Carbon cleaning, now stuck intake valve...
eppy
Maryland, USA
C?ID=178355
2011 GTI
135,000 miles
Chains and tensioner replaced my local VAG shop less than 5000 miles ago with OEM parts.
Car was throwing intake code 008213 for a couple of months but still getting 30MPG.
One day I was getting a miss fire so decided it was time to rip it apart.
I'm doing valve cleaning, new intake manifold, sent the injectors out for ultrasonic cleaning, and new water pump.
I noticed that the far right intake valve is not opening or closing when I turn the motor over. All other valves operate properly. I have spun the motor by hand and by cranking with the fuel pump fuse out. The valve never moves, stayed in the closed position at all times.
When I was doing the cleaning I may have spun the motor counter clockwise not knowing till after the fact to spin it clockwise. I was only spinning the motor with pulling/ pushing on the belt so I didn't get many turns on it. Even then I never remember the valve opening or closing.
When I cranked it over with the battery/ starter nothing sounded "bad".
Thoughts? Did my screw up throw something off with the timing?
Wouldn't more than one valve be doing that if that were the case?
:banghead::banghead::banghead::banghead:.
EDIT: Someone from another forum suggested the valve may have bent BEFORE this causing the misfire.
I just pulled the codes and the codes are -
008213
000768
000770
000769
008817
000772
On another note 1 of the 4 injectors would not stop leaking and the cleaning company suggested replacing as it will leak fuel into the cylinder after the car is off.
eppy
Maryland, USA
C?ID=178355
**** sorry about the cross post *******
2011 GTI
135,000 miles
:banghead::banghead::banghead::banghead::banghead:
008213
000768
000770
000769
008817
000772
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Uh... video? Having a hard time visualizing how that could happen without seriously damaged or outright missing parts.
Do you perhaps mean stuck open rather than stuck closed?
Try to avoid doing that, but you probably didn't hurt anything.
It's a decent possibility.
008213
000768
000770
000769
008817
000772
Complete un-edited Auto-Scan please. Looking up fault codes manually is a super PITA and we would still be missing all the fault elaboration and freeze-frame data.
rhinopower
C?ID=58979
If the valves arent moving, i would be taking the rocker cover off and see whats happening. If the camshaft snapped, are the lifters moving etc
Gone But Not Forgotten
Excuse me but does anyone know if carbon cleaning of plugged intakes or timing chain replacement or adjuster are now considered preventive maintenance as required in the RTFB during useful life warranties & being shifted to consumers for responsibility?
:p ........ fəˈsēSHəs
eppy
Maryland, USA
C?ID=178355
Please post a complete auto-scan & OBD2 data MODES 1,3,7&9.
Is this car modified?
Have you read the entire JPPSG thread?
I'm sorry I did not, but have now.
Car is modified-
HPA KO4 with all supporting mods, intake, full turbo back, turbo pipes, intercooler.
Clutch, LSD, and other things that would not be related to this issue.
The codes at the bottom of the list are from trying to crank with the battery/starter with the car apart so its throwing codes for stuff that is disconnected.
Video - https://youtu.be/BeBuX9DIpdM
I start at the affected cylinder pan to the others and back to the affected one.
