Fault Codes 02895 & 02897 for 2013 Audi S5 Please Help!
andrewgovroom
C?ID=370061
Hi everyone! I have a 2013 Audi S5 and I just got verified so i'm moving my thread to the proper location. I just got my first Ross-Tech VCDS earlier this week. I bought this VCDS because i'm hoping it could help me fix my fault codes 02895 & 02897 (Supply for Left & Right LED Parking Lamp/DRL Module-Electrical malfunction in circuit). One of my mechanics worker was messing around in my headlight system with some other code reader because I had a different fault code at the time. Some how he changed some settings and I ended up with 3 fault codes including the original one i came in with. Admittedly I caused the first fault code because I was messing around with my OBDEleven I just bought. I wanted to adjust my head light level and I followed this YouTube clip to do that.
https://www.youtube.com/watch?v=7bnqyqN49gA
Without really understanding or knowing how these diagnostic tools work, I some how caused my first fault code which was "Headlight range control defective!" The OBDEleven sorta crashed or froze half way when I was doing one of the steps in that video. But to keep a long story short. My mechanic was able to fix that in the adaptation section. The OBDEleven disabled something and caused the Headlight range control.
Soooo.... Now i'm left with the 2 remaining fault codes that my mechanic worker caused, whom also isn't familiar with Audi/VW. My mechanic and I have been doing alot of research and he thought it was both my DRL Modules, and his friend who is a Audi/VW mechanic said it was a common issue with my generation Audi. But I didn't think that because my DRL LEDs were working during the day! But regardless I had my mechanic replace both DRL Modules, and i'm still getting those 2 fault codes.
After that I started playing around with my mechanics Autel, learning about long coding and how these diagnosis tools worked. So basically after playing around with my headlights and the Autel, I concluded that the only reason why i'm getting these 2 fault codes is because when my head lights are on, the LED DRL doesn't dim and light up anymore. I only get these fault codes the moment my head lights are on!
Anyways I decided to buy Ross-Tech VCD so I have the right tools to try to fix his issue myself. But if someone here has any ideas or encounter similar situations, with a fix please let me know!
So far I did my first AutoScan and saved it yesterday, because a member here told me its the first thing I should do and post it. Then I went through the long code helper in the central electronics bit by bit and I didn't find anything to turn on the DRL with the low beam. However I did find a way to turn on the DRL with the high beam, but it didn't do anything, which I actually played with all these bits with my mechanics Autel.
Thank you in advance for any help or information you could provide!! :)
Here is the AutoScan Log I saved right after I finished installing and setting up the software on my laptop. Please note this Autoscan log is after I got the 2 fault codes. I do not have my original autoscan log given this is the first VCDS I ever bought. Thank you again for anyone who can help!
Saturday,25,May,2019,16:19:49:58979
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: WAUCGAFR6DA074900 License Plate:
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 22 36 42 44 46 47 52 53 56
5F 6C A9
VIN: WAUCGAFR6DA074900 Mileage: 79350km-49305miles
Address 01: Engine (J623-CGXC) Labels:. 06E-907-551-CGW.clb
Part No SW: 8K5 907 551 E HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0004
Revision: --H07---
Coding: 1A250034052600060000
Shop #: WSC 49910 001 1048576
ASAM Dataset: EV_ECM30TFS0218K5907551E 001004
ROD: EV_ECM30TFS0218K5907551E.rod
VCID: 3829292612DDEDF766D-806C
Part No SW: 8K2 927 156 M HW: 0B5 927 156 J
Component: 0B5 30TFSINAR H01 0009
Revision: --H01---
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001012
ROD: EV_TCMDL501021.rod
VCID: 40D941C64A0DA537DED-8014
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CK HW: 8K0 907 379 CK
Component: ESP8 quattro H09 0100
Coding: 291D1A
VCID: 04518DD61E157917BA5-8050
Part No SW: 8K0 907 064 GM HW: 8K0 907 064 FM
Component: BCM2 2.0 H12 0633
Coding: 0D804000000000000000
VCID: 015F84C201076C3F913-8054
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2313000061264006
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 E HW: 8T0 959 760 E
Component: MEM-BFS H10 0076
