New Member: 2017 Tiguan Auto Hold/Handbrake Issue
niggly60
C?ID=365548
Good evening.
I have been suffering from the dreaded Auto Hold problem for some time. The dealer has been unable/unwilling to resolve the problem- which curiously goes away when I take it in to them!
I know it is not driver error as many others have reported problems on TRocs, Seat Atecas and Tiguans.
It manifests itself in a reluctance to release the handbrake when pulling away (car is manual version), and manouvering using Auto Hold is a nightmare.
I understand that it may be possible to adjust the sensitivity of the Auto Hold, and/or handbrake function using VCDS. Does anyone know the channel and coding required to achieve this- and any security codes required?
Hi and welcome.
Please post an Auto-Scan so people can see exactly how your car is equipped and configured.
niggly60
C?ID=365548
Recent scan here:
Saturday,04,May,2019,15:11:10:03359
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
VIN: WVGZZZ5NZHWXXXXXX   License Plate:
Mileage: 37916km-23559mi   Repair Order:
Chassis Type: 5N-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 22 36 42 44 52 55 5F A5 BB BC
          CA
VIN: WVGZZZ5NZHWXXXXXX   Mileage: 37916km-23559miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 JC    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H24 3023
   Revision: B4H24---
   Coding: 0119001203471D082000
   ASAM Dataset: EV_ECM20TDI01104L906026JC 004002
   ROD: EV_ECM20TDI01104L906026GQ_004.rod
   VCID: 74B02969AE3BFE578A5-8020
17158 - Databus
          U0428 00 [032] - -
28991 - No Communications with NOX Sensor 1
          U029D 00 [032] - -
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 62126000000014
   Coding: 0AEE929A34230B734778070062C94950492CD0E2E046927D34605078C02A4200002F641A1B13111435351919323200
   VCID: 76B41361B847EC47B41-8022
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NA 907 044 K    HW: 5NA 907 044 K
   Component: AC Automat    H35 4003
   Revision: 20K08000    Serial number: 00000B00207067
   Coding: 0012012420211001110510000010112A
   ASAM Dataset: EV_ACClimaPrehVW37X 002014
   VCID: 47CAAEA58F2D25CF1F7-8012
   Subsystem 1 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
   Component: E265KlimaHeck  H02 0201
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001623202154
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F5AF645977DAD0FE77-802A
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 160708  033 0372
   Serial number: 00000001607050306596
   Component: RLHS  042 0105
   Serial number: S5Y16M08D17H05M33S09
   Coding: 00A8DD
   Serial number: 000000000ZY161960GTM
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000066626277
   Part No SW: 3Q0 919 294 A    HW: 3Q0 919 294
   Component: PDC 8 Kanal   H07 0020
   Serial number: 002607167478021
   Coding: 0071451801
   ASAM Dataset: EV_EPHBO18VW3260000 007015
   ROD: EV_EPHBO18VW3260000.rod
   VCID: 372ADE65FFCD554F6F7-8062
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 2A0140C158FF8728749C8065104085
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_001.rod
   VCID: 3B22C255C3E5712F8BF-806E
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0315
   Serial number: 003TDR21RP42
   Coding: 98CCC0C00C0000005C5400CF008800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 107845F9BAE3A2770ED-8044
   Belt Pretensioner left:
   Serial number: 5NC857705C0225Q00552
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 5NC857706C0228Q00087
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 000 508 16
   Serial number: 3570000000010A0D3D1D
   Subsystem 4 - Part No SW: -----------    HW: 480 001 708 16
   Serial number: 3580000000041C449B1J
   Subsystem 5 - Part No SW: -----------    HW: 480 402 208 16
   Serial number: 35100019920F2B2467F6
   Subsystem 6 - Part No SW: -----------    HW: 480 402 208 16
   Serial number: 35200019920F2B22E663
   Subsystem 7 - Part No SW: -----------    HW: 480 402 208 16
   Serial number: 3550001A320F2B23C0F3
   Pedestrian Protection Driver:
   Subsystem 8 - Part No SW: -----------    HW: 480 402 208 16
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001C121DBA0174E3
   Subsystem 9 - Part No SW: -----------    HW: 480 402 208 16
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001A920F2B2602D0
   Pedestrian Protection Center:
   Subsystem 10 - Part No SW: -----------    HW: 480 402 208 16
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001A920F2B2373D/
   Subsystem 11 - Part No SW: -----------    HW: 480 000 908 16
   Serial number: I0M00000000B57354D13
   Subsystem 12 - Part No SW: -----------    HW: 480 000 908 16
   Serial number: I0N00000000D57354D16
   Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20160722500627
   Coding: 0C00
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 41DEB0BDA1091BFFD13-8014
   Part No SW: 5NA 920 791 A    HW: 5NA 920 791 A
   Component: KOMBI         405 2153
   Coding: 27A400006F84260001886B031401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0005212445
