Transmission Issues (02E DSG)
loganlj2
C?ID=361442
Wednesday,08,May,2019,16:36:34:51346
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
Mileage: 165680km-102948mi   Repair Order:
Chassis Type: 1F (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 26 42 44 46 52 56 62 65 72
Mileage: 165680km-102948miles
   Part No SW: 1Q0 907 115 E    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0H23NS849
   Coding: 041C010A1C070160
   Shop #: WSC 00020 790 00000
   VCID: 2E050C5E8C1BCC573C1-807A
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 008 -
                    Fault Status: 01101000
                    Mileage: 165595 km
                    Time: 06:28:13
                    RPM: 3735 /min
                    Load: 13.3 %
                    Speed: 5.0 km/h
                    Temperature: 90.0°C
                    Temperature: 31.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.097 V
               P0300 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Mileage: 165609 km
                    Time: 07:35:46
                    RPM: 1134 /min
                    Load: 41.6 %
                    Temperature: 27.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.589 V
000770 - Cylinder 2
               P0302 - 001 - Misfire Detected - Intermittent
                    Mileage: 165609 km
                    Time: 07:35:52
                    RPM: 1210 /min
                    Load: 43.1 %
                    Temperature: 27.0°C
                    Temperature: 33.0°C
                    Voltage: 14.097 V
000772 - Cylinder 4
               P0304 - 008 - Misfire Detected - Intermittent
                    Mileage: 165609 km
                    Time: 14:02:25
                    RPM: 1136 /min
                    Load: 31.0 %
                    Temperature: 34.0°C
                    Temperature: 30.0°C
                    Voltage: 14.224 V
001152 - Coolant Fan Control Circuit 1
               P0480 - 002 - Electrical Malfunction - Intermittent
                    Mileage: 165609 km
                    Time: 00:07:55
                    RPM: 950 /min
                    Load: 20.0 %
                    Temperature: 60.0°C
                    Temperature: 18.0°C
                    Voltage: 14.478 V
Readiness: 0000 0001
   Part No SW: 02E 300 050 P    HW: 02E 927 770 AM
   Component: GSG DSG AG6     512 1461
   Revision:    51213    Serial number: 00001209082167
   Shop #: WSC 04940 001 00001
   VCID: 1F1BE19AFBB155DF877-804A
17252 - Transmission Fluid Pressure Adaptation at Limit
            P0868 - 001 -  - Intermittent
                    Fault Frequency: 255
                    Reset counter: 2
                    Mileage: 165663 km
19143 - Unexpected / Implausible Mechanical Gear Disengagement
            P2711 - 004 -  - Intermittent
                    Mileage: 165667 km
            P2711 - 002 -  - Intermittent
                    Mileage: 165668 km
            P2711 - 001 -  - Intermittent - MIL ON
                    Fault Status: 10100001
                    Mileage: 165669 km
17115 - Gear 1
            P0731 - 000 - Incorrect Ratio - Intermittent
                    Reset counter: 8
                    Mileage: 165669 km
   Revision: 00H11001
   Coding: 0021218
   VCID: 73B3DD2A27B9A1BF93F-8026
   Part No SW: 1K0 820 047 HJ    HW: 1K0 820 047 HJ
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
   Revision: 00H54000    Serial number: 00000008219300
   Coding: 918C8F0340041562470A00000C00000000395D036200010C000000000000
   VCID: 71BFD7225DA593AF613-8024
   Subsystem 1 - Part No: 1Q1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 020408 022  0501
   Coding: 00038805
   Shop #: WSC 00020
                    Fault Status: 01101100
                    Reset counter: 219
                    Mileage: 165637 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.25 V
                    Reset counter: 219
                    Mileage: 165636 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.20 V
Address 15: Airbags        Labels: 1Q0-959-655.lbl
   Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
   Component: 72 Airbag VW8C      0180
   Revision: 92010018    Serial number: 003B3003DRBS
   Coding: 0014130
   VCID: 3A2D300E405310F7909-806E
   Subsystem 1 - Part No: 1Q0 959 339 A
   Component: BF-Gewichtsens. 007 0003
   Subsystem 2 - Serial number: 3R45F
   Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332SRB406C34D98Aÿ†63
   Subsystem 5 - Serial number: 34D98Aÿ†6342SRB406C3D09FEÿ†63
   Subsystem 6 - Serial number: 3D09FEÿ†6372URB403CF3F0FOÿ†63
   Subsystem 7 - Serial number: F3F0FOÿ†6382URB401371DFFHÿ
   Subsystem 8 - Serial number: 71DFFHÿ
   Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
   Coding: 0010041
   VCID: 77ABE93A33C1CD9FAF7-8022
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No SW: 1Q0 920 974 B    HW: 1Q0 920 974 B
