2011 Passat B7 Euro Spec - RVC
bjornix
Norway
C?ID=222439
I need to replace the rear lid on my Passat estate and I was thinking of upgrading the rear view camera while I'm at it. My current RVC is mounted above the license plate next to the push button for the rear lid (3C9 827 566 A). I'd like to replace this with the "flip out" badge version (3AE 827 469) so it is less exposed to dirt, especially during winter time. I do have a couple of questions:
- ETKA lists 3AE 827 469 as an option for notchback only. Has anyone retrofitted this on an estate? Is it room for it? Any issues?
- Can I use the same wiring harness and/or control unit as before? Btw my current camera is a highline (i.e. has guidelines). I'll stick with the current push button for opening the read lid.
Wednesday,01,August,2018,11:40:42:22644
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 18.2.1.2
VIN: WVWZZZ3CZBE325045   License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 18 19 20 22 25 36 37 42 44
          46 47 4F 52 53 55 56 61 62 65 6C 6D 72 77
VIN: WVWZZZ3CZBE325045   Mileage: 85130km-52897miles
Address 01: Engine (J623-CFGB)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 BN    HW: 03L 907 309 N
   Component: R4 2.0l TDI   H24 9977
   Revision: 47H24---    Serial number: 00000000000000
   Coding: 001D003A046601080000
   Shop #: WSC 40190 222 00000
   ASAM Dataset: EV_ECM20TDI01103L906018BN 003007
   ROD: EV_ECM20TDI01103L906018BN.rod
   VCID: 77D302B3CE9530FC16-8022
   Part No SW: 02E 300 013 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2601
   Revision: 05351112    Serial number: 00001011091155
   Shop #: WSC 05311 000 00000
   VCID: 1B1B3E03DAFDB49CD2-804E
   Part No SW: 3AA 614 109 P    HW: 3AA 614 109 P
   Component: J104   C2 450M V560 0011
   Revision: --H07---    Serial number: 00000003272703
   Coding: 0121279
   VCID: 3A55DB877507ED9429-806E
   Part No SW: 3AA 907 044 AJ    HW: 3AA 907 044 AJ
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0014004802
   Shop #: WSC 00015 115 00000
   VCID: 78D1018FC38B3F841F-802C
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 A    HW: 3AA 937 087 A
   Component: BCM PQ47 H    413 0452
   Revision: BB413001
   Coding: 0002000000000000000C008874000DEC43D56388676DA5607F80C7240041
   Shop #: WSC 05311 123 12345
   VCID: 3851C18F8B0BFF84DF-806C
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 16111  10  0603
   Coding: 00B795
   Component: RLS 081210 05  54  0403
   Coding: 035028
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 D    HW: 3AA 919 475 A
   Component: PARKHILFE PLA H04 0007
   Revision: --------    Serial number: 20431034500293
   Coding: 308306
   ASAM Dataset: EV_EPHVA2C000000000 001006
   ROD: EV_EPHVA2C000000000_001_VW36.rod
   VCID: 3C59DD9FB733D3A43B-8068
Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
   Part No SW: 3AA 907 567     HW: 3AA 907 567
   Component: AC201  RDW A    031 0143
   Revision: 00031000    Serial number: 00000000078439
   Coding: 0010000
   Shop #: WSC 05311 000 08193
   VCID: 77D302B3069530FC16-8022
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 23111002930001
   Coding: 030180
   Shop #: WSC 05314 000 00000
   VCID: 277312F356B5607C46-8072
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__101 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PQS5JZW
   Coding: 0012337
   VCID: 4CB98D5F2F9363248B-8018
   Subsystem 1 - Serial number: 6332MTS673593060
   Subsystem 2 - Serial number: 6342MTS651483070
   Subsystem 3 - Serial number: 6351HTS6VLNTH9KR
   Subsystem 4 - Serial number: 6361HTS6PHRTF6KJ
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C9 953 501 BM    HW: 5K0 953 569 T
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20101130301577
   Coding: 399AA50001
   VCID: 75CF08BBD49942EC04-8020
   Coding: E30000
   Part No SW: 3AA 920 880 A    HW: 3AA 920 880 A
   Component: KOMBI         H02 0206
   Coding: 161F00
   Shop #: WSC 05314 115 12345
   VCID: 3147FCAB60712ECC98-8064
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 A
   Component: Standheizer     043 4730
   Revision: 00043000    Serial number: 09022127000000
   Coding: 0031032
   VCID: 334BF6A3526D1CDCEA-8066
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 091210F1003001
   Coding: 462006
   Shop #: WSC 05314 123 12345
   VCID: 3449F5BF97631BE4F3-8060
   Part No SW: 5K0 857 511 B    HW: 8P0 857 511 C
   Component: FLA           H04 0006
   Revision: AA001002
   Coding: 01018E67727261565623393E00
   VCID: 2D7FE0DB74494A2CBC-8078
   Part No SW: 0BS 907 554 B    HW: 0BS 907 554 B
   Component: Haldex 4Motion      4015
   Coding: 0000005
   VCID: 45AFB87B0CF9926C54-8010
   Part No SW: 3AA 959 799     HW: 3AA 959 799
   Component:    IMMO         083 0399
   Revision: 00083000    Serial number: VWZCZ000000000
   VCID: 052F787B4C79526C14-8050
   Part No SW: 3C8 959 760 A    HW: 3C8 959 760 A
   Component: Sitzmemory    H05 2201
   Revision: 00H05000
   Coding: 000039
   VCID: 334BF6A3926D1CDCEA-8066
