2018 NA Tiguan MQB - 03 ABS Security Code Needed
pillpusher84
C?ID=245751
I have a 2018 Tiguan SEL Premium R-Line (USA-Spec). I have validated all wiring is existing in-place, and have installed the Euro parking brake switch with auto-hold button. I am unable to code this, as there is nothing in the Long Coding Helper. I have gone into Adaptations, however the Auto_Hold line where i must change from not active to active requires a security code (which VCDS doesn't provide like other modules).
I have already tried the following Security Codes, and have not had success (despite the system accepting the security code). I still receive the error security code required after I attempt to code this to the vehicle.
10505, 10815, 11966, 15081, 18573, 19249, 20103, 24435, 25004, 28183, 31857, 37202, 40168, 40304, 44595
Can anyone, including Ross-Tech provide any guidance? I'm all for doing it by changing the long coding if someone knows what to change :)
Utilizing Hex-Net Enthusiast (10 VIN) with Windows 10 x64 via VMWare on my MacBook Pro with Latest Update to Hex-Net device as well as VCDS Beta release - latest update. I have no issues utilizing the software on my VM, so i know there is no issues there.
Saturday,20,April,2019,13:52:44:51577
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 19.1.2.0 (x64)  HEX-NET CB: 0.4502.4
Data version: 20190131 DS301.0
VIN:    License Plate:
Mileage: 532km-330mi   Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 36 39 3C 42 44
          47 4B 52 5F 6C 6D 75 A5 BB BC CA D6 D7
VIN:    Mileage: 532km-330miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 5NA 907 115 A    HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H31 0004
   Revision: 1DH31000
   Coding: 012A00122466010FB4000000000000000000000000000000
   Shop #: WSC 00066 790 00273
   ASAM Dataset: EV_ECM20TFS0115NA907115A 001005
   ROD: EV_ECM20TFS0115NA907115A.rod
   VCID: 3C34CB36B7A2DEA9AF-8069
Readiness: 1110 1101
   Part No SW: 09G 927 158 Q    HW: 09G 927 158
   Component: AISIN AQ8     206 3486
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00438
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 41CABAC2D040B341FC-8015
   Revision: 00000000    Serial number: 51378000000234
   Coding: 0BFA6BA454281B71C5790303A2C749D0D62AD8A3C045927C38415058C2AA4200002864121A1C230935351919323200
   Shop #: WSC 01383 790 50316
   VCID: 77BE141ACE043DF182-8023
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0483073383
   Coding: 132C2C0723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E30C13EA1BECCB981-806B
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11023040
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NN 907 044 K    HW: 5NN 907 044 K
   Component: AC Automat    H35 4401
   Revision: 20K03000    Serial number: 00000D00161194
   Coding: 00020024200118001105010C1211140E
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 54E483963F3236E947-8001
   Part No SW: 5Q0 937 087 AS    HW: 5Q0 937 087 AP
   Component: BCM PQ37BOSCH 034 0246
   Revision: --------    Serial number: C86418061800UE
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0C545BF6A7822E29DF-8059
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 180517  034 0373
   Serial number: 18050322323850
   Component: RLHS  050 0107
   Serial number: S8Y18M06D06H13M21S10
   Coding: 00A8DD
   Part No SW: 5QA 919 294 E    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0443
   Serial number: 000145450R18164
   Coding: 0471255811
   VCID: 4ED091FE111E5C3971-801B
   Component: ACCCONTIMQB   H02 0233
   Coding: 320000C158FF8728749C8145304097
   Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
   Component: AirbagVW21    004 0336
   Serial number: 003NUM09FBSC
   Coding: 8CCCFC00000000005000001AC20800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 05426ED284E85F6180-8051
   Occupant Detection:
   Serial number: IBH000000000009CSUC8
   Coding: 303352
   Subsystem 2 - Part No SW: -----------    HW: 480 002 605 18
   Serial number: 3570000000010B645032
   Subsystem 3 - Part No SW: -----------    HW: 480 000 505 18
   Serial number: 3580000000074C613E2M
   Subsystem 4 - Part No SW: -----------    HW: 480 401 105 18
   Serial number: 35100019929E7324671/
   Subsystem 5 - Part No SW: -----------    HW: 480 403 004 18
   Serial number: 3520001BD29C6BF1E3AW
   Subsystem 6 - Part No SW: -----------    HW: 480 402 605 18
   Serial number: 35500011E2AE89C621DK
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 605 18
   Component: FrontSensor_P  004 6149
   Serial number: 3560001222AE89C2123$
   Part No SW: 5Q0 953 507 JF    HW: 5Q0 953 549 D
   Component: Lenks. Modul  004 0140
   Revision: --------    Serial number: 21031820240163
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 034670CA8ADC6151AE-8057
