Mk5 GTI lost abs coding (MK60EC1)
Fredrick Awuor
Kenya
C?ID=309834
Hi guys,below is an autoscan of a 2009 GTI that had its ABS/ESP control replaced with an updated one elsewhere, owner claims the old one lost and refused to communicate.....unfortunately I forgot to check Advanced ID of cluster,Immo and ECU,however I think they've not been tampered with.....any help is greatly appreciated
Friday,26,April,2019,10:58:39:21182
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
VIN: WVWZZZ1KZ9U005513   License Plate: KCH629S 2.OL GTI
Mileage: 98060km-60931mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 62 72
VIN: WVWZZZ1KZ9U005513   Mileage: 98060km-60931miles
03-ABS Brakes -- Status: Not registered 0011
   Part No SW: 1K0 907 115 Q    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0H43ND86H
   Coding: 040300431C070160
   Shop #: WSC 00046 412 00000
   VCID: 34311E55A23E44474A5-8060
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow
                    Fault Status: 01100010
                    Fault Frequency: 11
                    Mileage: 97587 km
                    Time: 00:20:19
                    RPM: 758 /min
                    Load: 16.9 %
                    Temperature: 75.0°C
                    Temperature: 34.0°C
                    Absolute Pres.: 830.0 mbar
                    Voltage: 14.097 V
001056 - Catalyst System; Bank 1
               P0420 - 002 - Efficiency Below Threshold - MIL ON
                    Fault Status: 11100010
                    Mileage: 97626 km
                    Time: 23:01:24
                    RPM: 1370 /min
                    Load: 31.0 %
                    Speed: 57.0 km/h
                    Temperature: 85.0°C
                    Temperature: 39.0°C
                    Voltage: 13.970 V
   Part No SW: 02E 300 041 A    HW: 02E 927 770 AD
   Component: GSG DSG         041 0821
   Revision: 00004010    Serial number: 00000409220170
   Shop #: WSC 01279 785 00200
   VCID: 1079B2C5F66658670ED-8044
01208 - Data Records in Control Unit Altered
            000 -  -
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 30173 002 1048576
   VCID: 00598285AA0628E79ED-8054
                    Fault Status: 01100101
                    Reset counter: 0
                    Mileage: 97848 km
                    Count: 7
                    Count: 14
                    Count: 12800
                    Count: 279
                    Count: 44032
                    Reset counter: 0
                    Mileage: 97848 km
                    Count: 7
                    Count: 14
                    Count: 12800
                    Count: 295
                    Count: 44032
                    Reset counter: 0
                    Mileage: 97848 km
                    Count: 7
                    Count: 14
                    Count: 12800
                    Count: 270
                    Count: 44032
            000 -  -
                    Reset counter: 64
                    Mileage: 97848 km
                    Count: 7
                    Count: 14
                    Count: 12800
                    Count: 195
                    Count: 44032
   Part No SW: 1K0 907 044 DD    HW: 1K0 907 044 DD
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 6C81C635BA8EDC87525-8038
   Revision: 00H54000    Serial number: 00000008542185
   Coding: E78F0F2700041500471400001400000000097F075C000100000000000000
   VCID: 33331D49A730437F53F-8066
   Component: Wischer 250808 020  0501
   Coding: 00049109
   Shop #: WSC 00046
   Component: RLS     020708 046  0204
   Coding: 00733221
   Shop #: WSC 00046
01506 - Bulb for Rear Fog; Right (L47)
                    Fault Status: 00101100
                    Reset counter: 116
                    Mileage: 97848 km
                    Voltage: 12.10 V
   Component: 15 AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0BD5R3
   Coding: 0012597
   Subsystem 1 - Serial number: 6332MSME37550214+
   Subsystem 2 - Serial number: 6342MSME3B320A225
   Subsystem 3 - Serial number: 6352QSME691C1767Q
   Subsystem 4 - Serial number: 6362QSME685B134FV
   Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
   Component: J0527           752 0101
   Coding: 0012142
   VCID: 04518E95B21E34C7BA5-8050
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
   Part No SW: 1K6 920 864     HW: 1K6 920 864
   Component: KOMBIINSTRUMENT VDD 1214
   Revision: V0002000    Serial number: VWX7Z0H43ND86H
   Coding: 0007503
   Shop #: WSC 00000 263 1385455
   VCID: 6FBBD1398B98279F777-803A
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 080608F1001131
   Coding: E5817F060000020003
