New guy with mk7 window tweek
dillenger1
C?ID=368041
so i apologize for the large text still trying to figure the posting out..so i have a mk7 gsw tdi and i was trying to do comfort windows open tweek/install.i get though kessy to adjustable and activate open/close english.when i get to the german "kessy komfort oeffnen"i get service not supported in active session"
i then tried again and got "security access required". any pointers?
while playing with vcds my battery died after about 20 minutes(i thought this was premature)and i thought i bricked my ecm!!! haaaaaaa got me right by the short and curlys!!
Saturday,20,April,2019,19:30:15:61679
VCDS Version: 18.9.1.0 (x64)
VIN: 3VWCA7AU9FM501766   License Plate:
Mileage: 92834km-57684mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75
VIN: 3VWCA7AU9FM501766   Mileage: 92834km-57684miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 022 N    HW: 04L 907 309
   Component: R4 2.0l TDI   X23 9459
   Revision: 85X23---
   Coding: 011D0012032410081000
   ASAM Dataset: EV_ECM20TDI01104L997022N 004002
   ROD: EV_ECM20TDI01104L997022N.rod
   VCID: 3B7FDB52B2954F92C8-806E
Readiness: 0 0 0 1 0
   Part No SW: 0D9 300 041 N    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4512
   Revision: 05853104    Serial number: TFK01501120125
   Shop #: WSC 00066 790 00201
   ROD: EV_TCMDQ250021.rod
   VCID: 234F03322A251752E0-8076
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Revision: 00000000    Serial number: 50075000000447
   Coding: 04FA6AA12420096D007E020681C92520562490004081A4B200630050C002
   Shop #: WSC 01383 790 50316
   VCID: 4797B7A2FE5D1B725C-8012
   Revision: 00021000    Serial number: 0355862780
   Coding: 030C0C
   VCID: 3A71DE56BDAF769AD3-806E
   Part No SW: 5GM 907 426     HW: 5GM 907 426
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 02020104200100000000000000000000
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 050B7DAA84D1C962EE-8050
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 087 Q    HW: 5Q0 937 087 Q
   Revision: --------    Serial number: 86581712140706
   Coding: 000118424041804169E44000000403001800000000000000000000000000
   Shop #: WSC 00066 790 07031
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4993B19AE849ED024A-801C
   Component: WWS    141210  043 0581
   Serial number:         150203070414
541973 - Databus
                    Reset counter: 112
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:26:34
559125 - Databus
                    Reset counter: 112
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:26:34
555541 - Databus
                    Reset counter: 112
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:26:34
542229 - Databus
                    Reset counter: 112
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:26:34
542485 - Databus
                    Reset counter: 112
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:26:34
                    Reset counter: 118
                    Mileage: 92834 km
                    Date: 2019.04.19
                    Time: 07:01:30
   Serial number: 003GCR013TGL
   ROD: EV_AirbaVW20SMEVW37X.rod
   Occupant Detection:
   Serial number: IBH0000J1500029OTJ0P
   Coding: 303138
   Subsystem 2 - Part No SW: -----------    HW: 480 001 112 14
   Serial number: 35700000000942F8321G
   Subsystem 3 - Part No SW: -----------    HW: 480 001 112 14
   Serial number: 3580000000023D21221%
   Subsystem 4 - Part No SW: -----------    HW: 480 401 112 14
   Serial number: 3510002B31811B90813P
   Subsystem 5 - Part No SW: -----------    HW: 480 400 812 14
   Serial number: 35200029D1811B91527.