   Part No SW: 5NA 920 891 B    HW: 5NA 920 891 B
   Component: KOMBI         408 3196
   Coding: 03A5041AEF8CCF05028B6B0B54010000A0000000
   VCID: 43C6B0CACA5CA151EE-8017
   Component: GW MQB High   518 5323
   Serial number: 29051800840523
   Coding: 030500347F085900FB03225A1E0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 383CD726839AF2894B-806D
   Subsystem 2 - Part No SW: 5NN 959 442 A    HW: 5NN 959 442 A
   Serial number: 0751813431100760BO2B
   Coding: 2E0000
   Serial number: 3241795800
   Serial number: HA1-00013.03.18
   Coding: 0101
   VCID: 4CD49BF6E7026E291F-8019
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
   VCID: 45C2AED2C4689F61C0-8011
   Serial number: 18000159672004
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 3326E00A9AFC11D17E-8067
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006RE814890
   Coding: 0010000000000500018280808080000000008101000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3D32C632ACB8D7A198-8069
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 0477704930
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0477568755
   Coding: 020111
   Serial number: 5038816801267
   Coding: 001F1B205200028000000000
   VCID: 47DEA4DAFE648D7132-8013
   Revision: 00000000    Serial number: 0002499782
   Coding: 01000011004001
   Shop #: WSC 00066 790 00066
   ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
   VCID: 40CCBFC6DB4ABA49F3-8015
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1JMD02ANJZ
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E10F17E71DE3C3911-807B
   Serial number: 17061800840385
   Coding: 0000000501001D5200210F01090000000000000000000000000000000000
   VCID: 72A8250EA56658D9B5-8027
   Serial number: 6038815800395
   Coding: 003F13205E00028000000000
   VCID: 46C0A9DEF96E9479C9-8013
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    851 0867
   Coding: 027306020000000051220002001808001F0506E401200405C6
   Shop #: WSC 00066 790 00327
   ROD: EV_MUStd4CDELP_VW37.rod
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZJV1331104
   Subsystem 2 - Part No SW: 3G0 919 866 BP    HW: -----------
   Component: NAR 2018  --- 0715
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG029980
   Coding: 01230601A20F20003020400C
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
   VCID: 393AD222B890EB81B4-806D
   Part No SW: 5Q0 959 107 Q    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0266
   Revision: --------    Serial number: A2-C758-8700-2
   Coding: 0A28
   Component: OCULowMQBUS   009 0570
   Coding: 02230602C2823A037F1E06020000
   ROD: EV_OCULowMQB.rod
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 1272
   Serial number: 10031841P12811
   Coding: 0003070601020201002213548150490094000E200120
   VCID: 085C67E6B3FA4209FB-805D
   Part No SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
   Component: TSG HFS       012 0032
   Serial number: 0000317836690
   Coding: 002011200101028000000000
   ASAM Dataset: EV_DCURearDriveMAXCONT 006001
   VCID: 49DAA2E2E8707B0124-801D
   Component: TSG HBFS      012 0032
   Serial number: 0000317836857
   ASAM Dataset: EV_DCURearPasseMAXCONT 006001
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 00804073260C
   ROD: EV_SunRoofCONTIAU736_006.rod
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 1660399EE94EE4F979-8043
   Component: LED1R         H09 0003
   ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End----------(Elapsed Time: 02:09, VBatt start/end: 14.6V/14.6V)-----------
adema69
C?ID=367333
any updates on this? I am also trying to get security access code to change the xds on my 18 tiguan?
apial
Germany, Erfurt
C?ID=125504
Thank you!!! This is 100% accurate and works like a charm
Were you able to figure out the correct coding? I planned doing the same on a Tiguan US spec. I was able to change the adaption channels but I believe something in the long coding is mussing as well? I did not buy the switch yet, but dont think thats the problem as I dont even see a warning for the malfunction of the button. Also, some cars need cables from the button to the ABS module, was that the same for you as well?
Hi guys,
This isn't a Tiggy ... but we had a customer with a NAR market 2015 GTI report XDS success using SA 20103 = Adaptation Enabling (XDS) with this ABS:
>> Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
>> Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
>> Component: ESC H31 0371
>> Revision: 00000000 Serial number: 51154000000027
>> Coding: 01FA6BA134200973007F020281C82980D62C9000408194B400430050C009
>> ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
>> ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
>> VCID: 44D14CBFDE1DA277AE1-8010
I'll add that SA to 5Q0-907-379-ESP-V1.clb and pop an note in Don's SA thread.
