Hi everyone! I have a 2013 Audi S5 and I just got verified so i'm moving my thread to the proper location. I just got my first Ross-Tech VCDS earlier this week. I bought this VCDS because i'm hoping it could help me fix my fault codes 02895 & 02897 (Supply for Left & Right LED Parking Lamp/DRL Module-Electrical malfunction in circuit). One of my mechanics worker was messing around in my headlight system with some other code reader because I had a different fault code at the time. Some how he changed some settings and I ended up with 3 fault codes including the original one i came in with. Admittedly I caused the first fault code because I was messing around with my OBDEleven I just bought. I wanted to adjust my head light level and I followed this YouTube clip to do that.
https://www.youtube.com/watch?v=7bnqyqN49gA
Without really understanding or knowing how these diagnostic tools work, I some how caused my first fault code which was "Headlight range control defective!" The OBDEleven sorta crashed or froze half way when I was doing one of the steps in that video. But to keep a long story short. My mechanic was able to fix that in the adaptation section. The OBDEleven disabled something and caused the Headlight range control.
Soooo.... Now i'm left with the 2 remaining fault codes that my mechanic worker caused, whom also isn't familiar with Audi/VW. My mechanic and I have been doing alot of research and he thought it was both my DRL Modules, and his friend who is a Audi/VW mechanic said it was a common issue with my generation Audi. But I didn't think that because my DRL LEDs were working during the day! But regardless I had my mechanic replace both DRL Modules, and i'm still getting those 2 fault codes.
After that I started playing around with my mechanics Autel, learning about long coding and how these diagnosis tools worked. So basically after playing around with my headlights and the Autel, I concluded that the only reason why i'm getting these 2 fault codes is because when my head lights are on, the LED DRL doesn't dim and light up anymore. I only get these fault codes the moment my head lights are on!
Anyways I decided to buy Ross-Tech VCD so I have the right tools to try to fix his issue myself. But if someone here has any ideas or encounter similar situations, with a fix please let me know!
So far I did my first AutoScan and saved it yesterday, because a member here told me its the first thing I should do and post it. Then I went through the long code helper in the central electronics bit by bit and I didn't find anything to turn on the DRL with the low beam. However I did find a way to turn on the DRL with the high beam, but it didn't do anything, which I actually played with all these bits with my mechanics Autel.
Thank you in advance for any help or information you could provide!!
Here is the AutoScan Log I saved right after I finished installing and setting up the software on my laptop. Please note this Autoscan log is after I got the 2 fault codes. I do not have my original autoscan log given this is the first VCDS I ever bought. Thank you again for anyone who can help!
Saturday,25,May,2019,16:19:49:58979
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: WAUCGAFR6DA074900 License Plate:
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 22 36 42 44 46 47 52 53 56
5F 6C A9
VIN: WAUCGAFR6DA074900 Mileage: 79350km-49305miles
Address 01: Engine (J623-CGXC) Labels:. 06E-907-551-CGW.clb
Part No SW: 8K5 907 551 E HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0004
Revision: --H07---
Coding: 1A250034052600060000
Shop #: WSC 49910 001 1048576
ASAM Dataset: EV_ECM30TFS0218K5907551E 001004
ROD: EV_ECM30TFS0218K5907551E.rod
VCID: 3829292612DDEDF766D-806C
Part No SW: 8K2 927 156 M HW: 0B5 927 156 J
Component: 0B5 30TFSINAR H01 0009
Revision: --H01---
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001012
ROD: EV_TCMDL501021.rod
VCID: 40D941C64A0DA537DED-8014
Part No SW: 8K0 907 379 CK HW: 8K0 907 379 CK
Component: ESP8 quattro H09 0100
Coding: 291D1A
VCID: 04518DD61E157917BA5-8050
Part No SW: 8K0 907 064 GM HW: 8K0 907 064 FM
Component: BCM2 2.0 H12 0633
Coding: 0D804000000000000000
VCID: 015F84C201076C3F913-8054
