Installing Rear View Camera (RVC) in UK 2016 VW Polo 6C
FiftyPlus
Ireland
C?ID=348193
Hello. My first post here, so have mercy!
My kids share a Uk 2016 POLO 6C. It has Navigation & front/ rear park senors standard.
As it's mostly city driving I picked up a Reverse Camera kit. It included the camera & cabling but no coding information.
Connection is easy enough, 2 wires to Infotainment brains in the glovebox area and a few power connections.
Various Internet suggestions for activation RVC in related VW, but none identical to this car.
RVC appears in 2 places.
1) In the Park-Steer module Bit 4-5 has a drop down list with camera options. Selecting RVC makes no apparent difference.
2) In the Infotainment module Bit 4 is an option "RVC Low installed". If I select this I do get a reconfiguration of the Infotainment reverse screen but no image, and it only works for one "put into reverse" cycle, Then then a message "Park Assist unavailable". By deselecting the camera all returns to normal.
I have tried 1) & 2) individually & together and no difference in behaviour.
Behaviour is the same whether the camera is connected or not. I suspect the camera is not the issue but something else.
What thoughts please???
Hugh
FYI: Original Infotainment long code
02720001BE00000051111101008808001F0100C601200100CF
Original Steer/ Park assist long code
0031051001
FiftyPlus
Ireland
C?ID=348193
Thanks for the feedback. See a full Autoscan below.
Saturday,11,May,2019,18:20:50:16756
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
Workshop Code: 790 31414 000001
VIN: WVWZZZ6RZGU082432   License Plate: POLO 6C MAY 11
Mileage: 34484km-21427mi   Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 5F
VIN: WVWZZZ6RZGU082432   Mileage: 34484km-21427miles
Address 01: Engine (J623-CHYA)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 057 AA    HW: 04E 907 309 CB
   Component: R3 1.0l MPI   H20 2495
   Revision: 33H20000
   Coding: 01110072022401080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM10MPI01104C906057AA 001002
   ROD: EV_ECM10MPI01104C906057AB.rod
   VCID: 6491AF277EDFA8671A5-8030
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08504439160426
   Coding: 23DD2485492B33C20918106C0053C42492CC90080005CB098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 372B286B9FC993FF6F7-8062
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 C    HW: 6C0 820 045 C
   Component: AC Manuell    H03 0202
   Serial number:  1604221B-0344
   Coding: 200100001000100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 1F1BE0CB1739CBBF877-804A
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 C    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H08 0087
   Serial number: 006098188715
   Coding: 0300084042530A7B0FA44080B12703C800005B0257010000000000000000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005.rod
   VCID: 303913777AA744C72ED-8064
   Subsystem 1 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S3Y16M05D20H15M49S32
   Coding: 9038DD
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 6R0 959 802 DM    HW: 6R0 959 802 DM  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 0610
   Serial number: KU0KU010051661314151
   Coding: 1400A1
   Subsystem 3 - Part No SW: 6R0 959 801 DK    HW: 6R0 959 801 DK  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 0610
   Serial number: KU0KU002051661238443
   Coding: 0400A1
   Subsystem 4 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY160321GRQ
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000065394010
   Subsystem 6 - Part No SW: 6R0 959 812 AA    HW: 6R0 959 812 AA
   Component: J389__TSG_HR  003 0610
   Serial number: KU0KU006051661271634
   Coding: 1400A0
   Subsystem 7 - Part No SW: 6R0 959 811 AA    HW: 6R0 959 811 AA
   Component: J388__TSG_HL  003 0610
   Serial number: KU0KU028041661195010
   Coding: 0400A0
   Revision: --------    Serial number: 39331612511631
   Coding: 0031051001
   Shop #: WSC 31414 790 00001
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 43D34CBBDB11CF5FC3F-8016
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 J    HW: 6C0 959 655 J
   Component: VW20Airbag00C 002 0380
   Revision: --------    Serial number: 003TH006DZ2J
   Coding: 88C0C000000000005C000000008800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3A2D315FACDB8E97909-806E
   Subsystem 1 - Part No SW: -----------    HW: 410 822 504 16
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00A52085D128218
   Subsystem 2 - Part No SW: -----------    HW: 410 822 404 16
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00A9209A1C332FS
   Subsystem 3 - Part No SW: -----------    HW: 442 152 404 16
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00AF1D5E5B1A35X
   Subsystem 4 - Part No SW: -----------    HW: 442 150 303 16
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A0016294B6C9A66N
   Part No SW: 6C0 920 940 C    HW: 6C0 920 940 C
   Component: KOMBI         201 1420
   Coding: 272409002180260001086A001000000000000000
   VCID: 2411EF273E5FE867DA5-8070
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H08 0087
   Revision: --------    Serial number: 006098188715
   Coding: 030100046F0A640071000000000000010001010000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_VW26.rod
   VCID: 6597B22375E5D16F0DB-8030
   Subsystem 1 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A  Labels: 3C8-959-537.CLB
   Serial number: 1181614220001412AD1B
   Coding: 280000
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 63127I00412821093134
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 AG    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  322 3232
   Serial number: CG6B0465
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 6E85CD0FA01312377C1-803A
   Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
   Component: MU-S-ND-ER    H24 0252
   Serial number: VWZAZ2S0275217
   Coding: 02720001BE00000051111101008808001F0100C601200100CF
   ROD: EV_MUStd4CTSAT_VW26.rod
   Subsystem 1 - Part No SW: 6C0 919 603 A    HW: 6C0 919 603 A
   Component: ABTm_Std2_Nav  H53 1031
   Serial number: VWZ8Z9SKX0174S
End----------(Elapsed Time: 00:55, VBatt start/end: 14.7V/14.8V)-----------
Gashhey
C?ID=350180
Is this a badge reverse camera or just an aftermarket one?
If it’s the badge, I’ve recently retrofitted one and the cable from the badge has to plug into its self and that’ll fix it, as I had the same issue.
FiftyPlus
Ireland
C?ID=348193
No, it's the one that sits just over the number plate, it's supposed to be an original upgrade, but frankly the source proved to be a bit suspect, despite the nice website.
I think VW changed to the Number Plate camera on later cars. I am not an expert in any way on Polo's.
Can you elaborate a little on the problem as you saw it? I am assuming there is some interaction between the camera and the Infotainment module, so the module needs to see the camera correctly.
There are 5 wires from the cable loom supplied: Clear & Black, to the infotainment module: Pins 6 & 12 on the green connector
Brown to ground
Red to +12
Yellow to reversing light
So in theory pretty simple
Thanks!
http://vagtec.co.uk/eshop/volkswagen/polo/polo-6c/genuine-volkswagen-oem-retrofit-kit-rear-view-camera-vw-polo-6c.html