   Shop #: WSC 55455 002 1048576
   VCID: 35372351A9445D4F7DB-8060
            000 -  -
                    Fault Frequency: 49
                    Mileage: 97848 km
                    Time: 19:59:58
   Component: IMMO            VDD 1214
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         006 1210
   Coding: 0000694
   VCID: 392F2F61855CB92F993-806C
00914 - Window Regulator Switch; Rear Left; Driver (E53)
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 69     2301
   Revision: 00H15000
   VCID: 2A0D002D70FA02B7E09-807E
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 899002005103087F2D0484056008DF03E0FCA0
   VCID: 71BFD7419DAC316F613-8024
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Coding: 0000950
   VCID: 3A2D306D805AB237909-806E
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74B1DE55E2BE04478A5-8020
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1301
   Coding: 0000144
   Shop #: WSC 00046 412 1012544
   VCID: 38292A65BE56A02766D-806C
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0000144
End----------(Elapsed Time: 01:13, VBatt start/end: 13.6V/13.8V)-----------
Gone But Not Forgotten
Vehicle Identification No.WVWZZZ1KZ9U005513
ModelGolf 2,0
GOLF
Date of production04.09.2008
Model year2009
Sales type1K13V3
Engine CodeBWA
Transmission CodeKPV
Part No SW: 1K0 907 115 Q HW: 8P0 907 115 B <<<<<<<<<<<<<<<<<<<< FOD CHECK! PASS!
Part No SW: 02E 300 041 A HW: 02E 927 770 AD <<<<<<<<<<<<<<<<<<<< FOD CHECK! SUSPECT CHECK LEGACY ! ( 051R )
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP <<<<<<<<<<<<<<<<<<< FOD CHECK Legacy PASS!
Revision: 00H45001
Coding:
134B000C092200FFC81000E5901C00000000 VIN STRIP RHD THIS IS NOT YOUR CODING!
Coding: 133B200D092200FFC81004E5901C00813500 RHD TPMS HH TRY THESE FREDDY!
Coding: 133B600D092200FFC81006E5901C00813500
Hey Freddy :
Please POST ADV ID SCREENS 0x01 & 0x025 !
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PCWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components0HAVehicle class differentiation -1K0-
tail pipe0P1Rear side exhaust tailpipe
drive-off assistanceUG1Hill hold control
Emission standard0GGEmission standard EU4
Trailer hitch1D0without trailer towing
airbag4UFAirbag for driver and front passenger with front passenger airbag deactivation
Aktivkohlebehälter / Ottopartikelfilter1E1Activated carbon canister
Aerials8ZKAntenna for AM/FM reception, "diversity" (for Japan)
Exterior mirror setting6XQExterior mirrors with memory feature, power-folding/adjustable, separately heated
Left exterior mirror5SJLeft exterior mirror, convex
Right exterior mirror5RVRight exterior mirror, aspherical
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WCWithout "Multimedia" in vehicle
Equipment levelsA8HTop sports equipment
Brake type in rear1KVDisc brakes in rear (Geomet D)
batteriesJ0LBattery 340 A (70 Ah)
Brake type, front1LVSilver caliper
Components with special surface6FFExterior mirror housing and various attachments colour coded to vehicle
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0LComponent parts set, complying with vehicle type for Japan, various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VAWithout owner's manual
Operating voltage9Z0Operating voltage 12 V
brake wear indicator9U1brake wear indicator
Heated washer nozzles9T0Without heated washer nozzles
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A1CD changer preparation
"Charism"2H0Without "drive select"
Chrome packageQJ0Without aluminum/chrome work package
General operating permit, alterationsC24Operating permit, alteration
Roof rails/roof load rack3S0Without roof rails/roof load rack
Roof insert/convertible top3FAroof without cut out
Suspension system in rear1JERear sports shock absorption
Suspension system in frontG08Shock absorption in front
Load-through hatch/ski bag3X0without load through system
Insert for the filling up of unleaded fuel/fuel type2G7Filler neck module 1 with insert
Installation differentiation for components0ESInstallation differentiation for transmission DQ250 -- vehicle components --
Theft protection system7AAElectronic immobilizer
Inserts5MDDecorative aluminum inserts
Scuff plates7M6Protective film for scuff plate
Park distance control7X0Without park distance control
Electric interface for external useUF0Without electric interface
Manufacturing sequence differentiation0FVSouth Africa manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Standard pedestrian protection measures
Pedal clusterVF1pedal cluster
Headlight activation8K8Low beam assistant with "Coming Home" function
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Weight category rear axle0YCWeight range 3 installation control only, no requirement forecast
