HEX-NET - DS Download Failure - Error -8
BivDog
C?ID=282193
My HEX-NET has been used in the past with success and recently I did a hard reset due to inaccessibility due to a configured wireless network. Anyways I went to use my HEX-NET and it complain of missing ASAM file and ROD references were missing after reset. Attempted to update my HEX-NET via VCDS-Mobile with no luck and got Error code -8, download failed. I then took the HEX-NET to an 18.9 VCDS Windows Install it attempted to download DS: 60000050 and got the same error Error code -8, download failed. Upon that failure I thought well maybe I'm too far back for an incremental update so if I move to 19.4 (Beta) it will update since there are new ASAM/ROD files.
After installing 19.4 it upgraded the firmware (successfully) and when it attempted to download DS: 60000057 I got the same error. Seems like it dies during the "Building SD update..." phase. I realize this could go in either production (18.9) or Beta (19.4) but since the problem was consistent across 3 different software packages I figured I would post to the general board.
Windows 10
VCDS Interface Config V2.248
Interface: HN1-002665
CB: 0.4504
FW: 0.256
CFB: 0.10
BL: 0.28
DS: 0000050
Let me know if you need any additional information, look forward to any help.
Moving this to HEX-NET Support.
If you're using the HEX-NET with VCDS on a PC, the failure to download ROD data will not affect its functionality; this is only relevant to VCDS-Mobile.
BivDog
C?ID=282193
What about ASAM File(s)?
Good deal, so while I was on lunch I was able to upgrade the Rod files via VCDS-Mobile and the next problem hit where VCDS-Mobile is saying it needs to download an ASAM file and it seems like nothing is happening within VCDS-Mobile. Basically it shows the update page with zero activity. Is ASAM also a VCDS-Mobile component?
Is there a better way to get the ASAM file onto HEX-NET?
Generally I am a VCDS-Mobile user as the only Windows system for me a Desktop within the house.
Shaun
It can take a minute to sync the files it needs with the server before it starts. Also, you can try taking it inside and updating with VCIConfig on a pc, that can also pull any ASAM data it needs.
BivDog
C?ID=282193
Shaun, it's possible without the progress back on VCDS-Mobile moving that I'm pulling the plug early. I did bring the HN inside the PC and ironically VCDS (PC) is saying I need updated Rod files and I'm back at the -8 error. Below are some of my configurations from which I attempted to pull the ASAM files:
VCDS-Mobile:
iPad via 4G Tether
No progress update (could be patience related on my part)
VCDS (PC):
Windows 10 via Ethernet via 4G LTE Router
Result: Rod files need to be updated, -8 error
VCDS (PC)
Windows 10 via Ethernet via Comcast Business Class Cable modem
Router
Any way I can bypass the Rod file update via the PC and download the ASAM? Or any idea of what's causing the -8 error for all downloads?
Shaun
The ROD file update IS the ASAM data, different names for the same thing. Rod files contain ASAM data.
As for why you keep getting -8 errors, I'm not sure. You could try [Options] -> [Clear Rod Files] to make it forget the files it is currently trying to download, and then scan just one or two modules from your car and see if it can download those files individually.
Shaun
Try again and see if you have better results. I found something related to this and made some tweaks, but a proper fix may have to wait until the rest of the crew is back in the office next week.
BivDog
C?ID=282193
Shaun, so everything seemed to work the 2nd time around. I had cleared the Rod files based on your earlier post and originally had the same problem however sometime after this last post it seemed like the files started to flow. Thanks for working with me to get my HexNet back up and running.