Thursday,02,May,2019,21:51:38:09276
VCDS Version: Release 18.9.0 (x64) Running on Windows 10 x64
                Address 01: Engine       Labels: 06J-906-026-CCT.clb
Control Module Part Number: 1K0 907 115 AS    HW: 1K0 907 115 AA
  Component and/or Version: 2.0l R4/4V TFSI     0010
           Software Coding: 0403010A18070160
            Work Shop Code: WSC 59851 128 16480
                      VCID: 77D309CF06E978F2EA-8022
19 Faults Found:
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 212766 km
                    Date: 2027.14.23
                    Time: 05:43:47
                    RPM: 2437 /min
                    Load: 58.0 %
                    Speed: 83.0 km/h
                    Temperature: 36.0°C
                    Temperature: 7.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.224 V
                    Mileage: 215628 km
                    Date: 2028.14.21
                    Time: 14:48:05
                    RPM: 1462 /min
                    Load: 65.1 %
                    Speed: 30.0 km/h
                    Temperature: 95.0°C
                    Temperature: 31.0°C
                    Voltage: 13.843 V
               P0300 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 216655 km
                    Date: 2029.14.02
                    Time: 10:56:40
                    RPM: 1163 /min
                    Load: 38.0 %
                    Temperature: 27.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.716 V
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected - MIL ON
                    Mileage: 216655 km
                    Date: 2029.14.02
                    Time: 10:56:44
                    RPM: 1119 /min
                    Load: 35.7 %
                    Temperature: 27.0°C
                    Temperature: 29.0°C
                    Voltage: 14.097 V
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected - Intermittent - MIL ON
                    Mileage: 216787 km
                    Date: 2029.14.03
                    Time: 10:29:58
                    RPM: 965 /min
                    Load: 33.7 %
                    Temperature: 45.0°C
                    Temperature: 24.0°C
                    Voltage: 14.097 V
008817 - Oxygen (Lambda) Sensor Signal B1 S2
               P2271 - 000 - too Rich - Intermittent
                    Mileage: 217068 km
                    Date: 2029.14.08
                    Time: 20:18:21
                    RPM: 2771 /min
                    Load: 10.2 %
                    Speed: 112.0 km/h
                    Temperature: 94.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.716 V
000772 - Cylinder 4
               P0304 - 000 - Misfire Detected - Intermittent
                    Mileage: 217124 km
                    Date: 2029.14.09
                    Time: 06:22:23
                    RPM: 3693 /min
                    Load: 28.2 %
                    Speed: 149.0 km/h
                    Temperature: 94.0°C
                    Temperature: 30.0°C
                    Voltage: 13.716 V
000290 - Throttle Position Sensor (G69)
               P0122 - 000 - Signal too Low - MIL ON
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 18.0°C
                    Temperature: -40.0°C
                    Voltage: 11.938 V
000546 - Angle Sensor 2 for Throttle (G188)
               P0222 - 000 - Signal Too Low - MIL ON
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 18.0°C
                    Voltage: 11.938 V
008212 - Intake Manifold Flap Position Sensor (Bank 1)
               P2014 - 000 - Electrical Malfunction
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 18.0°C
                    Voltage: 11.938 V
000568 - Manifold Pressure / Boost Sensor (G31)
               P0238 - 000 - Signal too High
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 18.0°C
                    Voltage: 11.938 V
000400 - Fuel Pressure Sensor (G247)
               P0190 - 000 - Circuit Malfunction
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 18.0°C
                    Voltage: 11.938 V
001152 - Coolant Fan Control Circuit 1
               P0480 - 000 - Electrical Malfunction
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 18.0°C
                    Voltage: 11.938 V
001092 - EVAP Purge Control Valve (N80)
               P0444 - 000 - Circuit Open
                    Mileage: 217197 km
                    Date: 2029.14.10
                    Time: 00:00:21
                    RPM: 209 /min
                    Load: 100.0 %
                    Temperature: 18.0°C
                    Voltage: 10.668 V
008200 - Intake Manifold Flap; Bank 1
               P2008 - 000 - Electrical Malfunction
                    Mileage: 217197 km
                    Date: 2029.14.10
                    Time: 00:00:21
                    RPM: 209 /min
                    Load: 100.0 %
                    Temperature: 18.0°C
                    Voltage: 10.668 V
000275 - Intake Air Temp. Sensor (G42)
               P0113 - 000 - Signal too High
                    Mileage: 217197 km
                    Date: 2029.14.10
                    Time: 00:00:21
                    RPM: 215 /min
                    Load: 100.0 %
                    Temperature: 18.0°C
                    Voltage: 10.795 V
000112 - Sensor for Ambient Air Temperature (G17)
               P0070 - 000 - Malfunction
                    Mileage: 217197 km
                    Date: 2029.14.10
                    Time: 00:00:22
                    RPM: 216 /min
                    Load: 100.0 %
                    Temperature: 18.0°C
                    Voltage: 10.668 V
000835 - Camshaft Position Sensor (G40)
               P0343 - 000 - Signal too High - MIL ON
                    Mileage: 217197 km
                    Date: 2029.14.10
                    Time: 00:00:23
                    RPM: 215 /min
                    Load: 100.0 %
                    Temperature: 18.0°C
                    Voltage: 10.668 V
000256 - Mass Air Flow Sensor (G70)
               P0100 - 000 - Supply Voltage
                    Mileage: 217197 km
                    Date: 2029.14.10
                    Time: 00:00:24
                    RPM: 200 /min
                    Load: 100.0 %
                    Temperature: 18.0°C
                    Voltage: 11.684 V
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Wow.
