Disable Start/Stop system MQB
Amarton
Europe - Hungary
C?ID=338434
Hello.
I tried this script:
StartVCDS()
OpenUnit("19")
    TestComponent("GW MQB",1)
    TestAdpChannel("Start/stop start voltage limit","12.1", 1)
    ChangeAdpChannel("Start/stop start voltage limit", "12.1")
CloseUnit()
but not working.
This is the error message:
Desired value is not active in adaptation channel. Script is cancelled.
golfi_vend
Tartu, Estonia
C?ID=195131
Because You're testing adp channel to have value 12.1. That it's not plausible.
^^^Golfi_vend: are you absolutely sure? I had understood that the maximum voltage for this adp channel was 12.1V - albeit it's not necessary to use the MAX value for this tweak (12V would be perfectly OK)
Amarton
Europe - Hungary
C?ID=338434
I don't think this is the failure.
If I try 12, 9, 8 the results are same.
golfi_vend
Tartu, Estonia
C?ID=195131
Why then You don't change it manually and not with a script?
Issue here is that Your script checks it to have a value 12.1 before even applying the 12.1 value.
See it how it's wrong? - Check to have 12.1 then change to 12.1.
hadez16
C?ID=289891
Correct!
This line of code tests if the current value is already 12.1. If not, exit with an error.
Amarton
Europe - Hungary
C?ID=338434
This would be a part of my script. I would like to set the all car to default and I would like to make another script with all possible coding.
If I comment the Test line and run the script an alert window appears with questions (workshop code or something) and the script finishes with error (timeout)
hadez16
C?ID=289891
Missing Workshop code is not covered by the logics of the scripter. Ouch!
As this dialog window is not planned in the sequence, it exits.
hadez16
C?ID=289891
Stop. Now I get your point.
You have to set the third parameter of TestAdpChannel to 0 instead of 1.
0 means that the whole untit will be skipped if the condition isn't fullfilled instead of exiting with an error.
But that doesn't solve the missing workshop code issue.
Spacewalker
Poland
C?ID=159607
I did in my MK7 in gateway - Start Stop voltage limit ......from 12V to 7V and SS not work any longer
Amarton
Europe - Hungary
C?ID=338434
I also can it manually but with the script not working. The VCDS ask a question and this script could not handle it.
hadez16
C?ID=289891
Yes. You first need to handle the missing workshop code manually in order to enable coding by script in the future.
Amarton
Europe - Hungary
C?ID=338434
My workshop code is default (00000).
What to fix?
If I rewrite, will it affect the future? I don't want the workshop code to overwrite the original value.
hadez16
C?ID=289891
What to fix?
Try to change something manually (without the scripter) and press "No" when the dialog window about the workshop code appears.
If it works, then other codings can be done also via script and without any dialog anymore.
Pressing "Yes" will write a new workshop code into the unit. Check the manuel or the search function in the forum for this topic.
Amarton
Europe - Hungary
C?ID=338434
If I press NO, I get an error message. Invalid code (I tried it without script). Only YES button working and the WSC remains the original.
What happens if I set the car manufacturer WSC in VCDS? For example: WSC 73430 031 00207
The uninitialized control module warning is explained at the bottom of this page: Adaptation or Long Adaptation Screen. Most users just click [Yes] so the default non-zero numbers are entered.
The User Interface and Identification tab is located on the [Options] screen and this section explains those values: Options Screen > User Interface and Identification
  • If you want VCDS to enter the same values every time a Coding, Adaptation or similar operation is sent to a module you change the [Options] screen settings and [Save]. Delete config file and close will clear your saved values if you want VCDS to revert back to stealth mode at a later time.
  • If you do NOT want VCDS to overwrite the default values each time you can change from an all ZERO WSC, Importer or Equipment value manually directly from the Coding or Adaptation screen before clicking Do it or Save. However, if a module already has non-zero numbers like this:
    .. you cannot change them directly from the Coding or Adaptation screen. Instead, you would need to use option #1 (change the [Options] screen settings, Save, restart VCDS and change the channel in question) to change the numbers.
