;SW:3Q0-980-654 HW:3Q0-980-654 --- Frt Sens. Drv. Assist --- SA: S11111
;Component:MQB_B_MFK H04 0010, Coding:000408020000040100061344C050A10094000E200020
;EV_MFKBoschMQBB,001001,EV_MFKBoschMQBB_001_VW36.rod
;Wednesday,09,October,2019,18:06:36:16465
;VCDS Version: Release 19.6.2 (x64) Data version: 20190930 DS308.0
;VCID: 74B121E99E3F2AB7DDF-8020
Group,Description,Actual
IDE00018,Voltage terminal 15,12.8, V
IDE00102,Control Module temperature,27, °C
IDE00326-MAS02471,Steering wheel angle-Sign,Positive,
IDE00326,Steering wheel angle,8.2, °
IDE00767,No. of unscheduled ECU resets,4,
IDE00925-MAS02471,Yaw rate-Sign,Negative,
IDE00925,Yaw rate,0.03, °/s
IDE00973,Outside air temperature,17.0, °C
IDE01968,Dynamic calibration: yaw angle offset,0.000, °
IDE01969,Dynamic calibration: pitch angle offset,0.000, °
IDE01970,Dynamic calibration: roll angle offset,0.000, °
IDE01971,Lowest recorded control module temperature,-9, °C
IDE01972,Highest recorded control module temperature,70, °C
IDE02057,Dynamic calibration: status,Passive: no values stored,
IDE03222-MAS02534,Blindness detection-Clear view,Yes,
IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
IDE03222-MAS03399,Blindness detection-Blindness automatic distance control,No,
IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
IDE03222-MAS10690,Blindness detection-Activation condition,not activated,
IDE03222-MAS11902,Blindness detection-Blind DTC memory entry,No,
IDE03222-MAS11936,Blindness detection-Causes of blindness,Clear view,
IDE03222-MAS11937,Blindness detection-Pixel failure,0, %
IDE03222-MAS11949,Blindness detection-Windshield heater blindness,No,
IDE03354-MAS01632,Dynamic calibration: details-Status,Calibration not yet performed,
IDE03354-MAS02552,Dynamic calibration: details-Distance traveled with active dynamic calibration,0, km
IDE04036,High beam assistant: status,not active,
IDE04037,High beam recommendation,OFF,
IDE04123,High beam: reason for shut-off,255,
IDE04125,Visibility,Not Used,
IDE04312-MAS00084,System run time-Terminal 15 on,247.7, s
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE07214,Dynamic calibration: camera height offset,0, mm
IDE07543,Vehicle speed,0.00, km/h
IDE09433-MAS01632,Perception module for light assistant-Status,ERROR,
IDE09433-MAS08885,Perception module for light assistant-Object 1 removal,unknown Object_1_distance,
IDE09433-MAS08886,Perception module for light assistant-Object 2 removal,unknown Object_2_distance,
IDE09433-MAS08887,Perception module for light assistant-Object 1 horizontal position,unknown Object_1_horizontal_angle,
IDE09433-MAS08888,Perception module for light assistant-Object 2 horizontal position,unknown Object_2_horizontal_angle,
IDE09433-MAS08889,Perception module for light assistant-Object 1 vertical position,unknown Object_1_vertical_angle,
IDE09433-MAS08890,Perception module for light assistant-Object 2 vertical position,unknown Object_2_vertical_angle,
IDE09433-MAS08891,Perception module for light assistant-Object 1 horizontal expansion,unknown Object_1_horizontal_expansion,
IDE09433-MAS08892,Perception module for light assistant-Object 2 horizontal expansion,unknown Object_2_horizontal_expansion,
IDE09433-MAS08893,Perception module for light assistant-Object 1 ID,Not available,
IDE09433-MAS08894,Perception module for light assistant-Object 2 ID,Not available,
IDE09433-MAS08895,Perception module for light assistant-Object 1 replacement value,Not available,
IDE09433-MAS08896,Perception module for light assistant-Object 2 replacement value,Not available,
IDE09433-MAS08897,Perception module for light assistant-Object 1 horizontal quality left,unknown Object_1_horizontal_quality_left,
IDE09433-MAS08898,Perception module for light assistant-Object 2 horizontal quality left,unknown Object_2_horizontal_quality_left,
IDE09433-MAS08899,Perception module for light assistant-Object 1 horizontal quality right,unknown Object_1_horizontal_quality_right,
IDE09433-MAS08900,Perception module for light assistant-Object 2 horizontal quality right,unknown Object_2_horizontal_quality_right,
IDE09433-MAS08901,Perception module for light assistant-Object 1 vertical quality,unknown Object_1_vertical_quality,
IDE09433-MAS08902,Perception module for light assistant-Object 2 vertical quality,unknown Object_2_vertical_quality,