Weight category front axleL99Suspension range 99 installation control only, no requirement forecast
Base engineT594-cyl. petrol engine 2.0 l assembly 06F.C
Luggage netting/pocket on backrest(s)4U5Luggage pockets on backrest
Luggage compartment cover3U3Luggage compartment cover with luggage net
cruise control system8T2Electronic cruise control system (CCS)
Garage door openerVC0without Garage door opener
Luggage compartment trim5A7Comfort luggage compartment trim with service lid/snap-on cover
Transmission specificationsG1A6-speed automatic transmission
Brackets3P1Bracket for first aid kit and warning triangle
handle for hand brake lever6PChandbrake lever grip (leather)
Rear spoiler5J4Body-colored rear spoiler
Rear window wiper and washer system8M1Rear window wiper washer system with intermittent wipe
Rear seats3NURear bench seat, not split, split backrest, folding centre armrest
Heating and air-conditioning system9AKClimatronic with impact pressure control, CFC-free
Headlamps8JXTwin headlamps for driving on the left (gas discharge) w/ integrated high beam
Customized installationFC0Without individual installation
Interior light in footwell6T1Interior light in footwell
Instrument clustersU5EInstrument cluster, km/h speedometer Japan
Breakaway interior rearview mirror4L6Breakaway interior rearview mirror, auto-dimming
Sticker (customized or special edition)0KAWithout decals and emblems
Body styleK8GHatchback
Cassette and CD storage unit4W0without cassette / CD tray
coolbox1W2Glove compartment cooling system
child safety4H3Manual child lock
Electronic map cooling systemQS0Without electronic map cooling system
Child seatsQA0without child seat
Climatic zones0Y2Tropical zones
Compass/road sign displayQR0Without compass/road sign display/ dynamic road sign display
headrest for seat, rear3Q6Three rear head restraints
Head restraints5ZHHead restraints for front seats, tilt- and height-adjustable with integrated adjustment mechanism
Fuel tank treatment2LDFuel tank without differentiation of special material treatment (fluorination/co-extrusion)
Fuel quantity for initial filling1Z2Increase in initial standard fuel filling
Fuel systems1A5Petrol injector fuel system (FSI)
Body measures5C0Without special body measures
Child seat anchors in front3G0Without child seat anchora in front (ISOFIX)
Rear license plate bracket6P4Rear license plate carrier (Japan)
Front license plate bracket6W4License plate bracket fr (small, Japan)
Paint preservative/transit coating5K4Full body cover (shape-adapted system) with additional transport protection measures
Paint coatingFB0standard paint coating
Rear cargo area3GAWithout luggage compartment floor
Steering system arrangementL0RRight-hand drive
Reading lamp8S4Two reading lights front, two rear
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H0Without backrest release for front seats
Air duct, front areaVK1Air duct, type 1
Load edge protection2P1Plastic loading edge protection
Lumbar support7P4Manually adjustable lumbar support in front seats
steering wheels1MSLeather-wrapped steering wheel with tiptronic
Speaker installation8RW10 speakers (passive)
Headlight range control8Q3Dynamic headlight range control (self-adjusting while driving)
Center armrest6E3Center armrest in front
Marten repellerUM0Without marten repeller
Multi-function display/trip computer9Q1Multi-function display/trip computer
Engine cooling8Z6Hot country
Engine specificationsD2L4-cylinder petrol engine 2.0 L/147 KW (16 V) Turbo FSI, homogeneous Basic engine is: T59/T61/TQ2/TU2/TD6/TN6
Left vanity mirror4SFLeft vanity mirror illuminated, with cover and pocket, extractable
Right vanity mirror4TFVanity mirror, right, illuminated, with cover and pocket, extractable
Navigation device7Q0without navigation system
rear fog lamp8TDRear fog light for driving on the left
Front fog lamp/additional headlamp8WDIntegrated front fog light
Upgrading measuresGP0Vehicles w/o special upgrade measures
Rear of platform module base4P0Rear floor panel module, type 1
Platform group class7PAPlatform group class 1
Hubcaps1NLTrims for alloy wheels
WheelsCG6Alloy wheels 7.5J x 17
Radios8AMRadio for Japan
Smoker's/non-smoker's package9JBSmoker's package, ashtrays in front and rear
Tire pressure monitoring system7K6Tire pressure monitoring system
tireH6LTires 225/45 R17 91W
Tire suppliersV0GMICHELIN tires
Spare wheel/breakdown kit1G9Space-saving spare wheel for temporary use, radial tire (5-hole)
Restraint systems, front3QT3-point seat belts in front, with tensioner and height adjustment
PAATray areas package 1
PH2Air conditioning Climatronic
