV_12,non_blocked	0,21
IDE11502-ENG127574-Locked	menu	contents-FB_NAV_13,non_blocked	0,21
IDE11502-ENG127575-Locked	menu	contents-FB_NAV_14,non_blocked	0,21
IDE11502-ENG127576-Locked	menu	contents-FB_NAV_15,non_blocked	0,21
IDE11502-ENG127577-Locked	menu	contents-FB_NAV_16,non_blocked	0,21
IDE11502-ENG127578-Locked	menu	contents-FB_NAV_17,non_blocked	0,21
IDE11502-ENG127579-Locked	menu	contents-FB_NAV_18,non_blocked	0,21
IDE11502-ENG127580-Locked	menu	contents-FB_NAV_19,non_blocked	0,21
IDE11502-ENG127563-Locked	menu	contents-FB_NAV_2,non_blocked	0,21
IDE11502-ENG127581-Locked	menu	contents-FB_NAV_20,non_blocked	0,21
IDE11502-ENG127582-Locked	menu	contents-FB_NAV_21,non_blocked	0,21
IDE11502-ENG127583-Locked	menu	contents-FB_NAV_22,non_blocked	0,21
IDE11502-ENG127584-Locked	menu	contents-FB_NAV_23,non_blocked	0,21
IDE11502-ENG127585-Locked	menu	contents-FB_NAV_24,non_blocked	0,21
IDE11502-ENG127586-Locked	menu	contents-FB_NAV_25,non_blocked	0,21
IDE11502-ENG127587-Locked	menu	contents-FB_NAV_26,non_blocked	0,21
IDE11502-ENG127588-Locked	menu	contents-FB_NAV_27,non_blocked	0,21
IDE11502-ENG127589-Locked	menu	contents-FB_NAV_28,non_blocked	0,21
IDE11502-ENG127590-Locked	menu	contents-FB_NAV_29,non_blocked	0,21
IDE11502-ENG127564-Locked	menu	contents-FB_NAV_3,non_blocked	0,21
IDE11502-ENG127591-Locked	menu	contents-FB_NAV_30,non_blocked	0,21
IDE11502-ENG127592-Locked	menu	contents-FB_NAV_31,non_blocked	0,21
IDE11502-ENG127593-Locked	menu	contents-FB_NAV_32,non_blocked	0,21
IDE11502-ENG127594-Locked	menu	contents-FB_NAV_33,non_blocked	0,21
IDE11502-ENG127595-Locked	menu	contents-FB_NAV_34,non_blocked	0,21
IDE11502-ENG127596-Locked	menu	contents-FB_NAV_35,non_blocked	0,21
IDE11502-ENG127597-Locked	menu	contents-FB_NAV_36,non_blocked	0,21
IDE11502-ENG127598-Locked	menu	contents-FB_NAV_37,non_blocked	0,21
IDE11502-ENG127599-Locked	menu	contents-FB_NAV_38,non_blocked	0,21
IDE11502-ENG127600-Locked	menu	contents-FB_NAV_39,non_blocked	0,21
IDE11502-ENG127565-Locked	menu	contents-FB_NAV_4,non_blocked	0,21
IDE11502-ENG127566-Locked	menu	contents-FB_NAV_5,non_blocked	0,21
IDE11502-ENG127567-Locked	menu	contents-FB_NAV_6,non_blocked	0,21
IDE11502-ENG127568-Locked	menu	contents-FB_NAV_7,non_blocked	0,21
IDE11502-ENG127569-Locked	menu	contents-FB_NAV_8,non_blocked	0,21
IDE11502-ENG127570-Locked	menu	contents-FB_NAV_9,non_blocked	0,21
IDE11502-ENG127545-Locked	menu	contents-FB_PHONE_0,non_blocked	0,21
IDE11502-ENG127546-Locked	menu	contents-FB_PHONE_1,non_blocked	0,21
IDE11502-ENG127555-Locked	menu	contents-FB_PHONE_10,non_blocked	0,21
IDE11502-ENG127556-Locked	menu	contents-FB_PHONE_11,non_blocked	0,21
IDE11502-ENG127557-Locked	menu	contents-FB_PHONE_12,non_blocked	0,21
IDE11502-ENG127558-Locked	menu	contents-FB_PHONE_13,non_blocked	0,21
IDE11502-ENG127559-Locked	menu	contents-FB_PHONE_14,non_blocked	0,21
IDE11502-ENG127560-Locked	menu	contents-FB_PHONE_15,non_blocked	0,21
IDE11502-ENG127547-Locked	menu	contents-FB_PHONE_2,non_blocked	0,21
IDE11502-ENG127548-Locked	menu	contents-FB_PHONE_3,non_blocked	0,21
IDE11502-ENG127549-Locked	menu	contents-FB_PHONE_4,non_blocked	0,21
IDE11502-ENG127550-Locked	menu	contents-FB_PHONE_5,non_blocked	0,21
IDE11502-ENG127551-Locked	menu	contents-FB_PHONE_6,non_blocked	0,21
IDE11502-ENG127552-Locked	menu	contents-FB_PHONE_7,non_blocked	0,21
IDE11502-ENG127553-Locked	menu	contents-FB_PHONE_8,non_blocked	0,21
IDE11502-ENG127554-Locked	menu	contents-FB_PHONE_9,non_blocked	0,21
IDE11502-ENG127505-Locked	menu	contents-FB_TUNER_0,non_blocked	0,21
IDE11502-ENG127506-Locked	menu	contents-FB_TUNER_1,non_blocked	0,21
IDE11502-ENG127515-Locked	menu	contents-FB_TUNER_10,non_blocked	0,21
IDE11502-ENG127516-Locked	menu	contents-FB_TUNER_11,non_blocked	0,21
IDE11502-ENG127517-Locked	menu	contents-FB_TUNER_12,non_blocked	0,21
IDE11502-ENG127518-Locked	menu	contents-FB_TUNER_13,non_blocked	0,21
IDE11502-ENG127519-Locked	menu	contents-FB_TUNER_14,non_blocked	0,21
IDE11502-ENG127520-Locked	menu	contents-FB_TUNER_15,non_blocked	0,21
IDE11502-ENG127507-Locked	menu	contents-FB_TUNER_2,non_blocked	0,21
IDE11502-ENG127508-Locked	menu	contents-FB_TUNER_3,non_blocked	0,21
IDE11502-ENG127509-Locked	menu	contents-FB_TUNER_4,non_blocked	0,21
IDE11502-ENG127510-Locked	menu	contents-FB_TUNER_5,non_blocked	0,21
IDE11502-ENG127511-Locked	menu	contents-FB_TUNER_6,non_blocked	0,21
IDE11502-ENG127512-Locked	menu	contents-FB_TUNER_7,non_blocked	0,21
IDE11502-ENG127513-Locked	menu	contents-FB_TUNER_8,non_blocked	0,21
IDE11502-ENG127514-Locked	menu	contents-FB_TUNER_9,non_blocked	0,21
MAS00950-Audio	Parameter,0	0,1
MAS00951-Bluetooth,On	0,1
MAS02809-MAS02870-Check	tone	frequency-High	note	frequency	range,4000	Hz,6
MAS02809-MAS02871-Check	tone	frequency-Medium	note	frequency	range,1000	Hz,6
MAS02809-MAS02872-Check	tone	frequency-Low	note	frequency	range,100	Hz,6
MAS03782-WLAN,On	0,1
ENG117917-BAP_Debug_Mode_Release,not_released	0,1
ENG104140-Bluetooth_Phonebook_Access_Profile,PBAP	0,1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not	activated	0,6
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not	activated	0,6
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not	activated	0,6
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not	activated	0,6
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not	activated	0,6
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not	activated	0,6
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not	activated	0,6
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not	activated	0,6
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not	activated	0,6
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not	activated	0,6
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not	activated	0,6
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not	activated	0,6
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not	activated	0,6
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not	activated	0,6
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not	activated	0,6
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not	activated	0,6
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not	activated	0,6
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not	activated	0,6
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not	activated	0,6
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not	activated	0,6
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not	activated	0,6
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not	activated	0,6
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not	activated	0,6
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not	activated	0,6
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not	activated	0,6
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not	activated	0,6
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not	activated	0,6
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not	activated	0,6
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not	activated	0,6
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not	activated	0,6
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not	activated	0,6
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not	activated	0,6
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not	activated	0,6
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not	activated	0,6
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not	activated	0,6
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,not	activated	0,6
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not	activated	0,6
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not	activated	0,6
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,not	activated	0,6
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not	activated	0,6
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not	activated	0,6
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not	activated	0,6
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not	activated	0,6
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not	activated	0,6
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not	activated	0,6
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not	activated	0,6
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not	activated	0,6
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not	activated	0,6
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not	activated	0,6
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not	activated	0,6
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,activated	0,6
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,activated	0,6
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,activated	0,6
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,activated	0,6
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,activated	0,6
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not	activated	0,6
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not	activated	0,6
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not	activated	0,6
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not	activated	0,6
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not	activated	0,6
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not	activated	0,6
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not	activated	0,6
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not	activated	0,6
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not	activated	0,6
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not	activated	0,6
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not	activated	0,6
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not	activated	0,6
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not	activated	0,6
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not	activated	0,6
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not	activated	0,6
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,not	activated	0,6
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not	activated	0,6
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not	activated	0,6
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,not	activated	0,6
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not	activated	0,6
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not	activated	0,6
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not	activated	0,6
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not	activated	0,6
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not	activated	0,6
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not	activated	0,6
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not	activated	0,6
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not	activated	0,6
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not	activated	0,6
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not	activated	0,6
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not	activated	0,6
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,not	activated	0,6
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not	activated	0,6
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not	activated	0,6
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,not	activated	0,6
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not	activated	0,6
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,not	activated	0,6
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not	activated	0,6
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not	activated	0,6
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,not	activated	0,6
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not	activated	0,6
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not	activated	0,6
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not	activated	0,6
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not	activated	0,6
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,not	activated	0,6
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not	activated	0,6
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated	0,6
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,activated	0,6
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,activated	0,6
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated	0,6
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,activated	0,6
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,not	activated	0,6
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not	activated	0,6
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not	activated	0,6
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,not	activated	0,6
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not	activated	0,6
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not	activated	0,6
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not	activated	0,6
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not	activated	0,6
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not	activated	0,6
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not	activated	0,6
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not	activated	0,6
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not	activated	0,6
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not	activated	0,6
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not	activated	0,6
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not	activated	0,6
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not	activated	0,6
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not	activated	0,6
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not	activated	0,6
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not	activated	0,6
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not	activated	0,6
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not	activated	0,6
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not	activated	0,6
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not	activated	0,6
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not	activated	0,6
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not	activated	0,6
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,not	activated	0,6
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not	activated	0,6
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not	activated	0,6