Revision: AA000000 Serial number: 00000057786625
Coding: 00037025002C00000000
VCID: 45D750D255AF801FEDB-8010
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01180420130852
Coding: 6602228000
VCID: 392F2C222957F4FF993-806C
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000595553002
Coding: 26000095863CBFE0210048C300003D0D0F9CD388A209022100 0008004000030100000030000000
Shop #: WSC 06342 123 12345
VCID: 78A9E92652DD2DF7A6D-802C
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 150413 H15 0080
Serial number: SWF13040155466
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 21200973
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000000604131772
Component: USHL4.2 H30 0030
Serial number: 0000002274555R5LJ202
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: D358C0A6000000000001
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
Fault Status: 01101100
Fault Frequency: 11
Reset counter: 79
Mileage: 78678 km
Date: 2019.05.12
Time: 17:51:19
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Fault Frequency: 11
Reset counter: 79
Mileage: 78678 km
Date: 2019.05.12
Time: 17:51:20
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 P HW: 8K0 959 655 P
Serial number: 003KJD91N4TZ
Coding: 303343334830303030304A55304C38543053
VCID: 4ACD63EE7C316F67009-801E
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R130000CTN4
Serial number: 6334MSME7B4526019
Serial number: 6344MSME79053373B
Serial number: 6352QSME34313F4EO
Serial number: 6362QSME2730016EB
Serial number: 63732SME1A303652T
Serial number: 63832SME1A301E50Y
Part No SW: 8R0 953 568 S HW: 8R0 953 568 S
Component: Lenks.Modul H07 0171
Revision: 00000000 Serial number: 20130413000430
Coding: 000036
VCID: 51FF748291E75CBF413-8004
Part No SW: 8T0 920 983 P HW: 8T0 920 983 P
Component: KOMBIINSTR. H35 0556
Revision: 00200000 Serial number: UUZ25VH4E
Coding: 8BB701008301D705020200
Shop #: WSC 06325 123 12345
VCID: 4BC366EA73CB766F3BF-801E
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0056
Revision: 1Y070028 Serial number: 2841Y133288178
Coding: 80C303FF00
VCID: 4ACD63EE7CB16F67009-801E
Serial number: 0495750303
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H14 0100
Serial number: 000704130001416
VCID: 2F3B127AE7932A4F377-807A
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H10 0076
Revision: AA000000 Serial number: 00000057784899
Coding: 001B7B25002C00000000
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0304
Coding: 011C13224E00120102
VCID: 56F5879EB8093B87941-8002
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0010384982
Coding: 100000010001
Shop #: WSC 06324 000 00000
ROD: EV_RCEPSAU48X_008.rod
VCID: 34311D160EB509974A5-8060
Revision: 00002001 Serial number: 0304725176
Coding: 0106029A00FA400580B0003200000000
Component: GTO BF H01 0080
Serial number: 00000000000000659515
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H05 0220
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813013373802
VCID: 2D070872ED1F585F05B-8078
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
VCID: 55F78092A50F309F9DB-8000
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 10000000199777
ROD: EV_ParkiBrake_AU48.rod
Part No SW: 4G0 035 082 E HW: 4G0 035 082
Component: Radio U SIRIU H60 0121
Revision: AB001007 Serial number: 156DZ0D7715082
Coding: 020007010000000001
Shop #: WSC 06342 000 00000
VCID: 221DEB4EA4C19727A89-8076
Part No SW: 8R1 035 746 C HW: 8R1 035 746 B
Component: H-BNT-NA H44 0624
Revision: -------- Serial number: 204DX0D7573264
Coding: 140200020206A1EF45028B4E00000403140000000000000000
VCID: 372B2A1A1F43E28F6F7-8062
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Component: DU7 High H42 0104
Serial number: A130DL0D2702724
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000001473118
Component: CD-Database 4949
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H07--- Serial number: 525PA8-J31918V
Coding: 1000008
VCID: 382929261E5DEDF766D-806C
Part No SW: 8K0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0005
Serial number: 130319200578
ASAM Dataset: EV_SoundActuaGen2AU64X 002005
ROD: EV_SoundActuaGen2AU64X_002.rod
VCID: 72BDDB0E342147A7989-8026
End----(Elapsed Time: 01:49, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
I'm not that good with B8 stuff. At first I was thinking maybe Byte 2, bit 4: "Daytime Running Lights via DRL LEDs active" should be on, but then I compared with Eric's 2016 S4, which has an almost identical BCM, and I assume very similar headlights, and it's not set in that car, so I doubt that's it.
