Passat B8 basic settings (ABS / MK100IPB)
eden
Slovenia
C?ID=217860
After installing new tacho in my Passat B8 i receive more error messages. I install back old tacho and this mesages stay.
I give in ABS coding old coding and now i must to make basic settings for sensors. Please can you tell me how ?
Tnx
Wednesday,08,May,2019,07:46:37:34340
VCDS Version: 18.9.0.2 (x64)
VIN: WVWZZZ3CZFE447826   License Plate:
Mileage: 161278km-100213mi   Repair Order: menjava stevca
Chassis Type  3C-VW48 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 65 6C BB
          BC CA
VIN: WVWZZZ3CZFE447826   Mileage: 161278km-100213miles
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ES    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H21 1989
   Revision: B5H21---
   Coding: 01190012034405083000
   Shop #: WSC 29121 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906026ES 002002
   ROD: EV_ECM20TDI01104L906026FK.rod
   VCID: 7F0B74BAE67B58B2AC-802A
17158 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 161278 km
                    Engine speed: 0.00 /min
                    Coolant temperature: 67 °C
                    Intake air temperature: 49 °C
                    Voltage terminal 30: 12.660 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
                    Acceleration: 0.000 m/s²
   Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
   Component: ESC           H42 0609
   Revision: 00000000    Serial number: 63534000003493
   Coding: 0EEC6A8F34240B73077F060241C94970562CD0E0608292F11460F0084009
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 3D774EB2ACF78AA2FE-8068
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 247
                    Date: 2019.05.07
                    Time: 23:09:37
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 247
                    Date: 2019.05.07
                    Time: 23:09:37
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 247
                    Date: 2019.05.07
                    Time: 23:09:37
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 247
                    Date: 2019.05.07
                    Time: 23:09:37
8299 - Databus
                    Reset counter: 247
                    Date: 2019.05.07
                    Time: 23:09:37
33000 - Longitudinal Acceleration
          C10B1 29 [137] - Signal Implausible
                    Reset counter: 247
                    Date: 2019.05.07
                    Time: 23:09:37
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0357395923
   Coding: 000F3E0603
   Shop #: WSC 05311 115 00300
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   ROD: EV_KessyHellaMQBAB_VW48.rod
   VCID: 77FB9C9ACE4B60F2E4-8022
   Part No SW: 5G1 907 044     HW: 5G1 907 044
   Revision: 00001K10
   Coding: 11020114202100012015504C00101802
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 65C7C6D264E7E26246-8030
   Air quality sensor:
   Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86580301151324
   Coding: 00910C46C24102FF43C0400400180708189E000000000000000000000000
   Shop #: WSC 12345 123 61029
   ROD: EV_BCMBOSCH_014.rod
   VCID: 7DF78EB2EC774AA2BE-8028
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    141213  042 0607
   Serial number:         141219085831
   Component: RLHS  037 0059
   Serial number: S3Y16M05D12H12M50S47
   Coding: 028877
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 07 11 2014  00000968
   Sun Roof:
   Part No SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0053
   Revision: --------    Serial number: 39311500205593
   Coding: 0071151001
   Shop #: WSC 05311 115 00093
   ROD: EV_EPHVA18AU3700000_002_VW48.rod
   VCID: 40893746DB05E74A95-8014
13637426 - Databus
                    Reset counter: 247
                    Mileage: 161276 km
                    Date: 2019.05.07
                    Time: 23:02:35
   Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Component: ACC BOSCH MQB H04 0130
   Coding: 2A40600110FFC428949C804C
   ASAM Dataset: EV_ACCBOSCHVW48X 001007
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3363688A9AB34CD218-8066
0822 - Databus
                    Reset counter: 247
                    Mileage: 161276 km
                    Date: 2019.05.07
                    Time: 23:03:05
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 12.0 V
2101 - Databus
                    Reset counter: 247
                    Mileage: 161276 km
                    Date: 2019.05.07
                    Time: 23:03:05
2068 - Databus
                    Reset counter: 247
                    Mileage: 161276 km
                    Date: 2019.05.07
                    Time: 23:03:05
   Part No SW: 3Q0 959 655 AF    HW: 3Q0 959 655 AF
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R2P06CC89
   Coding: 88CCC000000000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 020DFD4E9589355AC3-8056
   Subsystem 1 - Part No SW: -----------    HW: 454 000 401 15