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not	activated	0,6
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not	activated	0,6
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not	activated	0,6
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not	activated	0,6
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not	activated	0,6
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not	activated	0,6
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not	activated	0,6
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not	activated	0,6
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not	activated	0,6
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not	activated	0,6
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not	activated	0,6
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not	activated	0,6
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,not	activated	0,6
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not	activated	0,6
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not	activated	0,6
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,not	activated	0,6
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not	activated	0,6
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not	activated	0,6
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not	activated	0,6
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not	activated	0,6
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not	activated	0,6
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not	activated	0,6
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not	activated	0,6
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not	activated	0,6
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not	activated	0,6
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not	activated	0,6
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not	activated	0,6
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,activated	0,6
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,activated	0,6
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,activated	0,6
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated	0,6
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,activated	0,6
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not	activated	0,6
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not	activated	0,6
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not	activated	0,6
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,not	activated	0,6
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not	activated	0,6
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not	activated	0,6
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not	activated	0,6
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not	activated	0,6
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not	activated	0,6
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not	activated	0,6
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not	activated	0,6
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not	activated	0,6
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not	activated	0,6
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not	activated	0,6
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not	activated	0,6
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,not	activated	0,6
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not	activated	0,6
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not	activated	0,6
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not	activated	0,6
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not	activated	0,6
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated	0,6
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not	activated	0,6
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not	activated	0,6
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated	0,6
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not	activated	0,6
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not	activated	0,6
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not	activated	0,6
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not	activated	0,6
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not	activated	0,6
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not	activated	0,6
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,not	activated	0,6
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not	activated	0,6
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not	activated	0,6
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not	activated	0,6
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not	activated	0,6
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not	activated	0,6
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not	activated	0,6
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not	activated	0,6
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not	activated	0,6
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not	activated	0,6
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not	activated	0,6
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not	activated	0,6
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not	activated	0,6
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not	activated	0,6
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not	activated	0,6
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not	activated	0,6
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not	activated	0,6
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not	activated	0,6
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not	activated	0,6
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not	activated	0,6
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not	activated	0,6
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not	activated	0,6
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not	activated	0,6
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not	activated	0,6
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not	activated	0,6
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not	activated	0,6
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not	activated	0,6
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not	activated	0,6
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not	activated	0,6
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not	activated	0,6
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,not	activated	0,6
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not	activated	0,6
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not	activated	0,6
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,not	activated	0,6
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not	activated	0,6
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not	activated	0,6
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not	activated	0,6
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not	activated	0,6
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not	activated	0,6
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not	activated	0,6
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not	activated	0,6
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not	activated	0,6
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not	activated	0,6
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not	activated	0,6
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not	activated	0,6
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not	activated	0,6
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not	activated	0,6
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not	activated	0,6
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not	activated	0,6
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not	activated	0,6
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not	activated	0,6
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not	activated	0,6
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not	activated	0,6
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not	activated	0,6
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not	activated	0,6
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not	activated	0,6
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not	activated	0,6
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not	activated	0,6
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not	activated	0,6
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not	activated	0,6
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not	activated	0,6
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not	activated	0,6
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not	activated	0,6
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not	activated	0,6
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not	activated	0,6
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not	activated	0,6
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not	activated	0,6
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not	activated	0,6
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not	activated	0,6
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not	activated	0,6
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not	activated	0,6
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not	activated	0,6
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not	activated	0,6
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not	activated	0,6
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not	activated	0,6
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not	activated	0,6
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not	activated	0,6
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not	activated	0,6
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not	activated	0,6
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not	activated	0,6
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,not	activated	0,6
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not	activated	0,6
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not	activated	0,6
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,not	activated	0,6
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not	activated	0,6
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not	activated	0,6
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not	activated	0,6
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not	activated	0,6
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not	activated	0,6
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not	activated	0,6
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not	activated	0,6
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not	activated	0,6
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not	activated	0,6
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not	activated	0,6
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not	activated	0,6
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,not	activated	0,6
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not	activated	0,6
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not	activated	0,6
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,not	activated	0,6
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not	activated	0,6
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,not	activated	0,6
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not	activated	0,6
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not	activated	0,6
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not	activated	0,6
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not	activated	0,6
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated	0,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus	extended	0,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not	activated	0,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not	activated	0,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,activated	0,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Databus	Infotainment	0,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not	activated	0,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not	activated	0,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,activated	0,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Databus	Infotainment	0,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not	activated	0,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not	activated	0,64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not	activated	0,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not	activated	0,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not	activated	0,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not	activated	0,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not	activated	0,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not	activated	0,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,not	activated	0,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,not	activated	0,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not	activated	0,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,not	activated	0,64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not	activated	0,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not	activated	0,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated	0,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not	activated	0,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not	activated	0,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,not	activated	0,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,not	activated	0,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not	activated	0,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not	activated	0,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not	activated	0,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,not	activated	0,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not	activated	0,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,not	activated	0,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not	activated	0,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not	activated	0,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not	