Friday,28,June,2019,13:33:13:30756
-- Windows Based VAG/VAS Emulator Running on Windows 7 x86(Parallels)
Version 19.6.0.4 HEX-NET : 0.4505.4
VIN: WAUZZZ4G9DN002xxx License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 34 3B 42 44 46 47 52 53
55 5F 62 72
VIN: WAUZZZ4G9DN002xxx Mileage: 152957km-95043miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: OK 0000
17-Instruments -- Status: Malfunction 0110
Address 01: Engine (J623-CLAA) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 311 E HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0001
Revision: 53H37---
Coding: 32254012052F09020000
Shop #: 02391 785 00200
Dataset: EV_ECM30TDI0114G0907311E 001001
ROD: EV_ECM30TDI0114G0907311E.rod
VCID: 2502F53824992267C4-8071
Part No SW: 4G0 927 156 S HW: 0B5 927 156 F
Component: 0B5 30 TDIRdW H10 0004
Revision: --H10--- Serial number: 0000000481
Dataset: EV_TCMDL501 A02196
ROD: EV_TCMDL501.rod
VCID: 3C34305CB71383AF8B-8069
Address 03: Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 27A6C705E465E3A0CB00
Dataset: EV_ESPPremiAU57X 004028
VCID: 36202274893F59FF7D-8063
Address 05: /Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 FG HW: 4H0 907 064 BG
Component: BCM2 2.0 H31 0560
Coding: 01B93006000000000000
Shop #: 53484 001 1048576
VCID: 73A6DB60D2CD0CD79A-8027
Component: J764 ELV H40 0046
Serial number: 2312000068673013
Part No SW: 4G0 820 043 K HW: 4G0 820 043 K
Component: KLIMA 4 ZONEN H12 0064
Serial number: 17041200040582
Coding: 3622007820
Dataset: EV_AirCondiComfoUDS 002036
VCID: 271EFF305E953077F6-8073
Part No SW: 4H0 907 063 BP HW: 4H0 907 063
Component: BCM1 2.0 H12 0111
Revision: 11012002 Serial number: 00000001287572
Coding: 260020118034A7E00905008300001D0CCF9DC70827080101000008402100
VCID: 77BEEF70C6B560F7A6-8023
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 120309 H35 0080
Serial number: 120317110929
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: H04 0003
Serial number: 20139503
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 HW: 4G0 941 531
Component: E1 - H07 0044
Serial number: 04 04 2012 00000812
Serial number: E9A80326000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 Q HW: 4H0 919 475 C
Component: PARKHILFE H07 0060
Revision: 11001001 Serial number: 55901208901402
Coding: 08030C
Dataset: EV_EPHVA18AU57X0000 004005
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 40CC44ACDBFBE74FD7-8015
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG0084EL%
Coding: 30323436313330303537554A305234473053
Dataset: EV_AirbaAU10BPAAU64X 001014
Serial number: 3575HRB405V1BEPSCHPX
Serial number: 3585HRB404V1BBH2C88D
Serial number: 3515JRB400E4UHGCIHF3
Serial number: 3525JRB401E4UHGC9P0W
Serial number: 3554VRB405D18E5G118X
Serial number: 3564VRB400M4UHPKL0FU
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20120417000975
Coding: 000035
VCID: 302C146C635B77CF27-8065
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0009
Part No SW: 4G9 920 980 B HW: 4G9 920 980 B
Component: TDieGb Nv H78 0416
Revision: 28131177 Serial number: 658190312596036
Coding: 33A7230813012600010600
Dataset: EV_RBD4K 004045
ROD: EV_RBD4K_AU57.rod
VCID: 32281E64655745DF51-8067
U1014 00 [009] - -
Reset counter: 112
Mileage: 152957 km
Date: 2019.06.28
Time: 10:02:34
Part No SW: 4G0 907 468 E HW: 4G0 907 468 A
Component: J533--Gateway H08 0213
Revision: -------- Serial number: 00000000198522
Coding: 00CD077D00
Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790922824
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 09011200000000000165
6151 - Instrument Cluster Control Module on Optical Bus
U10C0 00 [009] - No Communication
[Lost Communication With Instrument Panel Cluster (IPC) Control Module]
Reset counter: 112
Mileage: 152957 km
Date: 2019.06.28
Time: 13:25:49
Voltage terminal 30: 14.2 V
Voltage terminal 15: 14.2 V
Control Module temperature: 28 °C
System status: Terminal 15 on
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0064
Serial number: 19041200040530
Coding: 02
Dataset: EV_ClimaContrUnitRearUDS 002018
VCID: 2F2E1710766568373E-807B
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H18 0782
Coding: 008000
Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
VCID: 2E100A14716F613F35-807B
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H01 0051
Revision: -------- Serial number: EJ1BPA8200198M
Shop #: 00000 000 00000
Dataset: EV_SARA2 004010
ROD: EV_SARA2_004.rod
Part No SW: 4G8 959 793 G HW: 4G8 959 793 G
Component: FA H03 0505
Coding: 011F16004001620002080002
VCID: 44C448BCC7E3FB6FF3-8011
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0027470277
Coding: 101000010000
Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
Revision: 00002001 Serial number: 0174000735
Coding: 013F062220B9040083200904000104000000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Component: BACKUP HO H05 1501
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000043861
Coding: 030000
VCID: 1D72DDD804C9EAA79C-8049
Part No SW: 4G8 959 792 G HW: 4G8 959 792 G
Component: BF H03 0505
Coding: 011F16004401620002080002
VCID: 43C64BA0C2EDFC57CA-8017
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: -4 H03 0012
Revision: -------- Serial number: 00000000319415
Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A1806044D870D1FE9-807F
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0013
Serial number: 110620-0004-042
Coding: 17226F101000A300
Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 2C14001C4773132F1B-8079
Part No SW: 4G0 035 193 E HW: 4G0 035 193 D
Component: RMC Cnct Nav H52 0775
Coding: 0101050001E15B67082B060301020100000000
VCID: 2502F5382C992267C4-8071
Subsystem 1 - Part No: 8X0 919 884 D
Component: P13-50-11.06 0002
Subsystem 2 - Part No SW: 4G0 919 603 HW: 4G0 919 603
Component: DU6 Basic H42 0084
Serial number: 9464CT0C2521366
Subsystem 3 - Part No SW: 4G2 919 610 B HW: 4G2 919 610 B
Component: E380 BDT C7 H11 0204
Serial number: 90349LDC0017V
Reset counter: 112
Mileage: 152957 km
Date: 2019.06.28
Time: 13:26:37
Bin. Bits: 00000000 00000000
Bin. Bits: 00010000 00000000
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 G HW: 4G8 959 795 G
Component: HL H03 0505
Coding: 010F14004001620002080002
VCID: 46C052B4F1DFC97FED-8013
Address 72: Door, Rear Right (J389) Labels: None
Component: HR H03 0505
End----------(Elapsed Time: 01:42, VBatt start/end: 14.6V/14.6V)-----------