What his car does have (and yours doesn't) is Byte 3, bit 2: "Daytime Running Lights with Parking Lights inactive". Maye try that bit?
NEtech
Denmark
C?ID=56995
What his car does have (and yours doesn't) is Byte 3, bit 2: "Daytime Running Lights with Parking Lights inactive". Maybe try that bit?
Yes I would also try to remove that Bit and maybe Remove Byte 6 Bit 4
There are also a lot of Adaptation channel values that could have been changed.
andrewgovroom
C?ID=370061
Hello again Uew! Thank you for your advice and for cleaning up my auto scan code! Looks much cleaner. Yea, I ended up spending a lot of time playing with the DRL related options in the long code helper and I learned quite a bit. So The "Daytime Running Lights via DRL LEDs active", doesn't do anything when i try to active it. I get some kind of error if I remember correctly. The Byte 3, bit 2: "Daytime Running Lights with Parking Lights inactive" That just turns on the LED DRL when I turn on the parking light. I guess I forgot to turn that back off. But it didn't have any effect on the fault codes. I honestly don't think its anything in the long code at this point. Maybe its something in some Adaptation channel that I have no clue how to access or where to look for.
andrewgovroom
C?ID=370061
Hi NEtech! Thank you for your input and advice! I ended up spending quite a bit of time playing with the long code helper on head light/DRL related Byte and bits only. I turned things on and turned things off just to see what does what. I didn't find anything that fixed the issue. But I really think you are right about something that changed in the Adaption channel. Problem is I have no idea how I could find the list of channels and how to access the right ones. Would you happen to know where I could find the necessary channel lists? Thank you again for your help!
NEtech
Denmark
C?ID=56995
You could try and post data from [09] here, like Autoscan
[Applications]
[Controller Channel Map]
- Controller Address = 09
- Login or security code: 20113
- Function: Measuring values and Adaptations
- Output: Pre-label file /CSV file
[Go]
Like Autoscan the 2 csv files are in ..\Logs
andrewgovroom
C?ID=370061
[Applications]
[Go]
Okay, Thanks i'll give that a try.
andrewgovroom
C?ID=370061
[Applications]
[Go]
So I finally got the chance to get both the log files for the Measuring Values and Adaptions. I'm not too clear on how to really make sense of these files but if anyone could help me narrow down which channel I should look at to solve my fault codes it would be greatly appreciated! Thank you in advance for any help you could provide!