activated	0,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,not	activated	0,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not	activated	0,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,not	activated	0,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,not	activated	0,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,not	activated	0,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not	activated	0,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,not	activated	0,64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not	activated	0,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not	activated	0,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,not	activated	0,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,not	activated	0,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not	activated	0,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,not	activated	0,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,not	activated	0,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,not	activated	0,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not	activated	0,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,not	activated	0,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not	activated	0,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not	activated	0,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not	activated	0,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not	activated	0,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated	0,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal	15	0,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not	activated	0,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,not	activated	0,64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not	activated	0,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not	activated	0,64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not	activated	0,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,not	activated	0,64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not	activated	0,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not	activated	0,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not	activated	0,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not	activated	0,64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not	activated	0,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not	activated	0,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not	activated	0,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not	activated	0,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not	activated	0,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not	activated	0,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,not	activated	0,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,not	activated	0,64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not	activated	0,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not	activated	0,64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not	activated	0,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not	activated	0,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not	activated	0,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not	activated	0,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not	activated	0,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,not	activated	0,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated	0,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Databus	extended	0,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated	0,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Terminal	15	0,64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not	activated	0,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not	activated	0,64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not	activated	0,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not	activated	0,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not	activated	0,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,not	activated	0,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,not	activated	0,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,not	activated	0,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated	0,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus	Infotainment	0,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not	activated	0,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,not	activated	0,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,not	activated	0,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,not	activated	0,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not	available	0,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Not	available	0,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not	available	0,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not	available	0,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available	0,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus	Infotainment	0,8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Not	available	0,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Not	available	0,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available	0,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal	15	0,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not	available	0,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Not	available	0,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Not	available	0,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not	available	0,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Not	available	0,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Not	available	0,8
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0	0,6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,20	0,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,50	0,6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0	0,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,20	0,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,50	0,6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,3	0,12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10	0,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,15	0,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,60	0,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,0	0,12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,0	0,12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,2	%,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,10	%,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,15	%,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,90	%,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,0	%,12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,0	%,12
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,00	0	0	0	1	0	0	0	0	1	0	0	0	0	1	0	0	0	0	1	2D	1E	37	28	37	28	2D	1E	7	64	1E	4	10	3	0A	0	0	0	1	3	0,4
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0	0,2
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0	0,2
ENG117919-Startup_Screen_Sticker_HMI,00	2	0,2
ENG109862-ENG117847-Vehicle_configuration-advanced_range_display,On	0,3
ENG109862-ENG142146-Vehicle_configuration-allow_message_editing,OFF	0,3
ENG109862-ENG130249-Vehicle_configuration-Apple_DIO,On	0,3
ENG109862-ENG185764-Vehicle_configuration-Apple_DIO_Wireless,OFF	0,3
ENG109862-ENG152525-Vehicle_configuration-Baidu_Car_Life,OFF	0,3
ENG109862-ENG152559-Vehicle_configuration-Baidu_Car_Life_ios,OFF	0,3
ENG109862-ENG185765-Vehicle_configuration-Baidu_Car_Life_ios_Wireless,OFF	0,3
ENG109862-ENG185766-Vehicle_configuration-Baidu_Car_Life_Wireless,OFF	0,3
ENG109862-ENG152560-Vehicle_configuration-block_hmi_function_p_epb,blocked	0,3
ENG109862-ENG142151-Vehicle_configuration-conditioning_variant,0	0,3
ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_call,On	0,3
ENG109862-ENG142145-Vehicle_configuration-esim_data_only_sms_support,OFF	0,3
ENG109862-ENG185778-Vehicle_configuration-FoD,SWaP	0,3
ENG109862-ENG130248-Vehicle_configuration-Google_GAL,On	0,3
ENG109862-ENG185779-Vehicle_configuration-Google_GAL_Wireless,OFF	0,3
ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverarts,OFF	0,3
ENG109862-ENG117851-Vehicle_configuration-gracenote_local_other,OFF	0,3
ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverarts,OFF	0,3
ENG109862-ENG117849-Vehicle_configuration-gracenote_online_other,OFF	0,3
ENG109862-ENG152533-Vehicle_configuration-Hybrid_Radio_additional_online_data,not	activated	0,3
ENG109862-ENG152534-Vehicle_configuration-Hybrid_Radio_Range_Extender,Deactivated	0,3
ENG109862-ENG125049-Vehicle_configuration-Joker_button_1,Not	Present	0,3
ENG109862-ENG125050-Vehicle_configuration-Joker_button_2,Not	Present	0,3
ENG109862-ENG127492-Vehicle_configuration-LGI,OFF	0,3
ENG109862-ENG130246-Vehicle_configuration-LTE_modul,activated	0,3
ENG109862-ENG142142-Vehicle_configuration-map_email_support,OFF	0,3
ENG109862-ENG142143-Vehicle_configuration-map_instant_messaging_support,OFF	0,3
ENG109862-ENG142141-Vehicle_configuration-map_sms_support,OFF	0,3
ENG109862-ENG142152-Vehicle_configuration-Map_Style,0	0,3
ENG109862-ENG152537-Vehicle_configuration-media_control,not	activated	0,3
ENG109862-ENG138662-Vehicle_configuration-Mirror_link,OFF	0,3
ENG109862-ENG142148-Vehicle_configuration-MirrorLink_Country_Code,MIB_EU	0,3
ENG109862-ENG142150-Vehicle_configuration-MirrorLink_RGB_Preference,RGB565	0,3
ENG109862-ENG117843-Vehicle_configuration-my_audi,OFF	0,3
ENG109862-ENG117845-Vehicle_configuration-online_dictation,OFF	0,3
ENG109862-ENG127495-Vehicle_configuration-online_media,OFF	0,3
ENG109862-ENG117840-Vehicle_configuration-online_navigation,OFF	0,3
ENG109862-ENG117837-Vehicle_configuration-online_POI,OFF	0,3
ENG109862-ENG117838-Vehicle_configuration-online_POI_voice,OFF	0,3
ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_services,OFF	0,3
ENG109862-ENG152553-Vehicle_configuration-online_radio,Deactivated	0,3
ENG109862-ENG117841-Vehicle_configuration-online_street_view,OFF	0,3
ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unit,OFF	0,3
ENG109862-ENG167521-Vehicle_configuration-perso_v_threshold,00	0,3
ENG109862-ENG167522-Vehicle_configuration-perso_v_threshold_hysteresis,00	0,3
ENG109862-ENG152554-Vehicle_configuration-Phone_HMI_Privacy,0	0,3
ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_mode,Data	&	language	service	active	0,3
ENG109862-ENG117844-Vehicle_configuration-picture_navi,On	0,3
ENG109862-ENG167523-Vehicle_configuration-Pilot_Parking,not	activated	0,3
ENG109862-ENG167525-Vehicle_configuration-Popup_if_GPS_services_in_use,not	activated	0,3
ENG109862-ENG152555-Vehicle_configuration-Privacy_WithPINRequest,0	0,3
ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgi,OFF	0,3
ENG109862-ENG137646-Vehicle_configuration-ProbeCar_vzo,OFF	0,3
ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5	0,3
ENG109862-ENG117846-Vehicle_configuration-remote_HMI,OFF	0,3
ENG109862-ENG138661-Vehicle_configuration-RSE_software_component,activated	0,3
ENG109862-ENG245031-Vehicle_configuration-rvc_low_black_screen_trunk_open,not	activated	0,3
ENG109862-ENG244966-Vehicle_configuration-rvc_low_black_screen_velocity_threshold,not	activated	0,3
ENG109862-ENG245015-Vehicle_configuration-rvc_low_failsafe,not	activated	0,3
ENG109862-ENG126143-Vehicle_configuration-RVC_video_input,FBAS	0,3
ENG109862-ENG152556-Vehicle_configuration-scon_telephony,not	activated	0,3
ENG109862-ENG142081-Vehicle_configuration-sd_slot_deactivation,no	restriction	0,3
ENG109862-ENG138660-Vehicle_configuration-SDS_Region_Flag,no_region	0,3
ENG109862-ENG152557-Vehicle_configuration-show_volte_hmi_switch,not	activated	0,3
ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switch,Not	Present	0,3
ENG109862-ENG142144-Vehicle_configuration-sim_data_only_sms_support,OFF	0,3
ENG109862-ENG138663-Vehicle_configuration-Smartphone_interface_for_rhmi,activated	0,3
ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode,1	0,3
ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_hold,OFF	0,3
ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_calling,OFF	0,3
ENG109862-ENG130247-Vehicle_configuration-Support_second_phone,On	0,3
ENG109862-ENG167531-Vehicle_configuration-Tencent_myCar_canceling_share_location,OFF	0,3
ENG109862-ENG126994-Vehicle_configuration-TPEG_availability,OFF	0,3
ENG109862-ENG152571-Vehicle_configuration-unblock_functions_while_piloted_driving,blocked	0,3
ENG109862-ENG137647-Vehicle_configuration-UOTA,OFF	0,3
ENG109862-ENG167532-Vehicle_configuration-UOTA_2,OFF	0,3
ENG109862-ENG117852-Vehicle_configuration-UPnP,OFF	0,3
ENG109862-ENG142149-Vehicle_configuration-vehicle_leaving_sound,not	activated	0,3
ENG109862-ENG142147-Vehicle_configuration-vehicle_readiness_sound,not	activated	0,3
ENG109862-ENG152558-Vehicle_configuration-voice_over_lte,not	activated	0,3
ENG109862-ENG117836-Vehicle_configuration-VZAPro,OFF	0,3
ENG109862-ENG127494-Vehicle_configuration-VZO,OFF	0,3
ENG109862-ENG137648-Vehicle_configuration-WiFi_Client_HMI,OFF	0,3
ENG109862-ENG117842-Vehicle_configuration-WIFI_Hotspot,On	0,3
ENG109862-ENG152572-Vehicle_configuration-wlan_5ghz_switch,not	activated	0,3
Elapsed	Time:	00:33
	SW:1K8-919-472-C			HW:5Q0-919-294-A	---		Park/Steer	Assist
	Component:PARKHILFE	8K		H03	480	Coding:0021151011
	EV_EPHVA18VW364GP00,001007,EV_EPHVA18VW364GP00_VW32.rod
	Saturday,25,May,2019,11:56:38:46309
	VCDS	Version:	Release	18.9.1	(x64)		Data	version:	20190114	DS296.0
	VCID:	372BD66C6FC6CAEF6F7-8062
IDE00001-Production	mode,Deactivating	0,3
IDE01165-Park	assist	activation	tone,On	0,1
IDE01169-Audio	reduction	request,On	0,1
IDE01170-Visual	display	for	park	assist,OPS	display	0,1
IDE02332-Deactivate	production	mode,0	0,3
IDE03782-Switch-off	speed	for	parking	assist,15	km/h,1
MAS01426-Speaker	volume	for	rear	park	assist,Stage	5	0,1
MAS01427-Speaker	frequency	for	rear	park	assist,Stage	4	0,1
MAS01428-Speaker	volume	for	front	park	assist,Stage	4	0,1
MAS01429-Speaker	frequency	for	front	park	assist,Stage	6	0,1
Elapsed	Time:	00:05
Ljubo
Croatia
C?ID=271067
Why you activate display clima configuration
kamold
Australia
C?ID=241363
Try turning off VPS in 5F adaptations:
siLc
Tallinn, Estonia
C?ID=330192
I can try later today (and also obtain an up-to-date autoscan) but this will turn off the RVC, won't it?
kamold
Australia
C?ID=241363
No this is just Visual Parking System.
