2009 Caddy - 1.9 TDI - G83 Sensor Radiator
Gashhey
C?ID=350180
2009 Caddy - 1.9 TDI - G83 Sensor Radiator fault.
I've tried replacing the sensor however it hasnt seemed to help. I've tried using a testmeter to check the voltage however none of them have any connectivity through the wire that connects into the sensor.
Sunday,12,May,2019,14:07:36:18214
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
VIN: WV1ZZZ2KZAX063763   License Plate: SCAN
Mileage: 245250km-152391mi   Repair Order:
Chassis Type: 2K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 46 52 56
VIN: WV1ZZZ2KZAX063763   Mileage: 245250km-152391miles
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 021 PD    HW: 03G 906 021 CG
   Component: R4 1,9L EDC  000SG  2387
   Revision: --H11---    Serial number: VWX7Z0I93NQ0KX
   Coding: 0000071
   Shop #: WSC 00000 256 01574
   VCID: 70B9D32AE6A761E76ED-8024
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
               P2185 - 000 - Signal too High
                    Mileage: 245250 km
                    Time: 13:47:34
                    Voltage: 11.55 V
                    Bin. Bits: 00000100
                    Temperature: 16.2°C
                    Temperature: 11.7°C
Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AF    HW: 1K0 907 379 AF
   Component: MABS MK70M          0104
   Revision: 00H32001
   Coding: 0020801
   Shop #: WSC 35110 377 00157
   VCID: 76B5E53284C34FD7B41-8022
   Part No SW: 2K0 820 047 BM    HW: 2K0 820 047 BM
   Component: Climatic PQ35   143 1515
   Revision: 00143033    Serial number: 00000000000000
   VCID: 71BFD62EEDAD68EF613-8024
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 01000003455243
   Coding: 00804F030004100057000000000000000008FB075C000120000000000000
   Shop #: WSC 35110 377 08192
   VCID: 323D1922282B13F7589-8066
   Subsystem 1 - Part No: 1T2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 071009 021  0512
   Coding: 00038805
   Shop #: WSC 35110
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 2Q AIRBAG VW52  025 2400
   Revision: 06025000    Serial number: 0037TR05HC4I
   Coding: 0012881
   VCID: 7DA7FA1EA1F51C8FF5B-8028
   Part No SW: 1K0 953 549 CT    HW: 1K0 953 549 CT
   Component: J0527           053 0111
   Coding: 0000001
   VCID: 065595F2F4235F57A41-8052
   Part No SW: 2K0 920 944 C    HW: 2K0 920 944 C
   Component: KOMBIINSTRUMENT VDD 1222
   Revision: V0002000    Serial number: VWX7Z0I93NQ0KX
   Coding: 0016401
   Shop #: WSC 00288 210 87232
   VCID: 2C01075A0A0F4507125-8078
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0111
   Revision:   H07 01    Serial number: 221009F1000624
   Coding: 89801F06000202007401
   VCID: 698FBE4EC57D902F293-803C
   Component: IMMO            VDD 1222
Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
   Part No: 1K0 959 793
   Component: Tuersteuergeraet 02 0160
   Coding: 0000000
   Part No: 1K0 959 433 CP
   Coding: 018A0C087F2D84054858061000C0
   VCID: 005983EAD60771679ED-8054
Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
   Part No: 1K0 959 792
   Coding: 0000000
   VCID: 75B7E23E99C544CFBDB-8020
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  013 0036
   Revision: 00000000    Serial number: VWZ1Z2I6759399
   Coding: 0000020001
   VCID: 6597B27E2565B44F0DB-8030
End----(Elapsed Time: 00:50, VBatt start/end: 11.7V/11.8V. VIgn 11.8V)-----
Please explain what you mean by this. How exactly did you test this?
Gashhey
C?ID=350180
My bad.
Checked the connector that plugs into the sensor (I think) and it’s not showing any voltage and isn’t it meant to show 5V?