;SW:8K0-907-063-DH   HW:8K0-907-063-DH ---  Cent. Elect. --- SA: 20113
;Component:BCM1 1.0      H16 0103	 Coding:26000095863CBFE0210048C300003D0D0F9CD388A2090221000008004000030100000030000000
;Thursday	30	May	2019	21:46:46:58979
;VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
;VCID: 78A9E92652DD2DF7A6D-802C
Channel		Field 1	Field 2	Field 3	Field 4
1	100	- 	- 	- 	-
2		ERROR:	Channel 02	Not	Available
3	9	- 	- 	- 	-
4		ERROR:	Channel 04	Not	Available
5		ERROR:	Channel 05	Not	Available
6	800	OFF	N/A	N/A	N/A
7	900	OFF	N/A	N/A	N/A
8		ERROR:	Channel 08	Not	Available
9		ERROR:	Channel 09	Not	Available
10		ERROR:	Channel 10	Not	Available
11		ERROR:	Channel 11	Not	Available
12	120	N/A	N/A	N/A	N/A
13	60	N/A	N/A	N/A	N/A
14	15	N/A	N/A	N/A	N/A
15		ERROR:	Channel 15	Not	Available
16	3	N/A	N/A	N/A	N/A
17	15	N/A	N/A	N/A	N/A
18	255	N/A	N/A	N/A	N/A
19	1	N/A	N/A	N/A	N/A
20	0	N/A	N/A	N/A	N/A
21	1	N/A	N/A	N/A	N/A
22	1	N/A	N/A	N/A	N/A
23	1	N/A	N/A	N/A	N/A
24	1	N/A	N/A	N/A	N/A
25	2000	N/A	N/A	N/A	N/A
26	5	N/A	N/A	N/A	N/A
27		ERROR:	Channel 27	Not	Available
28		ERROR:	Channel 28	Not	Available
29		ERROR:	Channel 29	Not	Available
30		ERROR:	Channel 30	Not	Available
31		ERROR:	Channel 31	Not	Available
32		ERROR:	Channel 32	Not	Available
33		ERROR:	Channel 33	Not	Available
34	4	N/A	N/A	N/A	N/A
35	0	N/A	N/A	N/A	N/A
36		ERROR:	Channel 36	Not	Available
37	3	N/A	N/A	N/A	N/A
38	0	N/A	N/A	N/A	N/A
39	0	N/A	N/A	N/A	N/A
40	117	21.5°C	OFF	N/A	N/A
41	1	N/A	N/A	N/A	N/A
42	1	N/A	N/A	N/A	N/A
43	20	N/A	N/A	N/A	N/A
44	1	N/A	N/A	N/A	N/A
45	0	N/A	N/A	N/A	N/A
46	1	N/A	N/A	N/A	N/A
47	1	N/A	N/A	N/A	N/A
48	120	N/A	N/A	N/A	N/A
49	120	N/A	N/A	N/A	N/A
50	120	N/A	N/A	N/A	N/A
51	120	N/A	N/A	N/A	N/A
52	120	N/A	N/A	N/A	N/A
53	0	N/A	N/A	N/A	N/A
54		ERROR:	Channel 54	Not	Available
55	1	N/A	N/A	N/A	N/A
56	1	N/A	N/A	N/A	N/A
57	0	N/A	N/A	N/A	N/A
58	1	N/A	N/A	N/A	N/A
59	60	N/A	N/A	N/A	N/A
60	1	N/A	N/A	N/A	N/A
61		ERROR:	Channel 61	Not	Available
62		ERROR:	Channel 62	Not	Available
63	2	N/A	N/A	N/A	N/A
64	2	N/A	N/A	N/A	N/A
65	0	N/A	N/A	N/A	N/A
66	15	N/A	N/A	N/A	N/A
67	0	N/A	N/A	N/A	N/A
68	2	N/A	N/A	N/A	N/A
69	600	N/A	N/A	N/A	N/A
70	14	N/A	N/A	N/A	N/A
71		ERROR:	Channel 71	Not	Available
72		ERROR:	Channel 72	Not	Available
73		ERROR:	Channel 73	Not	Available
74		ERROR:	Channel 74	Not	Available
75		ERROR:	Channel 75	Not	Available
76		ERROR:	Channel 76	Not	Available
77		ERROR:	Channel 77	Not	Available
78		ERROR:	Channel 78	Not	Available
79		ERROR:	Channel 79	Not	Available
80		ERROR:	Channel 80	Not	Available
81		ERROR:	Channel 81	Not	Available
82		ERROR:	Channel 82	Not	Available
83		ERROR:	Channel 83	Not	Available
84		ERROR:	Channel 84	Not	Available
85		ERROR:	Channel 85	Not	Available
86		ERROR:	Channel 86	Not	Available
87		ERROR:	Channel 87	Not	Available
88		ERROR:	Channel 88	Not	Available
89		ERROR:	Channel 89	Not	Available
90		ERROR:	Channel 90	Not	Available
91		ERROR:	Channel 91	Not	Available