It's an extra feature that has the parking views like the top down view for reversing with a trailer. It also adds some views with big blocks to assist in parking. I don't like it personally.
Try with it off and on see which you prefer
https://www.drive2.ru/l/473523650151056180/
siLc
Tallinn, Estonia
C?ID=330192
Had a quick look and disabling the VPS still disables the highline RVC but leaves the unwanted behaviour in place. With my newer DM 5C0035680G this is also the case.
I'm thinking this behaviour is caused by the coding of the PDC - had a chat with my colleauge and he remembered clearly the R to P behaviour was correct before recoding the PDC to get rid of the RCTA error. Unfortunately a large chunk of this module 1K8 919 472C seems to be undocumented label-wise.
A fresh autoscan:
Tuesday,28,May,2019,16:02:20:46309
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
Dealer/Shop Name: VWRetrofits
Workshop Code: 123 12345 098765
VIN: WVWZZZ3CZCE149555   License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 3C 42 44 46 47 4C 4F 52
          53 55 5F 61 62 6C 72
VIN: WVWZZZ3CZCE149555   Mileage: 335860km-208693miles
Address 01: Engine (J623-CFGB)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 NT    HW: 03L 907 309 AE
   Component: R4 2,0L EDC   H27 2473
   Revision: 41H27---    Serial number: 00000000000000
   Coding: 001D0012046401080000
   Shop #: WSC 00015 115 00000
   ASAM Dataset: EV_ECM20TDI01103L906018NT 003004
   ROD: EV_ECM20TDI01103L906018NC.rod
   VCID: 094F609449B20C1FC93-805C
   Part No SW: 02E 300 057 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3113
   Revision: 05551213    Serial number: 00001203121663
   Shop #: WSC 05311 000 00000
   VCID: 24111120C2D0B177DA5-8070
   Part No SW: 3AA 614 109 AJ    HW: 3AA 614 109 AJ
   Component: J104   C2 450M VE8A 0023
   Revision: --H07---    Serial number: 00000005472483
   Coding: 0122300
   VCID: 75B71C6439CA78FFBDB-8020
   Part No SW: 3AA 907 044 F    HW: 3AA 907 044 F
   Component: Climatronic   H03 0404
   Revision: 00001K01
   Coding: 0011004803
   VCID: 3333E27C7BBE26CF53F-8066
Address 09: Cent. Elect. (J519)       Labels:. User\3AA-937-087.lbl
   Part No SW: 3AA 937 087 H    HW: 3AA 937 087 H
   Component: BCM PQ47 H+   421 0464
   Revision: BC421001
   Coding: 0008000000000000001C0080740029F423D50088672D8760E480C7240041
   Shop #: WSC 05311 123 08193
   VCID: 3FDBBE4C4776F2AFA77-806A
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 21021  10  0603
   Coding: 00B795
   Component: RLS 170312 05  54  0403
   Coding: 024D2A
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331626405049
   Coding: 0021151011
   Shop #: WSC 12345 123 98765
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
   Part No SW: 3AA 907 567 A    HW: 3AA 907 567
   Component: AC201  RDW A    036 0170
   Revision: 00036000    Serial number: 00000000540740
   Coding: 0010000
   Shop #: WSC 05311 000 08193
   VCID: 3829D5506E58C59766D-806C
   Part No SW: 5N0 959 655 T    HW: 5N0 959 655 T
   Component: J234__11R VW10 HI   2118
   Revision: 24017000    Serial number: 003LDP5MB9AX
   Coding: 0012626
   VCID: 4EC59388FCDC6B275C1-801A
   Subsystem 1 - Serial number: 6332MTS680270602
   Subsystem 2 - Serial number: 6342MTS640730592
   Subsystem 3 - Serial number: 6351HTS6E2OGMAKR
   Subsystem 4 - Serial number: 6361HTS6R1AHMAKR
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C9 953 501 BM    HW: 5K0 953 569 T
   Revision: FF010040    Serial number: 20120322300300
   Coding: 3992A50001
   VCID: 75B71C64354A78FFBDB-8020
   Coding: E30000
   Part No SW: 3AA 920 880 C    HW: 3AA 920 880 C
   Component: KOMBI         H03 0408
   Coding: 161F01
   Shop #: WSC 05311 115 08193
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
          U0056 00 [008] - Performance
          [Datenbus Kombi/Fahrwerk: keine Kommunikation]
                    Reset counter: 172
10486016 - Control module
          B2001 00 [009] - Incorrect software version
          [BAP: Steuergerät falsche Softwareversion]
                    Reset counter: 132
                    Mileage: 335550 km
                    Date: 2019.05.25
                    Time: 10:29:48
   Part No SW: 7N0 907 530 BL    HW: 1K0 907 951
   Component: J533  Gateway H41 1682
   Revision:   H41       Serial number: 100112F1002116
   Coding: 462006
   VCID: 7BA30A5C13EE2E8FCBF-802E
   Part No SW: 3AA 959 799 A    HW: 3AA 959 799 A
   Component:    IMMO         083 0402
   Revision: 00083000    Serial number: VWZCZ000000000
   VCID: 46D5ABA814ACA367E41-8012
   Part No SW: 3AA 907 566 B    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0040
   Revision: 00H02000    Serial number: 6PZ 010 316-08
   Coding: 0000172
   Subsystem 1 - Part No: 3AA 907 568 B
   Component: J0770_SWA_Slave_H02 0040
   Subsystem 2 - Serial number: 6PZ 010 316-28
   Subsystem 3 - Serial number: 5F07.03.1200H020003C730455ÿ
   Subsystem 4 - Serial number: 730455ÿ
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0004585626
   Coding: 0200FF
   Shop #: WSC 05311 115 00000
   VCID: 3537DC6475CA38FF7DB-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 703     HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0407
   Serial number: 00000002803340
   Coding: 0000D8
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.311 1002
   Revision: 1AH03734    Serial number: 00120720345801
   Coding: 0000258
   VCID: 3C21C9405A60E9B7825-8068
Address 46: Central Conv.        Labels:. User\3C0-959-799-46.lbl
   Component: 02 KESSY PQ47   083 0346
   Coding: 0191020052C30E76340494157E004FCE705801030434B8
   Component: Neigungssensor  004 0611
   Subsystem 4 - Component:       ViP n.mounted
   Part No SW: 5K0 035 456 C    HW: 5K0 035 456 C
   Component: KonzernAmp 8K H07 0202
   Revision: --------    Serial number: EAA086A0009398
   ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
   ROD: EV_AudioVerst8KanalBNO2.rod
   VCID: 2A0DFF18AC746707E09-807E
   Component: EZE_2         H41 1682
   Coding: 00000008
   VCID: 6FBB2E0C5796422F777-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0004586703
   Coding: 0200FE
   ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
   VCID: 3635DB6868CC33E7741-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 704     HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0407
   Serial number: 00000002805260
   Coding: 0000D8
   Revision:   H19       Serial number: 00000000064936
   Coding: 0022167
   VCID: 3635DB68644C33E7741-8062
   Component: AFS-ECU       H04 0111
   Coding: 029200000B000200
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   Subsystem 1 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H04 0012
   Coding: 230000
   Subsystem 2 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H04 0012
   Coding: 230000
   Part No SW: 5C0 035 680 B    HW: 5C0 035 680 B
   Component: MU-S-N-ER     H20 0252
   Serial number: VWZAZ2R0221946
   Coding: 02740401AA00000011110003000908001F0100C4002001000C
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 20191D30DA48AD57BED-8074
   Subsystem 1 - Part No SW: 5NA 919 866 R    HW: -----------
   Component: ECE AS 19/20  --- 1115
7201 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 132
                    Mileage: 335550 km
                    Date: 2019.05.25
                    Time: 11:20:39
                    Voltage terminal 30: 11.9 V
                    BAP-BAP_Function_ID: 02
   Component: Batt.regelung H41 1682
   Coding: 030F1859
   VCID: 71BF287441A254DF613-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900436783
   Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Component: VW428 RVC Mid H04 0040
   Coding: 012408012201000300
   ASAM Dataset: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAVW428.rod
   VCID: 3039ED708AA81DD72ED-8064
End----------(Elapsed Time: 01:46, VBatt start/end: 13.3V/13.3V)-----------
kamold
Australia
C?ID=241363
That's weird, if I disable VPS I still have normal RVC operation.
I have the RCTA missing message in park assist still.
