Transporter T5 GP retrofit Mk100 ABS from T6
dnoermann
C?ID=358118
Hallo @all.
I am retrofitting the ABS from the T6 back into my T5 GP.
To do this i analysed about 50 Autoscans from T6 to understand the Coding.
My findings i already posted here: https://forums.ross-tech.com/showthread.php?13832-Want-ESP-TC-Button-in-my-2017-Caddy-abs-mk100-coding&p=154762&viewfull=1#post154762
I did a lot of testing on the Bench over the Winter, now the ABS is in the Car and i am facing one last Error, whell two, but for the "Airbag_03 frame timeout" error i already have the solution, i just need Airbag Controller from T6.
Now the Last Error wich i dont understand:
8324 - Databus
          U1122 00 [137] - Implausible Message
          [ACAN: LW1_ID wrong value]
What does this Error mean, from which ECU is this CAN Message comming ?
Autoscan:
Wednesday,24,April,2019,20:47:53:01479
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
VIN: WV2ZZZ7HZEH______   License Plate: T6_ABS_OHNE_BERG
Mileage: 166000km-103147mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 18 19 22 25 2E 37 3C 55 56 61 69
          6C 6E 77 0B
VIN: WV2ZZZ7HZEH______   Mileage: 166000km-103147miles
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 019 HM    HW: 03L 907 309 L
   Component: R4 2,0L EDC   H38 8375
   Revision: 22H38---    Serial number: 00000000000000
   Coding: 0125401A233601080000
   ASAM Dataset: EV_ECM20BTD01103L906019HJ 003005
   ROD: EV_ECM20BTD01103L906019HJ.rod
   VCID: 7DA60C6E3D71329FF5B-8028
   Part No SW: 0BT 300 011 Q    HW: 0BH 927 711 G
   Component: DSG DQ500-7A  H11 2236
   Revision: 00H11V01
   ROD: EV_TCMDQ500021.rod
   VCID: 3C20C16A66EBFB97825-8068
Address 03: ABS Brakes (J104)       Labels:. User\TEST-03.lbl
   Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Revision: 00000000    Serial number: 43036000000361
   Coding: 517E809865__80__8A__01__A6__0196380000
   VCID: 40D8B59A0A039F77DED-8014
8229 - Databus
          [ACAN: Airbag_03 frame timeout]
                    Reset counter: 38
                    Mileage: 166000 km
                    Date: 2019.04.24
                    Time: 00:27:25
8324 - Databus
                    Reset counter: 38
                    Mileage: 166000 km
                    Date: 2019.04.24
                    Time: 00:27:19
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 7E5 907 040 AC    HW: 7E5 907 040 AC
   Component: ClimatronicT5 H19 0407
   Revision: 00001004
   Coding: 0000000103
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 698E483E59F9BE3F293-803C
   Slave 1:
   Subsystem 1 - Part No SW: 7E5 907 049 B    HW: 7E5 907 049 B
   Component: Heckbedienung  H10 0202
   Serial number: BHB-0010710130015098
   Part No SW: 7H0 937 090 B    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0712
   Revision: B9074001    Serial number: 0571 284130784
   Coding: E0A0393A0A21201301280F716EEB8FD50290662F7E857801320000020000
   VCID: 2D06FC2EAD11621F05B-8078
   Component: RLS 071013 05  54  0403
   Coding: 02252E
   Subsystem 2 - Part No SW: 7E0 959 801 J    HW: 7E0 959 801 J  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8652
   Serial number: KU0KU008101300018609
   Coding: 0400A1
   Subsystem 3 - Part No SW: 7E0 959 802 J    HW: 7E0 959 802 J  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8652
   Serial number: KU0KU002101300011203
   Coding: 1400A1
   Subsystem 4 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TK6  H07 0022
   Serial number: 70000000000000636886
   Coding: E20000
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28261326801945
   Coding: 318102
   ASAM Dataset: EV_VW75XParkAssis8K 001003
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 3B22C27663E5FCAF8BF-806E
   Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
