Golf GTI 2010 warning light | Byte 18 and LED tail lights
missmouse
C?ID=96900
Hi, I have a 2010 Golf GTI 2010 Mk6 & have a dash warning light on telling me I have a fault in rear right tail lamp. This is since I fitted LED tail; lamps. I read I can code this out on long coding byte 18 but when I go there I get a warning that any changes may cause damage. Then even if I do try to make any changes, I cannot do so!
Is there any way I can do this?
( I dont wish to fit resistors to the led's)
Thanks,
Simon
missmouse
C?ID=96900
Ok, I managed to change byte 18 code 00 to 15 but that has made no difference! Any ideas?
Dana
Western PA, USA
missmouse
C?ID=96900
Hi, Ive got the logs saved to my laptop but I am unable to copy & paste them here for some reason?
Will I just write out the relevant part of the log?
Huh? I can't think of any reason why you wouldn't be able to copy & paste text here.
Are you trying to copy & paste an entire file? You need to open the file with Notepad, select the text you want to copy, then copy & paste that text.
missmouse
C?ID=96900
Managed it! I had to email it to myself first!
Chassis Type: 1K-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
VIN: WVWZZZ1KZAW095150   Mileage: 190290km-118240miles
Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
   Part No SW: 5K0 907 115     HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI*    0050
   Revision: AAH06---    Serial number:
   Coding: 0403000C1C070060
   Shop #: WSC 66565 257 00032
   VCID: 67D9DE77563B88727C-8032
005727 - Oil Pressure Regulation Valve
               P165F - 000 - Short to GND - Intermittent
                    Fault Frequency: 22
                    Mileage: 190285 km
                    Date: 2013.10.16
                    Time: 14:25:28
                    RPM: 185 /min
                    Load: 96.4 %
                    Temperature: 25.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 1030.0 mbar
                    Voltage: 10.287 V
006469 - Control Module 1 for Cooling Fan
               P1945 - 000 - Output Short Circuit
                    Mileage: 190286 km
                    Date: 2013.10.16
                    Time: 14:27:31
                    RPM: 1813 /min
                    Load: 41.2 %
                    Speed: 36.0 km/h
                    Temperature: 52.0°C
                    Temperature: 24.0°C
                    Voltage: 14.097 V
   Part No SW: 02E 300 051 R    HW: 02E 927 770 AM
   Component: GSG DSG AG6     521 1975
   Revision: 05652104    Serial number: 00001306260661
   Shop #: WSC 04940 001 00001
   VCID: 224F8F63FD99AD5AEB-8076
   Part No SW: 1K0 907 379 AM    HW: 1K0 907 379 AM
   Component: ESP MK60EC1   H45 0108
   Revision: 00H45001
   Coding: 163B600D892B00FF680C06E991190081B108
   VCID: 7DF59C1FE4A732A2B6-8028
   Part No SW: 5K0 907 044 BC    HW: 5K0 907 044 BC
   Component: Climatronic   H14 0608
   Revision: 00003001
   Coding: 0000000000
   ASAM Dataset: EV_Climatronic A01001
   VCID: 6DD5AC5FBCC7A22206-8038
13701888 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 250
                    Mileage: 190297 km
                    Date: 2019.05.27
                    Time: 09:08:06
9481988 - Air Quality Sensor
          B10AF 04 [009] - Internal System Fault
                    Reset counter: 210
                    Mileage: 190297 km
                    Date: 2019.05.27
                    Time: 09:08:06
   Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
   Component: BCM PQ35  M   103 0541
   Revision: 00103 AE
   Coding: 00180A3F9033F1C044080080140001E443D11588536D8960648000200000
   VCID: 306B752B63750FCA6D-8064
   Component: Wischer 30070  21  0501
   Coding: 009795
   Component: RLS 300709 05  54  0402
   Coding: 0330AD
   Subsystem 4 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    035 0604
   Serial number: 003C2RA1VM3P
   Coding: 00003233
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 77F98E37CE9B18F2EC-8022
   Serial number: 71695449ZZZZZZZZZZZZ
   Serial number: 246D1249ZZZZZZZZZZZZ
   Serial number: 36022B08ZZZZZZZZZZZZ
   Serial number: 28023145ZZZZZZZZZZZZ
   Part No SW: 1K0 953 549 CE    HW: 1K0 953 549 CE
   Component: J0527           055 0111
   Coding: 0001602
   VCID: 77F98E37069B18F2EC-8022
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000131
   Part No SW: 5K6 920 970 B    HW: 5K6 920 970 B
   Component: KOMBI         H05 0206
   Coding: 470900
   VCID: 33617A279A6334D210-8066
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H07 0081
   Revision:   H07 01    Serial number: 220709F2002672
   Coding: ED807F06000212000003
   VCID: 66C7D3735131917A47-8032
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H05 0206
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667522868
   VCID: 2647937351B1517A87-8072
   Component: Tuer-SG         009 2110
   Coding: 0000692
   VCID: 316D702FA87F06C262-8064
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 74     2901
   Revision: 00H17000
   VCID: 2F697657BE4B103274-807A
   Coding: 0000692
   VCID: 326F7F23AD793DDA1B-8066
   Part No SW: 3C8 035 195 G    HW: 3C8 035 195 G
   Component: Radio RCD510  050 0207
   Revision: 00000001    Serial number: VWZ1Z3L6688143
   Coding: 01000400040005
   VCID: 2C53615B4F5D6B2A51-8078
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 3463793B576D33EA09-8060
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0000144
   VCID: 3565443F5C172AE23E-8060
End-------------------------(Elapsed Time: 02:20)--------------------------
langers2k
C?ID=224085
I'm not 100% sure if that BCM will support LED lighting, I know I've had issues with some 087 units running SW:05xx and below.