I haven't had a chance to do any comparisons, but here are my admaps:
5F
;SW:5C0-035-680-B   HW:5C0-035-680-B ---  Information Electr.
;Component:MU-S-N-ER     H22 0253	 Coding:021306013C00000011110005000808001F0200D4002001004F
;EV_MUStd4CTSAT	1022	EV_MUStd4CTSAT_VW26.rod
;Wednesday	29	May
;VCDS Version: Beta 19.4.0  Data version: 20190411 DS307.0
;VCID: 20191E4B3A4D80279FB-8074
IDE00001-Production mode	00 00 00 	3
IDE00346-Summertime-automatic	none 	1
IDE00758-Base volume of telephone	50%	1
IDE00759-Base volume of speech output	50%	1
IDE00760-Microphone sensitivity	0 dB	1
IDE00769-Number 1 for Info call	5E 05 A1 80 00 04 02 04 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE00770-Number 1 for roadside assistance	5E 05 A1 80 84 20 34 56 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages	OFF 	1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages	OFF 	1
IDE00845-Wheel circ.	0 mm	2
IDE02121-CD eject button	Enabled 	1
IDE02122-Developer mode	activated 	1
IDE02330-Number 2 for Info call	5E 06 91 14 08 40 20 40 F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE02331-Number 2 for roadside assistance	5E 06 91 14 48 08 42 63 F5 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE02332-Deactivate production mode	0	3
IDE02476-MAS03001-Electrical test of loudspeakers-Mode	automatic 	49
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency	19000 Hz	49
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume	36	49
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency	19000 Hz	49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume	36	49
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency	19000 Hz	49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume	36	49
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency	19000 Hz	49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume	36	49
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency	19000 Hz	49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume	36	49
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency	19000 Hz	49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume	36	49
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency	19000 Hz	49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume	36	49
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency	19000 Hz	49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume	36	49
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency	19000 Hz	49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume	36	49
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency	19000 Hz	49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume	36	49
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency	19000 Hz	49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume	36	49
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency	19000 Hz	49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume	36	49
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency	19000 Hz	49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume	36	49
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency	19000 Hz	49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume	36	49
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency	19000 Hz	49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume	36	49
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency	19000 Hz	49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume	36	49
IDE02502-Confirmation of installation change	45 16 	2
IDE02607-Wheel pulse	0	2
IDE02699-Number 1 for roadside assistance	5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE02701-Number 1 (roaming) for roadside assistance	5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE04331-Selection of release codes for a SWaP function	FF FF FF FF 	4
IDE04550-Bluetooth: Sniff mode	OFF 	1
IDE05111-Fee-based traffic information (TMC)	1024	2
IDE05113-Infotainment Recorder	activated 	1
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass	OFF 	1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default	On 	1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS	OFF 	1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo	OFF 	1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass	OFF 	1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1	OFF 	1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2	OFF 	1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner	-128	40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio	5	40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM)	4	40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM)	7	40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB)	4	40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB	-128	40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP	-128	40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay	-128	40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter	-128	40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN	-128	40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray	-128	40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice	-128	40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA	0	40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud	-128	40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD	-128	40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI	-128	40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP	0	40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP	-128	40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink	-128	40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP	-128	40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB	-128	40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice	-128	40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM	7	40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep	-128	40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging	-128	40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen	-128	40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning	-128	40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav	-128	40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS	-128	40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online	-128	40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal	-128	40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI	-128	40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN	-128	40
IDE10480-MAS10741-Interface for external media: activation-Connection 1	activated 	4
IDE10480-MAS10742-Interface for external media: activation-Connection 2	not activated 	4
IDE10480-MAS10743-Interface for external media: activation-Connection 3	not activated 	4
IDE10480-MAS10744-Interface for external media: activation-Connection 4	not activated 	4
IDE10604-Menu entries for mobile online services	activated 	1
IDE11122-Country identification: country of sale HMI	CG 	2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0	non_blocked 	21
IDE11502-ENG127602-Locked menu contents-FB_CAR_1	non_blocked 	21
IDE11502-ENG127611-Locked menu contents-FB_CAR_10	non_blocked 	21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11	non_blocked 	21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12	non_blocked 	21
IDE11502-ENG127614-Locked menu contents-FB_CAR_13	non_blocked 	21
IDE11502-ENG127615-Locked menu contents-FB_CAR_14	non_blocked 	21
IDE11502-ENG127616-Locked menu contents-FB_CAR_15	non_blocked 	21
IDE11502-ENG127617-Locked menu contents-FB_CAR_16	non_blocked 	21
IDE11502-ENG127618-Locked menu contents-FB_CAR_17	non_blocked 	21
IDE11502-ENG127619-Locked menu contents-FB_CAR_18	non_blocked 	21
IDE11502-ENG127620-Locked menu contents-FB_CAR_19	non_blocked 	21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2	non_blocked 	21
IDE11502-ENG127621-Locked menu contents-FB_CAR_20	non_blocked 	21
IDE11502-ENG127622-Locked menu contents-FB_CAR_21	non_blocked 	21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22	non_blocked 	21
IDE11502-ENG127624-Locked menu contents-FB_CAR_23	non_blocked 	21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3	non_blocked 	21
IDE11502-ENG127605-Locked menu contents-FB_CAR_4	non_blocked 	21
IDE11502-ENG127606-Locked menu contents-FB_CAR_5	non_blocked 	21
IDE11502-ENG127607-Locked menu contents-FB_CAR_6	non_blocked 	21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7	non_blocked 	21
IDE11502-ENG127609-Locked menu contents-FB_CAR_8	non_blocked 	21
IDE11502-ENG127610-Locked menu contents-FB_CAR_9	non_blocked 	21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0	non_blocked 	21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1	non_blocked 	21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10	non_blocked 	21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11	non_blocked 	21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12	non_blocked 	21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13	non_blocked 	21
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14	non_blocked 	21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15	non_blocked 	21
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16	non_blocked 	21
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17	non_blocked 	21
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18	non_blocked 	21
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19	non_blocked 	21
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2	non_blocked 	21
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20	non_blocked 	21
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21	non_blocked 	21
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22	non_blocked 	21
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23	non_blocked 	21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3	non_blocked 	21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4	non_blocked 	21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5	non_blocked 	21
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6	non_blocked 	21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7	non_blocked 	21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8	non_blocked 	21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9	non_blocked 	21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0	non_blocked 	21
IDE11502-ENG127626-Locked menu contents-FB_MISC_1	non_blocked 	21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10	non_blocked 	21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11	non_blocked 	21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12	non_blocked 	21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13	non_blocked 	21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14	non_blocked 	21
IDE11502-ENG127640-Locked menu contents-FB_MISC_15	non_blocked 	21
IDE11502-ENG127641-Locked menu contents-FB_MISC_16	non_blocked 	21
IDE11502-ENG127642-Locked menu contents-FB_MISC_17	non_blocked 	21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18	non_blocked 	21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19	non_blocked 	21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2	non_blocked 	21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20	non_blocked 	21
IDE11502-ENG127646-Locked menu contents-FB_MISC_21	non_blocked 	21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22	non_blocked 	21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23	non_blocked 	21
IDE11502-ENG127649-Locked menu contents-FB_MISC_24	non_blocked 	21
IDE11502-ENG127650-Locked menu contents-FB_MISC_25	non_blocked 	21
IDE11502-ENG127651-Locked menu contents-FB_MISC_26	non_blocked 	21
IDE11502-ENG127652-Locked menu contents-FB_MISC_27	non_blocked 	21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28	non_blocked 	21
IDE11502-ENG127654-Locked menu contents-FB_MISC_29	non_blocked 	21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3	non_blocked 	21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30	non_blocked 	21
IDE11502-ENG127656-Locked menu contents-FB_MISC_31	non_blocked 	21
IDE11502-ENG127657-Locked menu contents-FB_MISC_32	non_blocked 	21
IDE11502-ENG127658-Locked menu contents-FB_MISC_33	non_blocked 	21
IDE11502-ENG127659-Locked menu contents-FB_MISC_34	non_blocked 	21
IDE11502-ENG127660-Locked menu contents-FB_MISC_35	non_blocked 	21
IDE11502-ENG127661-Locked menu contents-FB_MISC_36	non_blocked 	21
IDE11502-ENG127662-Locked menu contents-FB_MISC_37	non_blocked 	21
IDE11502-ENG127663-Locked menu contents-FB_MISC_38	non_blocked 	21
IDE11502-ENG127664-Locked menu contents-FB_MISC_39	non_blocked 	21
IDE11502-ENG127629-Locked menu contents-FB_MISC_4	non_blocked 	21
IDE11502-ENG127665-Locked menu contents-FB_MISC_40	non_blocked 	21
IDE11502-ENG127666-Locked menu contents-FB_MISC_41	non_blocked 	21
IDE11502-ENG127667-Locked menu contents-FB_MISC_42	non_blocked 	21
IDE11502-ENG127668-Locked menu contents-FB_MISC_43	non_blocked 	21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44	non_blocked 	21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45	non_blocked 	21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46	non_blocked 	21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47	non_blocked 	21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5	non_blocked 	21
IDE11502-ENG127631-Locked menu contents-FB_MISC_6	non_blocked 	21
IDE11502-ENG127632-Locked menu contents-FB_MISC_7	non_blocked 	21
IDE11502-ENG127633-Locked menu contents-FB_MISC_8	non_blocked 	21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9	non_blocked 	21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0	non_blocked 	21
IDE11502-ENG127562-Locked menu contents-FB_NAV_1	non_blocked 	21
IDE11502-ENG127571-Locked menu contents-FB_NAV_10	non_blocked 	21
IDE11502-ENG127572-Locked menu contents-FB_NAV_11	non_blocked 	21
IDE11502-ENG127573-Locked menu contents-FB_NAV_12	non_blocked 	21
IDE11502-ENG127574-Locked menu contents-FB_NAV_13	non_blocked 	21
IDE11502-ENG127575-Locked menu contents-FB_NAV_14	non_blocked 	21
IDE11502-ENG127576-Locked menu contents-FB_NAV_15	non_blocked 	21
IDE11502-ENG127577-Locked menu contents-FB_NAV_16	non_blocked 	21
IDE11502-ENG127578-Locked menu contents-FB_NAV_17	non_blocked 	21
IDE11502-ENG127579-Locked menu contents-FB_NAV_18	non_blocked 	21
IDE11502-ENG127580-Locked menu contents-FB_NAV_19	non_blocked 	21
IDE11502-ENG127563-Locked menu contents-FB_NAV_2	non_blocked 	21
IDE11502-ENG127581-Locked menu contents-FB_NAV_20	non_blocked 	21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21	non_blocked 	21
IDE11502-ENG127583-Locked menu contents-FB_NAV_22	non_blocked 	21
IDE11502-ENG127584-Locked menu contents-FB_NAV_23	non_blocked 	21
IDE11502-ENG127585-Locked menu contents-FB_NAV_24	non_blocked 	21
IDE11502-ENG127586-Locked menu contents-FB_NAV_25	non_blocked 	21
IDE11502-ENG127587-Locked menu contents-FB_NAV_26	non_blocked 	21
IDE11502-ENG127588-Locked menu contents-FB_NAV_27	non_blocked 	21
IDE11502-ENG127589-Locked menu contents-FB_NAV_28	non_blocked 	21
IDE11502-ENG127590-Locked menu contents-FB_NAV_29	non_blocked 	21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3	non_blocked 	21
IDE11502-ENG127591-Locked menu contents-FB_NAV_30	non_blocked 	21