PXRXenon light (right-hand drive)
W4B4-door incl. power windows rear
Side airbag4X4Side airbag in front and rear with curtain airbag
Gearshift knob/handle6Q6Gearshift knob/handle in aluminum
Special labels/plates0SLLabels in Japanese
Locking mechanism for boot lid/cover rear4E0Tailgate/trunk lid unlocking from outside
Front seat, left3TUSports seat, front left
Front seat, right3SUSports seat in front, right
Nameplates for sales nameQD0Without lettering for sales name
Seat belt check9P1Seat belt reminder, electric contact in buckle
Outer rear seat belts3ZB3-point seat belts, outer rear with ECE label
Center rear seat belts3C73-point seat belt for center rear seat
seat coversN2TSeat trim covers in fabric
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A0without seat heater
Safety head restraint system3K1with safety head restraint system
Side lights7R3Side turn signal lights (white)
Horns8Y1Two-tone horn
Control number (no PR family)S0TPre-production series/SOP next MY
Side and rear windows4KFheat protective glass for door, side and rear windows, darkened from b-pillar
Protective side molding4B2Body-colored protective side molding
Sunroof roller blind for rear/side windows3Y0without roller blind
Supertone system and tone sequence control9J0Without supertone system and tone sequence control
power outlet7B212 volt socket in luggage compartment
Bumper2JGbumper in color of vehicle
Rear stabilizer0BFRear stabilizer
Front stabilizer bar0AEFront stabilizer bar
Drawers under front seatsQN3Drawers under front seats
Heavy-duty/sports version2UCSports version
Headlamp washer system8X1Headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N3intermittent windscreen wiper with rain sensor
Special approval measures3M0Without special measures
Nameplate set0NHNameplate set "GTI"
Special alarm systems9A0Without taxi alarm system
Door storage compartments in front3YRDoor pockets with insert mats
Mass damper for steering wheels1Q1Mass damper for steering wheel, 26.5Hz
Door and lid locking system4K3Central locking w/ radio remote control, interior controls and SAFELOCK
Type approval countries/countries with special requirementsB29Type approval Japan
Carrier frequency for remote control5D3Carrier frequency 315 MHz with reduced transmitting power
Partition3CAwithout partition
Door and side trim panels4AFDoor and side trim panel in foam film and woven fabric
doors0A24 doors
TV reception/digital radio receptionQV0without TV/digital radio reception
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EJSpecial identification plate
Delivery equipment2A8Delivery equipment, water border
First aid kit / warning triangle1T0Without first-aid material, without warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone / telematics9W0Without car phone preparation/ installation
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG1LongLife Service Regime
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GFWindshield in heat-insulating glass
Washer fluid level indicator8W1Washer fluid level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Additional body panels, side6EAWithout additional side body covers (stone guard)
Additional child seat anchors3B4Child seat anchors for child seat system ISOFIX
Auxiliary heating system9M0Without auxiliary heater/parking heater
Hi Jack,
I see where you are going, and I also started with a similar Japanese market RHD config 13 | C8 config, but I get the impression this one is going to use a baseline such as 16006000090000006800060090000081B100 due to the brake booster/master cyl part numbers.
I located one baseline example scan online and that source was https://forums.ross-tech.com/showth...BS-Golf-GTI_2009&p=79959&viewfull=1#post79959
16__60__09__00__68__06__90__0081B100
Additional scans were via email so I can't share them openly.
Fredrick,
Please do post those Advs! This is a travel weekend for me but Jack may be able to sort you out after you post those logs.
Fredrick Awuor
Kenya
C?ID=309834
Hi Jack,
Fredrick,
Saturday,27,April,2019,13:24:03:21182
VIN: WVWZZZ1KZ9U005513   License Plate: ADVANCED ID 0X01
                Address 01: Engine
Control Module Part Number: 1K0 907 115 Q
  Component and/or Version: 2.0l R4/4V TFSI     0020
           Software Coding: 040300431C070160
            Work Shop Code: WSC 00046
Advanced Identification
     Identification: RB8-658
     Revision: 5BH16---
     Date: 23.05.08
     Test stand number: 1360
     Manufacturer number: 0681
Flash Status
     Programming Attempts: 0
     Successful Attempts: 0
     Programming Status: 00000000
     Required Conditions: 00000000
Software
     A000
     A4.9.6
Misc.
