VW JETTA 2005.5 Fails New Throttle Valve and has bad acceleration issue.
peter11742
C?ID=356126
This is the story with the Jetta.
VW refuse to work on it and they offered some credit for 3 year old jetta.
Of course we refused it.
Now it travels to a shop that is good for European cars after one month we had an answer it can not be fixed.
Now the car is back in my driveway.
I had to make some plan to see if the car will be saved.
I installed a new Throttle valve that I opened previous and inspected and found to be clean and all the connections inside perfect Ebay $75.00.
Now I use my vcds program and I select 01 Engine and adaptation 10, #60 The program finds some values but the end last indicator has error it does not pass.
Now I know why the car when you try to accelerate is not working good.
My idea is if the cpu does not see the throttle and I can not do the adaptation procedure I have to try a different cpu to see if the other cpu will fix the problem.
I have one cpu from one different Jetta and I wander if I can copy all the settings from my original cpu to this other cpu then I can try to see if this will work.
The new cpu has immobilizer fixed already.
Let me see if anyone had this problem or any one can help here.
Best regards.
Peter11742
Please post an Auto-Scan for context.
If the replacement ECU already has Immo defeat, and if it is the correct ECU for the car, then there really aren't any settings to copy. Install ECU, do a TBA, done.
peter11742
C?ID=356126
Uwe.
Thank you. Please explain to me what is TBA.
The controller is from a crashed Jetta in florida.
I will try to day with the full scan so you can tell me if any other issue needs to be fixed.
The car is in my driveway so I have plenty of time to play with it.
peter11742
C?ID=356126
Uwe.
After your reply I took the controller and I installed it on the Jetta.
I did a quick scan and I see new errors from the new controller that I did not have before.
I took the car in the local streets I was driving at 20 miles and I push the Throttle to the floor Jetta jumped and with out any hesitation went to 50 miles.
The car is good now but we must see how we fix the errors.
I am sorry but I forgot how to add my new VCDS scan for you to tell me what is important to fix.
Uwe Thank you one more time this was a good guess and it worked.
peter11742
C?ID=356126
Uwe.
Here are the messages from the new controller.
Let me know what is very important to be fixed.
The car works fine but I like to prevent errors in the future.
Monday,20,May,2019,12:54:18:56328
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
VIN: WVWDS71KX6W202080   License Plate: 1944TODAY
Mileage: 174370km-108348mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 47 52 56 62
          72
VIN: WVWDS71KX6W202080   Mileage: 174370km-108348miles
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 AN    HW: Hardware No
   Component: 2.5l R5/4V      G   6744
   Revision: --------    Serial number: VWZ7Z0F3905772
   Coding: 0000003
   Shop #: WSC 01279 785 00200
   VCID: 75B7E3AE59CCF62FBDB-8020
000152 - Intake Air Temperature Sensor 2 (G299)
               P0098 - 002 - Signal too Low
                    Fault Status: 01100010
                    Mileage: 174377 km
                    Time: 00:40:04
                    Temperature: 21.0°C
                    Temperature: -40.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.557 V
000275 - Intake Air Temp. Sensor (G42)
               P0113 - 002 - Signal too High
                    Mileage: 174377 km
                    Time: 00:40:04
                    Temperature: 21.0°C
                    Voltage: 11.557 V
000258 - Mass Air Flow Sensor (G70)
               P0102 - 002 - Signal too Low
                    Mileage: 174377 km
                    Time: 00:40:08
                    RPM: 740 /min
                    Load: 83.5 %
                    Temperature: 21.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 9.144 V
Readiness: 0110 1101
   Part No: 09G 927 750 AS
   Component: AQ 250 6F           0649
   Coding: 0000008
   Shop #: WSC 00066 000 00000
   VCID: 025D88721802D197889-8056
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0021122
   VCID: 3A2D309230525957909-806E
   Part No: 1K0 907 044 AC
   Component: ClimatronicPQ35 066 0404
   VCID: 6889BADA1E7E1BC736D-803C
            000 -  -  - Intermittent
   Part No SW: 1K0 937 049 C    HW: 1K0 937 049 C*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000000006675
   Coding: 44058E03400418000014000000140000002077035C
   VCID: 2F3B11C6FB108CFF377-807A
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 12345
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 12345
02403 - Terminal 15 for Interior
02402 - Control Circuit for Terminal 15 for Interior
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
   Component: SDAR XM         H03 0060
   Revision: 00000000    Serial number: AUZ4Z7D7020608
   VCID: 2B0305D6CF08F0DF1BF-807E
            000 -  -
                    Reset counter: 195
                    Mileage: 174377 km
                    Time: 00:00:04
01304 - Radio
                    Fault Status: 01101000
                    Reset counter: 235
                    Mileage: 174365 km
                    Time: 19:38:24
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 1S AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD009JN8