IDE11502-ENG127592-Locked menu contents-FB_NAV_31	non_blocked 	21
IDE11502-ENG127593-Locked menu contents-FB_NAV_32	non_blocked 	21
IDE11502-ENG127594-Locked menu contents-FB_NAV_33	non_blocked 	21
IDE11502-ENG127595-Locked menu contents-FB_NAV_34	non_blocked 	21
IDE11502-ENG127596-Locked menu contents-FB_NAV_35	non_blocked 	21
IDE11502-ENG127597-Locked menu contents-FB_NAV_36	non_blocked 	21
IDE11502-ENG127598-Locked menu contents-FB_NAV_37	non_blocked 	21
IDE11502-ENG127599-Locked menu contents-FB_NAV_38	non_blocked 	21
IDE11502-ENG127600-Locked menu contents-FB_NAV_39	non_blocked 	21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4	non_blocked 	21
IDE11502-ENG127566-Locked menu contents-FB_NAV_5	non_blocked 	21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6	non_blocked 	21
IDE11502-ENG127568-Locked menu contents-FB_NAV_7	non_blocked 	21
IDE11502-ENG127569-Locked menu contents-FB_NAV_8	non_blocked 	21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9	non_blocked 	21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0	non_blocked 	21
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1	non_blocked 	21
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10	non_blocked 	21
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11	non_blocked 	21
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12	non_blocked 	21
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13	non_blocked 	21
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14	non_blocked 	21
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15	non_blocked 	21
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2	non_blocked 	21
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3	non_blocked 	21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4	non_blocked 	21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5	non_blocked 	21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6	non_blocked 	21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7	non_blocked 	21
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8	non_blocked 	21
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9	non_blocked 	21
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0	non_blocked 	21
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1	non_blocked 	21
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10	non_blocked 	21
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11	non_blocked 	21
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12	non_blocked 	21
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13	non_blocked 	21
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14	non_blocked 	21
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15	non_blocked 	21
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2	non_blocked 	21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3	non_blocked 	21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4	non_blocked 	21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5	non_blocked 	21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6	non_blocked 	21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7	non_blocked 	21
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8	non_blocked 	21
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9	non_blocked 	21
MAS00950-Audio Parameter	0	1
MAS00951-Bluetooth	On 	1
MAS02809-MAS02870-Check tone frequency-High note frequency range	4000 Hz	6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range	1000 Hz	6
MAS02809-MAS02872-Check tone frequency-Low note frequency range	100 Hz	6
MAS03782-WLAN	On 	1
ENG117917-BAP_Debug_Mode_Release	not_released 	1
ENG104140-Bluetooth_Phonebook_Access_Profile	PBAP 	1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization	not activated 	60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer	not activated 	60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off	not activated 	60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high	not activated 	60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill	not activated 	60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation	not activated 	60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer	not activated 	60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off	not activated 	60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high	not activated 	60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill	not activated 	60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent	not activated 	60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer	not activated 	60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off	not activated 	60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high	not activated 	60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill	not activated 	60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC	not activated 	60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer	not activated 	60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off	not activated 	60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high	not activated 	60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill	not activated 	60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key	not activated 	60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer	not activated 	60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off	not activated 	60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high	not activated 	60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill	not activated 	60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue	not activated 	60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer	not activated 	60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off	not activated 	60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high	not activated 	60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill	not activated 	60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper	not activated 	60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer	not activated 	60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off	not activated 	60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high	not activated 	60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill	not activated 	60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination	not activated 	60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer	not activated 	60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off	not activated 	60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high	not activated 	60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill	not activated 	60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope	not activated 	60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer	not activated 	60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off	not activated 	60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high	not activated 	60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill	not activated 	60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification	not activated 	60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer	not activated 	60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off	not activated 	60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high	not activated 	60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill	not activated 	60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating	not activated 	60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer	not activated 	60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off	not activated 	60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high	not activated 	60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill	not activated 	60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv	not activated 	60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer	not activated 	60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off	not activated 	60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high	not activated 	60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill	not activated 	60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management	not activated 	60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer	not activated 	60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off	not activated 	60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high	not activated 	60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill	not activated 	60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE	not activated 	60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer	not activated 	60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off	not activated 	60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high	not activated 	60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill	not activated 	60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer	not activated 	60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer	not activated 	60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off	not activated 	60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high	not activated 	60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill	not activated 	60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function	not activated 	60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer	not activated 	60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off	not activated 	60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high	not activated 	60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill	not activated 	60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror	not activated 	60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer	not activated 	60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off	not activated 	60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high	not activated 	60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill	not activated 	60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking	not activated 	60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer	not activated 	60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off	not activated 	60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high	not activated 	60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill	not activated 	60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master	not activated 	60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer	not activated 	60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off	not activated 	60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high	not activated 	60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill	not activated 	60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma	not activated 	60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer	not activated 	60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off	not activated 	60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high	not activated 	60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill	not activated 	60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration	not activated 	60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer	not activated 	60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off	not activated 	60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high	not activated 	60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill	not activated 	60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock	not activated 	60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer	not activated 	60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off	not activated 	60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high	not activated 	60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill	not activated 	60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass	not activated 	60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer	not activated 	60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off	not activated 	60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high	not activated 	60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill	not activated 	60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist	not activated 	60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer	not activated 	60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off	not activated 	60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high	not activated 	60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill	not activated 	60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration	not activated 	60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer	not activated 	60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off	not activated 	60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high	not activated 	60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill	not activated 	60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school	not activated 	60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer	not activated 	60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off	not activated 	60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high	not activated 	60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill	not activated 	60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall	not activated 	60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer	not activated 	60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off	not activated 	60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high	not activated 	60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill	not activated 	60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist	not activated 	60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer	not activated 	60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off	not activated 	60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high	not activated 	60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill	not activated 	60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI	not activated 	60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer	not activated 	60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off	not activated 	60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high	not activated 	60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill	not activated 	60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination	not activated 	60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer	not activated 	60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off	not activated 	60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high	not activated 	60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill	not activated 	60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display	not activated 	60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer	not activated 	60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off	not activated 	60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high	not activated 	60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill	not activated 	