   Coding: 030500041F087300FB07225E0A0F00010001050000000000000000000000
   ROD: EV_GatewLear_013_VW37.rod
   VCID: 7CA00149866BB617C25-8028
   Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 2181604401300585AT2B
   Coding: 2C0000
   Serial number: 7203401004
   Serial number: HA1-00011.07.16
   Coding: 0101
   VCID: 4ACC97919C3FD8A7009-801E
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0020
   Serial number: Y0006PHB14851
   Coding: 0014000000000500018281818181000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   VCID: 3C20C149C6EB7617825-8068
   Serial number: 030416ED314107
   Coding: 003F0220D201048000001000
   VCID: 43D2BAB5BB1509EFC3F-8016
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 9107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D6A4ADB52137DFEDB-8010
   Serial number: 090716EG905536
   Coding: 003F0020DE01048000001000
   VCID: 42DCBFB1A40F00E7C89-8016
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0051
   Coding: 08AE00104B200201
   ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0751
   Coding: 02730601FF00000051110101008808001F0100E6012000008F
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 313EE07D11A98B7F213-8064
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL036AK
   Subsystem 2 - Part No SW: 5NA 919 866 H    HW: -----------
   Component: ECE1 2019/20  --- 1115
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0220
   Serial number: 19081611P11296
   Coding: 0003070600000401000213448050A10094000E200040
   VCID: 3A2CC751CCDF4827909-806E
   Serial number: 280716EGS12886
   Coding: 002A00200100048000001000
   Serial number: 290716EGS18653
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     013 0005
   Coding: 308040732602
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3D26CC4DDDF17F1FB5B-8068
End----(Elapsed Time: 01:32, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
Do you think the three faults under the Engine section are anything to be concerned about- or something left over from a recent battery disconnection?
Not sure. They're all "Intermittent - Not Confirmed". Do they come back if you clear them?
As for your Auto-Hold issues: I see this is a new-style Tiguan with the EPB integrated into the ABS. The ABS module has several Adaptation channels that might affect this behavior:
IDE05264 -- AUTO HOLD increase threshold: reduced tensioning force (%)
IDE05265 -- AUTO HOLD increase threshold: full tensioning force (%)
IDE06139 -- AUTO HOLD slippage recognition (not activated / activated)
I would start by having a look at what's in those channels.
I do not know whether a Security Access code would be required to change them.
PS: I got you Verified and am moving this to the Tweaks section.
^^^ niggly: Hi - to add to Uwe's sage advice:
I'm not sure if my issue is my Antipodean version of English but in reading your description of the problem ("reluctance to release the handbrake when pulling away"), you might also consider the Hill-hold function.
In the hex03 module, there is an adapptation channel with the appropriately name descriptor:MAS02138-Hill-start assistant and the factory setting is normally normal. But it's possible to set this to early - might be worth consideration IMO.
PS: And if you want to disable Hill-hold entirely, you will find a discourse on the topic HERE (don't worry about reference to "MK7" - the vehicle shares your Tiggy's MQB platform DNA)
niggly60
C?ID=365548
Thank you for all your replies.
With reference to the Hill Hold Assist- I was aware of Hill Hold, and had seen the adaptation channel in the controller, but is it the same thing as Auto Hold- ie will changes to Hill Hold affect the way Auto Hold works?
niggly:I'm not sure of the official definitions, but my understanding is that Auto-hold and hill-hold are related. However, the two are kind-of different because they separately target opposite ends of the car's travel.
AUTO-hold targets the stopped behavior of the car -the function assures an automatic hold over the vehicle when stationary (regardless of the way the vehicle was brought to a stop). For auto-hold, the pressure required is calculated and set by the ABS module @ address hex03. After the car is stopped for a period of time, the system then changes over to the EPB (i.e. the holding torque is calculated and passed on from the ABS control unit to the EPB)
Hill hold targets the way that the EPB releases itself when the vehicle is driven off. It's a complex system of balance between the EPB, the accelerator and clutch pedal.
So the two functions do different things!!;) If you alter the auto-hold function, it won't/shouldn't affect hill-hold (except at the extremes - I guess)
niggly60
C?ID=365548
What a brilliant explanation Don, Thank you for taking the time to answer.
From what you've described, it certainly looks like Hill Hold is the area I need to look at- since most of the issues I've experienced relate to problems pulling away and manouvering.