   Coding: 0012627
   VCID: 2E050CC2FC1A85F73C1-807A
   Subsystem 1 - Part No: 1K0 959 339 B
   Component: BF-Gewichtsens. 006 0003
   Subsystem 2 - Serial number: 6332MSME06015E276
   Subsystem 3 - Serial number: 6342MSME0738210E7
   Subsystem 4 - Serial number: 6351HSME041B522B3
   Subsystem 5 - Serial number: 6361HSME040D4E1FJ
   Subsystem 6 - Serial number: 63727SME052B4110R
   Subsystem 7 - Serial number: 63827SME052C093A2
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - Intermittent - MIL ON
00591 - Seat Belt Switch; Driver (E24)
            010 - Open or Short to Plus - Intermittent - MIL ON
            002 - Lower Limit Exceeded - Intermittent - MIL ON
   Part No SW: 1K0 953 549 AC    HW: 1K0 953 549 AC
   Component: J0527           010 0045
   Coding: 0012041
   VCID: 73B3DDB657B8E81F93F-8026
   Component: E0221           004 0030
   Part No: 1K0 920 971 C
   Component: KOMBIINSTRUMENT 3HL 2120
   Coding: 0023203
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104A120448
   Coding: 3F7F03620F1002
   VCID: 290FFFDEC5F4E2CFE93-807C
01304 - Radio
                    Reset counter: 235
                    Mileage: 174349 km
                    Time: 00:13:54
                    Reset counter: 233
                    Mileage: 174349 km
                    Time: 00:37:06
                    Reset counter: 233
                    Mileage: 174349 km
                    Time: 00:00:01
00469 - Infotainment Databus in Single Wire Operation
                    Fault Status: 00101011
                    Reset counter: 233
                    Mileage: 174349 km
                    Time: 23:27:28
                    Fault Status: 00101100
                    Reset counter: 233
                    Mileage: 174349 km
                    Time: 23:27:23
                    Reset counter: 233
                    Mileage: 174365 km
                    Time: 23:29:39
   Part No SW: 1K5 919 965     HW: 1K5 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 0371356TMVE903
   VCID: 78A9EA9A4EDE8B47A6D-802C
   Component: IMMO            3HL 2120
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 A    HW: 3C0 959 760 A
   Component: Sitzverstellung     0601
   Revision: 00002000    Serial number: 00000000000000
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2339
   Coding: 0001271
   VCID: 363524A2044ABD37741-8062
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.3       1502
   VCID: 303912BAE62E93072ED-8064
                    Mileage: 4320 km
                    Temperature: 19.0°C
                    Voltage: 11.50 V
                    Voltage: 11.40 V
   Part No SW: 1K0 959 433 AT    HW: 1K0 959 433 AT
   Component:    KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 13100F880106281B0906050FA0080F0490A540
   Component: LIN BACKUP HORN H02 1301
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Fault Frequency: 19
                    Reset counter: 195
                    Fault Status: 01110011
                    Reset counter: 193
00123 - Outside Warning Light/Door exit Light; Rear Right
                    Fault Status: 01111001
                    Reset counter: 193
                    Reset counter: 193
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No: 1K6 035 456
   Component: 08K Audioverst.     0003
   Revision: 00002000    Serial number: 00000000002248
   VCID: 698FBFDE057422CF293-803C
   Part No: 1K0 959 702 K
   Coding: 0001271
   VCID: 372B29A60340443F6F7-8062
00110 - Right Mirror Turn Signal Lamp (L132)
Address 56: Radio
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2416
   Coding: 0000144
   VCID: 313F17BEED249A0F213-8064
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 323D18B2E822A117589-8066
End----------(Elapsed Time: 01:18, VBatt start/end: 14.2V/14.1V)-----------
Hmm, orginal ECU was:
Address 01: Engine        Labels: 06A-906-032-BGQ.lbl
   Part No SW: 06A 906 032 QC    HW: Hardware No
   Component: 2.5l R5/4V      G   6605
   Revision: 00000000    Serial number: VWZ7Z0D1108127
   Coding: 0000003
   VCID: 6FBBD1C63B90CCFF771-803A
Since the label files are different, one might think that there are some differences between these ECUs and/or the sensors they use. That makes trouble-shooting those fault codes exceedingly difficult.
Do you have the VIN of the car your new ECU was originally in? If so, it might be useful for you to compare the wiring diagrams and check part numbers for sensors between the cars.
peter11742
C?ID=356126
Uwe.
I have now the Bosh p/n original 261208541 other one 261201290 this is a bit older.
If I do not get error messages I will use the car.
I will also try to find a bosh ecu close to my numbers and get it fixed for immobilizer.
Thanks for your answers
Bosch number is not what you should primarily look at. You should check what VAG software numbers are applicable to your exact car by VIN.
peter11742
C?ID=356126
Uwe.
You are an expert on your field.
I am an expert in the medical service mri cat scanners retired.
Looking ecu by the car's VIN the price goes to $350.00 up to $1,000.00
So today I found an older production ecu proved to me that the throttle in the Jetta works good and fixed the choking of the Jetta during the acceleration with the old ecu.
I also learned that around the ecu have devices that change after 1000 numbers.
