Audi Q5 Error
ShatrunjayTayal
C?ID=340062
Hi All,
I am getting various errors in my AUDI Q5 2011 2.0 TDI, An year ago it had EGR fault, so instead of replacing the EGR, I had an EGR and DPF delete with a remap. Recently the car has been throwing all sorts of errors to do with control modules, mostly around handbrake sensor. We also took it a garage, who think it could Crankshaft position sensor.
However my feel is that it could be wiring issue or a faulty module/relay (based on google search, I have no clue what a relay is). It’s currently a bit freaky to drive the car when it goes to into limp mode on a motorway.
Please share your valuable advice
Hope i am pasting the code correctly.
Wednesday,01,May,2019,09:57:28:18679
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
VIN: WAUZZZ8R0CA0xxxxx   License Plate:
Mileage: 137600km-85500mi   Repair Order:
Chassis Type: 8R-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 5F 62
          6D 72
VIN: WAUZZZ8R0CA0xxxxx   Mileage: 137600km-85500miles
Address 01: Engine (J623-CGLB)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 MQ    HW: 03L 906 018 DN
   Component: R4 2,0L EDC   X25 2844
   Revision: 45X25---
   Coding: 2A254012042702080000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20TDI01103L906018MQ 003010
   ROD: EV_ECM20TDI01103L906018MQ.rod
   VCID: 05576DDC05A5A95FADB-8050
          U1113 00 [039] - -
                    Mileage: 137600 km
                    Date: 2019.05.01
                    Time: 09:54:38
                    Engine speed: 930.00 /min
                    Normed load value: 27.1 %
                    Coolant temperature: 73 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 14.440 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 129
                    Cruise Control System (CCS): status-Bits 0-7: 236
                    Cruise control switch-off: irreversible-Bits 0-7: 4
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 16
4124 - Sensor Reference Voltage B
          P0651 00 [167] - Open Circuit
                    Mileage: 137600 km
                    Date: 2019.05.01
                    Time: 09:54:38
                    Exh.gas temp.sen 1: 71.1 °C
                    Exh.gas temp.sen 2: -0.0 °C
                    Exh.gas temp.sen 3: 143.8 °C
                    Exh.gas temp.sen 4: 142.3 °C
                    Shut-off timer: last engine shut-off time: 211 s
   Part No SW: 8R0 927 156 T    HW: 0B5 927 156 F
   Component: 0B5 20 TDIRdW H10 0007
   Revision: --H10---    Serial number: 0000000603
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 4CC198F8664F9817325-8018
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 G    HW: 8R0 907 379 G
   Component: ESP8 quattro  H07 0070
   Coding: 0D1540
   Shop #: WSC 06334 000 00000
   VCID: 44D1B0D84E9F5057FA5-8010
   Part No SW: 8K0 907 064 CQ    HW: 8K0 907 064 CQ
   Component: BCM2 2.0      H05 0435
   Coding: 011500
   VCID: 015F79CC110D857F913-8054
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H60 0072
   Serial number: 0511000050165008
   Serial number: 2311000191762011
   Part No SW: 8T2 820 043 AD    HW: 8T2 820 043 AD
   Component: KLIMA 1 ZONE  H08 0182
   Revision: B0000000    Serial number: 01100920110610
   Coding: 34150000
   Shop #: WSC 36954 001 1048576
   VCID: 74B120185EBFA0D78A5-8020
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 25
                    Mileage: 137600 km
                    Date: 2019.05.01
                    Time: 09:54:34
                    Temperature: 17.0°C
                    RPM: 920 /min
   Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
   Component: BCM1 1.0      H30 0392
   Revision: 09030001    Serial number: 00000001042307
   Coding: 26001011403489010000000000001D0D401D470802010101000000
   Shop #: WSC 06335 123 12345
   VCID: 3A2DCE203C5B16A7909-806E
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 110826  H11 0050
