This car has several issues, main one key does not communicate with locking system. Have not validated key battery, but wonder is J519, which I guess many manufacturers call body control has an issue. Also need to get a wire diag but on the 07Jetta is this thing under the seat and floating in water. Also the lean burn up off idle would like to access is the HPFP follower going west, all questions as I'm not into the gas engines, mostly diesel. Question??, with vag hooked up will I see a signal if looking at specific door locks when key buttons is initiated?? He is driving it now and will see what pops up again over time, but some went away and did not come back initially, will see.
Showed 2 scans here, then cleared all codes and see which come back over time as did not know who has played around in there before me. any advice would be appreciated, have a nice day.
LARIMORE.
LARIMORE.
Tuesday,16,April,2019,08:03:40:01722
VCDS Version: 18.9.1.0 (x64)
VIN: 3VWXJ71K07M053595 License Plate: KENT
Mileage: 182360km-113313mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 37 42 44 46 47 52 55 56 62
65 72
VIN: 3VWXJ71K07M053595 Mileage: 182360km-113313miles
62-Door, Rear Left -- Status: Malfunction 1010
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: 5BH14--- Serial number: VWZ7Z0F8085563
Coding: 0403010A1C070160
Shop #: WSC 23322 444 50471
VCID: 2B5E1D9C8A038A1258-807E
008567 - Bank 1; System Too Lean off Idle
P2177 - 001 - - MIL ON
Fault Status: 11100001
Mileage: 182174 km
Time: 00:41:23
RPM: 2349 /min
Load: 32.5 %
Speed: 92.0 km/h
Temperature: 90.0°C
Temperature: 10.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
Part No SW: 02E 300 043 C HW: 02E 927 770 AE
Component: GSG DSG 070 1158
Revision: 04507000 Serial number: 00000607190247
Shop #: WSC 00066 000 00000
VCID: 142CA660377D35EA69-8040
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73EEC5FC12B392D2D0-8026
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
VCID: 70E4CAF063A5A9CA2D-8024
00457 - Control Module for Network (J519)
013 - Check DTC Memory
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000000449768
Coding: 17078E234004150007140000001400000028770B5C0000
VCID: 377631EC464B3EF22C-8062
Component: Wischer 200906 020 0501
Coding: 00038805
Shop #: WSC 00066
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 231
Mileage: 182367 km
Voltage: 13.75 V
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7F8017815
VCID: 2A50189885F9931AA3-807E
Reset counter: 219
Mileage: 164555 km
Time: 01:02:56
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D05SLVW
Coding: 0013889
VCID: 6CDCDE804F8D4D2A11-8038
Subsystem 1 - Part No: 1K0 959 339 F
Component: BF-Gewichtsens. 007 0005
Subsystem 2 - Serial number: 6332MSME123B61296
Subsystem 3 - Serial number: 6342MSME117B6829H
Subsystem 4 - Serial number: 6351HSME2B2153630
Subsystem 5 - Serial number: 6361HSME0A6D0D77O
Subsystem 6 - Serial number: 63727SME0A5C47121
Subsystem 7 - Serial number: 63827SME0A600C12Z
Part No SW: 1K0 953 549 AS HW: 1K0 953 549 AS
Component: J0527 035 0070
Coding: 0012121
VCID: 030E953C4213A252C0-8056
Component: E0221 002 0010
Part No SW: 1K6 920 973 A HW: 1K6 920 973 A
Revision: V0003000 Serial number: VWZ7Z0F8085563
Coding: 0023207
Shop #: WSC 25807 067 57207
VCID: 31620FF4A82FE0C262-8064
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001067180623
Coding: 7FBF036A07001002
VCID: 2C5C1E808F0D8D2A51-8078
Reset counter: 253
Mileage: 181984 km
Time: 17:19:43
Component: IMMO VDD 1610
Address 37: Navigation Labels: 1K0-919-887-MFD2.lbl
Part No: 1K0 919 887 G
Component: Navigation 0050
Coding: 0000101
VCID: 3D7A23C4647714A2F6-8068
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1125
Revision: 12006001 Serial number: 00000528468825
Coding: 0001205
VCID: 3B7E2DDC7A631A92C8-806E
Fault Status: 00100101
Reset counter: 6
Mileage: 182163 km
01552 - Motor for Central Locking; Drivers Door (V56); Lock
Fault Status: 00101100
Reset counter: 16
Mileage: 149518 km
Fault Status: 01101000
Reset counter: 231
Mileage: 149518 km
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
Shop #: WSC 02069 000 90108
VCID: 346C06E0573DD5EA09-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CD HW: 1K0 959 433 CD
Component: KSG PQ35 RDK 051 0215
Revision: 00051000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DC00
VCID: 74ECC6E017BD95EAC9-8020
Fault Status: 01101101
Reset counter: 231
Mileage: 182367 km
Time: 07:57:13
Address 47: Sound System Labels: 3C0-035-456.clb
Part No: 1K6 035 456 A
Component: 08K Audioverst. 0005
Revision: 00003000 Serial number: 00000000010980
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1125
Revision: 12006001 Serial number: 00000045668825
Coding: 0001204
VCID: 3C7C2EC07F6D1DAAC1-8068
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
Address 56: Radio Labels: 1K0-035-095.lbl
Part No: 1K0 035 095 H
Component: Radio 0050
Coding: 0010046
00857 - CD Changer Unit (R41)
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1115
Revision: 12005001 Serial number: 00000000409119
Coding: 0001168
VCID: 3E7824C869710FBAEF-806A
Reset counter: 16
Mileage: 151011 km
Fault Status: 01101100
Reset counter: 231
Mileage: 151011 km
Component: RDK 0420
Coding: 0100101
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1115
Revision: 12005001 Serial number: 00000000453392
Coding: 0001168
VCID: 3F8659CC6E7B06B2E4-806A
Reset counter: 16
Mileage: 164552 km
Fault Frequency: 69
Reset counter: 231
Mileage: 164552 km
End-------------------------(Elapsed Time: 02:21)--------------------------
Tuesday,16,April,2019,08:14:38:01722
VIN: 3VWXJ71K07M053595 License Plate: KENT 2
65 72
Readiness: 0110 0101
Revision: 00H11001
Coding: 0021122
Coding: 00038805
Shop #: WSC 00066
Reset counter: 232
Mileage: 182367 km
Voltage: 13.85 V
Reset counter: 232
Mileage: 182367 km
Time: 08:09:06
Coding: 0013889
Coding: 0012121
Coding: 0023207
Coding: 0000101
Coding: 0001205
Reset counter: 232
Mileage: 182367 km
Time: 08:11:20
Coding: 0001204
Coding: 0000003
Coding: 0010046
Coding: 0001168
Component: RDK 0420
Coding: 0100101
Coding: 0001168
End-------------------------(Elapsed Time: 02:19)--------------------------
