Seat Leon ARL code faults
daniel.b
Europe
C?ID=318819
Hey,
I have a problem with recurring errors on the engine. After deleting they return after some time. Mass, relay and fuse have been checked. Where to find the reason? Maybe the ecu driver is damaged?
Wednesday,15,May,2019,18:04:11:07292
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4441.4
VIN:   License Plate: Seat Leon 2004r. ARL
Mileage: 230860km-143449mi   Repair Order:
Chassis Type: 1M (1M - Seat Leon (2000 > 2005))
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ4R099078   Mileage: 230860km-143449miles
Address 01: Engine        Labels: 038-906-019-ARL.lbl
   Part No: 038 906 019 KG
   Component: 1,9l R4 EDC G000SG  5342
   Coding: 00002
   Shop #: WSC 06402
   VCID: E680E9CA807B317AC7-4B3C
   VSSZZZ1MZ4R099078     SEZ7Z0D2463301
18080 - Coolant Fan Control 1
            P1672 - 35-10 - Open or Short to Ground - Intermittent
17957 - Boost Pressure Regulation Valve (N75)
            P1549 - 35-00 - Open or Short to Ground
17932 - Fuel Pump Relay (J17)
            P1524 - 35-10 - Open or Short to Ground - Intermittent
Readiness: 1 1 1 0 1
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 K
   Component: ASR FRONT MK60      0103
   Coding: 0022017
   Shop #: WSC 00001 001 00001
   VCID: B228459A2C339DDA9B-5184
Address 08: Auto HVAC        Labels: 1M0-820-043.lbl
   Part No: 1M0 820 043 E
   Component: 1M-CLIMATRONIC    X0702
   Coding: 00043
   Shop #: WSC 06402
   VCID: A404B3C236C7036A19-258E
   Part No: 1C0 909 605 A
   Component: 39 AIRBAG VW51 0A   0008
   Coding: 13113
   Shop #: WSC 06401
   VCID: A208B5DA2CD30D5A6B-5160
Address 17: Instruments        Labels: 1M0-920-xx2-17.lbl
   Part No: 1M0 920 822 E
   Component: KOMBI+WEGFAHRSP VDO V05
   Coding: 05124
   Shop #: WSC 30546
   VCID: AA185DFA54E3D51A23-5160
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 06402
   VCID: F0AC8F92B2BFEFCAAD-5160
   Part No: 1C0 959 799 F
   Component: 9V Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 06402
   VCID: BA386DBAA443659A53-4B1E
   Component: 9V Tőrsteuer.FS KLO 0202
   Component: 9V Tőrsteuer.BF KLO 0202
   Component: 9V Tőrsteuer.HL KLO 0202
   Component: 9V Tőrsteuer.HR KLO 0202
End----(Elapsed Time: 02:47, VBatt start/end: 12.1V/11.7V. VIgn 11.8V)-----
Check wiring diagrams and see if these these three actuators have something in common.
