2016 Audi S6 5F module multiple (12) invalid data record faults
acruxksa
C?ID=367340
Greetings all,
I've recently (January) noticed multiple errors when I scan my 2016 S6.
I've tried clearing codes, but they immediately reappear. I've searched many different places and not really found any solutions. In fact, I've only found one other site (germany) with a nearly identical issue and the only post to help with the problem simply said to check the Ross-Tech forums. :D
In any case, everything in the MMI appears to be working correctly, however I don't really spend much time in the MMI, so there could easily be some obscure issues I don't know about.
Thursday,25,April,2019,12:15:14:25693
VCDS Version: 19.1.2.0 (x64)  HEX-V2 CB: 0.4502.4
Data version: 20190131 DS301.0
VIN: WAUH2AFC2GN111129   License Plate:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C 42
          44 46 52 53 55 5F 62 6C 6D 72 82 85 8B 8E 8F 90 A9 BA
VIN: WAUH2AFC2GN111129   Mileage: 27520km-17100miles
Address 01: Engine (------CTGE)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 014 D    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H63 0001
   Revision: NCH63---
   Coding: 0A2500326546010E3000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM40TFS0114G0906014D 001001
   ROD: EV_ECM40TFS0114G0906014D.rod
   VCID: 2313EEE3AB53BDCF951-8076
   Part No SW: 4G0 927 166 F    HW: 0B5 927 156 K
   Component: 0B5 40TFSINAR H03 0006
   Revision: --H03---
   ASAM Dataset: EV_TCMDL501021 001022
   ROD: EV_TCMDL501021.rod
   VCID: 303911AFEAA51657183-8064
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 65BED449A67D2B921B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DF446B510F8FDFE7D-8014
36352 - Function Restricted due to Insufficient Voltage
          U1400 00 [032] - -
          [HydraulicSupplyUndervoltage]
161792 - Tire Pressure Warning
          C102D 00 [032] - -
   Part No SW: 4H0 907 064 GR    HW: 4H0 907 064 GR
   Component: BCM2 2.0      H37 0572
   Coding: 0DA86F4E000000000000
   VCID: 7F5B029367FB392FD19-802A
   Serial number: 3215000000846013
   Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
   Serial number: 04111500041747
   Coding: 680130781D0000
   Shop #: WSC 12345 123 61029
   VCID: 6A8DC3C70CF9AC87167-803E
   Part No SW: 4H0 907 063 DM    HW: 4H0 907 063 AM
   Component: BCM1 2.0      H20 0311
   Revision: 21020001    Serial number: 00001194339402
   Coding: 01058011043C9FF2F98048C7A0003800CF9CD208AE08022180000894F10017020060002D0B0000
   VCID: 76B5E7B748C1786782F-8022
   Component: WWS57X 150919  H38 0080
   Serial number:         151017070051
   Coding: 0045F7
   Serial number: 60888246
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AN    HW: 4G0 941 531 AN
   Component: E1 - LDS  H07 0044
   Serial number: 03 11 2015  00001483
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z02171EF8
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA122107000016568117
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 677809D7000000000001
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0055
   Coding: 7E01010102
   ASAM Dataset: EV_AdaptCruisContrAU57X 002015
   VCID: 290FFCCBC97F679FDFD-807C
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G0002NPUD
   Coding: 303331343135303334354A55304C34473053
   VCID: 34311DBF1EBD2A777CB-8060
   Serial number: 6940000Y150001ESXX0$
   Serial number: 3575HRB405N3M470G11W
   Serial number: 3585HRB405D3N3J8BHAK
   Serial number: 3515JRB405L3K3ICO8O+
   Serial number: 3525JRB405J3K16049M-
   Serial number: 3554VRB401C555N0IQ4H
   Serial number: 3564VRB400O555N0NHH
   Revision: --------    Serial number: 90372OK40007T
   Coding: 0000FC
   VCID: 372B2AB30F4BC16F599-8062
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 19 10 2015  A0045760
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G0 920 982 L    HW: 4G0 920 982 L
   Component: TBenUsaAccNv  H11 0106
   Revision: 08001098    Serial number: 658051115596026
   Coding: 0BCF0905BF51D705020200
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K.rod
   VCID: 353720BB15C7337F4B5-8060
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002038353
   Coding: C0ED074814
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: 3B23368333E3E50FBD1-806E
   Serial number: 4244978203
   Voltage stabilizer:
   Serial number: 15071500000000000624
   Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
   Component: DYNAMIKLENK.  H06 0740
   Revision: 52001005    Serial number: --------------
   Coding: 0E0100
   VCID: 3A2D33873C59DC07A67-806E
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   VCID: 678BBAF31F6B91EF099-8032
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H17 0200
   Serial number: 000211150001000
   VCID: 2809F9CFD2755E97C03-807C
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 05111500041327
   Coding: 20
   VCID: 3D27389B2DF7EB3F835-8068
   Coding: 008006
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3B12D3F79B09AF019-807A
   Revision: AA000000    Serial number: 00000168888249
   VCID: 77ABEAB34FCB016F999-8022
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E01V0DH
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372B2AB30FCBC16F599-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H07 0060
   Serial number: 0385415921
   Coding: 040211
   VCID: 392F2C8B39DFD71FAFD-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H07 0060
   Serial number: 0385487334
   Coding: 040211
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F17015E00628002000013
   VCID: 45D7507B45A7A3FFDB5-8010
   Component: RCevo         H53 0202
   Revision: 00000002    Serial number: 0000343099
   Coding: 011001010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2D33873CD9DC07A67-806E
   Revision: 00002001    Serial number: 0385136188
   Coding: 0106063A00FA718580B0088402070E470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000321307
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST000M4X2P00000
   Coding: 101F02
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00016043344
   Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93657219
   Component: TSG BF        H03 0511
   Coding: 011F17015E00628002000002
   VCID: 46D5577778A1A8E7D2F-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001647140
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D0708DBFD977BBF335-8078
   Coding: 04FA0A1122600400
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 025 B    HW: 4G1 035 025