IDE09433-MAS08903,Perception module for light assistant-Object 1 Object type,Not available,
IDE09433-MAS08904,Perception module for light assistant-Object 2 Object type,Not available,
IDE09433-MAS08905,Perception module for light assistant-Object 1 Object quality,<= 50%,
IDE09433-MAS08906,Perception module for light assistant-Object 2 Object quality,<= 50%,
IDE09433-MAS08907,Perception module for light assistant-Cause for passive switching,Restricted view,
IDE09436,Recognized street illumination,Not available,
IDE09438,Drive sequence,Left hand driv.,
IDE09441,Traffic sign 1,0,
IDE09442,Traffic sign 2,0,
IDE09443,Traffic sign 3,0,
IDE09444,Traffic sign 4,0,
IDE09445,Traffic sign 5,0,
IDE09446,Additional signs 1,0,
IDE09447,Additional signs 2,0,
IDE09448,Additional signs 3,0,
IDE09449,Additional signs 4,0,
IDE09450,Additional signs 5,0,
IDE10220,Initial online calibration active,not active,
IDE10396-ENG130851,Vehicle moving on its own-Pitch_rate,0.01, °/s
IDE10396-ENG130850,Vehicle moving on its own-Roll_rate,0.00, °/s
IDE10396-ENG119266,Vehicle moving on its own-Yaw_rate,0.00, °/s
IDE10398-MAS10691,Self-glare-Self-glare quality,0, %
IDE10398-MAS11502,Self-glare-Self-glare recognition,No,
IDE10398-MAS11503,Self-glare-Self-glare status,not active,
IDE10403,Current initial calibration: status,Initial static calibration not OK.,
IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,1.0000,
IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,1.0000,
IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,1.0000,
IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,1.0000,
IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,-0.515, °
IDE10405-MAS10709,Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality,1.0000,
IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,-3.481, °
IDE10405-MAS10711,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality,1.0000,
IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,-0.591, °
IDE10405-MAS10713,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality,1.0000,
IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1317, mm
IDE10405-MAS10715,Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality,1.0000,
IDE10405-MAS10716,Initial dynamic calibration: details-Distance traveled with active initial calibration,0, m
IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,Installation position incorrect,
IDE10406-MAS10995,Last initial calibrations: details-Penultimate initial calibration: error code,Installation position incorrect,
IDE10406-MAS10996,Last initial calibrations: details-Third-to-last initial calibration: error code,Installation position incorrect,
IDE10406-MAS10997,Last initial calibrations: details-Fourth-to-last initial calibration: error code,Installation position incorrect,
IDE10547,Status of camera,ERROR,
IDE10664-MAS00106,Current initial calibration: details-Year,2019,
IDE10664-MAS00107,Current initial calibration: details-Month,10,
IDE10664-MAS00108,Current initial calibration: details-Day,9,
IDE10664-MAS00109,Current initial calibration: details-Hours,17,
IDE10664-MAS00110,Current initial calibration: details-Minutes,26,
IDE10664-MAS00111,Current initial calibration: details-Seconds,10,
IDE10664-MAS00711,Current initial calibration: details-Odometer reading,43955,
IDE10664-MAS01632,Current initial calibration: details-Status,Installation position incorrect,
IDE10664-MAS02541,Current initial calibration: details-Rear projection fault,0,
IDE10664-MAS02542,Current initial calibration: details-Calibration marks,00111111 ,
IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,-----------------,
IDE10664-MAS03010,Current initial calibration: details-Focal length,1386,
IDE10664-MAS03075,Current initial calibration: details-Calibration point X coordinates on imaging sensor,644,
IDE10664-MAS03076,Current initial calibration: details-Calibration point Y coordinates on imaging sensor,353,
IDE10664,Current initial calibration: details,00111111 ,
IDE10664,Current initial calibration: details,00110011 ,
IDE11956,Boot manager version,31 12 30 01,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,10,
MAS00464-MAS00108,Standard - ambient data 1-Day,9,