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 E
   Component: RNS-MID       H21 6270
   Revision: AB001001    Serial number: VWZ6Z7N9312149
   Coding: 00050002010000800000
   VCID: 364DCFB7811F09F4CD-8062
   Component: EU West V15  8515
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0529
   Revision: 12110009    Serial number: 0001828416
   Coding: 0211FF
   Shop #: WSC 05311 115 00000
   VCID: 354FC8BB941902ECC4-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 703     HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0407
   Serial number: 00000001741953
   Coding: 0000D8
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.318 0802
   Revision: 1AH03729    Serial number: 00103360113601
   Coding: 0000258
   VCID: 3B5BDE837A3DD49C32-806E
Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
   Component: 02 KESSY PQ47   083 0323
   Coding: 01900A00D2C30E76300494157E00CFCE705801030424B8
   Subsystem 1 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HORN H11 9004
   Component: Neigungssensor  004 0611
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No SW: 3AA 035 456 A    HW: 3AA 035 456 A
   Component: DSP 10 Kanal        0020
   Revision: 00H02001    Serial number: 75818000267704
   VCID: 2D7FE0DBB4494A2CBC-8078
   Component: EZE_2         H41 1614
   Coding: 050B0508
   VCID: 6FC33AD3BEC5783CCE-803A
   Component: J245EE20SKB13  H02 0220
   Subsystem 3 - Part No SW: 3AA 919 204     HW: 3AA 919 204
   Component: Analoguhr  003 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0529
   Revision: 14110009    Serial number: 0001832542
   Coding: 0211FE
   VCID: 364DCFB7891F09F4CD-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 704     HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0407
   Serial number: 00000001755172
   Coding: 0000D8
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000077057
   Coding: 0022067
   Component: AFS-ECU       H04 0111
   Coding: 02B2000003000200
   Shop #: WSC 05311 115 12345
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   VCID: 3753C2B38E15F0FCD6-8062
   Subsystem 1 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H04 0012
   Coding: 230000
   Subsystem 2 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H04 0012
   Coding: 230000
   Component: Batt.regelung H41 1614
   Coding: 030B185A
   VCID: 71C73CABA8F16ECCD8-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370219854
   Part No SW: 3AA 907 273 F    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0011
   Serial number: 30000000049734
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_005.rod
   Part No SW: 3C9 907 441     HW: 3C9 907 441
   Component: J772__Rearview      0020
   Revision: 00H08000    Serial number: 525PA8-J0X1596
   Coding: 0020007
   VCID: 68F151CF5B2BAF048F-803C
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 3C9 827 383 J    HW: 3C9 827 383 J
   Component: J605  HECKDECKEL    0804
   Revision: 00H27001
   VCID: 3851C18F4B0BFF84DF-806C
   Subsystem 1 - Part No: 3C9 827 384 J
   Component: J756  HECKDECKEL    0804
   Subsystem 2 - Serial number: 1000H27001001B0090ÿ
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
   Component: Telefon       022 0946
   Revision: --------    Serial number: 35502105030069
   Coding: 020000000100010000000001
   ASAM Dataset: EV_UHVPremi 002708
   ROD: EV_UHVPremi.rod
   VCID: 246905FF2F838B6463-8070
End-------------------------(Elapsed Time: 04:28)--------------------------
kamold
Australia
C?ID=241363
I've seen it done online. Involves a bit of cutting of the existing sheet metal in the boot to make a hole for the camera:
https://www.drive2.ru/l/7098739/
siLc
Tallinn, Estonia
C?ID=330192
kamold
Australia
C?ID=241363
Wow that's a neat solution!
I've never even thought about it because the only things we need to wash off the camera lens here are spiders, drop bears (look them up) and crocodiles ;)
bjornix
Norway
C?ID=222439
@siLc: That does look a lot easier than cutting of the existing sheet metal, and would undoubtedly work with the existing wiring. But does it really get the job done when the lens is covered with dirt?
siLc
Tallinn, Estonia
C?ID=330192
I mainly used it in the wintertime when watery dirt covered the RVC and it took care of it fine. Havent had the chance to use it in a drier time of year.
bjornix
Norway
C?ID=222439
Great, thanks! Think I will give the rear lid button case with integrated washer nozzle a try. Do you happen to have the part numbers for the extra parts needed? Splitter, coupling elements, hoses etc. Tried to search ETKA, but couldn't find the A4 Y-splitter you mentioned. Don't know if something like this would work?
siLc
Tallinn, Estonia
C?ID=330192
You can make do with only the splitter, which is 8W9 955 934. This is my setup.
I was retrofitting a MIB2 compatible highline RVC at the time and I had to file the sides and back of the camera to fit inside the rear lid button case. Since you have the older style of camera, you may or may not have to do the same.