   Subsystem 6 - Part No SW: -----------    HW: 480 400 212 14
   Serial number: 3550002C718B3AB3F1CN
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 212 14
   Serial number: 3560002C718B3AB2B23B
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20141217500378
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 040D60AE8FEBF06AF9-8050
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 0BA4121A2180CF05020868001000000000000000
   VCID: 65CB5D2A649129624E-8030
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 22011510001256
   Coding: 0901000800087300EF0000081C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 00199
   ROD: EV_GatewConti_011_VW37.rod
   VCID: 71E3397AA059F5C222-8024
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 27140003150690014527
   Coding: 29FFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0020000
   Revision: 00000000    Serial number: 15000015147004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 346DF06E9FCB80EA09-8060
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 080115060502XI
   Coding: 003013200000040000000000
   VCID: 3E79D246A1875ABAEF-806A
   Serial number: 00000000000000550428
   Coding: 011000
                    Reset counter: 72
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:45:14
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 438FA3B2CA65375280-8016
19460 - Databus
                    Fault Frequency: 47
                    Reset counter: 112
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:45:15
                    Motor status: 00
                    Supply voltage: 11.75 V
                    Temperature: 43.0 °C
                    KFC: 4C
                    KFA: 00 04
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 11.72 V
                    uAdSensI_SwitchedKl30_xdu16: 11.72 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 131214060503EY
   VCID: 3D7BD54AAC8141A2F6-8068
   Serial number: 00000000000000539641
   Coding: 091000
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     014 0645
   Serial number: V7B00401151026
   Coding: 02730200FF00000021220001001800001F0100140100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 64CD402E6FAB506A59-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS50155R
0020 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 72
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:45:15
                    Voltage terminal 30: 11.7 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Component: OCULowMQBUS   007 0564
   Coding: 02730002C2821A017F1E06000000
   Shop #: WSC 00066 790 00123
   ROD: EV_OCULowMQB.rod
End-------------------------(Elapsed Time: 03:45)--------------------------
dillenger1
C?ID=368041
   Revision: 85X23---
   Coding: 030C0C
   Revision: 00001K01
541973 - Databus
                    Reset counter: 112
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:26:34
559125 - Databus
                    Reset counter: 112
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:26:34
555541 - Databus
                    Reset counter: 112
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:26:34
542229 - Databus
                    Reset counter: 112
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:26:34
542485 - Databus
                    Reset counter: 112
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:26:34
                    Reset counter: 118
                    Mileage: 92834 km
                    Date: 2019.04.19
                    Time: 07:01:30
   Occupant Detection:
   Coding: 303138
   Coding: 0410
   Coding: 29FFFF
   Coding: 011000
                    Reset counter: 72
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:45:14
   Coding: 0102
19460 - Databus
                    Fault Frequency: 47
                    Reset counter: 112
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:45:15
                    Motor status: 00
                    KFC: 4C
                    KFA: 00 04
   Coding: 091000
                    Reset counter: 72
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:45:15
dillenger1
C?ID=368041
yah sorry just testing
i do have an issue(see top) with adaptations for my comfort open/close window tweek.
dillenger: Hi and thanks for the warning - I had never realized that my family jewels were at risk every time I fired-up VCDS ( clearly the lack of a warning label by Ross-Tech on their software is a lamentable deficiency)!!! ;)
As for your question - yes to change the adaptation channels in the BCM (what VCDS reports as "Central Elect." module) you will need to enter the magic number 31347 after selecting Security Access-16 in the Open Controller screen (and, I don't believe that a testicle guard is necessary for this bit - but I could be wrong!!)
dillenger1
C?ID=368041
so i have to back out and and enter the access code? because I entered it once(31347)and i was able to activate the access cntrl2 "US comfort open and close" and the german close only. German OPEN was locked out
So - look HERE for a step-by-step (visual) instruction for the tweak. I acknowledge the author - fudsey for the document.
Please note that the screen shots in the PDF document were made some time ago using a now obsolete version of VCDS. Since then, the crazy, zany software guys @ RT (;)) have introduced a nifty search box for finding the adaptation channel needed (the BCM on these cars have a channel count exceeding 1,000!).
Just type-in a section of the channel name in the search box and then click on the pull-down facility above the search box to find the channel names that comply with the search criteria
PS: another facility that might be useful is RT's on-line manual HERE
dillenger1
C?ID=368041
thank youy sir!!i watched a video on it and the guys channels seemed to be simplified starting in alphabetical order.Mine seems to be a mess and huuuuuugee