MAS00464-MAS00109,Standard - ambient data 1-Hours,18,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,7,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,18,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,121,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,43955, km
ENG130806-ENG130856,Blindness_Matrix-Blindness_Matrix_1_1,7,
ENG130806-ENG130857,Blindness_Matrix-Blindness_Matrix_1_2,7,
ENG130806-ENG130858,Blindness_Matrix-Blindness_Matrix_1_3,7,
ENG130806-ENG130859,Blindness_Matrix-Blindness_Matrix_1_4,7,
ENG130806-ENG130860,Blindness_Matrix-Blindness_Matrix_1_5,7,
ENG130806-ENG130861,Blindness_Matrix-Blindness_Matrix_2_1,7,
ENG130806-ENG130862,Blindness_Matrix-Blindness_Matrix_2_2,7,
ENG130806-ENG130863,Blindness_Matrix-Blindness_Matrix_2_3,7,
ENG130806-ENG130864,Blindness_Matrix-Blindness_Matrix_2_4,7,
ENG130806-ENG130865,Blindness_Matrix-Blindness_Matrix_2_5,7,
ENG130806-ENG130866,Blindness_Matrix-Blindness_Matrix_3_1,7,
ENG130806-ENG130867,Blindness_Matrix-Blindness_Matrix_3_2,7,
ENG130806-ENG130868,Blindness_Matrix-Blindness_Matrix_3_3,7,
ENG130806-ENG130869,Blindness_Matrix-Blindness_Matrix_3_4,7,
ENG130806-ENG130870,Blindness_Matrix-Blindness_Matrix_3_5,7,
ENG130806-ENG130871,Blindness_Matrix-Blindness_Matrix_4_1,7,
ENG130806-ENG130872,Blindness_Matrix-Blindness_Matrix_4_2,7,
ENG130806-ENG130873,Blindness_Matrix-Blindness_Matrix_4_3,7,
ENG130806-ENG130874,Blindness_Matrix-Blindness_Matrix_4_4,7,
ENG130806-ENG130875,Blindness_Matrix-Blindness_Matrix_4_5,7,
ENG130806-ENG130876,Blindness_Matrix-Blindness_Matrix_5_1,7,
ENG130806-ENG130877,Blindness_Matrix-Blindness_Matrix_5_2,7,
ENG130806-ENG130878,Blindness_Matrix-Blindness_Matrix_5_3,7,
ENG130806-ENG130879,Blindness_Matrix-Blindness_Matrix_5_4,7,
ENG130806-ENG130880,Blindness_Matrix-Blindness_Matrix_5_5,7,
ENG120402-ENG120253,Camera_information-par_camera_control_average,409,
ENG120402-ENG120255,Camera_information-par_frame_counter,8911,
ENG130822-ENG130854,camera_state_details-camera_debug_requests,00000001 ,
ENG130822-ENG130853,camera_state_details-camera_hot_restart_counter,0,
ENG130822-ENG130852,camera_state_details-camera_system_state_details,31,
ENG130822-ENG130855,camera_state_details-Kamera Debug Information,00000000 00000000 00000000 00000010 ,
ENG130795,Count_street_lighting,0,
ENG120438,EH_Sys_Country_Code,0,
ENG130820-ENG130848,Ehr-Ehr_mem_usage_attributes,46, %
ENG130820-ENG130847,Ehr-Ehr_mem_usage_segments,100, %
ENG130820-ENG130849,Ehr-Ehr_mem_usage_speedlimits,47, %
ENG130820-ENG130846,Ehr-EHR_SW_Version,01 00 01,
ENG130816-ENG131033,hca_Parameter_App_001_App_050-hca_Parameter_par_App_001,4223557550,
ENG130816-ENG131034,hca_Parameter_App_001_App_050-hca_Parameter_par_App_002,3800488123,
ENG130816-ENG131035,hca_Parameter_App_001_App_050-hca_Parameter_par_App_003,3216172011,
ENG130816-ENG131036,hca_Parameter_App_001_App_050-hca_Parameter_par_App_004,4294967294,
ENG130816-ENG131037,hca_Parameter_App_001_App_050-hca_Parameter_par_App_005,4160749567,
ENG130816-ENG131038,hca_Parameter_App_001_App_050-hca_Parameter_par_App_006,4294967295,
ENG130816-ENG131039,hca_Parameter_App_001_App_050-hca_Parameter_par_App_007,1067030938,
ENG130816-ENG131040,hca_Parameter_App_001_App_050-hca_Parameter_par_App_008,1092616192,
ENG130816-ENG131041,hca_Parameter_App_001_App_050-hca_Parameter_par_App_009,1070386381,
ENG130816-ENG131042,hca_Parameter_App_001_App_050-hca_Parameter_par_App_010,1057803469,
ENG130816-ENG131043,hca_Parameter_App_001_App_050-hca_Parameter_par_App_011,1048576000,
ENG130816-ENG131044,hca_Parameter_App_001_App_050-hca_Parameter_par_App_012,1048576000,
ENG130816-ENG131045,hca_Parameter_App_001_App_050-hca_Parameter_par_App_013,1036831949,
ENG130816-ENG131046,hca_Parameter_App_001_App_050-hca_Parameter_par_App_014,1050253722,
ENG130816-ENG131047,hca_Parameter_App_001_App_050-hca_Parameter_par_App_015,0,
ENG130816-ENG131048,hca_Parameter_App_001_App_050-hca_Parameter_par_App_016,0,
ENG130816-ENG131049,hca_Parameter_App_001_App_050-hca_Parameter_par_App_017,1071225242,
ENG130816-ENG131050,hca_Parameter_App_001_App_050-hca_Parameter_par_App_018,1120403456,
ENG130816-ENG131051,hca_Parameter_App_001_App_050-hca_Parameter_par_App_019,3,
