2011 Golf 1.6 TDI - sensor reference voltage - maybe crankshaft position sensor???
Jim Beagley
C?ID=349735
I have had a Golf in the workshop today, which intermittently stutters and loses power in a manner that suggests a crankshaft sensor fault. However the persistent fault code shows "6557 - Sensor Reference Voltage B P0653 00 [167] - Too High".
When the car came in, there was a couple of crankshaft sensor codes stored, but they have not returned yet. Any feedback much appreciated. Below is an autoscan, and also a scan of the engine module fault codes when the car first arrived. The problem is very intermitent - most of the time, the car drives normally.
   Coding: 08114014030500080000
   ASAM Dataset: EV_ECM16TDI02103L997557N 003003
   ROD: EV_ECM16TDI02103L997557A.rod
   VCID: 47DEA616FEB442725C-8012
                    Mileage: 117676 km
                    Date: 2019.05.03
                    Time: 05:35:03
                    Engine speed: 1207.75 /min
                    Normed load value: 10.2 %
                    Vehicle speed: 33 km/h
                    Coolant temperature: 53 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 14.456 V
                    Battery voltage: 14.5 V
                    Supply voltage of analog output 1-VCC_1: 4.94 V
                    Supply voltage of analog output 2-VCC_2: 6.57 V
                    Fuel high pressure sensor: unconditioned voltage-VP_PFU: 1.1884 V
                    Intake manif runner actuator: uncond volt actual value-V_PORT[0]: 4.995 V
                    Throttle valve adapter: uncond voltage actual value-V_THR[0]: 4.443 V
                    Voltage equivalent of valve for fuel metering-VP_CFB_VCV: 3.1705 V
   Revision: 00H31001
   Coding: 263B400D09220000641102E490210081310000
   VCID: 7BB60AE6FAFCD69288-802E
   Part No SW: 7N0 907 426 AM    HW: 7N0 907 426 AM
   Component: AC Manuell    H19 0304
   Revision: 00001015
   Coding: 0000004002
   VCID: 7F4EFEF6E6E4CAB2A4-802A
   Part No SW: 1K0 937 084 F    HW: 1K0 937 084 F
   Component: BCM PQ35  B   110 0651
   Revision: 00110 AC
   Coding: 40180A3A802518E0400000C0100000E44B010E88524D8960648000000040
   VCID: 312AE8CE6830ECC262-8064
   Subsystem 1 - Part No: 5M0 955 119 D
   Component: Wischer 10061  26  0513
   Coding: 009795
   Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Component: AirbagVW10    013 0613
   Serial number: 003G6RA2JTC
   Coding: 00003236
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3228E7C26536D7DA1B-8066
   Subsystem 1 - Part No SW: 5M0 955 557     HW: 5M0 955 557
   Serial number: 3572MSME6975105DZZZ$
   Subsystem 2 - Part No SW: 5M0 955 557     HW: 5M0 955 557
   Serial number: 3582MSME2D4B425CZZZ4
   Serial number: 3511HSME021C7D27ZZZP
   Serial number: 3521HSME3D597C27ZZZ/
   Part No SW: 5K0 953 507 AS    HW: 5K0 953 549 C
   Revision: --------    Serial number:  90422KFG0012J
   Coding: 5080040000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 014A780E9010BC42D2-8054
   Part No SW: 5M0 920 962 A    HW: 5M0 920 962 A
   Component: KOMBI         H03 0605
   Coding: 470B00
   VCID: 2F2EEEB67604FA3274-807A
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 190611F2001153
   Coding: 359003
   VCID: 3522DCDE9C58C0E23E-8060
   Component: IMMO          H03 0605
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A983FA28D665F1A63-803E
   Part No SW: 5K0 959 701 F    HW: 5K0 959 701 F
   Component: Tuer-SG         009 2122
   Coding: 0000692
   VCID: 3522DCDE5C58C0E23E-8060
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 69     3201
   Revision: 00H20000
   VCID: 3424E1DA5722D9EA09-8060
   Part No SW: 5K0 959 702 F    HW: 5K0 959 702 F
   Coding: 0000692
   VCID: 3620DBD2415ECBFA37-8062
   Part No SW: 5M0 035 156 D    HW: 5M0 035 156 D
   Component: Radio         H42 0105
   Revision: R0000000    Serial number: VWZAZ1L2016749
   Coding: 0000020002
   VCID: 2A18FFA245E69F1AA3-807E
