AUDI A1 8X Abs not coded fault
Pnr_coding
london
C?ID=301569
Hi guys i recently did some work on this audi a1 airbags to be specific, and now i have abs, traction and tyre light on. I didn't do a scan prior to work, well not with my vagcom so don't know what the long coding is, how can i get the right long coding? please help.
Chassis Type: 8X-AU21 (8U0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 5F
VIN: WAUZZZ8X6CB243319   Mileage: 27280km-16951miles
Address 01: Engine (J623-CAVG)       Labels:. 03C-907-309-V1.clb
   Part No SW: 03C 906 027 CF    HW: 03C 906 027 CF
   Component: 1.4l R4/4V TS H08 3064
   Revision: LFH08---    Serial number:
   Coding: 00250012000400000000
   Shop #: WSC 00046 790 00000
   ASAM Dataset: EV_ECM14TSI01103C906027CF 001007
   ROD: EV_ECM14TSI01103C906027CF.rod
   VCID: 6788B2D6CFE0148F3F7-8032
4650 - Brake Booster Pressure Sensor
          P0557 00 [039] - Short to GND
                    Mileage: 27286 km
                    Date: 2019.03.24
                    Time: 21:50:14
                    Engine speed: 0.00 /min
                    Coolant temperature: 78 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 11.968 V
                    Mass flow through throttle valve: 0.0 kg/h
                    Median injection timing: 0.000 ms
                    Engine operating condition: Idling
Readiness: 1110 0101
   Part No SW: 0AM 300 053 G    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 3072
   Revision: 00043014    Serial number: CU501203196852
   Shop #: WSC 00046 000 00000
   VCID: 303A198A363E93372ED-513C
Address 03: ABS Brakes
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 8X0 820 043 B    HW: 8X0 820 043 B
   Component: Klima 1 Zone  H12 0070
   Serial number: 00000000123049
   Coding: 6420000000
   ASAM Dataset: EV_AirCondiFrontAU210 006035
   ROD: EV_AirCondiFrontAU210_006.rod
   VCID: 33301686CBB8A82F53F-8066
Address 09: Cent. Elect.
   Part No SW: 8X0 959 655 B    HW: 8X0 959 655 B
   Component: Airbag10.41   H05 0009
   Revision: --------    Serial number: 003KZ001BAD7
   Coding: 30314539303330303034554A305238583053
   ASAM Dataset: EV_Airba1041BPAAU210 001018
   ROD: EV_Airba1041BPAAU210.rod
   VCID: 49CC546EB934C2FF093-801C
   Serial number: 3554VRB404T0R8AC20T$
   Serial number: 3575HRB405N1TEI4DP2+
   Serial number: 3585HRB405N1TEI47H1R
   Rear Impact Crash Sensor:
   Serial number: 3515ZRB40610OPMM61Q9
   Part No SW: 8X0 953 501 B    HW: 5K0 953 569 H
   Revision: FF010017    Serial number: 20120423100292
   Coding: 1994004000
   VCID: 392C24AEE9D4527F993-806C
365080 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
                    Reset counter: 246
                    Mileage: 27286 km
                    Date: 2019.03.24
                    Time: 21:51:25
1140738 - Steering angle sensor
                    Reset counter: 246
                    Mileage: 27286 km
                    Date: 2019.03.24
                    Time: 21:51:25
                    UBat: 12.10 V
                    MC1 interner Fehlercode: 0
                    MC2 interner Fehlercode: 0
   Part No SW: 8X0 920 980 E    HW: 8X0 920 980 E
   Component: KOMBI_MEDIUM  H03 0180
   Coding: 43DE00
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390
   VCID: 41DC4C4E81040ABFD13-8014
   Part No SW: 8U0 907 468 G    HW: 8U0 907 468 G
   Component: GAT 4CAN 1L M H13 0058
   Revision: 1P090032    Serial number: 3241P124170370
   Coding: F0C40064000100010153
   VCID: 46D65F52A8AA2D87E41-8012
   Component: IMMO          H03 0180
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
   ROD: EV_Immo_UDS_VDD_AU10.rod
   Part No SW: 8X0 959 793 K    HW: 8X0 959 793 K
   Component: TSG FA        H10 0415
   Coding: 011E02200C01000100
   VCID: 55F4881E650C961F9DB-8000
   Part No: 6R0 423 156 B
   Coding: 11251
   Shop #: WSC 00046
   VCID: 2F381AF62E508CCF377-807A
Address 46: Central Conv.
   Part No SW: 8X0 959 792 K    HW: 8X0 959 792 K
   Component: TSG BF        H10 0415
   VCID: 54F2751A6EF68F176A5-8000
   Part No SW: 8X0 907 357 B    HW: 8X0 907 357 A
   Component: ****LWR12**** H02 0021
   Serial number: 120419-0001-166
   Coding: 1131941010002400
   ROD: EV_HeadlRegulBasic.rod
0077 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
          [Fehlerhaftes Signal in CAN-Message mBremse_2 (0x5A0)]
                    Reset counter: 246
                    Mileage: 27286 km
                    Date: 2019.03.24
                    Time: 21:52:01
393989 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 246
                    Mileage: 27286 km
                    Date: 2019.03.24
                    Time: 21:52:00
   Part No SW: 8X0 035 193 E    HW: 8X0 035 193 D
   Component: RMC Cnct Nav  H52 0775
   Coding: 01010001008051070023000103010000000000
   VCID: 3A2E3BA2EC525967909-806E
   Subsystem 1 - Part No SW: 8X0 919 603     HW: 8X0 919 603
   Component: DU6 Basic  H42 0084
   Serial number: 9462D.0C2544982
South Molton, UK
Your problem most likely isn't coding - it's that three modules cannot be reached (ABS, Cent Elect and Central Conv).