ENG130816-ENG131052,hca_Parameter_App_001_App_050-hca_Parameter_par_App_020,1045220557,
ENG130816-ENG131053,hca_Parameter_App_001_App_050-hca_Parameter_par_App_021,1133576192,
ENG130816-ENG131054,hca_Parameter_App_001_App_050-hca_Parameter_par_App_022,1065353216,
ENG130816-ENG131055,hca_Parameter_App_001_App_050-hca_Parameter_par_App_023,750,
ENG130816-ENG131056,hca_Parameter_App_001_App_050-hca_Parameter_par_App_024,3,
ENG130816-ENG131057,hca_Parameter_App_001_App_050-hca_Parameter_par_App_025,2,
ENG130816-ENG131058,hca_Parameter_App_001_App_050-hca_Parameter_par_App_026,1092301619,
ENG130816-ENG131059,hca_Parameter_App_001_App_050-hca_Parameter_par_App_027,20,
ENG130816-ENG131060,hca_Parameter_App_001_App_050-hca_Parameter_par_App_028,1060320051,
ENG130816-ENG131061,hca_Parameter_App_001_App_050-hca_Parameter_par_App_029,1045220557,
ENG130816-ENG131062,hca_Parameter_App_001_App_050-hca_Parameter_par_App_030,1058642330,
ENG130816-ENG131063,hca_Parameter_App_001_App_050-hca_Parameter_par_App_031,5,
ENG130816-ENG131064,hca_Parameter_App_001_App_050-hca_Parameter_par_App_032,1055286886,
ENG130816-ENG131065,hca_Parameter_App_001_App_050-hca_Parameter_par_App_033,1028443341,
ENG130816-ENG131066,hca_Parameter_App_001_App_050-hca_Parameter_par_App_034,1200,
ENG130816-ENG131067,hca_Parameter_App_001_App_050-hca_Parameter_par_App_035,1133903872,
ENG130816-ENG131068,hca_Parameter_App_001_App_050-hca_Parameter_par_App_036,1079320248,
ENG130816-ENG131069,hca_Parameter_App_001_App_050-hca_Parameter_par_App_037,1069547520,
ENG130816-ENG131070,hca_Parameter_App_001_App_050-hca_Parameter_par_App_038,50,
ENG130816-ENG131071,hca_Parameter_App_001_App_050-hca_Parameter_par_App_039,1045220557,
ENG130816-ENG00000,hca_Parameter_App_001_App_050-hca_Parameter_par_App_040,100,
ENG130816-ENG00001,hca_Parameter_App_001_App_050-hca_Parameter_par_App_041,1065353216,
ENG130816-ENG00002,hca_Parameter_App_001_App_050-hca_Parameter_par_App_042,5,
ENG130816-ENG00003,hca_Parameter_App_001_App_050-hca_Parameter_par_App_043,1028443341,
ENG130816-ENG00004,hca_Parameter_App_001_App_050-hca_Parameter_par_App_044,1079320248,
ENG130816-ENG00005,hca_Parameter_App_001_App_050-hca_Parameter_par_App_045,1050253722,
ENG130816-ENG00006,hca_Parameter_App_001_App_050-hca_Parameter_par_App_046,1053609165,
ENG130816-ENG00007,hca_Parameter_App_001_App_050-hca_Parameter_par_App_047,1036831949,
ENG130816-ENG00008,hca_Parameter_App_001_App_050-hca_Parameter_par_App_048,1000593162,
ENG130816-ENG00009,hca_Parameter_App_001_App_050-hca_Parameter_par_App_049,995640528,
ENG130816-ENG00010,hca_Parameter_App_001_App_050-hca_Parameter_par_App_050,1050253722,
ENG130799-ENG00011,hca_Parameter_App_051_App_100-hca_Parameter_par_App_051,1093781265,
ENG130799-ENG00012,hca_Parameter_App_051_App_100-hca_Parameter_par_App_052,1099257191,
ENG130799-ENG00013,hca_Parameter_App_051_App_100-hca_Parameter_par_App_053,1065353216,
ENG130799-ENG00014,hca_Parameter_App_051_App_100-hca_Parameter_par_App_054,1065353216,
ENG130799-ENG00015,hca_Parameter_App_051_App_100-hca_Parameter_par_App_055,1065353216,
ENG130799-ENG00016,hca_Parameter_App_051_App_100-hca_Parameter_par_App_056,1099258921,
ENG130799-ENG00017,hca_Parameter_App_051_App_100-hca_Parameter_par_App_057,1115815936,
ENG130799-ENG00018,hca_Parameter_App_051_App_100-hca_Parameter_par_App_058,1133576192,
ENG130799-ENG00019,hca_Parameter_App_051_App_100-hca_Parameter_par_App_059,1118218879,
ENG130799-ENG00020,hca_Parameter_App_051_App_100-hca_Parameter_par_App_060,1036831949,
ENG130799-ENG00021,hca_Parameter_App_051_App_100-hca_Parameter_par_App_061,1101004800,
ENG130799-ENG00022,hca_Parameter_App_051_App_100-hca_Parameter_par_App_062,1000593162,
ENG130799-ENG00023,hca_Parameter_App_051_App_100-hca_Parameter_par_App_063,1063675494,
ENG130799-ENG00024,hca_Parameter_App_051_App_100-hca_Parameter_par_App_064,1110558481,
ENG130799-ENG00025,hca_Parameter_App_051_App_100-hca_Parameter_par_App_065,1109102140,
ENG130799-ENG00026,hca_Parameter_App_051_App_100-hca_Parameter_par_App_066,1090865070,
ENG130799-ENG00027,hca_Parameter_App_051_App_100-hca_Parameter_par_App_067,1073741824,
ENG130799-ENG00028,hca_Parameter_App_051_App_100-hca_Parameter_par_App_068,1069547520,
ENG130799-ENG00029,hca_Parameter_App_051_App_100-hca_Parameter_par_App_069,50,