Where in the UK are you? It sounds like you might need to find a VCP or ODIS-e user to tweak the lighting config.
missmouse
C?ID=96900
Hi, Im near Glasgow, however if its not possible to code out the warning light I understand a resistor can be added to the circuit to fool the BCU?
langers2k
C?ID=224085
Too far away for me to take a look.
You can add resistors, just make sure they are well attached to something that can take the heat as they will warm up.
You might also want to check all the exterior lamps (sidelight, indicators, fogs, reverse, brakes, DRL?) are working correctly since you changed the byte 18 value.
missmouse
C?ID=96900
should I change it back to 00 since it made no difference?
( everything works as before)
Dana
Western PA, USA
Thanks for the scan. HEX 15 would work with a newer SWL but it won't on this BCM.
I'm reasonably confident HEX 02 was factory (under those 00's) for incandescent tails whit a rear fog light. HEX 04 should work for you in this condition providing the LED tail lights are VW (rather than aftermarket).
P.S. Coding it back to 00 won't do any good. That was a spoofed value hiding the original coding.
missmouse
C?ID=96900
Thanks, Ill give that a go & let you know!
Dana
Western PA, USA
Sounds good.
I managed to miss the warning from langers2k. Although I don't think you will have an issue with this Golf ... some early (2009/10 production) Golf 6 based models such as the Octavia did have issues where Coding to any of the 255 (00 through FF) possible Byte 18 issues did NOT restore lighting issues after modifications to Byte 18. In those cases you needed to tweak the EEPROM directly which isn't supported by VCDS. There was an test plan the dealer could run with GFF/ODIS and other tools (which can tweak the EEPROM directly) can be used if you know what to change.
missmouse
C?ID=96900
Thanks for this! 04 worked! :thumbs:
Northern8019
Northwest, UK
C?ID=557374
Morning
I'm in a similar situation to Miss mouse, Wondering if someone can advise on the best way forward.
I've a 2009 mk6 gtd UK spec, Halogen all around
I've installed OEM rear LED lights, they work fin but now have bulb out warning on the dash. Looking around on here and other mk6 forums is suggest recoding the 09, byte 18. my byte 18 currently shows 00 so i cant see what the current coding is in the background
Do i code byte 18 in the binary to copy what other people have done, or was think of installing a newer highline BCM/CECM
Below is the current details of my BCM, the all light work exactly as they should aside from the bulb out issue
The highline unit I've got is 1K0 937 087J ( if its easy to swap out and use the 087 unit i was think, or messing with that coding, they I don't wreck the current 086 unit)
Comments appreciated please
   Component: BCM PQ35  M   103 0575
   Revision: 00103 AG
   Coding: 46180A3A9025F10044080080240001E443510088536D8160648000200000
   VCID: 3038EC9F9A2FEFDA9F3-8064
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 17031  21  0512
   Coding: 009795
   Component: RLS 250310 05  54  0403
   Coding: 0330AD
00984 - Left Tail Light (M4)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 73
                    Mileage: 245561 km
                    Date: 2018.06.12
                    Time: 15:59:45
                        Term 15 On
                    Voltage: 14.10 V
                        Term 50 Off
00985 - Right Tail Light (M2)
                    Reset counter: 73
                    Mileage: 245561 km
                    Date: 2018.06.12
                    Time: 15:59:45
                        Term 15 On
                    Voltage: 14.10 V
                        Term 50 Off
                    Reset counter: 73
                    Mileage: 245561 km
                    Date: 2018.06.12
                    Time: 15:59:45
                        Term 15 On
                    Voltage: 14.10 V
                        Term 50 Off
                    Reset counter: 73
                    Mileage: 245561 km
                    Date: 2018.06.12
                    Time: 15:59:45
                        Term 15 On
                    Voltage: 14.10 V
                        Term 50 Off
Zagor
Italy
C?ID=96696
The problem can only be solved with Odis Engineering or with VCP, by modifying 3 memory addresses in the BCM eeprom
