2011 Seat Ibiza ST, Can't change ABS code
Dannozz
C?ID=114179
Hi guys,
I just retrofitted rear brake disks on my 1.2TDI Ibiza and I wanted to change the ABS coding(Bosch ESP 8.2I). But I am keeping Error code 22. Can someone point me out what I am doing wrong here?
Old with rear drum config: 110224DB817500B3882C24E681D200521700
New with rear disk config: 110228DB817500B3882C24E681D200521700
Saturday,20,April,2019,19:32:12:30519
VCDS Version: 18.9.1.0 (x64)
VIN: VSSZZZ6JZBR181741   License Plate: XX-XXX-X
Mileage: 155820km-96822mi   Repair Order:
Chassis Type: 6J-SE25 (6R0)
Scan: 01 03 08 09 10 15 17 19 25 44 4B 56 61
VIN: VSSZZZ6JZBR181741   Mileage: 155820km-96822miles
Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 AA    HW: 03P 906 021 BC
   Component: R3 1.2l TDI   H06 9978
   Revision: 12005001    Serial number:
   Coding: 00114036032401080000
   Shop #: WSC 48890 002 104857
   ASAM Dataset: EV_ECM12TDI03103P906021AA 001018
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 67D755529E1AE3727C-8032
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 110224DB817500B3882C24E681D200521700
   Shop #: WSC 00046 123 12345
   VCID: 071775D2B25A03729C-8052
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
   Part No SW: 6J0 820 043 C    HW: 6J0 820 043 C
   Component: Climatronic   H07 0606
   Revision: S0000000
   VCID: 244D025E27ACC86A99-8070
00457 - Control Module for Network (J519)
                    Fault Status: 00101101
                    Reset counter: 246
                    Mileage: 155742 km
                    Date: 2019.04.20
                    Time: 09:33:56
   Part No SW: 6R0 937 088 F    HW: 6R0 937 088
   Component: BCM PQ25 Re4  H46 0351
   Revision: BU046001    Serial number: 0379 109110736
   Coding: 3B980FF8C9A10F00013007F07E8B9EC9DF8063F97E8C6809300000000000
   Shop #: WSC 12302 002 104857
   VCID: 4183ABCAD8FEFD4292-8014
   Component: RLS 030511 05  54  0403
   Coding: 07242D
   Subsystem 2 - Part No SW: 6R0 959 801 N    HW: 6R0 959 801 N  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 3110
   Coding: 420000
   Subsystem 3 - Part No SW: 6R0 959 802 Q    HW: 6R0 959 802 Q  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 3110
   Coding: 420000
   Subsystem 4 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3121
   Subsystem 5 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3121
                    Fault Status: 00101010
                    Reset counter: 239
                    Mileage: 155624 km
                    Date: 2019.04.16
                    Time: 20:31:29
Address 10: Park/Steer Assist (J446)       Labels:| 6J0-919-475.clb
   Part No SW: 6J0 919 475 B    HW: 6J0 919 475 B
   Component: PARKHILFE 4K  H07 0008
   Revision: --------    Serial number: 80331110625011
   Coding: 100007
   Shop #: WSC 06402 785 00200
   ASAM Dataset: EV_SE250ParkiAssis2 S01006
   ROD: EV_SE250ParkiAssis2.rod
   VCID: 356BCF1A943641E23E-8060
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10AirbagA09 H09 0020
   Revision: --------    Serial number: 003GX00L2J2A
   Coding: 003039
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A918CE6EDC83E1A43-801E
   Serial number: 3495RRB40530I4AGLPG-
   Serial number: 3505RRB40530I4AGNOKX
   Part No SW: 6J0 920 840 E    HW: 6J0 920 840 E
   Component: KOMBI         H01 0711
   Coding: 111A01
   VCID: 2C5DEA7E477C002A51-8078
Address 19: CAN Gateway (J533)       Labels:. 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H38 0025
   Revision:   H38       Serial number: 260311F2002607
   Coding: 2532C2
   VCID: 336FF10292425FD210-8066
   Component: IMMO          H01 0711
   Coding: 000002
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD12C668D08DE1A63-803E
   Part No: 6R0 423 156 B
   Coding: 11251
   Shop #: WSC 06402
   VCID: 2F67FD72EA6A7B3274-807A
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441
   Component: MF-Modul       0007 0001
   Coding: 0000001
   Shop #: WSC 00046 000 00000
   VCID: 70E53E0E63D424CA2D-8024
Address 56: Radio (J503)       Labels:. 6J0-035-153.clb
   Part No SW: 6J1 035 153 G    HW: 6J1 035 153 G
   Component: Radio         H14 0204
   Revision: R0000000    Serial number: SEZAZ2L1884499
   Coding: 0104040001
   VCID: 2953136A408E1502AA-807C
00856 - Radio Antenna
                    Fault Status: 00100111
                    Reset counter: 239
                    Mileage: 155589 km
                    Date: 2019.04.15
                    Time: 17:56:31
                    Fault Frequency: 13
                    Reset counter: 199
                    Mileage: 155624 km
                    Date: 2019.04.16
                    Time: 20:24:48
   Part No SW: 6R0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H38 0025
   Coding: 030F185A
   VCID: 74ED321ED7CC18EAC9-8020
   Subsystem 1 - Part No SW: 6R0 915 181 B    HW: 6R0 915 181
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370150042
End-------------------------(Elapsed Time: 02:37)--------------------------
General VW/Audi Repair is for things that don't involve VCDS at all.
Moved to Retrofits.
Remind me, Error 22 is "Conditions Not Correct"?
Are you by chance trying to do this with the engine running?
Dannozz
C?ID=114179
No, It was on ignition only.
Dannozz
C?ID=114179
The problem is solved now. Apparently I had to change byte 10 also. Thanks Iichel and Luigid(from uk-polo) for pointing it out for me.
The reference video for the future retrofitters: https://www.youtube.com/watch?time_continue=2&v=8KuUtIizboE (thanks again Luigid)
Old drum coding:110224DB817500B3882C24E681D200521700
the new correct 110228DB817500B3882C14E681D200521700
iichel
Eindhoven, NB, NL
C?ID=284912
I'm here as well ;)