   Serial number: 3576U000000E8C70721G
   Subsystem 2 - Part No SW: -----------    HW: 454 000 301 15
   Serial number: 3586U000000972707211
   Subsystem 3 - Part No SW: -----------    HW: 454 800 701 15
   Serial number: 3516RA0E68E05000000D
   Subsystem 4 - Part No SW: -----------    HW: 454 800 801 15
   Serial number: 3526RE8348B05000000A
   Subsystem 5 - Part No SW: -----------    HW: 454 800 301 15
   Serial number: 3556V36124A05000000
          B13BC F2 [008] - No function
                    Mileage: 161276 km
                    Date: 2019.05.07
                    Time: 00:00:57
   Part No SW: 5Q0 953 569 B    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0205
   Revision: --------    Serial number: 20160203500079
   Coding: 0400
   Shop #: WSC 46287 002 1048576
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001009
   ROD: EV_SMLSVALEOMQBLRH.rod
   Part No SW: 3G0 920 751     HW: 3G0 920 751
   Component: KOMBI         308 4311
   Coding: 0BA501902E800008008DFE051800000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009043
   ROD: EV_DashBoardVDDMQBAB_VW48.rod
   VCID: 62CDDDCE75C9955AA3-8036
16776967 - Databus
                    Reset counter: 32
                    Mileage: 161276 km
                    Date: 2019.05.07
                    Time: 00:00:43
   Revision: --------    Serial number: 19121410803720
   Coding: 030300044F087300FF00025A080F00010001070000000000000000000000
   ROD: EV_GatewConti_011_VW48.rod
   VCID: 72EDAD8EA52905DAD3-8026
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29160000008240116013
   Coding: 2C0000
   Serial number: 2895365303
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 1712201400010411
   Serial number: 14000315613005
   Coding: 0000000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71EFA282A02F3EC22A-8024
   Serial number: 221214BLL01893
   Coding: 003F1B205400020000001000
   VCID: 428D3D4ED509F55A83-8016
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    203 2033
   Revision: 00000000    Serial number: 0000114805
   Coding: 01000010005000
   Shop #: WSC 00015 115 00300
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008.rod
   VCID: 3B7340AAB2E38492C0-806E
   Serial number: 161214BLG08549
   Coding: 003F1120D400020000001000
   VCID: 418F3242D00FEE429A-8014
   Component: AFS-ECU       H01 0110
   Coding: 039A00000F200200
   Shop #: WSC 64272 001 1048576
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   VCID: 3F8B34BAA6FB98B2EC-806A
   Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 0001
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 0001
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
   Part No SW: 3Q0 035 864     HW: 3Q0 035 864
   Component: MU-S-N-ER     H10 0140
   Serial number: VWZAZ2P8504048
   Coding: 02840101FF0000001111000100090A001F01008401200100CD
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 6ED5B9FEB111213A37-803A
   Component: ABT_High  H42 0022
   Serial number: VWZ8Z9M2300ME3
   Subsystem 2 - Part No SW: V03 825 254 A    HW: -----------
   Component: ECE DL1 19/20  --- 1115
7206 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 32
                    Mileage: 161276 km
                    Date: 2019.05.07
                    Time: 00:07:14
                    Voltage terminal 30: 12.5 V
                    BAP-BAP_Function_ID: 02
   Serial number: 30000000005415
   ROD: EV_RDKBERU30_006_VW48.rod
   VCID: 34616B969FBD4BEA01-8060
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H07 0100
   Coding: 0184010142002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
   ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
   Part No SW: 5Q0 959 595 D    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0028
   Serial number: 181214BLH19573
   Coding: 000E01200100020000001000
   VCID: 44813B56CF1DFB6AB1-8010
   Component: TSG HBFS      020 0028
   Serial number: 181214BLH19576
Address CA: Sunroof
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
End-------------------------(Elapsed Time: 05:37)--------------------------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
You can use drop-down menu in [Basic Setting], similar procedure see here.
eden
Slovenia
C?ID=217860
tnx for answer.
its basic settings the same for MQB vihicle ? my car is Passat B8 2015...
tnx
DrPeter
16.4905° S, 151.7375° W
tnx for answer.
tnx
Like Boki Ar said, it is not exactly the same procedure but should be similar for these Basic Settings in the [03]:
- Basic setting for brake pressure sensor
- Basic setting for inlet/cut-out valves
- Basic setting of ESP sensor unit
(You will need to use the Security Access code [40168] to enable the Basic Setting for each Basic Settings procedure performed and VCDS will have a pull down menu in the Basic Setting page)
This next part is different:
- The Basic Settings of the G85-Steering Angle Sensor should be performed in the [44-Steering Assist] controller.