ENG130799-ENG00030,hca_Parameter_App_051_App_100-hca_Parameter_par_App_070,1041865114,
ENG130799-ENG00031,hca_Parameter_App_051_App_100-hca_Parameter_par_App_071,500,
ENG130799-ENG00032,hca_Parameter_App_051_App_100-hca_Parameter_par_App_072,1050253722,
ENG130799-ENG00033,hca_Parameter_App_051_App_100-hca_Parameter_par_App_073,200,
ENG130799-ENG00034,hca_Parameter_App_051_App_100-hca_Parameter_par_App_074,1039516303,
ENG130799-ENG00035,hca_Parameter_App_051_App_100-hca_Parameter_par_App_075,155,
ENG130799-ENG00036,hca_Parameter_App_051_App_100-hca_Parameter_par_App_076,1050253722,
ENG130799-ENG00037,hca_Parameter_App_051_App_100-hca_Parameter_par_App_077,1056964608,
ENG130799-ENG00038,hca_Parameter_App_051_App_100-hca_Parameter_par_App_078,1039516303,
ENG130799-ENG00039,hca_Parameter_App_051_App_100-hca_Parameter_par_App_079,1069547520,
ENG130799-ENG00040,hca_Parameter_App_051_App_100-hca_Parameter_par_App_080,2,
ENG130799-ENG00041,hca_Parameter_App_051_App_100-hca_Parameter_par_App_081,1056964608,
ENG130799-ENG00042,hca_Parameter_App_051_App_100-hca_Parameter_par_App_082,1120403456,
ENG130799-ENG00043,hca_Parameter_App_051_App_100-hca_Parameter_par_App_083,1073741824,
ENG130799-ENG00044,hca_Parameter_App_051_App_100-hca_Parameter_par_App_084,1075838976,
ENG130799-ENG00045,hca_Parameter_App_051_App_100-hca_Parameter_par_App_085,150,
ENG130799-ENG00046,hca_Parameter_App_051_App_100-hca_Parameter_par_App_086,3,
ENG130799-ENG00047,hca_Parameter_App_051_App_100-hca_Parameter_par_App_087,1,
ENG130799-ENG00048,hca_Parameter_App_051_App_100-hca_Parameter_par_App_088,3212836864,
ENG130799-ENG00049,hca_Parameter_App_051_App_100-hca_Parameter_par_App_089,17950,
ENG130799-ENG00050,hca_Parameter_App_051_App_100-hca_Parameter_par_App_090,1053609165,
ENG130799-ENG00051,hca_Parameter_App_051_App_100-hca_Parameter_par_App_091,1090865070,
ENG130799-ENG00052,hca_Parameter_App_051_App_100-hca_Parameter_par_App_092,10,
ENG130799-ENG00053,hca_Parameter_App_051_App_100-hca_Parameter_par_App_093,100,
ENG130799-ENG00054,hca_Parameter_App_051_App_100-hca_Parameter_par_App_094,1112014848,
ENG130799-ENG00055,hca_Parameter_App_051_App_100-hca_Parameter_par_App_095,3192704205,
ENG130799-ENG00056,hca_Parameter_App_051_App_100-hca_Parameter_par_App_096,100,
ENG130799-ENG00057,hca_Parameter_App_051_App_100-hca_Parameter_par_App_097,3137540719,
ENG130799-ENG00058,hca_Parameter_App_051_App_100-hca_Parameter_par_App_098,1017370378,
ENG130799-ENG00059,hca_Parameter_App_051_App_100-hca_Parameter_par_App_099,25,
ENG130799-ENG00060,hca_Parameter_App_051_App_100-hca_Parameter_par_App_100,1068615546,
ENG130817-ENG130933,hca_Parameter_App_101_App_150-hca_Parameter_par_App_101,17000,
ENG130817-ENG130934,hca_Parameter_App_101_App_150-hca_Parameter_par_App_102,1045220557,
ENG130817-ENG130935,hca_Parameter_App_101_App_150-hca_Parameter_par_App_103,3221225472,
ENG130817-ENG130936,hca_Parameter_App_101_App_150-hca_Parameter_par_App_104,150,
ENG130817-ENG130937,hca_Parameter_App_101_App_150-hca_Parameter_par_App_105,1119215065,
ENG130817-ENG130938,hca_Parameter_App_101_App_150-hca_Parameter_par_App_106,1120403456,
ENG130817-ENG130939,hca_Parameter_App_101_App_150-hca_Parameter_par_App_107,32699,
ENG130817-ENG130940,hca_Parameter_App_101_App_150-hca_Parameter_par_App_108,1039516303,
ENG130817-ENG130941,hca_Parameter_App_101_App_150-hca_Parameter_par_App_109,1099956224,
ENG130817-ENG130942,hca_Parameter_App_101_App_150-hca_Parameter_par_App_110,1133903872,
ENG130817-ENG130943,hca_Parameter_App_101_App_150-hca_Parameter_par_App_111,1135542272,
ENG130817-ENG130944,hca_Parameter_App_101_App_150-hca_Parameter_par_App_112,500,
ENG130817-ENG130945,hca_Parameter_App_101_App_150-hca_Parameter_par_App_113,1073741824,
ENG130817-ENG130946,hca_Parameter_App_101_App_150-hca_Parameter_par_App_114,50,
ENG130817-ENG130947,hca_Parameter_App_101_App_150-hca_Parameter_par_App_115,12073,
ENG130817-ENG130948,hca_Parameter_App_101_App_150-hca_Parameter_par_App_116,1041865114,
ENG130817-ENG130949,hca_Parameter_App_101_App_150-hca_Parameter_par_App_117,1056964608,
ENG130817-ENG130950,hca_Parameter_App_101_App_150-hca_Parameter_par_App_118,8946808,
ENG130817-ENG130951,hca_Parameter_App_101_App_150-hca_Parameter_par_App_119,1073741824,