92		ERROR:	Channel 92	Not	Available
93		ERROR:	Channel 93	Not	Available
94		ERROR:	Channel 94	Not	Available
95		ERROR:	Channel 95	Not	Available
96		ERROR:	Channel 96	Not	Available
97		ERROR:	Channel 97	Not	Available
98		ERROR:	Channel 98	Not	Available
99		ERROR:	Channel 99	Not	Available
100	26	N/A	N/A	N/A	N/A
101	28	N/A	N/A	N/A	N/A
102	36	N/A	N/A	N/A	N/A
103	38	N/A	N/A	N/A	N/A
104	46	N/A	N/A	N/A	N/A
105	48	N/A	N/A	N/A	N/A
106	56	N/A	N/A	N/A	N/A
107	58	N/A	N/A	N/A	N/A
108	66	N/A	N/A	N/A	N/A
109	68	N/A	N/A	N/A	N/A
110	94	N/A	N/A	N/A	N/A
111	96	N/A	N/A	N/A	N/A
112		ERROR:	Channel 112	Not	Available
113		ERROR:	Channel 113	Not	Available
114		ERROR:	Channel 114	Not	Available
115		ERROR:	Channel 115	Not	Available
116		ERROR:	Channel 116	Not	Available
117		ERROR:	Channel 117	Not	Available
118		ERROR:	Channel 118	Not	Available
119		ERROR:	Channel 119	Not	Available
120		ERROR:	Channel 120	Not	Available
121	10	N/A	N/A	N/A	N/A
122	13	N/A	N/A	N/A	N/A
123	6	N/A	N/A	N/A	N/A
124	20	N/A	N/A	N/A	N/A
125	0	N/A	N/A	N/A	N/A
126	100	N/A	N/A	N/A	N/A
127	0	N/A	N/A	N/A	N/A
128	30	N/A	N/A	N/A	N/A
129		ERROR:	Channel 129	Not	Available
130		ERROR:	Channel 130	Not	Available
131		ERROR:	Channel 131	Not	Available
132		ERROR:	Channel 132	Not	Available
133		ERROR:	Channel 133	Not	Available
134		ERROR:	Channel 134	Not	Available
135		ERROR:	Channel 135	Not	Available
136		ERROR:	Channel 136	Not	Available
137		ERROR:	Channel 137	Not	Available
138		ERROR:	Channel 138	Not	Available
139		ERROR:	Channel 139	Not	Available
140		ERROR:	Channel 140	Not	Available
141		ERROR:	Channel 141	Not	Available
142		ERROR:	Channel 142	Not	Available
143		ERROR:	Channel 143	Not	Available
144		ERROR:	Channel 144	Not	Available
145		ERROR:	Channel 145	Not	Available
146		ERROR:	Channel 146	Not	Available
147		ERROR:	Channel 147	Not	Available
148		ERROR:	Channel 148	Not	Available
149		ERROR:	Channel 149	Not	Available
150		ERROR:	Channel 150	Not	Available
151		ERROR:	Channel 151	Not	Available
152		ERROR:	Channel 152	Not	Available
153		ERROR:	Channel 153	Not	Available
154		ERROR:	Channel 154	Not	Available
155		ERROR:	Channel 155	Not	Available
156		ERROR:	Channel 156	Not	Available
157		ERROR:	Channel 157	Not	Available
158		ERROR:	Channel 158	Not	Available
159		ERROR:	Channel 159	Not	Available
160		ERROR:	Channel 160	Not	Available
161		ERROR:	Channel 161	Not	Available
162		ERROR:	Channel 162	Not	Available
163		ERROR:	Channel 163	Not	Available
164		ERROR:	Channel 164	Not	Available
165		ERROR:	Channel 165	Not	Available
166		ERROR:	Channel 166	Not	Available
167		ERROR:	Channel 167	Not	Available
168		ERROR:	Channel 168	Not	Available
169		ERROR:	Channel 169	Not	Available
170		ERROR:	Channel 170	Not	Available
171		ERROR:	Channel 171	Not	Available
172		ERROR:	Channel 172	Not	Available
173		ERROR:	Channel 173	Not	Available
174		ERROR:	Channel 174	Not	Available
175		ERROR:	Channel 175	Not	Available
