BCM / CECM upgrade to highline
markmeus
C?ID=149531
Hi folks,
I have a 2012 SEAT Leon on which I have retrofitted Xenon headlights.
I know I need a 087 CECM to operate the Xenon shutters for high beam which my 086 CECM doesn't support. But it seems there are lots of different versions of the CECM with different part numbers, so I'm looking for some advice on how to find the correct part number i need to be compatible with my car.
Here is the autoscan from VCDS
I'm not concerned about the various fault codes yet, I've had the CECM unplugged so I'm reckoning that's where most of those fault codes are coming from.
Wednesday,10,December,2014,19:55:58:49204
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: VSSZZZ1PZCR044720   License Plate:
Mileage: 48100km-29887mi   Repair Order:
Chassis Type: 1P (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
VIN: VSSZZZ1PZCR044720   Mileage: 48100km-29887miles
09-Cent. Elect. -- Status: Malfunction 1010
46-Central Conv. -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CFHC)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 FJ    HW: 03L 906 018 FJ
   Component: R4 2,0L EDC   H24 7898
   Revision: 42H24---    Serial number:
   Coding: 00190012042500080000
   ASAM Dataset: EV_ECM20TDI01103L906018FJ 003004
   ROD: EV_ECM20TDI01103L906018DP.rod
   VCID: 77F7DD59CE0D70995E1-8022
   Revision: 00H31001
   Coding: 133B4012092600FEC81202E690190082350800
   Shop #: WSC 04941 000 00000
   VCID: 7BFFC169FA2554F93A9-802E
   Part No SW: 5P0 907 044 S    HW: 5P0 907 044 S
   Component: Climatronic   H18 0804
   Revision: 00001001
   Coding: 0000000002
   Shop #: WSC 06402 785 00200
   ROD: EV_ClimaAutoBasis_SE35.rod
   VCID: 40857685DB43F7212FB-8015
   Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
   Component: BCM PQ35 M    021 0064
   Revision: BC021001
   Coding: 46180A3EC825B0C042C80084950089CC44F90008627D8560488428000040
   VCID: 3E79087DA9B781D15D7-806B
   Subsystem 1 - Part No: 1P0 955 119 D
   Component: Wischer 02121  26  0611
   Coding: 00DB90
   Subsystem 2 - Part No SW: 1P0 955 559 A    HW: 1P0 955 559 A  Labels: 1P0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 02542E
   Subsystem 3 - Part No: 1P0 951 171
   Component: Innenraumuebe  010 4971
7 Faults Found:
00927 - Terminal 30 (Right)
                    Fault Status: 00101011
                    Reset counter: 137
                        Term 15 Off
                    Voltage: 12.00 V
                    Reset counter: 137
                        Term 15 Off
                    Voltage: 12.00 V
01495 - Bulb for High-Beams; Left (M30)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 94
                    Mileage: 47887 km
                    Date: 2014.12.02
                    Time: 05:59:46
                    Voltage: 14.30 V
                    Reset counter: 94
                    Mileage: 47887 km
                    Date: 2014.12.02
                    Time: 05:59:46
                    Voltage: 14.10 V
                    Reset counter: 137
                    Mileage: 47933 km
                    Date: 2014.12.05
                    Time: 08:41:29
                        Term 15 Off
                    Voltage: 12.00 V
                    Fault Status: 00101010
                    Reset counter: 137
                    Mileage: 47933 km
                    Date: 2014.12.04
                    Time: 12:50:07
                        Term 15 Off
                    Voltage: 11.90 V
                    Reset counter: 138
                    Mileage: 47973 km
                    Date: 2014.12.06
                    Time: 14:13:03
                        Term 15 Off
                    Voltage: 12.30 V
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 5P0 919 475 B    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H08 0008
   Revision: --------    Serial number: 36861133004507
   Coding: 100004
   VCID: 3A71046DB59FADF161F-806F
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__A0E VW10 HI   1918
   Revision: 23016000    Serial number: 003K0PQDQPT
   Coding: 0012357
   VCID: 4C9D52B52F0B2341C33-8019
   Subsystem 1 - Serial number: 6332MTS622972991
   Subsystem 2 - Serial number: 6342MTS622863401
   Subsystem 3 - Serial number: 6351HTS6PJHIT9KR
   Subsystem 4 - Serial number: 6361HTS6QCGK0AKR
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20120102301801
   Coding: 108A140002
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79F3DB61F81966E9285-802C
   Subsystem 1 - Part No SW: 1P0 959 538 D    HW: 1P0 959 538 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP  H02 0102
   Coding: E20000
   Part No SW: 1P0 920 953 D    HW: 1P0 920 953 D
   Component: KOMBI         H05 0607
   Coding: 110B01
   Shop #: WSC 13107 102 20971
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 3163234160E96EA9D05-8064
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 137
                    Mileage: 47933 km
                    Date: 2014.12.05
                    Time: 08:41:30
13631488 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 137
                    Mileage: 47933 km
                    Date: 2014.12.05
                    Time: 08:41:32