Pnr_coding
london
C?ID=301569
Thank you, when I did the first scan it said not coded, I'll go back to the drawing board.
Pnr_coding
london
C?ID=301569
Audi A1 abs long coding
I am trying to input new long coding number supplied by visvag but it won't accept, there is a warning from vis4vag suggesting I may need to contact you guys as my manufacturer for my diagnostic device please help me this is stressing me out.
South Molton, UK
For us to be able to suggest ABS coding you'll need to post a full unedited VCDS Auto-Scan here - see my signature for a link to a HowTo.
Pnr_coding
london
C?ID=301569
thanks for such a rapid response petroldave, I hope I've done that right. my battery voltage is low but only because I've been at this for hours I had to jump start my car and run it just to get the voltage backup
VIN: WAUZZZ8X6CB243319 Mileage: 27730km-17230miles
VCID: 6788B2D6CFE0148F6B3-8032
VCID: 303A198A363E93377A9-513C
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BB HW: 6R0 907 379 AH
Component: ESP8.2i front H07 0001
Revision: --------
Coding: 000000000000000000000000000000000000
VCID: 7F580AB6B7B0BC4FB33-802A
Coding: 6420000000
VCID: 33301686CBB8A82F07B-8066
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 G HW: 8X0 907 063 G
Component: BCM PQ35 M 110 0655
Revision: 00110 AE
Coding: 0E000A28A805F100201843E02100894C53FF721721215922E40800870040
Shop #: WSC 00046 123 12345
VCID: 40DA494A8A8E03B78A9-8014
Subsystem 3 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
VCID: 49CC546EB934C2FF5D7-801C
Coding: 1994000000
Shop #: WSC 00046 790 12345
VCID: 392C24AEE9D4527FCD7-806C
Reset counter: 34
Mileage: 27732 km
Date: 2019.08.23
Time: 16:39:09
Reset counter: 34
Mileage: 27732 km
Date: 2019.08.23
Time: 16:39:09
UBat: 11.30 V
Coding: 43DC00
VCID: 41DC4C4E81040ABF857-8014
VCID: 46D65F52A8AA2D87B05-8012
Coding: 000002
VCID: 55F4881E650C961FC9F-8000
Coding: 11251
Shop #: WSC 00046
VCID: 2F381AF62E508CCF633-807A
Coding: 011E02200C01000102
VCID: 54F2751A6EF68F173E1-8000
Coding: 1131941010000400
393989 - Headlight
Reset counter: 34
Mileage: 27732 km
Date: 2019.08.23
Time: 16:39:28
VCID: 3A2E3BA2EC525967C4D-806E
End----(Elapsed Time: 01:31, VBatt start/end: 11.2V/11.2V. VIgn 11.2V)-----
What caused this ABS to lose coding and why do you not have a prior scan? ;)
Pnr_coding
london
C?ID=301569
Hello uwe, stupidly I never scanned the car upon purchase I won't be making that mistake again, I bought it as a salvage car and changed the airbags I also had the battery off for several days as I was doing the work in between my regular job
Pnr_coding
london
C?ID=301569
I'm still learning about the do's and don'ts of vcds. I've had it for some time now but never really applied myself but now I want to learn all I can as I am now considering buying damaged cars and repairing them as a hobby.
iichel
Eindhoven, NB, NL
C?ID=284912
First guess: 330448E9436E00BBCC2512E2C2D500890D00
Pnr_coding
london
C?ID=301569
Thank you iichel I will try this now
Pnr_coding
london
C?ID=301569
Unfortunately that didn't work but thanks iichel, is it something I'm doing wrong?
Pnr_coding
london
C?ID=301569
Sorry petrol Dave, I think this may be due to my voltage falling under the threshold, but the original fault was no coding, the long coding consisted of multiple zeros
South Molton, UK
So please post an Auto-Scan showing the car in that state where all the modules can be communicated with :thumbs:
United States
Hi guys,
There were 2 threads related to this car which are merged into one at this time. I have an e-mail from the OP in Support and I'll report back here if we have any coding suggestions.
United States
Based on this random RHD UK market scan found online: https://www.audi-sport.net/xf/threads/instrument-coding-on-an-a1.135453/#post-1552614
.. the PR-Codes (after I reconstructed that VIN based on ABS coding) are a near identical match to this car. The differences are insignificant; With / Without Connectivity package, Nav, Steering wheel Flappy paddles, etc. The Engine, Trans, Drive-side, Brakes, 7K0 TPMS and similar are identical.
The ABS baseline coding breaks down as follows:
Complete​
330448E9436D00B9CC2D12EAC2D600890D00
Complete w/o VIN​
3300480043000000CC001200C20000890D00
Shortened w/o VIN​
33484300CC12C200890D00
Next, Slipping in VIN Bytes for the car in question (WAUZZZ8X6CB243319) results in:
330448E9437100B5CC2812E3C2DA00890D00
That's the same shortened coding as iichel's - but my VIN digits aren't the same as his. I'm not extremely confident when it comes to RoW 6R ESP8.2i front and I may be using the wrong VIN chart ... but Pnr_coding please see it my coding string is accepted at some point:
iichel
Eindhoven, NB, NL
C?ID=284912
I sent you an email Dana on suppprt@
Pnr_coding
london
C?ID=301569
Thank you so much dana, code 330448E9437100B5CC2812E3C2DA00890D00 worked, I still have the traction light on for some reason but the abs and tire light have gone, 2 down and one to go, also thanks to all other help it is really appreciated.
South Molton, UK
If you could post an up-to-date Auto-Scan it would help us to help you ...