176		ERROR:	Channel 176	Not	Available
177		ERROR:	Channel 177	Not	Available
178		ERROR:	Channel 178	Not	Available
179		ERROR:	Channel 179	Not	Available
180		ERROR:	Channel 180	Not	Available
181		ERROR:	Channel 181	Not	Available
182		ERROR:	Channel 182	Not	Available
183		ERROR:	Channel 183	Not	Available
184		ERROR:	Channel 184	Not	Available
185		ERROR:	Channel 185	Not	Available
186		ERROR:	Channel 186	Not	Available
187		ERROR:	Channel 187	Not	Available
188		ERROR:	Channel 188	Not	Available
189		ERROR:	Channel 189	Not	Available
190	0	N/A	N/A	N/A	N/A
191	0	N/A	N/A	N/A	N/A
192	0	N/A	N/A	N/A	N/A
193		ERROR:	Security	access	required
194		ERROR:	Security	access	required
195		ERROR:	Security	access	required
196		ERROR:	Security	access	required
197		ERROR:	Security	access	required
198		ERROR:	Security	access	required
199	0	N/A	N/A	N/A	N/A
200		ERROR:	Channel 200	Not	Available
201		ERROR:	Security	access	required
202		ERROR:	Security	access	required
203		ERROR:	Security	access	required
204		ERROR:	Security	access	required
205	1	N/A	N/A	N/A	N/A
206	1	not available	not available	N/A	N/A
207	0	N/A	N/A	N/A	N/A
208	1	N/A	N/A	N/A	N/A
209	1	N/A	N/A	N/A	N/A
210	1	not available	N/A	N/A	N/A
211	1	not available	N/A	N/A	N/A
212	1	not available	N/A	N/A	N/A
213	1	not available	N/A	N/A	N/A
214	1	not available	N/A	N/A	N/A
215		ERROR:	Security	access	required
216		ERROR:	Channel 216	Not	Available
217		ERROR:	Security	access	required
218		ERROR:	Channel 218	Not	Available
219		ERROR:	Security	access	required
220	0	N/A	N/A	N/A	N/A
221	0	N/A	N/A	N/A	N/A
222	150	N/A	N/A	N/A	N/A
223	197	N/A	N/A	N/A	N/A
224	1	N/A	N/A	N/A	N/A
225	5	N/A	N/A	N/A	N/A
226	5	N/A	N/A	N/A	N/A
227	1	N/A	N/A	N/A	N/A
228	0	N/A	N/A	N/A	N/A
229	4	N/A	N/A	N/A	N/A
230	4	N/A	N/A	N/A	N/A
231	4	N/A	N/A	N/A	N/A
232	6	N/A	N/A	N/A	N/A
233	15	N/A	N/A	N/A	N/A
234	27	N/A	N/A	N/A	N/A
235	0	N/A	N/A	N/A	N/A
236	0	N/A	N/A	N/A	N/A
237		ERROR:	Security	access	required
238		ERROR:	Security	access	required
239		ERROR:	Security	access	required
240		ERROR:	Security	access	required
241		ERROR:	Security	access	required
242		ERROR:	Security	access	required
243		ERROR:	Security	access	required
244		ERROR:	Channel 244	Not	Available
245		ERROR:	Channel 245	Not	Available
246		ERROR:	Channel 246	Not	Available
247		ERROR:	Channel 247	Not	Available
248		ERROR:	Channel 248	Not	Available
249		ERROR:	Channel 249	Not	Available
250		ERROR:	Security	access	required
251		ERROR:	Channel 251	Not	Available
252		ERROR:	Channel 252	Not	Available
253		ERROR:	Channel 253	Not	Available
254		ERROR:	Security	access	required
255		ERROR:	Security	access	required
;Thursday	30	May	2019	21:46:07:58979
Group	Field 1	Data type	Field 2	Data type	Field 3	Data type	Field 4	Data type
1	11.90 V		11.80 V
2	11.90 V		11.90 V		11.90 V
3	Inactive		Inactive		Inactive		N/A
4	ON		ON		ON		7.10 V
5	100.00%		-
6	Not Oper.		0		0
7	center		2		Not Oper.		Not Oper.
