2014 Passat B7 CFFB DTC 2650/U0415 without any other DTC
MartinsX
Riga, Latvia
C?ID=268515
Glow plug light is flashing, CCS does not work, this is the only one DTC. After clearing it comes back after restarting ignition. Car is stock, without any modifications, how far I know. Any ideas what direction to dig, what parts or circuits to check etc are welcome.
Wednesday,08,May,2019,20:51:05:32442
VCDS Version: 18.9.1.0
VIN: WVWZZZ3CZEE138371   License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4C 4F 52 53 56
          61 62 72
VIN: WVWZZZ3CZEE138371   Mileage: 105180km-65355miles
   Part No SW: 03L 906 018 PR    HW: 03L 907 309 AE
   Component: R4 2.0l TDI   H28 9979
   Revision: 41H28---    Serial number: 00000000000000
   Coding: 00190012042401080000
   Shop #: WSC 33468 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018PR 003007
   ROD: EV_ECM20TDI01103L906018PR.rod
   VCID: 0919F71BA847F8028A-805C
2650 - Implausible Data Received from ABS Control Module
          U0415 00 [167] - -
                    Mileage: 105186 km
                    Date: 2019.05.08
                    Time: 19:46:57
                    Engine speed: 0.00 /min
                    Coolant temperature: 35 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 12.280 V
                    Limitation: accelerator pedal: 126.7 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 42
                    selected gear-Bits 0-7: 0
   Part No SW: 3AA 614 109 AQ    HW: 3AA 614 109 AQ
   Component: J104   C2 450M VD07 0030
   Revision: --H07---    Serial number: 00000008010088
   Coding: 0003504
   Shop #: WSC 05311 000 00001
   VCID: 7CF79ECF3F95DDAA81-8028
   Part No SW: 3AA 907 044 BQ    HW: 3AA 907 044 BQ
   Component: Climatronic   H05 0505
   Revision: 00001K02
   Coding: 061400C803
   Shop #: WSC 00015 115 00001
   VCID: 000FEA3F9B7DB94ADD-8054
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 N    HW: 3AA 937 087 N
   Component: BCM PQ47 M    422 0475
   Revision: BA422001
   Coding: 0008000000000000009800805000006403010088424D85606480C7200041
   VCID: 45813B2BCCDF5C62AE-8010
   Subsystem 1 - Part No SW: 3AB 955 419 A    HW: 3AB 955 419 A  Labels: 1KX-955-119.CLB
   Component: WWS471 100314  24  0654
   Coding: 044D9D
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0018
   Revision: --------    Serial number: 28231410102213
   Coding: 108002
   ASAM Dataset: EV_EPHVA18VW47X0000 001006
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 3F8D29C3A60306B2E4-806A
   Component: J234__107 VW10 HI   2518
   Revision: 27019000    Serial number: 003L7P7HFXBA
   Coding: 0012343
   Subsystem 1 - Serial number: 6332MTS665490874
   Subsystem 2 - Serial number: 6342MTS633710884
   Subsystem 3 - Serial number: 6351HTS6O6RRQCKJ
   Subsystem 4 - Serial number: 6361HTS6CH9TQCKJ
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C9 953 501 DB    HW: 5K0 953 569 AT
   Component: LENKS.MODUL   0140
   Revision: FF010042    Serial number: 20140309100303
   Coding: 5180250000
   VCID: 6CD7AE8F87F54D2A11-8038
   Part No SW: 3AA 920 870 P    HW: 3AA 920 870 P
   Coding: 161F01
   Shop #: WSC 05314 115 00001
   Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1642
   Revision:   H55       Serial number: 060414F1003846
   Coding: 462006
   Shop #: WSC 05314 000 00001
   VCID: 7BF59DD3FA9BDA9288-802E
   Part No SW: 3AA 959 433 B    HW: 3AA 959 433 B
   Component:    IMMO         043 0407
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 387F42DF4B2D318A25-806C
   Revision: A1001003    Serial number: 7666074631
   Coding: 020100
   VCID: 2B556D934A7B8A1258-807E
   Part No SW: 3C8 035 279 F    HW: 3C8 035 279 F
   Component: RNS315-EU   H77 0410
   Serial number: VWZAZ2P0210389
   Coding: 040004110400110000011301
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 2E5364877169FF3A7F-807A
   Component: EUR_W_V5  0055
   Part No SW: 3AA 959 701     HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0533
   Revision: 13110009    Serial number: 0008315074
   Coding: 0204B5
