Check Engine Light Today
Gmickey
C?ID=354933
Hi all,
Forgive me if this is in bad taste, but I am in a "try before you buy" situation with a friends car and it threw a check engine light today. I ran a scan and this is the result. I would like to understand the cause, but also want to ask the general question as to whether this car seems like a straightforward purchase or might be a risk. Single owner, high miles, but always serviced on time and at dealer. Thanks!
Thursday,16,May,2019,16:47:10:43616
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
VIN: WAULFAFR9AA02XXXX   License Plate: XXXXXXX
Mileage: 239960km-149104mi   Repair Order:
Chassis Type: FR-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56
          77
VIN: WAULFAFR9AA020103   Mileage: 239960km-149104miles
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H15 0001
   Revision: E1H15---
   Coding: 0114010A190F0160
   Shop #: WSC 09211 444 182470
   ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
   ROD: EV_ECM20TFS0118K2907115AL.rod
   VCID: 79AFEFA0A953F4CFD93-802C
9 Faults Found:
4629 - ECM Power Relay Load Circuit
          P068A 00 [032] - Opens Too Early
2921 - Knock Sensor 1 (G61)
          P0328 00 [096] - Signal too High
4054 - Cylinder 1
          P0301 00 [096] - Misfire Detected
                    Mileage: 238782 km
                    Date: 2018.06.22
                    Time: 15:28:41
                    Engine speed: 1214.00 /min
                    Normed load value: 21.2 %
                    Coolant temperature: 35 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 13.523 V
                    Unlearning counter according OBD: 4
4063 - Cylinder 4
          P0304 00 [096] - Misfire Detected
                    Mileage: 238782 km
                    Date: 2018.06.22
                    Time: 15:28:41
4057 - Cylinder 2
          P0302 00 [096] - Misfire Detected
                    Mileage: 238782 km
                    Date: 2018.06.22
                    Time: 15:28:41
4051 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [096] - -
                    Mileage: 238782 km
                    Date: 2018.06.22
                    Time: 15:27:54
                    Engine speed: 1206.00 /min
                    Normed load value: 18.8 %
                    Coolant temperature: 22 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 11.190 V
4106 - Bank 1; System too Rich at Idle
          P2188 00 [096] - -
7665 - EVAP Emission Control Sys
          P0442 00 [096] - Small Leak
7666 - EVAP System
          P0456 00 [237] - Very Small Leak Detected
                    Mileage: 238697 km
                    Date: 2018.02.07
                    Time: 15:21:12
                    Engine speed: 1571.00 /min
                    Normed load value: 15.7 %
                    Vehicle speed: 45 km/h
                    Coolant temperature: 66 °C
                    Voltage terminal 30: 14.065 V
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 J    HW: 0B6 927 156
   Component: 0B6 20TFSIUSA H05 0008
   Revision: --H05---
   Coding: 001012
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMAL651 A01006
   ROD: EV_TCMAL651.rod
   VCID: 3D273BB0FDFB08EFB5B-8068
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
   Component: ESP8 quattro  H04 0010
   Coding: 150D18
   VCID: 7AADF0ACACD5FFD7D09-802E
02214 - Tire Pressure Warning
            000 -  -  - Intermittent
                    Reset counter: 195
                    Mileage: 239565 km
                    Date: 2018.11.29
                    Time: 12:34:09
                    Hex Value: 0x4000
                    Hex Value: 0x4006
                    Hex Value: 0x1237
                    Hex Value: 0x1FB2
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
   Component: BCM2 1.1      H02 0324
   Coding: 090000
   VCID: 78A9EAA492D9EDC7A6D-802C
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Serial number: 0509000049953018
   Serial number: 0209000063527007
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 C    HW: 8T0 959 760 C
   Component: MEM-BFS       H10 0074
   Revision: AA000000    Serial number: 00001010004295
   Coding: 08017025002400001000
   VCID: 43D34D489B9F7E1FC3F-8016
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01150920090294
   Coding: 64022000
   VCID: 00598244CA09A5079ED-8054
                    Reset counter: 155
                    Mileage: 239566 km
                    Date: 2019.05.08
                    Time: 21:15:33
                    Temperature: 13.0°C
                    Voltage: 12.60 V
                    Output: 0 W
                    Output: 0 W
                    Temperature: 22.0°C
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000340407
   Coding: 26001091063CAF010000080300003D3D0F1C528800010161000000
   VCID: 3C2136B4E66101E7825-8068
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 120909  H14 0070
   Serial number: SWF09090125441
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10596177
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 AN    HW: 8K0 941 531 AN
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002807091472
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