ENG130817-ENG130952,hca_Parameter_App_101_App_150-hca_Parameter_par_App_120,1112014848,
ENG130817-ENG130953,hca_Parameter_App_101_App_150-hca_Parameter_par_App_121,1041865114,
ENG130817-ENG130954,hca_Parameter_App_101_App_150-hca_Parameter_par_App_122,1092616192,
ENG130817-ENG130955,hca_Parameter_App_101_App_150-hca_Parameter_par_App_123,1065353216,
ENG130817-ENG130956,hca_Parameter_App_101_App_150-hca_Parameter_par_App_124,1099956224,
ENG130817-ENG130957,hca_Parameter_App_101_App_150-hca_Parameter_par_App_125,1085392762,
ENG130817-ENG130958,hca_Parameter_App_101_App_150-hca_Parameter_par_App_126,3,
ENG130817-ENG130959,hca_Parameter_App_101_App_150-hca_Parameter_par_App_127,150,
ENG130817-ENG130960,hca_Parameter_App_101_App_150-hca_Parameter_par_App_128,1067030938,
ENG130817-ENG130961,hca_Parameter_App_101_App_150-hca_Parameter_par_App_129,1056964608,
ENG130817-ENG130962,hca_Parameter_App_101_App_150-hca_Parameter_par_App_130,1090833613,
ENG130817-ENG130963,hca_Parameter_App_101_App_150-hca_Parameter_par_App_131,1090868530,
ENG130817-ENG130964,hca_Parameter_App_101_App_150-hca_Parameter_par_App_132,1085276160,
ENG130817-ENG130965,hca_Parameter_App_101_App_150-hca_Parameter_par_App_133,1000593162,
ENG130817-ENG130966,hca_Parameter_App_101_App_150-hca_Parameter_par_App_134,1020054733,
ENG130817-ENG130967,hca_Parameter_App_101_App_150-hca_Parameter_par_App_135,1008981770,
ENG130817-ENG130968,hca_Parameter_App_101_App_150-hca_Parameter_par_App_136,1025758986,
ENG130817-ENG130969,hca_Parameter_App_101_App_150-hca_Parameter_par_App_137,1058642330,
ENG130817-ENG130970,hca_Parameter_App_101_App_150-hca_Parameter_par_App_138,1063675494,
ENG130817-ENG130971,hca_Parameter_App_101_App_150-hca_Parameter_par_App_139,1061997773,
ENG130817-ENG130972,hca_Parameter_App_101_App_150-hca_Parameter_par_App_140,1065353216,
ENG130817-ENG130973,hca_Parameter_App_101_App_150-hca_Parameter_par_App_141,1050253722,
ENG130817-ENG130974,hca_Parameter_App_101_App_150-hca_Parameter_par_App_142,1060320051,
ENG130817-ENG130975,hca_Parameter_App_101_App_150-hca_Parameter_par_App_143,1050253722,
ENG130817-ENG130976,hca_Parameter_App_101_App_150-hca_Parameter_par_App_144,1061997773,
ENG130817-ENG130977,hca_Parameter_App_101_App_150-hca_Parameter_par_App_145,0,
ENG130817-ENG130978,hca_Parameter_App_101_App_150-hca_Parameter_par_App_146,1060320051,
ENG130817-ENG130979,hca_Parameter_App_101_App_150-hca_Parameter_par_App_147,1056964608,
ENG130817-ENG130980,hca_Parameter_App_101_App_150-hca_Parameter_par_App_148,1082130432,
ENG130817-ENG130981,hca_Parameter_App_101_App_150-hca_Parameter_par_App_149,1065353216,
ENG130817-ENG130982,hca_Parameter_App_101_App_150-hca_Parameter_par_App_150,1074580685,
ENG130810-ENG130983,hca_Parameter_App_151_App_200-hca_Parameter_par_App_151,1071225242,
ENG130810-ENG130984,hca_Parameter_App_151_App_200-hca_Parameter_par_App_152,1060320051,
ENG130810-ENG130985,hca_Parameter_App_151_App_200-hca_Parameter_par_App_153,1076363264,
ENG130810-ENG130986,hca_Parameter_App_151_App_200-hca_Parameter_par_App_154,1099257138,
ENG130810-ENG130987,hca_Parameter_App_151_App_200-hca_Parameter_par_App_155,1056964608,
ENG130810-ENG130988,hca_Parameter_App_151_App_200-hca_Parameter_par_App_156,0,
ENG130810-ENG130989,hca_Parameter_App_151_App_200-hca_Parameter_par_App_157,1060320051,
ENG130810-ENG130990,hca_Parameter_App_151_App_200-hca_Parameter_par_App_158,0,
ENG130810-ENG130991,hca_Parameter_App_151_App_200-hca_Parameter_par_App_159,1056964608,
ENG130810-ENG130992,hca_Parameter_App_151_App_200-hca_Parameter_par_App_160,1056964608,
ENG130810-ENG130993,hca_Parameter_App_151_App_200-hca_Parameter_par_App_161,1120403456,
ENG130810-ENG130994,hca_Parameter_App_151_App_200-hca_Parameter_par_App_162,1092324898,
ENG130810-ENG130995,hca_Parameter_App_151_App_200-hca_Parameter_par_App_163,1036831949,
ENG130810-ENG130996,hca_Parameter_App_151_App_200-hca_Parameter_par_App_164,1073741824,
ENG130810-ENG130997,hca_Parameter_App_151_App_200-hca_Parameter_par_App_165,1067869798,
ENG130810-ENG130998,hca_Parameter_App_151_App_200-hca_Parameter_par_App_166,1066192077,
ENG130810-ENG130999,hca_Parameter_App_151_App_200-hca_Parameter_par_App_167,1077936128,
ENG130810-ENG131000,hca_Parameter_App_151_App_200-hca_Parameter_par_App_168,1020054733,