   Shop #: WSC 05311 115 00001
   VCID: 74E7B6EFDFC595EAC9-8020
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  005 0503
   Serial number: 00000003930193
   Coding: 010490
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.309 1401
   Revision: 1BH04739    Serial number: 00140940362101
   Coding: 0000258
   VCID: 41892F3B18F7704292-8014
   Component:    KSG PQ47 ELV 043 0645
   Coding: 0291028052830E76340494157C084F0B605C00
   Component: EZE_2         H55 1642
   Coding: 00000008
   VCID: 6FEDB983BEE3B63234-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0004
   Part No SW: 3AA 959 702     HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0533
   Revision: 15110009    Serial number: 0008404183
   Coding: 0204B4
   ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
   VCID: 75E18BEBD4BF8CE2FE-8020
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 704 A    HW: 3AA 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  005 0503
   Serial number: 00000003931649
   Coding: 010490
   Revision:   H19       Serial number: 00000002138466
   Coding: 0022167
   VCID: 36634CE74139C7FA37-8062
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AM
   Component: Batt.regelung H55 1642
   Coding: 030F1859
   VCID: 71E9BFFBA8D7A0C222-8024
   Component: J367-BDM  H07 0180
   Serial number: 31086L10061491996634
End-------------------------(Elapsed Time: 03:10)--------------------------
That one is a head scratcher. Even the extended info for that fault has nothing more than, "Invalid Data Received FromAnti-Lock Brake System Control Module". But no clue why.
MartinsX
Riga, Latvia
C?ID=268515
There are couple TPI's for gasoline engines, according those TPI's the ECU FW update should solve the problem. Can't find TDI related similar TPI.
golfi_vend
Tartu, Estonia
C?ID=195131
SW is already quite high with tdi-fix.
I would look into undocumented adp channels that need to be confed according to base engine pr code. Unfortunitely B7 abs doesn't have them in label file. If i get a chanche I will look them up from my memos.
MartinsX
Riga, Latvia
C?ID=268515
Thanks, golfi_vend, will wait for some news from You. Have located used ABS module, will have it handy for testing next week. BTW AQ module production is cancelled, it is superseded by BM already in 2012, car is MY2014 :confused:
golfi_vend
Tartu, Estonia
C?ID=195131
A021,0,Overboost (OB) / Overload Operation
A021,5,Overboost (OB) / Overload Operation
A021,6,The Overboost Level specifies how the Hydraulic System will behave in
A021,7,an Overload Sitation. Check the Data Plate for the Engine Type/PR-Code.
A021,8,
A021,9, 4 = PR-DB0/D4L/D4X/D31/D42
A021,10,7 = PR-D34/D38/D48/D67/D91/D93/D94/D2D/D2L/DE2/M92
A021,11,X = Other engines
A021,11,
A061,0,Vacuum Level / Hydraulic Brake Booster (HBO/HBV)
A061,1,Brake Booster
A061,2,Brake Booster,Status
A061,5,Vacuum Level / Hydraulic Brake Booster (HBO/HBV)
A061,6,The Vacuum Level specifies how the Hydraulic Brake Booster.
A061,7,is engaged. Check the Data Plate for the Engine Type/PR-Code.
A061,9,0 = PR-D2D/D2L/D4X/D4L/D34/D38/D42/D48/D67/D91/D93/D94/DB0/DE2/M92
A061,10,1 = PR-D4X(With 1AS)
A061,11,1 = PR-D4L/D42(With 1AS)
A061,12,1 = PR-D2L/D2D/D67(With 1AS)
A061,12,X = Other Engines
Maybe some of them are existing in original label file, but I know I added some to my own file.
If checking the Adp channels in 03 doesn't resolve this you might want to re-code 01 and 03 back to the original values.
golfi_vend
Tartu, Estonia
C?ID=195131
Can't see nothing wrong with ABS
MartinsX
Riga, Latvia
C?ID=268515
Sorry for giving feedback so late. This issue was solved a lot of months ago. The car just visited my workshop with another problem and I remembered that I haven't told the Forum what was the problem :confused:
I found an additional aftermarket immobilizer sitting on powertrain CAN and messing up data exchange... Customer didn't told me that he have such device installed... :banghead:
morski
Cheshire UK
C?ID=90186
Ghost immobiliser by any chance?