   Part No SW: 5K0 959 703 E    HW: 5K0 959 703 E
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   Part No SW: 5K0 959 704 E    HW: 5K0 959 704 E
   Coding: 0000144
   VCID: 373ED6D6465432F22C-8062
End----------(Elapsed Time: 00:52, VBatt start/end: 14.3V/14.3V)-----------
                Address 01: Engine       Labels: 03L-906-023-CAY.clb
Control Module Part Number: 03L 997 557 N    HW: 03L 907 425 C
  Component and/or Version: R4 1.6l TDI   H43 9981
           Software Coding: 08114014030500080000
            Work Shop Code: WSC 01357 011 00200
              ASAM Dataset: EV_ECM16TDI02103L997557N 003003 (VW36)
          P0653 00 [172] - Too High
                    Mileage: 117665 km
                    Date: 2089.14.19
                    Time: 02:26:17
                    Engine speed: 1307.50 /min
                    Normed load value: 34.1 %
                    Vehicle speed: 22 km/h
                    Coolant temperature: 19 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 14.344 V
                    Battery voltage: 13.1 V
                    Supply voltage of analog output 1-VCC_1: 4.95 V
                    Fuel high pressure sensor: unconditioned voltage-VP_PFU: 0.5518 V
                    Throttle valve adapter: uncond voltage actual value-V_THR[0]: 3.799 V
                    Voltage equivalent of valve for fuel metering-VP_CFB_VCV: 3.2877 V
6114 - Crankshaft Position Sensor (G28)
          P0336 00 [096] - Missing Tooth
                    Mileage: 117668 km
                    Date: 2089.14.19
                    Time: 02:30:39
                    Engine speed: 1429.50 /min
                    Vehicle speed: 39 km/h
                    Coolant temperature: 50 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 14.569 V
                    Engine speed: 1430 /min
                    Accelerator position: normalized-Accelerator position: 43.55 %
                    Battery voltage: 14.6 V
6110 - Crankshaft Position Sensor (G28)
          P0335 00 [096] - Malfunction
                    Mileage: 117672 km
                    Date: 2089.14.19
                    Time: 02:44:24
                    Engine speed: 0.00 /min
                    Vehicle speed: 79 km/h
                    Coolant temperature: 69 °C
                    Intake air temperature: 14 °C
                    Engine speed: 0 /min
                    Accelerator position: normalized-Accelerator position: 0.00 %
                    Battery voltage: 14.3 V
7597 - Control Module Malfunction - DBW Throttle Monitoring
          P1388 00 [172] - -
                    Mileage: 117668 km
                    Date: 2089.14.19
                    Time: 02:30:50
                    Engine speed: 2032.75 /min
                    Normed load value: 43.9 %
                    Vehicle speed: 55 km/h
                    Environmental conditions-LV_TQI_MON_ACT_MON: 00000001
                    Environmental conditions-VP_MU_AN_DIG_MON: 1.8750 V
                    Environmental conditions-VP_MC_AN_DIG_MON: 1.4502 V
Readiness: 1 2 0 0 0
Many thanks!
Jim
Gone But Not Forgotten
Hey Jim,
I bet the alternator is wigging out in overcharge condition from weak battery, connectivity issue or plain old faulty regulator. Be sure to check if supported by LIN & BCM is making correct load requests with ECU. Don't forget to check for faulty freewheel clutch on alternator serpetine too!
Load test G28 tracks and inspect ECU for water ingress.
Change G28....
Jim Beagley
C?ID=349735
Thanks Jack - good point about the alternator - i'll check the voltages and connections. I thought the 'B' voltage was a stabilised 5V reference voltage put out by the ECU to supply the sensors - can this be affected by the alternator voltage?
I've replaced many of the freewheeling clutched pulleys, but usually because they make a noise. I didnt realise it could alter the alternator output. I'll check it out...
Many thanks