ENG130810-ENG131001,hca_Parameter_App_151_App_200-hca_Parameter_par_App_169,1036831949,
ENG130810-ENG131002,hca_Parameter_App_151_App_200-hca_Parameter_par_App_170,1034147594,
ENG130810-ENG131003,hca_Parameter_App_151_App_200-hca_Parameter_par_App_171,1036831949,
ENG130810-ENG131004,hca_Parameter_App_151_App_200-hca_Parameter_par_App_172,1036831949,
ENG130810-ENG131005,hca_Parameter_App_151_App_200-hca_Parameter_par_App_173,1036831949,
ENG130810-ENG131006,hca_Parameter_App_151_App_200-hca_Parameter_par_App_174,1028443341,
ENG130810-ENG131007,hca_Parameter_App_151_App_200-hca_Parameter_par_App_175,100,
ENG130810-ENG131008,hca_Parameter_App_151_App_200-hca_Parameter_par_App_176,150,
ENG130810-ENG131009,hca_Parameter_App_151_App_200-hca_Parameter_par_App_177,250,
ENG130810-ENG131010,hca_Parameter_App_151_App_200-hca_Parameter_par_App_178,500,
ENG130810-ENG131011,hca_Parameter_App_151_App_200-hca_Parameter_par_App_179,200,
ENG130810-ENG131012,hca_Parameter_App_151_App_200-hca_Parameter_par_App_180,1,
ENG130810-ENG131013,hca_Parameter_App_151_App_200-hca_Parameter_par_App_181,200,
ENG130810-ENG131014,hca_Parameter_App_151_App_200-hca_Parameter_par_App_182,150,
ENG130810-ENG131015,hca_Parameter_App_151_App_200-hca_Parameter_par_App_183,5,
ENG130810-ENG131016,hca_Parameter_App_151_App_200-hca_Parameter_par_App_184,1041865114,
ENG130810-ENG131017,hca_Parameter_App_151_App_200-hca_Parameter_par_App_185,2,
ENG130810-ENG131018,hca_Parameter_App_151_App_200-hca_Parameter_par_App_186,150,
ENG130810-ENG131019,hca_Parameter_App_151_App_200-hca_Parameter_par_App_187,150,
ENG130810-ENG131020,hca_Parameter_App_151_App_200-hca_Parameter_par_App_188,0,
ENG130810-ENG131021,hca_Parameter_App_151_App_200-hca_Parameter_par_App_189,100,
ENG130810-ENG131022,hca_Parameter_App_151_App_200-hca_Parameter_par_App_190,250,
ENG130810-ENG131023,hca_Parameter_App_151_App_200-hca_Parameter_par_App_191,6,
ENG130810-ENG131024,hca_Parameter_App_151_App_200-hca_Parameter_par_App_192,1080033280,
ENG130810-ENG131025,hca_Parameter_App_151_App_200-hca_Parameter_par_App_193,0,
ENG130810-ENG131026,hca_Parameter_App_151_App_200-hca_Parameter_par_App_194,0,
ENG130810-ENG131027,hca_Parameter_App_151_App_200-hca_Parameter_par_App_195,1099257191,
ENG130810-ENG131028,hca_Parameter_App_151_App_200-hca_Parameter_par_App_196,0,
ENG130810-ENG131029,hca_Parameter_App_151_App_200-hca_Parameter_par_App_197,4294967295,
ENG130810-ENG131030,hca_Parameter_App_151_App_200-hca_Parameter_par_App_198,1613874181,
ENG130810-ENG131031,hca_Parameter_App_151_App_200-hca_Parameter_par_App_199,3393735333,
ENG130810-ENG131032,hca_Parameter_App_151_App_200-hca_Parameter_par_App_200,0,
ENG120389-ENG120177,hca_Parameter_Fzg-hca_Parameter_par_Fzg_Breite,1.8437500, m
ENG120389-ENG120180,hca_Parameter_Fzg-hca_Parameter_par_Fzg_Lenkuebers,15.0000000,
ENG120389-ENG120178,hca_Parameter_Fzg-hca_Parameter_par_Fzg_Radstand,2.7890625, m
ENG120389-ENG120179,hca_Parameter_Fzg-hca_Parameter_par_Fzg_Vchar,32.50, m/s
ENG120417-ENG120274,Person_hca_Key_0-hmi_Hca_An,OFF,
ENG120417-ENG120277,Person_hca_Key_0-hmi_System_Mode,vibration_off,
ENG120417-ENG120276,Person_hca_Key_0-hmi_Warning_Intensity,Medium,
ENG120417-ENG120275,Person_hca_Key_0-hmi_Warning_Time,Early,
ENG120418-ENG120274,Person_hca_Key_1-hmi_Hca_An,On,
ENG120418-ENG120277,Person_hca_Key_1-hmi_System_Mode,vibration_off,
ENG120418-ENG120276,Person_hca_Key_1-hmi_Warning_Intensity,Medium,
ENG120418-ENG120275,Person_hca_Key_1-hmi_Warning_Time,Late,
ENG120419-ENG120274,Person_hca_Key_2-hmi_Hca_An,OFF,
ENG120419-ENG120277,Person_hca_Key_2-hmi_System_Mode,vibration_off,
ENG120419-ENG120276,Person_hca_Key_2-hmi_Warning_Intensity,Medium,
ENG120419-ENG120275,Person_hca_Key_2-hmi_Warning_Time,Late,
ENG120420-ENG120274,Person_hca_Key_3-hmi_Hca_An,OFF,
ENG120420-ENG120277,Person_hca_Key_3-hmi_System_Mode,vibration_off,
ENG120420-ENG120276,Person_hca_Key_3-hmi_Warning_Intensity,Medium,
ENG120420-ENG120275,Person_hca_Key_3-hmi_Warning_Time,Early,
ENG130791-ENG00068,Rsr_objects_01-Rsr_objects_01_add1_attribute,0,
ENG130791-ENG00067,Rsr_objects_01-Rsr_objects_01_add1_class,no_Information,
ENG130791-ENG00066,Rsr_objects_01-Rsr_objects_01_attribute,0,