So Texas had my ecu very close to my original numbers original 261 208 541 Texas 261 208 566 and the cost $30.00
I hope this time the ross-tech software will much all the devises.This will happen in 2 weeks I will inform you with this project it is a learning process for every one.
Immobilizer will be a problem with a new ecu, but I can look my current unit and see what they did inside the board.
As always. Thank you for your good information.
peter11742
C?ID=356126
Uwe.
I received a good ECU from California that matches mine and the car starts and works good.
After I clear all errors now I get a new one " MIL request signal active check TMC for errors P1624 ". I delete this error but it comes back quickly. I have no other error.
You probably know what the ECU is looking.
Can you guide me so I can see if I need any other part or I can repair a missing wire or fuse.
I found on the ECU some notes the car had manual transmission is this maybe the reason of the error? how I can make the ECU to have autotransmission?.
I also have the original ECU that fails on acceleration.
Many thanks.
Peter
Post up a fresh scan with the new ECU installed please.
peter11742
C?ID=356126
Uwe.
I found the problem with the Jetta.
The new ECU gave me the problem with the error description.
The feed back from the PS 15 is not working.
I found the cable between the relay feed post with a resistor is not going back to the ECU.
Tomorrow I will open the cable and I hope I will find the cable's cut. The cable goes under the fuse relay box.
The power is on the pin of the relay post after the resistor.
I will post all my findings when I will fix the car. It is the worst problem for errors ever, even the wire color is wrong I will post the proper colors from the bottom of the fuse box.
I also made the manual transmission to be automatic your program made it easy. I still have the issue of the car chocking when I accelerate.
Peter
Westbury, UK
This is why I always say to NEVER trust the wire colors... over the years I've seen so many vehicles where the wire colors do not match the WD on cars new out of the factory.
peter11742
C?ID=356126
My latest scan
UWE this is my car: Please let me know if I can fix it. The throttle valve is not working and I can not see it on address 060.
Friday,14,June,2019,17:04:50:56328
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4505.4
VIN: 3VWSG71KX5M639565   License Plate: 6/14;19
          72
VIN: 3VWSG71KX5M639565   Mileage: 174370km-108348miles
   Component: 2.5l R5/4V      G   6654
   Revision: 00000000    Serial number: VWZ7Z0E2142030
   Coding: 0000003
   VCID: 6FBBD1C63B90CCFF777-803A
Readiness: 0010 1101
   Coding: 0000008
   Coding: 0021122
00576 - Terminal 15
            006 - Short to Plus - Intermittent
   Coding: 44058E03400410000014000000140000002077035C
   Coding: 00065493
   Shop #: WSC 12345
   Coding: 00217125
   Shop #: WSC 12345
            000 -  -
                    Reset counter: 235
                    Mileage: 174377 km
                    Time: 00:00:03
01304 - Radio
                    Reset counter: 235
                    Mileage: 174377 km
                    Time: 05:38:54
   Coding: 0012627
   Coding: 0012041
   Coding: 0023203
   Coding: 0001271
                    Reset counter: 195
   Coding: 0001271
Address 56: Radio
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:13, VBatt start/end: 12.2V/12.2V)-----------
[Select]
[01-Engine]
[Measuring Blocks]
Group 060.
peter11742
C?ID=356126
Uwe.
This was what i did and I did not find the throttle is not visible. I just updated the the software to the latest settings. I will try tomorrow. For all the people when you get brake switch week signal a few times you have a surprize on the harness of the switch. The cable and the socket were oxidized like the battery I couldn't take the harness out of the socket. I used a small screwdriver and i cleaned all the white stuff finally it came out. I spray with a strong cleaner and after it dried I used oil in the terminals 3 times until they were ready I inserted the plug and I never sow the error.
peter11742
C?ID=356126
Uwe.
You had the best idea throttle passed.
Now I have a light in the center of the dashboard that displays Passenger air-bag is off.
In the VCDS I have no errors on the air bags.
I hope I can find this issue on google.
Thanks as always.
Peter
Uwe.
Thanks as always.
Peter
That light is normal if there is nobody in the passenger seat. What happens when you put someone in that seat?
peter11742
C?ID=356126
Uwe.
I did not see you in my yard how did you fix the Jetta. Good work.
Yesterday I had to fix the drivers belt switch the seat is motorized the cable blue color was broken Half it's length I fixed and with it the car is done.
Thanks for your perfect answers.
Now the car is a Jetta 2006 and no more error codes.
When I will get a bmw or mercedes turbo diesel wagon we are going to see how will work together.
The software ver 19 is improved tremendously and has good speed.
Peter
peter11742
C?ID=356126
Hi Uwe.
I left the car for 2 days alone.
I started and I have a surprise Error P1432 04 Secondary air injection valve N112 open circuit.
The car wants to go but it stops and then it goes for ever with same sequence.
I do not know how to proceed The car is ready for any service I will keep it this way until is fixed.
I forgot to tell you I found one more broken wire the 0 volts BLK/GRN of relay J271 which I have an external jamber.
Let my know what is this problem I am sure you know.
Thanks.
Peter
