1K Golf trans code 01299
HCAE
New Zealand
C?ID=213797
Hi All
Got this one here, has been stolen and recovered, steering shroud etc was smashed. Had multiple codes for steering wheel stuff and what not. had missing fuses which I have fitted and only have 1 last fault as seen below. I have tried a second hand module and have the same fault. It comes back straight away after clearing. Please help!
Cheers
Wednesday,01,May,2019,15:22:33:55685
VCDS Version: 18.9.1.0 (x64)
VIN: WVWZZZ1KZ5U000924   License Plate: GGK741
Mileage: 142930km-88812mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 62 72
VIN: WVWZZZ1KZ5U000924   Mileage: 142930km-88812miles
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 906 056 BN    HW: Hardware No
   Component: MED9.5.10        00 9271
   Revision: 00000000    Serial number: VWZ7Z0D0124052
   Coding: 0000075
   Shop #: WSC 00046 412 00000
   VCID: 70EFC2BB637A96CA2D-8024
Readiness: 1110 0101
   Part No: 09G 927 750 FA
   Component: AQ 250 6F           0843
   Coding: 0000072
   VCID: 75E1F3AF1C18B3E2FE-8020
   Part No: 1K0 907 379 M
   Component: ESP FRONT MK60      0105
   Coding: 0019074
   VCID: 3C77268B7FB222AAC1-8068
   Part No: 1K0 820 047 CR
   Component: Climatic PQ35   081 0404
   VCID: 76E3F4A3011EB8FAF7-8022
   Part No SW: 1K0 937 049 S    HW: 1K0 937 049 S*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000826335
   Coding: 008D0F0600041800001400001400000000
   VCID: 3F8D51876EA439B2E4-806A
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00049109
   Part No SW: 1K0 909 605 F    HW: 1K0 909 605 F
   Component: 02 AIRBAG VW8R  023 5600
   Revision: 07023000    Serial number: 0037RD0491G.
   Coding: 0012338
   VCID: 2F6D01C7BEC4C93274-807A
   Subsystem 1 - Serial number: 6332MSME0329054B5
   Subsystem 2 - Serial number: 6342MSME0328093A7
   Subsystem 3 - Serial number: 6351HSME02530E461
   Subsystem 4 - Serial number: 6361HSME025B0C064
   Part No SW: 1K0 953 549     HW: 1K0 953 549
   Component: Lenksäulenmodul 012 0030
   Coding: 0010002
   VCID: 6FEDC1C77E44893234-803A
   Part No: 1K0 920 851 A
   Component: KOMBIINSTRUMENT VDD 0814
   Coding: 0003503
   Shop #: WSC 00999 444 64523
   VCID: 2643E4E3913E887A87-8072
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 21001045050319
   Coding: 3F3F0300070003
   Shop #: WSC 00046 412 12345
   VCID: 275DE9E796349172BC-8072
   Component: IMMO            VDD 0814
   Shop #: WSC 06402 145 00197
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX1.lbl
   Part No: 1K0 959 701 G
   Component: Tuersteuergeraet 09 0148
   Coding: 0000054
   VCID: 326B08B3ADF6E4DA1B-8066
   Part No: 1K2 909 144 F
   Component: EPS_ZFLS Kl.0       1301
   Part No: 1K0 959 433 BN
   Component: 01 KSG              0301
   Coding: 80C802087F2D8404085F01E010
   VCID: 7DF1EB8F2428EBA2B6-8028
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX1.lbl
   Part No: 1K0 959 702 G
   Coding: 0000054
   VCID: 33650DB752ECEDD210-8066
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0202
   Coding: 0000016
   VCID: 306F02BBA3FAD6CA6D-8064
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
   VCID: 316907BFA8F0DFC262-8064
End-------------------------(Elapsed Time: 01:34)--------------------------
Jef
HQ
NostraJackAss
Wiring or fuse faulty still most likely, not as likely a J217 but I'd might consider a gateway if wiring checks out.
Are all modules correct part numbers and firmware levels for compatibility?
Have you tried a twisted test overlay and ohmed out termination resistors in CAN?
HCAE
New Zealand
C?ID=213797
CAN Resistance is 60 ohms as expected. Good power and earth to TCM. Second hand TCM and Gateway make no difference.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
From our wiki web site:
If the fault is only found in one control module, then most likely that module is the issue.
http://wiki.ross-tech.com/wiki/index.php/01299
I'd get my hands on the J217 TCM module and start with verifying the powers/grounds/data electrical paths are to factory design.
'tis true for the No Communications origin, but this is Implausible Signal, which means it's receiving stuff but doesn't like something about what it received. I'd hunt for some other piece of sad or incorrect or miscoded hardware the transmission expects to hear from regularly. Including but not limited to:
I don't see this in PartsLink24 as a valid ABS module for your VIN, or in fact any 2005 Golf.
So...
Let's talk more about "steering wheel stuff and what not." Has the ABS module been replaced? Have any other modules been replaced or recoded?