ENG130791-ENG00065,Rsr_objects_01-Rsr_objects_01_class,no_Information,
ENG130791-ENG00064,Rsr_objects_01-Rsr_objects_01_objectid,0,
ENG130811-ENG00073,Rsr_objects_02-Rsr_objects_02_add1_attribute,0,
ENG130811-ENG00072,Rsr_objects_02-Rsr_objects_02_add1_class,no_Information,
ENG130811-ENG00071,Rsr_objects_02-Rsr_objects_02_attribute,0,
ENG130811-ENG00070,Rsr_objects_02-Rsr_objects_02_class,no_Information,
ENG130811-ENG00069,Rsr_objects_02-Rsr_objects_02_objectid,0,
ENG130804-ENG00078,Rsr_objects_03-Rsr_objects_03_add1_attribute,0,
ENG130804-ENG00077,Rsr_objects_03-Rsr_objects_03_add1_class,no_Information,
ENG130804-ENG00076,Rsr_objects_03-Rsr_objects_03_attribute,0,
ENG130804-ENG00075,Rsr_objects_03-Rsr_objects_03_class,no_Information,
ENG130804-ENG00074,Rsr_objects_03-Rsr_objects_03_objectid,0,
ENG130792-ENG00083,Rsr_objects_04-Rsr_objects_04_add1_attribute,0,
ENG130792-ENG00082,Rsr_objects_04-Rsr_objects_04_add1_class,no_Information,
ENG130792-ENG00081,Rsr_objects_04-Rsr_objects_04_attribute,0,
ENG130792-ENG00080,Rsr_objects_04-Rsr_objects_04_class,no_Information,
ENG130792-ENG00079,Rsr_objects_04-Rsr_objects_04_objectid,0,
ENG130809-ENG00088,Rsr_objects_05-Rsr_objects_05_add1_attribute,0,
ENG130809-ENG00087,Rsr_objects_05-Rsr_objects_05_add1_class,no_Information,
ENG130809-ENG00086,Rsr_objects_05-Rsr_objects_05_attribute,0,
ENG130809-ENG00085,Rsr_objects_05-Rsr_objects_05_class,no_Information,
ENG130809-ENG00084,Rsr_objects_05-Rsr_objects_05_objectid,0,
ENG130805-ENG00093,Rsr_objects_06-Rsr_objects_06_add1_attribute,0,
ENG130805-ENG00092,Rsr_objects_06-Rsr_objects_06_add1_class,no_Information,
ENG130805-ENG00091,Rsr_objects_06-Rsr_objects_06_attribute,0,
ENG130805-ENG00090,Rsr_objects_06-Rsr_objects_06_class,no_Information,
ENG130805-ENG00089,Rsr_objects_06-Rsr_objects_06_objectid,0,
ENG130797-ENG00098,Rsr_objects_07-Rsr_objects_07_add1_attribute,0,
ENG130797-ENG00097,Rsr_objects_07-Rsr_objects_07_add1_class,no_Information,
ENG130797-ENG00096,Rsr_objects_07-Rsr_objects_07_attribute,0,
ENG130797-ENG00095,Rsr_objects_07-Rsr_objects_07_class,no_Information,
ENG130797-ENG00094,Rsr_objects_07-Rsr_objects_07_objectid,0,
ENG130819-ENG00103,Rsr_objects_08-Rsr_objects_08_add1_attribute,0,
ENG130819-ENG00102,Rsr_objects_08-Rsr_objects_08_add1_class,no_Information,
ENG130819-ENG00101,Rsr_objects_08-Rsr_objects_08_attribute,0,
ENG130819-ENG00100,Rsr_objects_08-Rsr_objects_08_class,no_Information,
ENG130819-ENG00099,Rsr_objects_08-Rsr_objects_08_objectid,0,
ENG130790-ENG00108,Rsr_objects_09-Rsr_objects_09_add1_attribute,0,
ENG130790-ENG00107,Rsr_objects_09-Rsr_objects_09_add1_class,no_Information,
ENG130790-ENG00106,Rsr_objects_09-Rsr_objects_09_attribute,0,
ENG130790-ENG00105,Rsr_objects_09-Rsr_objects_09_class,no_Information,
ENG130790-ENG00104,Rsr_objects_09-Rsr_objects_09_objectid,0,
ENG130814-ENG130845,VZE_message_text-Par_vze_message_text,1,
ENG130789,VZF_Warning_Traffic_Sig_1,not activated,
ENG130801,VZF_Warning_Traffic_Sig_2,not activated,
ENG130800,VZF_Warning_Traffic_Sig_3,not activated,
ENG130802,VZF_Warning_Traffic_Sig_4,not activated,
ENG130803,VZF_Warning_Traffic_Sig_5,not activated,
ENG130818-MAS01505,Windscreen_heater_camera-Engine off,No,
ENG130818-MAS02374,Windscreen_heater_camera-System malfunction,System malfunction,
ENG130818-MAS03849,Windscreen_heater_camera-Crash signal,not active,
ENG130818-ENG120256,Windscreen_heater_camera-par_Actuator_test,not active,
ENG130818-ENG120266,Windscreen_heater_camera-par_Ambient_temperature_too_low,No,
ENG130818-ENG120257,Windscreen_heater_camera-par_Blindness_activation,no request,
ENG130818-ENG120260,Windscreen_heater_camera-par_camera_temperature_too_high,No,
ENG130818-ENG120258,Windscreen_heater_camera-par_condensation_danger_activation,no request,
ENG130818-ENG120268,Windscreen_heater_camera-par_current_windscreen_heater,0.0, A
ENG130818-ENG120265,Windscreen_heater_camera-par_Heating_time_exceeded,No,
ENG130818-ENG120259,Windscreen_heater_camera-par_initial_heating,not active,
ENG130818-ENG130881,Windscreen_heater_camera-par_preventive_heating,not active,
ENG130818-ENG120264,Windscreen_heater_camera-par_Windscreenheater_error,not active,
ENG130818-ENG101577,Windscreen_heater_camera-Windscreen_heater_state_of_activation,ERROR,
Elapsed Time: 02:07