     Hardware number: 8P0 907 115 B
     Immo Challenge: 99 F4 A8 9A
Car Info
     Chassis Number: WVWZZZ1KZ9U005513
VCDS Info:
       Labels: 06F-907-115-AXX.clb
       Readiness: 06F-907-115-AXX.crd
Control Module Part Number: 1K6 920 864
  Component and/or Version: KOMBIINSTRUMENT VDD 1214
           Software Coding: 0007503
            Work Shop Code: WSC 00000
     Identification: VDD-024
     Revision: V0002000
     Date: 13.05.08
     Test stand number: 7702
     Manufacturer number: 0601
Flash Status
     Flash Tool Code: 00000 000 00000
     Flash Date: --.--.--
Software
     DKBI339
     Y012
     Z0014
Misc.
     Hardware number: 1K6 920 864
     Lot Number: 000
     Type Lock: 0000
Car Info
VCDS Info:
Fredrick Awuor
Kenya
C?ID=309834
Saturday,27,April,2019,13:26:51:21182
VIN: WVWZZZ1KZ9U005513   License Plate: ADVANCED ID 0X25
  Component and/or Version: IMMO            VDD 1214
           Software Coding:
     Revision: V0002000
     Date: 13.05.08
Flash Status
Software
     DKBI339
     Y012
     Z0014
Misc.
     Lot Number: 000
     Type Lock: 0000
Car Info
VCDS Info:
Fredrick Awuor
Kenya
C?ID=309834
@Dana @Jack...../\
REPORT PLEASE FREDDY
https://forums.ross-tech.com/showth...ding-(MK60EC1)&p=162876&viewfull=1#post162876
Fredrick Awuor
Kenya
C?ID=309834
Will have car tomorrow and get back.... thanks
Fredrick Awuor
Kenya
C?ID=309834
A big thank you to Jack and Dana.....all the two codings were accepted,but I went the extra mile to see if all would stay but the second one was dumped multiple times even after completing basic settings without exiting 0x03 ,and it also antagonized 0x17 and a code popped up about 'control module in instrument cluster,intermittent'
Now this is the autoscan after basic settings...now Jack the tranny was replaced with an incompatible one,hence the suspect FOD
Monday,29,April,2019,16:13:29:21182
VIN: WVWZZZ1KZ9U005513   License Plate: GTI
Mileage: 98170km-61000mi   Repair Order:
VIN: WVWZZZ1KZ9U005513   Mileage: 98170km-61000miles
               P0441 - 002 - Incorrect Flow - Intermittent
                    Mileage: 98067 km
                    Time: 15:33:36
                    RPM: 760 /min
                    Load: 18.0 %
                    Temperature: 85.0°C
                    Temperature: 38.0°C
                    Voltage: 13.970 V
Readiness: 0000 0001
            000 -  -
   Revision: 00H45001
   Coding: 00049109
   Shop #: WSC 00046
   Coding: 00733221
   Shop #: WSC 00046
                    Reset counter: 116
                    Mileage: 97848 km
                    Voltage: 12.10 V
   Coding: 0012597
   Coding: 0012142
00576 - Terminal 15
   Coding: 0007503
   Coding: ED817F060000020003
            000 -  -  - Intermittent
                    Fault Frequency: 87
                    Mileage: 97848 km
                    Time: 19:59:58
   Coding: 0000694
   Revision: 00H15000
   Coding: 0000950
00936 - Electric Window Switch in Front Passenger Door (E107).
   Coding: 0000003
   Coding: 0000144
00937 - Switch for Electric Window; Rear Left (E52)
   Coding: 0000144
End----------(Elapsed Time: 01:09, VBatt start/end: 13.7V/13.6V)-----------
Trowbridge, UK
@Frederick Awuor - 168 posts and still you don't put your Auto-Scan in CODE tags? :facepalm:
It's not complicated and makes it MUCH easier for the rest of us to read - see my signature for a How To :thumbs:
Fredrick Awuor
Kenya
C?ID=309834
oh my,ive not given it a serious thought,let me kick away this laziness
