Enabling Passive ABS - lost original MK60-AT coding
voughtt
Redwood City, Ca
C?ID=229918
I'll repost what I've written elsewhere, as it sums up what I'm experiencing:
I've searched high and low, and unfortunately, I somehow either didn't preserve my default coding for the ABS module or mucked it up somehow.
Using the VCDS documentation (waiting on my account on the Ross Tech forum to be activated) and several web resources, I'm attempting to enable the Passive TPMS on my 2006 A3 S-Line with 18" wheels and the MK60 ABS controller. I followed the excellent tutorial at OOOO-A3's weblog, but the thing that's missing in the engine coding value to sum the correct value for my 3.2l VR6-equipped car.
The formula should be something like:
Vehicle Model Code
+Front Brake PR Code
+Suspension Type
+Engine Code
+TPMS PR Code value (7K0 PR Code)
Sum is passive TPMS disabled.
My understanding is that I should be able to subtract the value of the 7K0 PR code and get Passive TPMS. Except when I enter that value (0004738) I simply get a blinking TPMS warning - I think it's because all the examples of coding I've found are for the four-cylinder engine, and I accidentally waxed my original coding, so I can't subtract the 7K0 value from it.
I've verified the MK60 ABS unit, brake code, and suspension type on my PR sticker; how do I find the default coding for the 3.2l VR6 to sum the correct coding that will enable my passive TPMS?
The earliest Auto-Scan I've found on my machine is listed below:
Thursday,30,October,2014,17:51:20:42699
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN: WAUKD78P36A083401   License Plate: NV
Mileage: 163160km-101382mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 22 25 42 44 46 52 55 56 62 72
          77
VIN: WAUKD78P36A083401   Mileage: 163160km/101382miles
0F-Digital Radio -- Status: Not registered 0001
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 GP    HW: 000 000 000 00
   Component: MOTRONIC ME7.1.1G   8192
   Revision: --H01---    Serial number: AUX7Z0E9FN60S8
   Coding: 0000178
   Shop #: WSC 06314 000 00000
   VCID: 5FCD8BAC8E9B57E6C27-800A
   Part No SW: 02E 300 047 A    HW: 02E 927 770 AD
   Component: GSG DSG         070 1002
   Revision: 04507000    Serial number: 00000509071118
   VCID: 1623EE88212156AE511-8043
Address 03: ABS Brakes        Labels: 1K0-614-517-MK60-A.lbl
   Part No SW: 1K0 614 517 S    HW: 1K0 614 517 S
   Component: ESP 4MOTION MK60-AT 0102
   Revision: 00T12001
   Coding: 0021122
   VCID: 377D030C46EB4FA66A7-8062
   Part No SW: 8P0 820 043 L    HW: 8P0 820 043 L
   Component: KlimavollautomatH17 0200
   Revision: 021822      Serial number: 8P0820043L
   VCID: 356109045CE7BDB678B-8060
01301 - Control Module for Voice Recognition (J507)
                    Fault Frequency: 11
                    Reset counter: 13
                    Mileage: 155995 km
                    Date: 2014.03.10
                    Time: 17:52:40
Address 09: Cent. Elect.        Labels: 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 F    HW: 8P0 907 279 F
   Component: Bordnetz-SG     H36 1201
   Revision: 00H36000    Serial number: 00000002238767
   Coding: F18C5F81C014100000181800180000000028FE175A1500
   Shop #: WSC 06314 000 08192
   VCID: 408F68D01325081EDBD-8015
   Subsystem 1 - Part No: 8P1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H01 0130
   Coding: 00062736
   Shop #: WSC 06314
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00150573
   Shop #: WSC 06314
01598 - Drive Battery Voltage
                    Fault Frequency: 46
                    Reset counter: 251
                    Mileage: 158674 km
                    Date: 2014.08.09
                    Time: 12:11:00
                    Voltage: 13.50 V
Address 15: Airbags        Labels: 8P0-959-655-94.lbl
   Part No SW: 8P0 959 655 A    HW: 8P0 959 655 A
   Component:    Airbag 9.41  H12 3770
   Revision: 91H12377    Serial number: 0035W000918F
   Coding: 0432605
   Subsystem 1 - Part No: 8P0 910 339
   Component: BF-Gewichtsens. 001 0020
   Subsystem 2 - Serial number: 35MB2
   Subsystem 3 - Serial number: 0001.01.000000100000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB401F5549F.ÿ†63
   Subsystem 5 - Serial number: 5549F.ÿ†6342DRB401F4C80D.ÿ†63