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2313000061264006
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 E HW: 8T0 959 760 E
Component: MEM-BFS H10 0076
Revision: AA000000 Serial number: 00000057786625
Coding: 00037025002C00000000
VCID: 45D750D255AF801FEDB-8010
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01180420130852
Coding: 6602228000
VCID: 392F2C222957F4FF993-806C
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000595553002
Coding: 26000095863CBFE0210048C300003D0D0F9CD388A209022100 0008004000030100000030000000
Shop #: WSC 06342 123 12345
VCID: 78A9E92652DD2DF7A6D-802C
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 150413 H15 0080
Serial number: SWF13040155466
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 21200973
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000000604131772
Component: USHL4.2 H30 0030
Serial number: 0000002274555R5LJ202
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: D358C0A6000000000001
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
Fault Status: 01101100
Fault Frequency: 11
Reset counter: 79
Mileage: 78678 km
Date: 2019.05.12
Time: 17:51:19
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Fault Frequency: 11
Reset counter: 79
Mileage: 78678 km
Date: 2019.05.12
Time: 17:51:20
Part No SW: 8K0 959 655 P HW: 8K0 959 655 P
Serial number: 003KJD91N4TZ
Coding: 303343334830303030304A55304C38543053
VCID: 4ACD63EE7C316F67009-801E
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R130000CTN4
Serial number: 6334MSME7B4526019
Serial number: 6344MSME79053373B
Serial number: 6352QSME34313F4EO
Serial number: 6362QSME2730016EB
Serial number: 63732SME1A303652T
Serial number: 63832SME1A301E50Y
Part No SW: 8R0 953 568 S HW: 8R0 953 568 S
Component: Lenks.Modul H07 0171
Revision: 00000000 Serial number: 20130413000430
Coding: 000036
VCID: 51FF748291E75CBF413-8004
Part No SW: 8T0 920 983 P HW: 8T0 920 983 P
Component: KOMBIINSTR. H35 0556
Revision: 00200000 Serial number: UUZ25VH4E
Coding: 8BB701008301D705020200
Shop #: WSC 06325 123 12345
VCID: 4BC366EA73CB766F3BF-801E
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0056
Revision: 1Y070028 Serial number: 2841Y133288178
Coding: 80C303FF00
VCID: 4ACD63EE7CB16F67009-801E
Serial number: 0495750303
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H14 0100
Serial number: 000704130001416
VCID: 2F3B127AE7932A4F377-807A
Component: MEM-FS H10 0076
Revision: AA000000 Serial number: 00000057784899
Coding: 001B7B25002C00000000
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0304
Coding: 011C13224E00120102
VCID: 56F5879EB8093B87941-8002
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0010384982
Coding: 100000010001
Shop #: WSC 06324 000 00000
ROD: EV_RCEPSAU48X_008.rod
VCID: 34311D160EB509974A5-8060
Revision: 00002001 Serial number: 0304725176
Coding: 0106029A00FA400580B0003200000000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000659515
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H05 0220
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813013373802
VCID: 2D070872ED1F585F05B-8078
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
VCID: 55F78092A50F309F9DB-8000
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 10000000199777
ROD: EV_ParkiBrake_AU48.rod
Part No SW: 4G0 035 082 E HW: 4G0 035 082
Component: Radio U SIRIU H60 0121
Revision: AB001007 Serial number: 156DZ0D7715082
Coding: 020007010000000001
Shop #: WSC 06342 000 00000
VCID: 221DEB4EA4C19727A89-8076
Part No SW: 8R1 035 746 C HW: 8R1 035 746 B
Component: H-BNT-NA H44 0624
Revision: -------- Serial number: 204DX0D7573264
Coding: 140200020206A1EF45028B4E00000403140000000000000000
VCID: 372B2A1A1F43E28F6F7-8062
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Component: DU7 High H42 0104
Serial number: A130DL0D2702724
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000001473118
Component: CD-Database 4949
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H07--- Serial number: 525PA8-J31918V
Coding: 1000008
VCID: 382929261E5DEDF766D-806C
Part No SW: 8K0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0005
Serial number: 130319200578
VCID: 72BDDB0E342147A7989-8026
End----(Elapsed Time: 01:49, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