60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid	not activated 	60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer	not activated 	60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off	not activated 	60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high	not activated 	60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill	not activated 	60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant	activated 	60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer	not activated 	60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off	not activated 	60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high	not activated 	60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill	activated 	60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning	not activated 	60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer	not activated 	60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off	not activated 	60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high	not activated 	60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill	not activated 	60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker	not activated 	60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer	not activated 	60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off	not activated 	60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high	not activated 	60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill	not activated 	60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision	not activated 	60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer	not activated 	60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off	not activated 	60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high	not activated 	60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill	not activated 	60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level	not activated 	60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer	not activated 	60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off	not activated 	60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high	not activated 	60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill	not activated 	60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc	activated 	60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer	not activated 	60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off	not activated 	60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high	activated 	60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill	not activated 	60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist	not activated 	60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer	not activated 	60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off	not activated 	60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high	not activated 	60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill	not activated 	60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk	not activated 	60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer	not activated 	60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off	not activated 	60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high	not activated 	60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill	not activated 	60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment	not activated 	60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer	not activated 	60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off	not activated 	60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high	not activated 	60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill	not activated 	60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load	not activated 	60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer	not activated 	60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off	not activated 	60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high	not activated 	60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill	not activated 	60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification	not activated 	60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer	not activated 	60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off	not activated 	60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high	not activated 	60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill	not activated 	60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration	not activated 	60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer	not activated 	60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off	not activated 	60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high	not activated 	60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill	not activated 	60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic	not activated 	60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer	not activated 	60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off	not activated 	60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high	not activated 	60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill	not activated 	60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia	not activated 	60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer	not activated 	60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off	not activated 	60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high	not activated 	60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill	not activated 	60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view	not activated 	60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer	not activated 	60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off	not activated 	60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high	not activated 	60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill	not activated 	60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions	not activated 	60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer	not activated 	60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off	not activated 	60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high	not activated 	60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill	not activated 	60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler	not activated 	60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer	not activated 	60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off	not activated 	60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high	not activated 	60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill	not activated 	60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI	not activated 	60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer	not activated 	60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off	not activated 	60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high	not activated 	60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill	not activated 	60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons	not activated 	60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer	not activated 	60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off	not activated 	60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high	not activated 	60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill	not activated 	60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant	not activated 	60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer	not activated 	60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off	not activated 	60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high	not activated 	60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill	not activated 	60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner	not activated 	60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer	not activated 	60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off	not activated 	60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high	not activated 	60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill	not activated 	60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo	not activated 	60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer	not activated 	60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off	not activated 	60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high	not activated 	60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill	not activated 	60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating	not activated 	60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer	not activated 	60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off	not activated 	60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high	not activated 	60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill	not activated 	60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin	not activated 	60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer	not activated 	60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off	not activated 	60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high	not activated 	60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill	not activated 	60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition	not activated 	60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer	not activated 	60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off	not activated 	60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high	not activated 	60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill	not activated 	60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows	not activated 	60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer	not activated 	60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off	not activated 	60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high	not activated 	60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill	not activated 	60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper	not activated 	60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer	not activated 	60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off	not activated 	60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high	not activated 	60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill	not activated 	60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol	not activated 	60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer	not activated 	60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off	not activated 	60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high	not activated 	60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill	not activated 	60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05	not activated 	64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus	not activated 	64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06	not activated 	64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus	not activated 	64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D	activated 	64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus	Databus Infotainment 	64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24	not activated 	64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus	not activated 	64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03	not activated 	64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus	not activated 	64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B	not activated 	64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus	not activated 	64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25	not activated 	64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus	not activated 	64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23	not activated 	64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus	not activated 	64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26	not activated 	64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus	not activated 	64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D	not activated 	64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus	not activated 	64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17	not activated 	64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus	not activated 	64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16	not activated 	64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus	not activated 	64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01	not activated 	64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus	not activated 	64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02	not activated 	64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus	not activated 	64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11	not activated 	64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus	not activated 	64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15	not activated 	64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus	not activated 	64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10	not activated 	64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus	not activated 	64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33	not activated 	64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus	not activated 	64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C	not activated 	64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C	not activated 	64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37	not activated 	64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus	not activated 	64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38	not activated 	64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus	not activated 	64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09	not activated 	64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus	not activated 	64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04	not activated 	64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus	not activated 	64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D	not activated 	64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus	not activated 	64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08	not activated 	64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus	not activated 	64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19	not activated 	64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus	not activated 	64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F	not activated 	64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus	not activated 	64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34	not activated 	64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34	not activated 	64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E	not activated 	64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus	not activated 	64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18	not activated 	64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus	not activated 	64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A	activated 	64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus	Terminal 15 	64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20	not activated 	64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus	not activated 	64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A	not activated 	64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A	not activated 	64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39	not activated 	64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39	not activated 	64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E	not activated 	64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus	not activated 	64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F	not activated 	64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus	not activated 	64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B	not activated 	64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B	not activated 	64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F	not activated 	64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F	not activated 	64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E	not activated 	64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E	not activated 	64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12	not activated 	64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus	not activated 	64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E	not activated 	64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus	not activated 	64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35	not activated 	64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35	not activated 	64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27	not activated 	64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus	not activated 	64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A	not activated 	64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus	not activated 	64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07	activated 	64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus	Terminal 15 	64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21	not activated 	64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus	not activated 	64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36	not activated 	64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36	not activated 	64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C	not activated 	64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus	not activated 	64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14	not activated 	64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus	not activated 	64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13	not activated 	64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus	not activated 	64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B	not activated 	64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus	not activated 	64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22	not activated 	64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus	not activated 	64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C	not activated 	64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus	not activated 	64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key	Not available 	8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus	Not available 	8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school	Not available 	8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus	Not available 	8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL	Not available 	8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus	Not available 	8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level	Not available 	8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus	Not available 	8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering	Available 	8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus	Terminal 15 	8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved	Not available 	8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1	Not available 	8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2	Not available 	8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3	Not available 	8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN	Not available 	8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus	Not available 	8
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1	0	6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2	20	6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3	50	6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1	0	6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2	20	6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3	50	6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1	3	12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2	10	12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3	15	12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4	60	12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5	0	12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6	0	12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1	2%	12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2	10%	12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3	15%	12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4	90%	12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5	0%	12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6	0%	12
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation	00 00 00 00 01 00 00 00 00 01 00 00 00 00 01 00 00 00 00 01 2D 1E 37 28 37 28 2D 1E 07 64 1E 04 10 03 0A 00 00 00 01 03 	40
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset	0	2
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset	0	2
ENG117919-Startup_Screen_Sticker_HMI	00 00 	2
ENG109862-ENG117847-Vehicle_configuration-advanced_range_display	OFF 	30
ENG109862-ENG142146-Vehicle_configuration-allow_message_editing	OFF 	30
ENG109862-ENG130249-Vehicle_configuration-Apple_DIO	On 	30
ENG109862-ENG185764-Vehicle_configuration-Apple_DIO_Wireless	OFF 	30
ENG109862-ENG152525-Vehicle_configuration-Baidu_Car_Life	OFF 	30
ENG109862-ENG152559-Vehicle_configuration-Baidu_Car_Life_ios	OFF 	30
ENG109862-ENG185765-Vehicle_configuration-Baidu_Car_Life_ios_Wireless	OFF 	30
ENG109862-ENG185766-Vehicle_configuration-Baidu_Car_Life_Wireless	OFF 	30
ENG109862-ENG152560-Vehicle_configuration-block_hmi_function_p_epb	blocked 	30
ENG109862-ENG142151-Vehicle_configuration-conditioning_variant	0	30
ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_call	On 	30
ENG109862-ENG142145-Vehicle_configuration-esim_data_only_sms_support	OFF 	30
ENG109862-ENG185778-Vehicle_configuration-FoD	SWaP 	30
ENG109862-ENG130248-Vehicle_configuration-Google_GAL	On 	30
ENG109862-ENG185779-Vehicle_configuration-Google_GAL_Wireless	OFF 	30
ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverarts	OFF 	30
ENG109862-ENG117851-Vehicle_configuration-gracenote_local_other	OFF 	30
ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverarts	OFF 	30
ENG109862-ENG117849-Vehicle_configuration-gracenote_online_other	OFF 	30
ENG109862-ENG152533-Vehicle_configuration-Hybrid_Radio_additional_online_data	not activated 	30
ENG109862-ENG152534-Vehicle_configuration-Hybrid_Radio_Range_Extender	Deactivated 	30
ENG109862-ENG125049-Vehicle_configuration-Joker_button_1	Not Present 	30
ENG109862-ENG125050-Vehicle_configuration-Joker_button_2	Not Present 	30
ENG109862-ENG127492-Vehicle_configuration-LGI	OFF 	30
ENG109862-ENG130246-Vehicle_configuration-LTE_modul	activated 	30
ENG109862-ENG142142-Vehicle_configuration-map_email_support	OFF 	30
ENG109862-ENG142143-Vehicle_configuration-map_instant_messaging_support	OFF 	30
ENG109862-ENG142141-Vehicle_configuration-map_sms_support	OFF 	30
ENG109862-ENG142152-Vehicle_configuration-Map_Style	0	30
ENG109862-ENG152537-Vehicle_configuration-media_control	not activated 	30
ENG109862-ENG138662-Vehicle_configuration-Mirror_link	OFF 	30
ENG109862-ENG142148-Vehicle_configuration-MirrorLink_Country_Code	MIB_EU 	30
ENG109862-ENG142150-Vehicle_configuration-MirrorLink_RGB_Preference	RGB565 	30
ENG109862-ENG117843-Vehicle_configuration-my_audi	OFF 	30
ENG109862-ENG117845-Vehicle_configuration-online_dictation	OFF 	30
ENG109862-ENG127495-Vehicle_configuration-online_media	OFF 	30
ENG109862-ENG117840-Vehicle_configuration-online_navigation	OFF 	30
ENG109862-ENG117837-Vehicle_configuration-online_POI	OFF 	30
ENG109862-ENG117838-Vehicle_configuration-online_POI_voice	OFF 	30
ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_services	OFF 	30
ENG109862-ENG152553-Vehicle_configuration-online_radio	Deactivated 	30
ENG109862-ENG117841-Vehicle_configuration-online_street_view	OFF 	30
ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unit	OFF 	30
ENG109862-ENG167521-Vehicle_configuration-perso_v_threshold	0	30
ENG109862-ENG167522-Vehicle_configuration-perso_v_threshold_hysteresis	0	30
ENG109862-ENG152554-Vehicle_configuration-Phone_HMI_Privacy	0	30
ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_mode	Data & language service active 	30
ENG109862-ENG117844-Vehicle_configuration-picture_navi	On 	30
ENG109862-ENG167523-Vehicle_configuration-Pilot_Parking	not activated 	30
ENG109862-ENG167525-Vehicle_configuration-Popup_if_GPS_services_in_use	not activated 	30
ENG109862-ENG152555-Vehicle_configuration-Privacy_WithPINRequest	0	30
ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgi	OFF 	30
ENG109862-ENG137646-Vehicle_configuration-ProbeCar_vzo	OFF 	30
ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_Version	PSD_1.5 	30
ENG109862-ENG117846-Vehicle_configuration-remote_HMI	OFF 	30
ENG109862-ENG138661-Vehicle_configuration-RSE_software_component	activated 	30
ENG109862-ENG245031-Vehicle_configuration-rvc_low_black_screen_trunk_open	not activated 	30
ENG109862-ENG244966-Vehicle_configuration-rvc_low_black_screen_velocity_threshold	not activated 	30
ENG109862-ENG245015-Vehicle_configuration-rvc_low_failsafe	not activated 	30
ENG109862-ENG126143-Vehicle_configuration-RVC_video_input	FBAS 	30
ENG109862-ENG152556-Vehicle_configuration-scon_telephony	not activated 	30
ENG109862-ENG142081-Vehicle_configuration-sd_slot_deactivation	no restriction 	30
ENG109862-ENG138660-Vehicle_configuration-SDS_Region_Flag	no_region 	30
ENG109862-ENG152557-Vehicle_configuration-show_volte_hmi_switch	not activated 	30
ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switch	Not Present 	30
ENG109862-ENG142144-Vehicle_configuration-sim_data_only_sms_support	OFF 	30
ENG109862-ENG138663-Vehicle_configuration-Smartphone_interface_for_rhmi	activated 	30
ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode	1	30
ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_hold	OFF 	30
ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_calling	OFF 	30
ENG109862-ENG130247-Vehicle_configuration-Support_second_phone	On 	30
ENG109862-ENG167531-Vehicle_configuration-Tencent_myCar_canceling_share_location	OFF 	30
ENG109862-ENG126994-Vehicle_configuration-TPEG_availability	OFF 	30
ENG109862-ENG152571-Vehicle_configuration-unblock_functions_while_piloted_driving	blocked 	30
ENG109862-ENG137647-Vehicle_configuration-UOTA	OFF 	30
ENG109862-ENG167532-Vehicle_configuration-UOTA_2	OFF 	30
ENG109862-ENG117852-Vehicle_configuration-UPnP	OFF 	30
ENG109862-ENG142149-Vehicle_configuration-vehicle_leaving_sound	not activated 	30
ENG109862-ENG142147-Vehicle_configuration-vehicle_readiness_sound	not activated 	30
ENG109862-ENG152558-Vehicle_configuration-voice_over_lte	not activated 	30
ENG109862-ENG117836-Vehicle_configuration-VZAPro	OFF 	30
ENG109862-ENG127494-Vehicle_configuration-VZO	OFF 	30
ENG109862-ENG137648-Vehicle_configuration-WiFi_Client_HMI	OFF 	30
ENG109862-ENG117842-Vehicle_configuration-WIFI_Hotspot	On 	30
ENG109862-ENG152572-Vehicle_configuration-wlan_5ghz_switch	not activated 	30
10
;SW:1K8-919-475-D   HW:5Q0-919-298 ---  Park/Steer Assist
;Component:PARKHILFE PLA H12 0480	 Coding:0131166011
;EV_EPHVA2CVW364GP00	1010	EV_EPHVA2CVW364GP00_VW36.rod
;Wednesday	29	May
;VCDS Version: Beta 19.4.0  Data version: 20190411 DS307.0
;VCID: 3B23C927B3EBC3FFAA9-806E
IDE00001-Production mode	Deactivating 	3
IDE00845-Wheel circ.	2100 mm	2
IDE01165-Park assist activation tone	On 	1
IDE01169-Audio reduction request	On 	1
IDE01170-Visual display for park assist	with OPS 360° 	1
IDE02328-Distance to curb	15 cm	1
IDE02329-Allowance for vehicle fittings (width)	0 cm	1
IDE02332-Deactivate production mode	0	3
IDE02333-Allowance for vehicle fittings (length)	0 cm	1
IDE03782-Switch-off speed for parking assist	15 km/h	1
IDE03783-Switch-on speed for parallel parking assist	37 km/h	1
MAS01426-Speaker volume for rear park assist	Stage 4 	1
MAS01427-Speaker frequency for rear park assist	Stage 4 	1
MAS01428-Speaker volume for front park assist	Stage 5 	1
MAS01429-Speaker frequency for front park assist	Stage 6 	1
kamold
Australia
C?ID=241363
I noticed you don't have RVC low coded in 5F:
Byte 19 bit 4.
Try enabling that and disable VPS in adaptations.
siLc
Tallinn, Estonia
C?ID=330192
I'm a bit skeptical of VPS having anything to do with this.
I looked up some autoscans from the reference section to compare PDC module codings. The following:
https://forums.ross-tech.com/showthread.php?9175-Seat-Alhambra-MY16&highlight=alhambra
https://forums.ross-tech.com/showthread.php?11211-2017-Scirocco-2-0tdi-150&highlight=scirocco
Compare my coding to these:
00[B][COLOR="#FF0000"]21[/COLOR][/B]151011 Patient
00[B]31[/B]151011 Alhambra
00[B]31[/B]051001 Scirocco
01[B]31[/B]166011 Yours
00[B]31[/B]163211 My B7
Alhambra is the closest to my colleauge B7's equipment - SEAT's DM, RVC high and 1K8 PDC. Your and mine is a PLA module, though the beginning of the coding string seems similar.
kamold
Australia
C?ID=241363
The coding is wrong though for 5F - its not coded for RVC....start there then VPS should become an option for how you want it to behave.
siLc
Tallinn, Estonia
C?ID=330192
It's been my current knowledge that turning on RVC high is solely through the VPS adp. In case of RVC low, its via the coding bit. So, even for RVC high, the RVC low coding bit needs to be set?
kamold
Australia
C?ID=241363
Yes I have 7N0 RVC module. RVC low is coded to on in 5F.
Then VPS adaptation becomes optional.
I'm not sure if this is the 'correct' way to do it but it's the way that I have and it seems to work well.
siLc
Tallinn, Estonia
C?ID=330192
I had a few minutes with the patient today and changed PDC coding to that of the example Alhambra. Unfortunately nothing changed...
I'll have another chance in a week or so.
kamold
Australia
C?ID=241363
Did you try disabling VPS and coding 5F byte 19?
siLc
Tallinn, Estonia
C?ID=330192
In the meantime, I fortunately remembered VCDS keeps a log of coding changes.
The last PDC coding that had the desired PDC turn off behaviour (but RTCA error occurred) was "0071055051".
siLc
Tallinn, Estonia
C?ID=330192
A conclusion to this thread.
I used the "other tool" and reparameterized the module with Passat CC parameters. This reset the coding to zeros. After recoding the annoying behaviour of the PDC not turning off when moving the shifter to P is gone :)