   Component: VW10Airbag003 H07 0013
   Revision: --------    Serial number: 003HM003VZ7W
   Coding: 000000000000000000000000000000003033
   Shop #: WSC 02754 790 50316
   VCID: 3634D34258C721C7741-8062
   Serial number: 3495ZRB400250KJKP1GY
   Serial number: 3505ZRB400450KJKN9O%
   Serial number: 3515ZRB400450KJKR8R6
   Serial number: 3525ZRB400450KJKDQ1S
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Coding: 050F010300
   VCID: 3A2CC7726CDFC5A7909-806E
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 819 008 F
   Component: J737__Standheizung  0605
   Revision: 00086000    Serial number: 09024901A00000
   Coding: 0021332
   Shop #: WSC 02757 790 00000
   VCID: 2C00F12A9A0B6B17125-8078
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0712
   Revision: B9074001
   Coding: 042200
   VCID: 70B8255A7AA34FF76ED-8024
   Part No SW: 09N 907 554 B    HW: 09N 907 554 B
   Component: Haldex 4Motion      6008
   Coding: 0000001
   Shop #: WSC 02756 790 00000
   VCID: 372ADE46534DD8CF6F7-8062
   Component: IMMO          H03 1104
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8C37325CFFB527209-803E
   Revision: A1001003    Serial number: 7665304253
   Coding: 010100
   VCID: 2B02F23693056C2F1BF-807E
03138 - Input AUX IN
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 38
   Part No SW: 7E0 035 680 B    HW: 7E0 035 680 B
   Component: RNS-MID       H09 5274
   Revision: AB001001    Serial number: VWZ6Z7N7280058
   Coding: 04000402040000A00014
   Shop #: WSC 02754 790 00000
   VCID: 2410190AFEDBA357DA5-8070
   Component: EU West V15  8515
   Part No SW: 7E0 907 566 B    HW: 4L0 907 566 A
   Component: J0769 SWA MasterH13 0120
   Revision: 00H13000    Serial number: 6PZ 009 014-07
   Coding: 0010161
   VCID: 2F3AE626AB1D100F377-807A
   Subsystem 1 - Part No: 7E0 907 568 B
   Component: J0770 SWA Slave H10 0120
   Subsystem 2 - Serial number: 6PZ 009 014-27
   Subsystem 3 - Serial number: 5F26.09.1300H10000AMS14437\FF
   Subsystem 4 - Serial number: S14437\FF
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357     HW: 6R0 907 357
   Component: LWR-ECU       H02 0070
   Coding: 028A000001000000
   Shop #: WSC 02757 790 50316
   ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
   ROD: EV_HeadlRegulVWLWRPt_VW25.rod
   VCID: 77AA1E461F4D18CFAF7-8022
   Part No SW: 7H0 907 534     HW: 7H0 937 090
   Component: Batt.regelung H74 0712
   Coding: 330B1A73
   VCID: 6B8232365385AC2F5BF-803E
   Subsystem 1 - Part No SW: 7E0 915 181 D    HW: 7E0 915 181 D
   Component: J367-BDM  H08 0182
   Serial number: 50262E43111931975854
   Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
   Component: Anhaenger     H10 0110
   Revision: 3B001001    Serial number: 00000194554106
   Coding: 410D000101000000
   VCID: 313EE05EB12906FF213-8064
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Revision: 00H12000    Serial number: 525PA8-J390101
   Coding: 0030015
   VCID: 6596440EB9619A5F0DB-8030
Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W2.clb
   Part No SW: 7E5 919 037 G    HW: 7E5 919 037 G
   Component: Dachdisplay   H15 0185
   Revision: 10100011    Serial number: 308907
   Coding: 000203
   VCID: 3536D44E45412ADF7DB-8060
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
   Component: Telefon       022 0971
   Revision: --------    Serial number: 35502105055314
   Coding: 020101000100000000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 2410190AFE5BA357DA5-8070
End----------(Elapsed Time: 02:19, VBatt start/end: 13.0V/13.0V)-----------
dnoermann
C?ID=358118
Whell, since no one helped, i had to find it myself. :)
8324 - Databus
LW ==> German: Lenkwinkelsensor ==> Steering Angle Sensor
Simply needed to change to the T6 Steering Angle Sensor