8	100.00%		- 		Not Oper.		2
9	100.00%		100.00%		100.00%		100.00%
10	- 		- 		- 		-
11	OFF		OFF		0.00%		0.00%
12	100.00%		100.00%		144		8
13	OFF		Not Oper.		0.00%		0.00%
14	9.00%		9.00%		100.00%		100.00%
15	OFF		- 		-
16	0.00%		0.00%		0.00%		19.00%
17	Not Oper.		- 		OFF		-
18	OFF		0x0001		0.000 A
19	OFF		514		Reached		OFF
20	ON		ON		0.00 km/h		Closed
21	Not Installed		ON		Inactive
22	OFF		Inactive		0		2
23	6.05 bar		- 		0x0042		0x0002
24	- 		0x0005		Not Oper.		0
25	Not Oper.		OFF
26	0		Not Oper.		- 		Not Oper.
27	- 		0x0002		Activated		Full
28	Full		Not Oper.		Inactive		Inactive
29	21.5°C
30	- 		- 		- 		-
31	Closed		-
32	Inactive		Inactive
33	- 		0.00%		0.00%
34	OFF		0.0 mA		0.00%
37	OFF		0.000 A		0.000 A
40	- 		- 		- 		-
41	1		Not Oper.		3.00%		0.00%
42	1679h
43	12.00%		82.00%		3.00%		0.00%
44	- 		- 		- 		-
45	0		0.00 km/h		2.5°
46	- 		-
47	- 		- 		-
48	0		0		0		0
49	103
50	0.00 ms		5.70 ms		0.12 ms		0.27 ms
51	2640		0
52	58435-33782-56015-0
53	C7500063 0060
54	FBL-Version: 24031.1.7.0
55	0
56	0		0		0
57	0		0		21
58	0		0		- 		-
59	OFF		OFF
60	0.0°C		21.5°C		0.0 A
61	0.0°C		22.0°C		0.0 A
62	0		0x0000		0		0x0000
63	- 		- 		-
64	- 		- 		-
65	- 		- 		- 		-
66	- 		-
67	- 		- 		-
68	- 		- 		-
69	- 		- 		- 		-
70	- 		- 		- 		-
71	- 		- 		- 		-
72	- 		- 		- 		-
73	0		0		0		0
74	0x0003		0x0003
75	23.0°C		44		10.3°C		22.9°C
76	0
77	14.3°C		22.1°C		55.00%		0
78	3		3		23.8°C		Inactive
79	- 		- 		- 		-
80	- 		- 		- 		-
81	- 		- 		- 		-
82	- 		- 		-
83	-
84	0		0		0		0
85	0		0		5		4
86	0		0		0		0
87	2		0		0		0
88	0
89	0		0		0		0
90	0		0		68		92
91	110		0		0		255
92	0		0		0		0
93	0		0		0		0
94	192		0		0		0
95	0		0		68		0
98	1.03 kOhm		7.96 kOhm		Closed		Closed
99	0x0034		0x0103		0		0
100	not available		not available		Occupied		Occupied
101	0.00%		0.00%		Faulty		Faulty
102	Intermed pos.		Inactive		not available		not available
103	- 		- 		- 		-
104	- 		- 		- 		-
105	- 		- 		- 		-
106	- 		- 		- 		-
107	Stage 0		Stage 0		21.5°C		23.5°C
108	0		- 		N/A		N/A
110	- 		- 		- 		-
111	- 		- 		- 		-
112	- 		- 		- 		-
113	- 		- 		- 		-
114	- 		- 		- 		-
115	- 		- 		- 		-
116	- 		- 		- 		-
117	- 		- 		- 		-
120	- 		- 		- 		N/A
121	- 		- 		- 		-
122	- 		- 		- 		-
125	- 		- 		- 		-
126	- 		- 		- 		-
127	- 		- 		- 		-
128	- 		- 		- 		-
129	- 		- 		- 		N/A
132	63.00%		61.00%		N/A		N/A
133	0		0		0		0
134	0		0		0		0
135	0		0		0		0
136	0		0		0		0
140	4.9 V		not available		OFF		not available
141	OFF		0.0 mm		-3.0 mm		not available
142	not available		39.90%		not available		40.70%
143	-7		-7		0		0
144	57.60%		-7		57.60%		-7
145	not available		not available		not available		not available
146	not available		not available		not available		not available
147	101.60%		101.60%		0		0
148	not available		not available		not available		not available
149	not available		not available		not available		not available
150	not available		not available		not available		ON