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 061211F2000697
   Coding: 350203
00457 - Control Module for Network (J519)
                    Fault Status: 00110100
                    Reset counter: 137
                    Mileage: 47933 km
                    Date: 2014.12.05
                    Time: 08:41:32
                    Reset counter: 137
                    Mileage: 47933 km
                    Date: 2014.12.05
                    Time: 08:41:32
   Component: IMMO          H05 0607
   VCID: 6AD1F42D8DBFDD71D1F-803F
   Revision: A1001003    Serial number: 7661516730
   VCID: 2953CB2140391669185-807C
   Part No SW: 1T0 035 680 P    HW: 1T0 035 680 P
   Component: RNS-MID       H08 5218
   Revision: AB001001    Serial number: VWZ6Z7M9706178
   Coding: 00000400040000A00300
   VCID: 3B7F0169BAA594F97A9-806E
   Subsystem 1 - Part No: 7N5 919 859
   Component: EU West V9  7918
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0508
   Revision: 12110009    Serial number: 0003506134
   Coding: 0012B0
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 6DDBFF31BC51CA49B4D-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704 E    HW: 3C0 959 794 E
   Component: J389__TSG-HR  007 1501
   Serial number: 00000006239847
   Coding: 000290
68098 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 137
                    Mileage: 47933 km
                    Date: 2014.12.05
                    Time: 08:41:31
68100 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 137
                    Mileage: 47933 km
                    Date: 2014.12.05
                    Time: 08:41:31
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 142    3305
   Revision: 00H22000
   Shop #: WSC 01806 210 90324
   VCID: 37771D59468DB0999E1-8062
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0508
   Revision: 14110009    Serial number: 0003502586
   Coding: 0012B0
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 6ED9F83DB15731518D7-803B
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703 E    HW: 3C0 959 795 E
   Component: J388__TSG-HL  007 1501
   Serial number: 00000006241444
   Coding: 000290
          U1111 00 [008] - -
                    Reset counter: 137
                    Mileage: 47933 km
                    Date: 2014.12.05
                    Time: 08:41:31
          U1111 00 [008] - -
                    Reset counter: 137
                    Mileage: 47933 km
                    Date: 2014.12.05
                    Time: 08:41:31
   Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Component: TELEFON       H09 2730
   Revision: 1B001001    Serial number: 00007661462358
   Coding: 0200000000010110
   ASAM Dataset: EV_UHVNA A01015
   ROD: EV_UHVNA.rod
   VCID: 356B1751948142898CD-8060
End-------------------------(Elapsed Time: 03:08)--------------------------
I appreciate any advice that can be offered.
golfhappy
C?ID=214466
Well there's a question! to settle this once and for all, do you really need a highline CECM to operate the shutters? i was told by Ultraxenon that they could retrofit my led bixenons on my GTD without the swap. As per my other Thread if you look through it they posted a picture of their wiring harnesses less the trigger wire cable that link into the gold connector and i think pins 47 and 48. So do they actually take power from the main beams to trigger the shutters. Both Carsystems and Kufatec both have the trigger wires. It's a mine field out there!!!!
I've also owned 2 Leon Fr's and the amount of time you're flashed is unreal.
markmeus
C?ID=149531
It's definitely a mine field, I got my head lights off eBay, the listing included Kufatec looms, I've noticed on the Kufatec site they claim their loom is only compatible with the pre facelift Leon so I'm even more confused.
According to SEAT a 5K0 937 087 S0J is the correct CECM for my car, but i was hoping other versions would work. There are none ending S0J on eBay and the idea of shelling out about £400 for a new CECM makes the whole project much less compelling.
golfhappy
C?ID=214466
markmeus
C?ID=149531
So an update, I gave up on eBay and ordered a new CECM from my chassis number.
It seems when ordering a replacement CECM VW will supply a highline version regardless of what was fitted at the chassis. I was provided with 5K0 937 087 AC.
It's now fitted to my car and my full beam is working as expected.
I am getting an error about the brake/tail lights - my car was factory fitted with LED tail lights so i presume there's something needing changed in the adaptation settings
And my DRLs arent working either, again probably just Long Coding but there are that many references to DRLs I'm not sure where to begin.
golfhappy
C?ID=214466
What i did was to collect the long codes of retrofitted bi xenons and then make an excell spreadsheet with the bytes numbers along the top.
Then populate it, in your instance from seat forums with known working long codes. Pop yours in at the top. It makes things that easier. I did ask the question about byte 13, no drop down box. Every man and his beast have theirs set at 00...mine 04. My drls work as per factory. I still get the error, due to a couple of wires joined in the harness. A new looms, looming!