That valve does look reasonably well closed and sealed, although you'd have to compression test to be absolutely certain. If it was bent, it'd be stuck at least partly open. Valve cover needs to come off for further diagnosis. If you're lucky, that's just a collapsed hydraulic lifter. If you're not lucky, there's a fully wiped out cam lobe, or some other parts fell off and started dancing around.
eppy
Maryland, USA
C?ID=178355
Wow.
100% sealed as the chamber held cleaning fluid when I was working on the valve.
Thoughts on this being a pre-existing issue that was throwing the misfire code or my shade tree ass messing something up?
I never checked the codes when it started to misfire, I drove it home, parked it, and torn it apart, thinking it was manifold/ carbon related.
The only questionable thing I did was possibly spinning the engine backwards during the cleaning.
Okay so no warranty, Emissions defeats and a most likely broken timing chain or sheared camshaft.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
There's an excellent probability this was the origin of your misfire.
There's no possible way you did that by rolling the engine backwards a little by hand.
Valve cover needs to come off for further diagnosis. I think Jack might be right about just outright breaking the camshaft.
eppy
Maryland, USA
C?ID=178355
I think the car will be heading to the shop for any further investigation.
I hope that this has nothing to do with the chains and tensioner work they did less than 5000 miles ago...... :confused:
Thanks for the help guys.
MVB_
C?ID=164610
Why not pull the PCV on this TSI and take a look at the intake cam valve train for #4. Maybe the rocker is missing. Example from FSI "race car" that was over revved.
eppy
Maryland, USA
C?ID=178355
MVB,
I'll pull the PVC this weekend and look, I didn't know that was an option.
The car did have an over rev years ago. 4th to 1st I think, locked the front wheels, one and only time I have done that in 27 years of driving.
The car didn't show any ill symptoms so I just kept driving it.
Maybe the rocker was "hanging in there" and finally gave up?
Threads merged into the General VW/Audi Repair section, which is the right place for this because a strictly mechanical problem like this has doesn't have much if anything to do with with VCDS.
MVB_
C?ID=164610
MVB,
You will have a nice widow to take a look-see
Yeah!..........and diagnostics are crippled anyway & causing VCDS to operate blind! :cry:
Tear it down OP!
PICTURES!
Pick a card any card & that labels the percent of catastrophic damage!
Z
eppy
Maryland, USA
C?ID=178355
Tear it down OP!
PICTURES!
Z
I'll report back with pics. :cry:
Zenerdiode
Newcastle, England
C?ID=24330
If a hydraulic lifter had bled down completely (burst or something) would it still produce even a little lift? However, as Max has suggested, you may have popped a rocker sometime...
p.s. Watching your little video; turning the engine over by hand, I can tell you are turning it correctly due to 1-3-4-2-(1). That sequence is burned into my head. :)
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
On reflection, I would think so, yeah. I don't know if they can even collapse that far mechanically if empty. The hydraulic component is just there to take up lash.
Something pretty awesome happened. Could be an ejected rocker arm, sheared camshaft, dunno. Looking forward to finding out. That PCV cover is will be a great window.
