ABS light traction light on
sufister
C?ID=275619
hi guys front left wheel speed sensor and wheel bearing has been replaced still same fault coming up have checked wiring at speed sensor all ok is it possible abs module at fault thx
Friday,17,May,2019,10:51:58:31334
VCDS Version: 18.9.1.0
VIN: VSSZZZ1PZ8R081182   License Plate: WG08PZU
Mileage: 212380km-131966mi   Repair Order:
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: VSSZZZ1PZ8R081182   Mileage: 212380km-131966miles
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 GQ    HW: 03G 906 018 GQ
   Component: R4 2.0l PPD1.2 G    2280
   Revision: --H52---    Serial number: SEX7Z0H031V0GP
   Coding: 0050072
   Shop #: WSC 66565 257 00032
   VCID: 7AFB85FD35A53F9A93-802E
Readiness: N/A
   Revision: 00H11001
   Coding: 0006786
   Shop #: WSC 04941 785 00200
   VCID: 73E5A8D912CF4ED2D0-8026
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
   Part No: 1P0 907 044 D
   Component: ClimatronicPQ35 011 0702
   VCID: 2D517EA1B46B582246-8078
   Revision: 00H54000    Serial number: 00000005476931
   Coding: E1880F2F00041000431D00000000000000007F075C400000000000000000
   Shop #: WSC 18434 020 328969
   VCID: 71E9A2D168D37CC222-8024
   Subsystem 1 - Part No: 1P0 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 250108 022  0601
   Coding: 00056208
   Shop #: WSC 18434
   Subsystem 2 - Part No: 1P0 955 559   Labels: 1P0-955-559.CLB
   Component: REGENLICHTSENSORH04 0090
   Coding: 00152622
   Shop #: WSC 18434
   Component: J234__A04 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DP0R0PM
   Coding: 0012340
   VCID: 3B7540F97A1FC692C8-806E
   Subsystem 1 - Serial number: 6333FTS612563627
   Subsystem 2 - Serial number: 6343FTS633093627
   Subsystem 3 - Serial number: 6353ETS6V4E1V5KJ
   Subsystem 4 - Serial number: 6363ETS6JN0ATVNH
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           752 0100
   Coding: 0002042
   VCID: 78FF9FF50BA92D8AE5-802C
   Component: E0221           005 0060
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No: 1P0 920 947 C
   Component: KOMBIINSTRUMENT VO3 0750
   Coding: 0002401
   Shop #: WSC 06441 785 00200
   VCID: 336568D9524F0ED210-8066
   Part No SW: 1K0 907 530 P    HW: 1K0 907 951
   Component: J533__Gateway   H16 0191
   Revision:   H16       Serial number: 2000K0811409CA
   Coding: E9807F060006020203
   VCID: 34676BC5574109EA09-8060
   Component: IMMO            VO3 0750
   Part No SW: 1T0 959 701 G    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1130
   Revision: 31008001    Serial number: 00000565079121
   Coding: 0000688
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.142 H08 1901
   VCID: 366351CD413D1BFA37-8062
   Coding: 998000005283CC7F0006850560085F86107C00
   Shop #: WSC 01706 476 89224
   VCID: 0305F819426F7E52C0-8056
   Subsystem 5 - Part No: 1P0 951 171
   Component: Innenraumueberw.010 4971
   Coding: 00000000
   Shop #: WSC 01706
   Subsystem 6 - Part No: 1K0 951 605 C
   Subsystem 7 - Component:       NGS n.mounted
   Part No SW: 1T0 959 702 G    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1130
   Revision: 31008001    Serial number: 00000538179031
   Coding: 0000688
   VCID: 3C7743E57F11C1AAC1-8068
Address 56: Radio
   Part No SW: 1K0 959 703 N    HW: 1K0 959 795 H
   Component: J388   TUER-SG HL   1108
   Revision: 11006001    Serial number: 00000002663685
   Coding: 0000144
   Part No SW: 1K0 959 704 N    HW: 1K0 959 794 H
   Component: J389   TUER-SG HR   1108
   Revision: 11006001    Serial number: 00000002675061
   Coding: 0000144
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 5P0 862 335 B    HW: 5P0 862 335 B
   Component: FSE_2P5x        H26 0110
   Revision: 00000001    Serial number: 00000005014075
   Coding: 0000555
   VCID: 326B6DDDAD5507DA1B-8066
End-------------------------(Elapsed Time: 02:20)--------------------------
HMC
C?ID=28246
Have you scoped the signal at the ABS module?
Regards HMC
Ashraf6119
C?ID=174194
Where was the sensor bought from...........? if it was after market one than compare the resistance with the known good one sensor, I have seen few after market sensor have high resistance and cause this problems or remove the new sensor and just plug it to other side and see if it clears the fault code.
Jefe
NY, USA
C?ID=369956
I know BMW bearings are unidirectional and if the encoder is on the wrong side..ie bearing backwards then you'll need to do over...
sufister
C?ID=275619
Bearing was complete bolt on im getting a reading on idle of 4km when the car is stand still, when moving readings are same on all four wheels
Ashraf6119
C?ID=174194
Have you tried to swap the new sensor to other side just plug it in no need to fit it and see what readings you getting.....?