HCAE
New Zealand
C?ID=213797
Interesting, I had a look at the coding of the ABS and it was a bit strange, I shall investigate this further on Monday....... Thanks!
HCAE
New Zealand
C?ID=213797
Certainly doesn't look like the ABS module has been touched, the number on the Pump sticker is 1K0 614 517K as per the picture. Only thing I have noticed is the MVB in the TCM 126-2 Distance regulation (J428) and 126-3 Steering Aid (J500) both read 0. Is that strange? didn't think the car had distance regulation.... but why is Steering Aid 0??
HCAE
New Zealand
C?ID=213797
Any thoughts on what the ABS coding should be? the PR codes don't match what the wiki suggest....
ABS/EDS/ASR/ESP (MK60)
Model:
+0000000 = Audi A3 (8P) / Seat Leon (1P) / VW Golf/Jetta (1K) / Skoda Octavia (1Z)
+0000064 = VW Touran (1T)
+0000080 = VW Caddy (2K)
+0000096 = VW Eos (1F)
+0000112 = Seat Altea/Toledo (5P) / VW Golf Plus (5M)
Frontbrakes (Sensor Cluster OLD):
+0000005 = FS III 54 15" (PR-1ZF/1ZM/1ZC)
+0000006 = FN III 54 15"/16" (PR-1ZE/1LJ/1ZP/1ZD/1LL)
+0000009 = FRNG 57 17" (PR-1LK)
Frontbrakes (Sensor Cluster NEW):
+0000001 = FS III 54 15" (PR-1ZF/1ZM/1ZC)
+0000002 = FN III 54 15"/16" (PR-1ZE/1LJ/1ZP/1ZD/1LL)
+0000008 = FRNG 57 17" (PR-1LK)
Suspension:
+0000640 = Standard/Sport Suspension (PR-2UA/2UC OR PR-UA0/UA1/UA9)
+0001152 = Rough Road/Comfort Suspension (PR-2UB/2UD OR PR-UA2)
Engine:
+0002048 = 1.4l / 1.6l & 1.6l FSI
+0004096 = 1.9l TDI PD / 2.0l FSI / 2.0l SDI PD & All with Automatic Transmission
+0006144 = 2.0l TDI PD
Tire Pressure Monitoring (TPMS):
+0000000 = with ABS based Tire Pressure Monitoring (PR-7K1/7K6)
+0016384 = without ABS based Tire Pressure Monitoring (PR-7K0/7K4/7K8)
PRCode: 0AD = Front stabilizer
PRCode: 0BD = Rear stabilizer
PRCode: 0TD = Front and rear floor mats
PRCode: 0YC = Weight range 3 installation control only no requirement forecast
PRCode: 1AS = Electronic stabilization program (ESP)
PRCode: 1G9 = Space-saving spare wheel for temporary use radial tire (5-hole)
PRCode: 1JA = Rear shock absorption basic design 1
PRCode: 1KD = Disc brakes rear
PRCode: 1NC = Full wheel covers
PRCode: 1ZP = Disc brakes front (Geomet D)
PRCode: 2JB = Standard bumpers
PRCode: 3U1 = Foldable trunk cover
PRCode: 3YQ = Door pockets without insert mats
PRCode: 4K3 = Radio remote controlled central locking operated from inside and safe securing
PRCode: 4R4 = Power windows with comfort operation andcircuit breaker
PRCode: 4UF = Driver's and front passenger air bag with front passenger air bag deactivation
PRCode: 4X4 = Side air bag front and rear with curtain air bag
PRCode: 5RV = Right exterior mirror: aspherical
PRCode: 5SJ = Left exterior mirror: convex
PRCode: 5TC = Without decorative inserts
PRCode: 8AM = Radio for Japan
PRCode: 8GG = Alternator 110 A
PRCode: 8RW = 10 speakers (passive)
PRCode: 8ZK = Antenna for AM/FM reception diversity(for Japan)
PRCode: B0L = Component parts set complying with vehicle type for Japan various parts
PRCode: C8V = Steel wheels 6J x 15
PRCode: E0A = No special edition
PRCode: G07 = Front shock absorption
PRCode: G1A = 6-speed automatic transmission
PRCode: H7F = Tires 195/65 R15 91H
PRCode: J1L = Battery 280 A (60 Ah)
PRCode: L06 = Suspension range 06 installation control only no requirement forecast
PRCode: MM8 = 4-cyl. gasoline engine 1.6 L/85 kW 16V fuel-stratified injection base engine is T72
PRCode: N4C = Fabric seat covering
PRCode: QG1 = Service interval prolongation
PRCode: T72 = 4-cylinder gasoline engine 1.6 L unit 03C.E (aluminum)
PRCode: V0G = MICHELIN tires
PRCode: X8A = National sales program Japan (FBU)
Jef
HQ
So after checking everything about 5 times, turns out doing a kick down basic setting reset fixed the issue... who'd have thought?!
I wonder if it is possible there was a fretting issue that was resolved from unplugging and plugging back up.