   Component: AirbagVW-AU10 H37 0520
   Serial number: 003EGD02CYY%
   Coding: 303333334330303030304A55304C38543053
   VCID: 42DD484C84057717C89-8016
   Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
   Component: BF-Gewichtss.  H01 0050
   Serial number: 5810000R0900004E33
   Serial number: 6334MSME4B754319H
   Serial number: 6344MSME4B4101511
   Serial number: 6352QSME6A3A0D02L
   Serial number: 6362QSME153B1228B
   Serial number: 63732SME0D390C2E9
   Serial number: 63832SME0539240AX
   Revision: --------    Serial number: 90319II8000EE
   Coding: 000036
   VCID: 3D273BB0FD7B08EFB5B-8068
   Part No SW: 8T0 920 950 Q    HW: 8T0 920 950 Q
   Component: KOMBIINSTR.   H33 0255
   Revision: 00000000    Serial number: CHU22J299
   Coding: 8B1701000300D705020000
   VCID: 46D5545CA8AD4B37E41-8012
   Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0105
   Revision: GB600050    Serial number: 5000G0990383BB
   Coding: 00C303
   VCID: 50F972045AE995874ED-8004
   Component: J367-BDM  H06 0170
   Serial number: 1908C051250809
                    Reset counter: 196
                    Mileage: 239566 km
                    Date: 2019.02.17
                    Time: 22:20:00
                    Bin. Bits:    00000
                    Voltage: 11.80 V
                    Count: 17
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0280
   Revision: 00000000
   Coding: 020302
   VCID: 392F2FA0E95334CF993-806C
   Component: MEM-FS        H10 0074
   Revision: AA000000    Serial number: 00001010004226
   Part No SW: 8T0 959 793 J    HW: 8T0 959 793 D
   Component: TSG FA        H07 1301
   Coding: 011C03224000120102
   Shop #: WSC 09211 444 175787
   Revision: 00002001    Serial number: 0121269251
   Coding: 0106029A007A440400B0000000000000
   Shop #: WSC 06342 000 00000
   Component: GTO BF  H06 0050
   Serial number: 00000000000000166955
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE19SKB12  H01 0220
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 81
                    Reset counter: 146
                    Mileage: 212188 km
                    Date: 2016.08.10
                    Time: 18:10:40
02616 - Fuel Tank Cap; Unlock
                    Fault Frequency: 83
                    Reset counter: 79
                    Mileage: 196824 km
                    Date: 2015.08.25
                    Time: 10:38:22
00218 - Humidity Sensor (G355)
                    Reset counter: 115
                    Mileage: 228304 km
                    Date: 2017.06.25
                    Time: 17:41:00
Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
   Part No SW: 8T0 035 223 AR    HW: 8T0 035 223 AJ
   Component: DSP Prem      H17 0320
   Revision: 00017001    Serial number: 34834004493702
   Coding: 0203010302
   VCID: 7EA5FCBCB0FDD3F7EC1-802A
   Part No SW: 8T0 959 792 J    HW: 8T0 959 792 D
   Component: TSG BF        H07 1301
   VCID: 4FFB717847D78A7F577-801A
   Revision: 00000003    Serial number: 10000000312954
   VCID: 34311E94CE31C9A74A5-8060
   Part No: 8K5 907 357
   Coding: 0000002
   Shop #: WSC 06324 000 00000
   VCID: 77ABE99893C7E2BFAF7-8022
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
   Component: Con3 Sirius   H04 0351
   Revision: 00000006    Serial number: AUZ5Z6I1267629
   Coding: 040300020104850043D9070800
   Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
   Component: Display
                    Reset counter: 209
                    Mileage: 238340 km
                    Date: 2018.01.04
                    Time: 12:03:58
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
            000 -  -
                    Reset counter: 135
                    Mileage: 238791 km
                    Date: 2018.07.10
                    Time: 17:21:27
   Part No SW: 8T0 862 336 D    HW: 8T0 862 336 D
   Component: FSE_256x BT     H37 0600
   Revision: 00000000    Serial number: 00000005051481
   Coding: 0010370
   VCID: 3C2136B4EA6101E7825-8068
End----(Elapsed Time: 01:46, VBatt start/end: 12.0V/11.9V. VIgn 12.0V)-----
Address 01: DTCs cleared
NostraJackAss
Go have car looked at & get a professional opinion.
That's called a pre-purchase inspection.
Too many faults with gimmick dealer maintenance program?
Never buy cars from friends or family!
Probably bad N80 from failed EVAP system or small vacuum leak.
Model Audi A5 Coupe
Quattro 2.0
A5CO
Date of production 23.09.2009
Model year 2010
Sales type 8T356L
Engine Code CAEB
Transmission Code LML
Emission standard 7GB Emission standard ULEV 2
Don't cars that are certified at ULEV2, automatically according to regulations of title 40 come with a SMOG useful life warranty of 150k?
Gmickey
C?ID=354933
Yes, a pre-purchase inspection is always good advice.
Not too afraid of buying from a friend. He knows little about cars and I would not begrudge him any more than a stranger if a problem occurred after purchase. There are no guarantees buying pre-owned cars.
The car drives very well, and for the mileage the suspension and steering feel very tight. I love the body style and interior. My daily driver is currently a 2002 Jetta with 206K (purchased with 153K, from a friend :)) So this would be a significant upgrade!