   Component: MU-H-LNS-US   043 0387
   Serial number: A278J0FB018296
   Coding: 017501020000000013220002041A00102F0006E5F17001047E
   VCID: 1D67D81B8D378B3FA35-8048
   Subsystem 1 - Part No SW: V03 959 802 DK    HW: -----------
   Component: NAR 2018/2019  --- 0066
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9FY803ALJ
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349OJV0005O
   Compact Disc Database:
   Component: Gracenote2  --- 3006
12 Faults Found:
1585 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for ASAM/ODX MUX]
                    Reset counter: 117
                    Mileage: 27520 km
                    Date: 2019.04.25
                    Time: 12:12:48
                    Voltage terminal 30: 12.1 V
1586 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for speed shutoff thresholds]
                    Reset counter: 117
                    Mileage: 27520 km
                    Date: 2019.04.25
                    Time: 12:12:48
1587 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for language]
                    Reset counter: 117
                    Mileage: 27520 km
                    Date: 2019.04.25
                    Time: 12:12:48
1588 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for visible MMI system languages]
                    Reset counter: 117
                    Mileage: 27520 km
                    Date: 2019.04.25
                    Time: 12:12:48
1589 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for power management timer]
                    Reset counter: 117
                    Mileage: 27520 km
                    Date: 2019.04.25
                    Time: 12:12:48
1590 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for sound audio parameters]
                    Reset counter: 117
                    Mileage: 27520 km
                    Date: 2019.04.25
                    Time: 12:12:48
1592 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for DAB frequency tables]
                    Reset counter: 117
                    Mileage: 27520 km
                    Date: 2019.04.25
                    Time: 12:12:48
1595 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for audio management HMI constants]
                    Reset counter: 117
                    Mileage: 27520 km
                    Date: 2019.04.25
                    Time: 12:12:48
1655 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for sound announcement audio parameters (optional)]
                    Reset counter: 117
                    Mileage: 27520 km
                    Date: 2019.04.25
                    Time: 12:12:48
1656 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for sound cabriolet audio parameters (optional)]
                    Reset counter: 117
                    Mileage: 27520 km
                    Date: 2019.04.25
                    Time: 12:12:48
1657 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for sound configuration audio parameters (optional)]
                    Reset counter: 117
                    Mileage: 27520 km
                    Date: 2019.04.25
                    Time: 12:12:48
1603 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for speech signal enhancement - telephone/voice recognition signal processing (SSE)]
                    Reset counter: 117
                    Mileage: 27520 km
                    Date: 2019.04.25
                    Time: 12:12:48
   Component: TSG HL        H03 0511
   Coding: 010F17004000628002000002
   VCID: 49CF5C4B69BF479F3FD-801C
   Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
   Component: TopView       H09 0361
   Revision: 11001001    Serial number: 82330JG0124466
   Coding: 0212000101010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
   Part No SW: 4G5 959 107 C    HW: 4G5 959 107 A
   Component: HDSG-Modul    H02 0049
   Revision: 13002001    Serial number: 287501745
   Coding: 111104C120
   ASAM Dataset: EV_HDSGAu571 001022
   ROD: EV_HDSGAu571.rod
   VCID: 323D1BA7E4A924476E7-8066
   Component: TSG HR        H03 0511
Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 M    HW: 4G0 919 604 M
   Component: HeadUpDisplay H08 0306
   Coding: C60000
   ASAM Dataset: EV_HUDContiC7 001027
   ROD: EV_HUDContiC7.rod
   Component: DPC-SG        H27 0081
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C0105DFC68D72B724B-8078
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E01010102
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
   VCID: 270BFAF3DF6B51EFC99-8072
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000621111157
   Coding: 04C1BA1B0111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Component: RGS-VL        H14 0080
   Coding: 0066E608031F0376070308014240C0010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F14ABE1AF1F5F17D-8064
   Component: RGS-VR        H14 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0010
   Serial number: 151008200568
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H10 0008
   Revision: 00001001    Serial number: 97813005998401
   ROD: EV_AEMLearAU64X_AU57.rod
End----------(Elapsed Time: 02:42, VBatt start/end: 12.0V/12.0V)-----------
I doubt there are any solutions for these faults short of taking the car to the dealer and asking them to connect it to the mothership's servers to download the correct data records. The problem with this is that if the MMI doesn't have any functional problems, they may not want to be bothered.
acruxksa
C?ID=367340
Thanks,
Given that there don't seem to be any issues with the MMI, I can understand that. I'll talk to them about it next time the car is in for service.
Guessing the errors were likely my fault somewhere down the line, although I'm not exactly sure how or when. (was using the obdeleven before making the jump to vcds and the hex-v2). I know they weren't there when I scanned with the other device immediately before purchasing the vehicle used in Nov 18'.
FadelBassel
Canada
C?ID=449869
Hi
video in motion is enabled using vcds software or carly or ....
that's why
FadelBassel
Canada
C?ID=449869
B2005 - Invalid data record​
Special Notes​
  • This fault usually means there's a bug in the factory firmware, parameter related data in the control unit is incorrect or parameter data is missing because the module has not been configured via SVM with a direct connection to VW/Audi headquarters.
