Hi.
My 2010 Audi A3 1.6 Cr Tdi has the Dpf warning light showing on my dash, and has since gone into limp mode.
I have read the WIKI page for Dpf regeneration for my model and got all the prerequisites to start a 'service regeneration of the particle filter' in 04 basic settings.
When I press [Go!] it comes up with 'FINISHED CORRECTLY - NO DISPLAY'.
The Ash volume is showing as 35.6g and Soot Mass as 24.9g in SHOW MEASURED DATA.
Is my only option to ' Emergency Regeneration whilst Driving' in Adaptation ?? and will it be safe with these values ??
Autoscan Log -
Thanks,
Chris.
Autoscan Log -
Tuesday,07,May,2019,08:48:22:09880
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: TRUZZZ8PXA1010894 License Plate:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 26 42 44 46 47 52 56 61 62 72
77
VIN: TRUZZZ8PXA1010894 Mileage: 116480km-72377miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 M HW: 03L 906 023 L
Component: 1,6l R4 CR td H23 8790
Revision: --H23--- Serial number: AUX7Z0J3FN8010
Coding: 00114036030501080000
Shop #: WSC 01236 785 00200
ASAM Dataset: EV_ECM16TDI02103L906023M 003009
ROD: EV_ECM16TDI02103L997557R.rod
VCID: 303911DD7AA13A072ED-8064
16848 - Diesel Particulate Filter
P2458 00 [173] - Regeneration Duration
Mileage: 116467 km
Date: 2019.05.06
Time: 12:35:45
Engine speed: 783.00 /min
Normed load value: 19.6 %
Coolant temperature: 82 °C
Intake air temperature: 28 °C
Voltage terminal 30: 14.795 V
Particle filter: soot mass measured-MASS_SOOT_PHY_PF: -5.48 g
Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 9.62 g
Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H: 554 km
Counter for regeneration time of diesel particle filter-T_INT_RGN_ACT_INI_PF_ENVD_H: 12596.0189 s
Particle filter: difference pressure-DIP_PF: 0.00 hPa
Particle filter: offset for differential press.-DIP_PF_AD[0]: 1.41 hPa
Service regeneration: Release conditions 3-FRF_STATE_RGN: 9
Readiness: 1110 1000
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 13422012092300FAC81304ED901D0091380800
Shop #: WSC 01236 758 00200
VCID: 7AADF3F5ECDD3057D09-802E
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0150
Revision: 000356 Serial number: 8P0820043BM
VCID: 78A9E9FDDED12247A6D-802C
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 105 0575
Revision: 00105 AK
Coding: 0E000A0FB205F140207060E02000014C531A5CAA0100C12AE4008F000055
VCID: 323D1BD5742D0817589-8066
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
Subsystem 2 - Part No: 8P7 951 177
Component: DWA-Sensor H0 H03 0040
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 G HW: 8P0 919 475
Component: PARKHILFE 4K H06 0120
Revision: 11001001 Serial number: 93641009706782
VCID: 42DD4B15C48DB897C89-8016
Address 15: Airbags Labels: 8P7-959-655.clb
Part No SW: 8P7 959 655 HW: 8P7 959 655
Component: SR Airbag 9.43 H01 0020
Revision: 93H01002 Serial number: 003BS000ZJ0A
Coding: 0021330
VCID: 06559705A42544B7A41-8052
Subsystem 1 - Serial number: 6332DRB409D18697-
Subsystem 2 - Serial number: 6342DRB409D0C726X
Subsystem 3 - Serial number: 63747RB40583A94DZ
Subsystem 4 - Serial number: 63847RB40583C919V
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0003011
VCID: 46D55705E4A584B7E41-8012
Component: E0221 H04 0100
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 J HW: 8P0 920 982 J
Component: KOMBIINSTR. VDO H03 0990
Revision: D0H03005 Serial number: 2243J005023206
Coding: 0004428
Shop #: WSC 12345 123 12345
VCID: 40D9411DC681AA87DED-8014
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H17 0233
Revision: H17 Serial number: 1521J104130013
Coding: E9A07F26100602049101
VCID: 6B83C6B19F8799DF5BF-803E
Revision: D0H03005 Serial number: AUX7Z0J3FN8010
Shop #: WSC 01236 210 01865
Address 26: Auto Roof Labels: Redir Fail!
Part No: 8P7 959 255 B
Component: VSG AUDI A3 H14 0130
VCID: 44D14D0DD299B6A7FA5-8010
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P7 959 801 E HW: 8P7 959 801 E
Component: Tuer-SG H04 0102
Coding: 0131836
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 233 3001
Revision: 00H17000
VCID: 313F14D97D2B330F213-8064
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P7 035 382 C HW: 8P7 035 382 C
Component: AB2 SUBWOOFERBOXH04 0160
Revision: 00003 Serial number: 92159949695479
VCID: 372B2AC1934FED3F6F7-8062
Address 52: Door Elect, Pass. Labels: None
Part No SW: 8P7 959 802 E HW: 8P7 959 802 E
Coding: 0131836
VCID: 45D75009D9A38FAFEDB-8010
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 S HW: 8P0 035 186 S
Component: R Concert2+ H03 0280
Revision: 00H03000 Serial number: AUZ1Z3K6032531
Coding: 0610311
Shop #: WSC 00006 210 83400
VCID: 42DD4B15C88DB897C89-8016
Time Indication: 15
Part No SW: 1K0 907 534 HW: 1K0 907 951
Component: Batt.regelung H17 0233
Revision: -------- Serial number: 1521J104130013
Coding: 0303085A
VCID: 6889B9BD8271B2C736D-803C
Subsystem 1 - Part No SW: 1K0 915 181 E HW: 1K0 915 181 A
Component: J367-BDM H07 0140
Serial number: 00000000005650166103
Part No SW: 8P7 959 811 B HW: 8P7 959 811 B
Component: Tuer-SG H01 0050
Coding: 0131216
Shop #: WSC 01236 785 1012552
Part No SW: 8P7 959 812 B HW: 8P7 959 812 B
Coding: 0131216
VCID: 43D34E11D797B19FC3F-8016
Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
Component: FSE_256x BT H38 0600
Revision: 00000000 Serial number: 00000005188620
Coding: 0001202
VCID: 75B7E0C9C9C35F2FBDB-8020
End----(Elapsed Time: 01:30, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Thanks,
Chris.