   Component: KOMBIINSTRUMENT VDD 2216
   Revision: V0002000    Serial number: VWX7Z0H23NS849
   Coding: 0023203
   Shop #: WSC 01023 444 76478
   VCID: 33331D2A6739E1BF53F-8066
   Part No SW: 1K0 907 530 P    HW: 1K0 907 951
   Component: J533__Gateway   H16 0192
   Revision:   H16       Serial number: 2500K08313032E
   Coding: ED807F270012025000
   VCID: 34311E366237E6874A5-8060
   Part No SW: 1Q0 919 965     HW: 1Q0 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 1350208TKV9902
   VCID: 79AFEF0205D5DBEFD93-802C
   Component: IMMO            VDD 2216
Address 26: Auto Roof        Labels: 1Q0-959-255.clb
   Part No SW: 1Q0 959 255 D    HW: 1Q0 959 255 D
   Component: Verdecksteuergeraet 0824
   Revision: 0033100M    Serial number: 080700719
   Coding: 0655364
   VCID: 392F2F0245551BEF993-806C
   Part No SW: 1Q0 959 701 E    HW: 1Q0 959 701 E
   Component: Tuer-SG         006 1211
   Coding: 0001207
   VCID: 3635243E744BF497741-8062
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   VCID: 35372332694DFF8F7DB-8060
   Coding: 13908A800186083F2C04040FB0080E0488DC00
   VCID: 04518EF672179607BA5-8050
   Part No SW: 1Q0 959 702 E    HW: 1Q0 959 702 E
   Coding: 0001206
   VCID: 372B293A73410D9F6F7-8062
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 C    HW: 1K0 035 161 C
   Component: Radio DE2       015 0019
   Revision: 00015000    Serial number: VWZ4Z7H6332787
   Coding: 0040402
00857 - CD Changer Unit (R41)
   Part No SW: 1Q0 959 703 A    HW: 1Q0 959 703 A
   Component: Tuer-SG         006 1301
   Coding: 0000128
   Shop #: WSC 00020 790 1012544
   Coding: 0100101
                    Reset counter: 216
                    Mileage: 165636 km
                    Time: 02:32:52
   Part No SW: 1Q0 959 704 A    HW: 1Q0 959 704 A
   Coding: 0000128
End----(Elapsed Time: 01:23, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Controller Software Versions:
ECU 1 = Engine        0020
ECU 2 = Auto Trans        1461
ECU 3 = ABS Brakes        0101
ECU 4 = Auto HVAC        1010
ECU 5 = Cent. Elect.        2202
Sub ECU 5 > 1 = Cent. Elect.        0501
ECU 6 = Airbags        0180
Sub ECU 6 > 1 = Airbags        7000
ECU 7 = Steering wheel        0101
ECU 8 = Instruments        Labels:
ECU 9 = CAN Gateway        0192
ECU 10 = Position Sensing        00
ECU 11 = Immobilizer        2216
ECU 12 = Auto Roof        0824
ECU 13 = Door Elect, Driver
ECU 14 = Steering Assist        190
ECU 15 = Central Conv.        0221
Sub ECU 15 > 1 = Central Conv.        d
Sub ECU 15 > 2 = Central Conv.        d
Sub ECU 15 > 3 = Central Conv.        d
ECU 16 = Door Elect, Pass.        1
ECU 17 = Radio        0019
ECU 18 = Door, Rear Left        130
ECU 19 = Tire Pressure        0450
ECU 20 = Door, Rear Right        13
I have a 2008 VW EOS 2.0L DSG. ABout a year ago, my car starting acting up showing the following symptoms when the car got up to highway speeds:
*Heavy Downshift - more of a big clunk
*PRNDS Lights Flashing
*Car going into transmission limp mode
Looking back at it, there were some other odd things that were happing with the car. It shifting sort of clunky going from P, and if you were to put it in reverse,it would roll forward a bit before R engaged.
I ended up parking the car and getting a new one because I didn't have time to deal with and and had just started a new job.
About a week ago, I decided to try and fix it. I bought a Hex-V2 and did the basic maintenance on it. I test drove it ~ 50 miles on back roads and didn't see the issue i had before (I had cleared codes before parking it) so I insured and registered it.
On the way to do emissions today. About 8 miles into the drive, the symptoms started occurring again. I turned right around and drove back home in limp mode at ~35 mph. When i pulled into my driveway, the car stuttered forward and completely powered down, smoke started billowing from the hood.
I tried starting the car again and there's just a knock and absolutely nothing else. Upon inspection of the fluid, it seems to be green and color and trails back about 100 feet. From what I can see, it looks like the leak came from the Mechatronics breather cap? I've attached a picture.
I had originally thought the issue with the car was a mechitronic issue and the mech needed to be replaced (before I had parked it.) Now i'm thinking i completely screwed the pooch and destroyed the transmission by driving it a few miles in limp mode. I've attached the VCDS reading from after today with the ignition on (but obviously not the engine because it won't turn.)
Very interested in what others have to say, and appreciate your input.
dillenger1
C?ID=368041
"basic maintenance" on the car?
South Molton, UK
Oil, Brakes, tire rotation, wipers & fluid - just a few basic things.
I was always told to remember the acronym POWER
Petrol (sorry gasoline)
Oil
Water
Electrics (i.e. battery)
Rubber (i.e. tires)