Have a look at this forum post,
MQB (Mk7 Golf) Steering Angle Sensor (G85) Calibration in 44 - Steering Assist
Let us know how this works for you, hope this helps,
drpeter
No, MK100IPB is UDS, MK60EC1 is not.
I don't recall seeing a detailed procedure for MK100IPB yet.
eden
Slovenia
C?ID=217860
drpeter
Tnx for that drpeter, in 03 ABS Brakes for my car is only this:
Is not the same so we Golf 1K. For which valves is this basic settings ? "Basic setting for inlet/cut-out valves"
Now i have only the problem with this:
Address CA: Sunroof
Sunroof not working.Why is this not compatible ?
Latest autoscan
Wednesday,08,May,2019,22:40:18:34340
VCDS Version: 18.9.1.0 (x64)
VIN: WVWZZZ3CZFE447826   License Plate: MB-JP
Mileage: 161371km-100271mi   Repair Order: po menjavi
          BC CA
VIN: WVWZZZ3CZFE447826   Mileage: 161371km-100271miles
   Revision: B5H21---
   VCID: 7F0B74BAE67B58B2A4-802A
   VCID: 3D774EB2ACF78AA2F6-8068
8299 - Databus
                    Reset counter: 250
                    Date: 2019.05.08
                    Time: 22:34:11
   Coding: 000F3E0603
   VCID: 77FB9C9ACE4B60F2EC-8022
   Revision: 00001K10
   VCID: 65C7C6D264E7E2624E-8030
   Air quality sensor:
   VCID: 7DF78EB2EC774AA2B6-8028
   Coding: 028877
   Sun Roof:
   Coding: 0071151001
   VCID: 40893746DB05E74A9D-8014
   VCID: 3363688A9AB34CD210-8066
   VCID: 020DFD4E9589355ACB-8056
   Coding: 0400
   VCID: 62CDDDCE75C9955AAB-8036
   VCID: 72EDAD8EA52905DADB-8026
   Coding: 2C0000
   Analog clock:
   VCID: 71EFA282A02F3EC222-8024
   VCID: 428D3D4ED509F55A8B-8016
   VCID: 3B7340AAB2E38492C8-806E
   VCID: 418F3242D00FEE4292-8014
   VCID: 3F8B34BAA6FB98B2E4-806A
   Coding: E02400
   Coding: E02400
   Coding: E02400
   Coding: E02400
   VCID: 6ED5B9FEB111213A3F-803A
   VCID: 34616B969FBD4BEA09-8060
   VCID: 44813B56CF1DFB6AB9-8010
Address CA: Sunroof
End-------------------------(Elapsed Time: 05:10)--------------------------
Address 03: DTCs cleared
Tnx for all
Because VAG started using a different addressing scheme for some control modules that the HEX+CAN isn't compatible with. However, I'm somewhat surprised to see this on a MY2015 car. I thought such modules were only being used on MY2016 and newer cars.
NEtech
Denmark
C?ID=56995
Interesting, it seems this [CA] 4M0 907 594 is used from 2015 on VW Passat (3C).
It could look like 4M0 907 594 B is old type controller, which old VCDS interface can communicate with.
After reviewing this German scan, in addition to a few in our collection created with a HEX-V2 or HEX-NET, and comparing part numbers it looks like that CA module is truly using a UDS long address. I'll keep this thread in mind if we have anything to add - but we are reasonably confident the OP would need a current generation interface.
When the time comes, the Why Upgrade? thread may be helpful but upgrading through PCI directly would be best since they assembled your HUC interface and ours don't ship with German VCDS activation. I wouldn't upgrade for access to CA alone but you may be interested in some of the new features such as Extended UDS Fault Code Information, Experimental Coding and Whole Vehicle Maps.
eden
Slovenia
C?ID=217860
Tnx for your answers. I now read this module with VCP and there is DTC for "basic settings". So i must now make basic settings for roof window. Have someone procedure for this ?
Tnx
Based on what we know about previous generation (J245) sunroofs/(J394) sliding shades and modern MQB (Mk7) based door module window Basic Settings I'd try the following options in VCDS:
[*IDE09818*] Sunroof: standardization
[*IDE09823*] Roof roller blind: reset standardization
I don't know if VCP is going to offer those exact groups.
eden
Slovenia
C?ID=217860
tnx Dana,
So i must buy new VCDS for read Sunroof module :D
Ok tnx for helping...
tnx Dana,
So i must buy new VCDS for read Sunroof module :D.
Ask your original supplier in Germany for upgrade options. Alternatively, used (but genuine!) HEX+CAN interfaces bring a very good price on eBay.