   Subsystem 6 - Serial number: 4C80D.ÿ†63528RB4009E17DBZÿ†63
   Subsystem 7 - Serial number: E17DBZÿ†63628RB4009E16BBXÿ†63
   Subsystem 8 - Serial number: E16BBXÿ†63729RB400BD2A62Rÿ†63
   Subsystem 9 - Serial number: D2A62Rÿ†63829RB400BD2A0FZÿ
   Subsystem 10 - Serial number: D2A0FZÿ
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
                    Fault Status: 00100001
                    Reset counter: 242
                    Mileage: 158704 km
                    Date: 2014.09.28
                    Time: 12:06:48
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H34 0070
   Coding: 0014142
   VCID: 41896DD4182F0116D43-8014
   Component: E0221           H07 0080
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
   Part No SW: 8P0 920 981 EX    HW: 8P0 920 981 EX
   Component: KOMBIINSTR. VDO H80 0460
   Revision: D09         Serial number: 224NGD09100017
   Coding: 0000204
   Shop #: WSC 50096 000 1048576
   VCID: 922B12988DC9CA8EBD9-80C7
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001059279C1A
   Coding: FF3F03C0072102
   VCID: 2A5B2A788559E24EE59-807F
                    Fault Frequency: 62
                    Reset counter: 235
                    Mileage: 161652 km
                    Date: 2014.10.16
                    Time: 21:49:52
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 B
   Component: HALDEX 4Motion      0107
   Coding: 0000001
   VCID: 2C572C608FADFC7E175-8079
   Revision: D09         Serial number: AUX7Z0E9FN60S8
   Shop #: WSC 26130 444 51767
01176 - Key
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN2.lbl
   Part No: 8P0 959 801 H
   Component: Tuer-SG         020 0090
   Coding: 0001209
00915 - Window Regulator Switch; Rear Right; Driver (E55)
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 326B3218AD89AA8E5D9-8067
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 D
   Component: 02 KSG          H04 0050
   Coding: 9AC003382D2D850FC88F047300
   VCID: 3D71112464D765F6B0B-8068
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN2.lbl
   Part No: 8P0 959 802 H
   Coding: 0001209
Address 55: Xenon Range        Labels: 4F0-910-357.lbl
   Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
   VCID: 285FD0709B55D05EF3D-807D
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H03 0010
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH03 0010
Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
   Part No SW: 8P0 035 195 K    HW: 8P0 035 195 K
   Component: symphony II US  H51 0460
   Revision:      04S    Serial number: AUZ5Z4E6102587
   Coding: 0000001
   Shop #: WSC 65337 005 00000
   VCID: 3A7B1A3875F952CE959-806F
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No: 8P4 959 801 D
   Component: Tuer-SG         020 0060
   Coding: 0001176
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No: 8P4 959 802 D
   Coding: 0001176
   Part No SW: 8P0 862 335 B    HW: 8P0 862 335 B
   Component: FSE_255x BT     H18 0160
   Revision: 00000001    Serial number: 00000000324678
   Coding: 0001277
voughtt
Redwood City, Ca
C?ID=229918
Thank you for your suggestion. I'll check that out a little later and report back.
Why doesn't the coding sum change depending on the engine? Is coding for all gasoline engines 2048? (edit: meant to type 4096)
I've got 1LJ front Brakes with the new cluster (+000002), UA9 suspension (+0000640) so it looks like the correct code (with +0004096 engine) is still 0021122. This is why I'm a bit stymied.
golfi_vend
Tartu, Estonia
C?ID=195131
If you would read this line, it states alla Automatic transmissions, so maybe thats why ;)
+0004096 = 1.9l TDI PD / 2.0l FSI / 2.0l SDI PD & All with Automatic Transmission
voughtt
Redwood City, Ca
C?ID=229918
Oh, hell. Thank you. I'll go away now. :-) Despite my mis-quote above, my sum is still 21122, and entering that number minus 16384 still gives me a coding that causes my TPMS light to blink. Resetting it via VCDS has no effect. I'll try the other two codes you offered, and appreciate your time.
voughtt
Redwood City, Ca
C?ID=229918
I tried all three codes with ignition cycle between; the result was the same for 4738; 4737 and 4744 both caused ESP/ABS lights with TPMS enabled. 4738 enabled TPMS but caused a blinking TPMS with no fault given.