   Serial number: 90243015110720004811
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 11656844
   Coding: 024D25
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000209110416
   Part No SW: 8K0 919 475 AA    HW: 8P0 919 475 N
   Component: PARKHILFE 8K  H01 0081
   Revision: 11001001    Serial number: 12501125601153
   Coding: 100108
   VCID: 78A9142842D7C4B7A6D-802C
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003JPD0AT10E
   Coding: 30473331313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 48C9A4E87237743716D-801C
   Serial number: 6334MSME6371126FE
   Serial number: 6344MSME60543767C
   Serial number: 6352QSME1F602644F
   Serial number: 6362QSME7F5F1760Y
   Serial number: 63732SME5F67174CD
   Serial number: 63832SME5766174E7
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372KI700142
   Coding: 000037
   Shop #: WSC 01211 210 01254
   VCID: 3D27C53C2D75219FB5B-8068
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 981 H    HW: 8R0 920 981 H
   Component: KOMBIINSTR.   H22 0258
   Revision: 00000000    Serial number: EK3231D9C
   Coding: 2F1F22000200A600010401
   VCID: 3FDBBF342779338FA77-806A
   Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0117
   Revision: EC000056    Serial number: 5600E11903065F
   Coding: 00C303
   VCID: 035373C40B11976F83F-8056
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790403717
   Part No SW: 8K0 959 793 N    HW: 8K0 959 793 N
   Component: TSG FA        H12 0357
   Revision:             Serial number: 0000012915691
   Coding: 011002204001440004
   VCID: 4BC39BE463C19F2F3BF-801E
   Revision: 00002001    Serial number: 0157982639
   Coding: 013B062020B930808420053280000000
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34804009683802
   VCID: 7AAD0E207CDBD6A7D09-802E
   Part No SW: 8K0 959 792 N    HW: 8K0 959 792 N
   Component: TSG BF        H12 0357
   Revision:             Serial number: 0000013241116
   Coding: 011002204C01440004
   VCID: 4ACD9EE06CBB8627009-801E
   Revision: 00000003    Serial number: 00000001017958
   VCID: 3431E0181E3FE0D74A5-8060
                    Fault Status: 11101101
                    Reset counter: 25
                    Mileage: 137600 km
                    Date: 2019.05.01
                    Time: 09:54:34
                    Voltage: 14.70 V
                    Count: 58
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Part No: 8K0 907 357 D
   Coding: 0000006
   VCID: 3635DA100443F2C7741-8062
   Part No SW: 4G0 035 061 P    HW: 4G0 035 061
   Component: Radio U DAB   H52 0151
   Revision: AB001007    Serial number: 232IT0B7500086
   Coding: 010103010000000001
   VCID: 2A0DFE60CCFBA627E09-807E
   Part No SW: 8T2 035 652 N    HW: 8T2 035 652 D
   Component: B-BN-EU       H61 0191
   Revision: --------    Serial number: 305IP0B7530205
   Coding: 01010106010581ED01000F0E000000030000
   VCID: 41DFB9CC518D457FD13-8014
   Subsystem 1 - Part No SW: 8T0 919 604     HW: 8T0 919 604
   Component: DU6 Basic  H42 0098
   Serial number: 9465I50B0369839
   Subsystem 2 - Part No SW: 8T0 919 609     HW: 8T0 919 609
   Serial number: 00000000934745
03175 - Invalid Data Set
            000 -  -
                    Reset counter: 25
                    Mileage: 137600 km
                    Date: 2019.05.01
                    Time: 09:54:36
                    Voltage: 14.60 V
   Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
   Component: TSG HL        H11 0357
   Revision:             Serial number: 0000013554417
   Coding: 010002204001240004
   VCID: 45D7ADDC45A5695FEDB-8010
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B23CB2433612FAF8BF-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H52 0330
   Serial number: 8R0827852B
   Component: TSG HR        H11 0357
   Revision:             Serial number: 0000013554423
End----------(Elapsed Time: 01:43, VBatt start/end: 14.5V/14.4V)-----------