151	3.8°		not available		Inactive		Inactive
152	0.00%		Inactive		0		not available
153	not available		not available		not available		not available
154	not available		not available		not available		not available
155	not available		not available		not available		not available
156	not available		not available		not available		not available
157	not available		not available		not available		not available
158	not available		not available		not available		not available
159	Reg. Position		Learned		not available		not available
160	Not Installed		255 cm		not available		not available
161	Reverse: No		Not Installed		0x0023		not available
162	Not Installed		Not Installed		Not Installed		Not Installed
163	65535 cm		65535 cm		65535 cm		65535 cm
164	Not Installed		Not Installed		Not Installed		Not Installed
165	Not Installed		Not Installed		Not Installed		Not Installed
166	0.00 ms		0.00 ms		0.00 ms		0.00 ms
167	Not Installed		Not Installed		Not Installed		Not Installed
168	Stage 4		Stage 4		Not Installed		Not Installed
169	Not Installed		Not Installed		ON		not available
170	Not Installed		Not Installed		OFF		not available
171	No		not Active		c.Switchoff		No
172	Not Installed		Not Installed		Yes		OFF
173	not Active		OFF		not available		not available
174	Stage 5		Stage 4		Not Installed		Not Installed
175	Active		OFF		not available		not available
176	Stage 4		Stage 4		Not Installed		Not Installed
177	not Active		OFF		not available		not available
178	Stage 4		Stage 4		Not Installed		Not Installed
179	not Active		OFF		not available		not available
180	Stage 4		Stage 4		Not Installed		Not Installed
181	Stage 4		Stage 4		Not Installed		Not Installed
182	Not Installed		21.0°C		0		not available
183	0		0		0		0:00 h
184	0		0		0		0:00 h
185	0		0		0		0:00 h
186	0		0		0		0:00 h
187	0		0		0		0:00 h
188	0		0		0		0:00 h
189	0		0		0		0:00 h
190	0		0		0		0:00 h
191	0		0		0		0:00 h
192	0		0		0		0:00 h
193	Not Installed		Not Installed		Not Installed		Not Installed
194	Not Installed		Not Installed		Not Installed		Not Installed
195	Not Installed		Not Installed		Not Installed		Not Installed
196	Not Installed		Not Installed		Not Installed		Not Installed
197	Not Installed		Not Installed		Not Installed		Not Installed
198	Not Installed		Not Installed		not available		not available
199	Not Installed		Not Installed		Not Installed		Not Installed
200	- 		- 		- 		-
201	- 		- 		- 		-
202	- 		- 		- 		-
203	- 		- 		- 		-
204	- 		- 		- 		-
205	- 		- 		- 		-
206	- 		- 		- 		-
207	- 		- 		- 		-
208	- 		- 		- 		-
209	- 		- 		- 		-
210	- 		- 		- 		-
211	- 		- 		- 		-
212	- 		- 		- 		-
213	- 		- 		- 		-
214	- 		- 		- 		-
215	- 		- 		- 		-
216	- 		- 		- 		-
217	- 		- 		- 		-
218	511		511		not available		0
251	0		2640		0		0
252	1		0		4096		0
253	0		N/A		N/A		N/A
Lok282
NJ, USA
C?ID=332352
Did you ever get this issue resolved ?
