Interface not found
tech-labs
Poland
C?ID=306072
Yesterday it was working just fine. Today the interface is not found. When I plug it into USB it blinks green a couple of times and that's it. VCDS doesn't see the interface. Windows shows device unrecognised (vendor/device descriptor failure). Tried with 2 different PC and 3 different cars. Any suggestions?
Edit: I tried rebooting windows, reinstalled vcds, etc. No effect.
Cheers,
Rafal
South Molton, UK
What type of interface do you have? HEX-CAN, HEX-V2, HEX-NET or something else?
Are you running Windows 10?
tech-labs
Poland
C?ID=306072
VCIConfig doesn't see the interface (dropdown list is empty). Windows 10 device manager tells Unknown USB Device "Device Descriptor Request Failed". I tried giving it a rest over the night but no luck.
Then I suggest you contact the local distributor you purchased it from so he can perform a physical evaluation.
tech-labs
Poland
C?ID=306072
Ok, thanks. I will contact local dealer. Hope they have some capabilities to fix things not only sell :)
