Volkswagen TDI Diesel Engines Overview
Andy
Sector 7G
HC424490
This thread is a brief overview of TDI information for Santos/Bruce to give out the URL to students in tomorrow's demonstration at Morton's Automotive.
There are 3 basic types of Volkswagen TDI engines:
  1. VE = "Verteiler" or distributor/divider. Older (typically 1996-2003) that use relatively low pressure mechanical pump to inject fuel via ball-and-spring injectors.
    http://www.cs.rochester.edu/~jag/vw/engine/fi/injpump.html
    http://ross-tech.com/vag-com/cars/tdi.html
    http://forums.tdiclub.com/showthread.php?t=163435
  2. PD= "Pumpe Düse" or Unit Injector, typically 2004-2005
    http://en.wikipedia.org/wiki/Unit_injector
    http://forums.tdiclub.com/showthread.php?t=44072
    https://sites.google.com/site/1810martin/vcds-and-pd-tdi-engine-health-check
    Source: http://forums.tdiclub.com/showthread.php?t=61956
  3. CR = Common Rail, typically 2009-present
    http://en.wikipedia.org/wiki/Common_rail
    http://www.natef.org/natef/media/natefmedia/vw files/2-0-tdi-ssp.pdf
    http://www.volkswagen.co.uk/technology/diesel/tdi
VATN (Variable Area Turbine Nozzle) Turbocharger
Source: http://www.technologie-entwicklung.de/Gasturbinen/VNT15-Turbo/vnt15-turbo.html
Some useful TDI procedures from the Ross-Tech Wiki:
http://wiki.ross-tech.com/wiki/index.php/Diesel_Particle_Filter_Emergency_Regeneration
http://wiki.ross-tech.com/wiki/index.php/Fuel_Pump_Basic_Settings_for_PD,_PPD,_and_CR_TDI_Engines
http://wiki.ross-tech.com/wiki/index.php/2.0L_CR_TDI
http://wiki.ross-tech.com/wiki/index.php/3.0l_V6_TDI_(BKS/BMK/BUN)
Nice overview of DPF and Urea Injection:
http://www.myturbodiesel.com/1000q/vw-touareg-tdi-dpf-audi-q7.htm
Ross-Tech VCDS user manual:
http://www.ross-tech.com/vcds/tour/main_screen.html
The Ross-Tech Wiki encyclopedia of repair information:
http://wiki.ross-tech.com/wiki/index.php/Main_Page
Official Factory Repair Information:
http://www.bentleypublishers.com/volkswagen/technical-training/
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
Bentley Publishers Technical Training:
Here's an example scan of a 2012 Jetta TDI:
VCDS Version: Release 11.11.4
Data version: 20120807
Friday,23,November,2012,16:55:59:47158
Chassis Type: 6N0
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 37 44 47 56
VIN: 3VWLL7AJ9CM026390
Part No SW: 03L 906 019 EG HW: 03L 907 309 AA
Component: R4 2,0L EDC G000AG 1590
Revision: 12H14--- Serial number:
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 74C914C2170319B835D
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 057 A HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2705
Revision: 05351113 Serial number: 00001105081061
Shop #: WSC 02069 000 90108
VCID: 1713034E263592A0F0F
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: B14B400C492400008D0E02ED92190042A70000
VCID: 7BDB3FFEFA5D56C0747
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 A HW: 5K0 959 434 A
Component: VWKESSYPQ35GP 085 0802
Revision: 00085000 Serial number: 0148571123
Coding: 030C0C
ASAM Dataset: EV_KESSY_PQ35GP A01018
ROD: EV_KESSY_PQ35GP_VW36.rod
VCID: 334BD7DE9A8D5E80EC7
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 AQ HW: 5C0 820 047 AQ
Component: J301 Klimaanlage 0203
Revision: 2001010S Serial number: 00000000493878
VCID: 6FC31BAE7E253A60C8F
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0251
Revision: B2066001 Serial number: 04371214111142
Coding: 7A994BBF28EB2E0008382000240884C50082502E6000000030 A000000000
Shop #: WSC 00066 123 12345
VCID: 2F43DBAE7EA57A6088F
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3464
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3464
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.019 H08 0006
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3464
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3464
Coding: 800000
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 013 0807
Serial number: 003GTM014M2D
Coding: 00003936
ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: 3449D4C29F8359B8F5D
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y1100006A8Z0S
Coding: 303241
Serial number: 3572MSME182B6560ZZZW
Serial number: 3582MSME2B04265FZZZ$
Serial number: 3516KSME444D5411ZZZP
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME514D5711ZZZR
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME410B1712ZZZL
Crash sensor for front airbag; passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME2A031712ZZZL
Part No SW: 5C6 920 951 A HW: 5C6 920 951 A
Component: KOMBI H04 0604
Coding: 270A01
Shop #: WSC 00066 000 00118
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 297735B64841145056B
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0251
Revision: B2066001
Coding: 102200
VCID: F0C198D2231BA598515
Component: IMMO H04 0604
Coding: 000007
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EAF58ABA0DC75F481F1
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 11000144042004
Coding: 4900000000000000
Shop #: WSC 00066 790 50316
ROD: EV_ELVMarquMPVW36X_VW36.rod
VCID: 2E7DC6AA71AF7368839
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660318597
Coding: 020000
VCID: 297735B64041145056B
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 B HW: 1K0 035 274 B
Component: RNS315-NAR H32 0265
Serial number: VWZAZ2L8461464
Coding: 040904410100060000001000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_RNS315NARV2UDS A01004
ROD: EV_RNS315NARV2UDS_VW36.rod
VCID: 236B279E2A6DCE001C7
Component: NAR_V2 0002
1048646 - Rear View Camera
B1102 31 [009] - No Signal
Reset counter: 168
Mileage: 34973 km
Date: 2014.14.16
Time: 09:59:39
1048669 - Tuner for Satelite Radio
B11CF 53 [009] - Deactivated
Reset counter: 144
Mileage: 8984 km
Date: 2006.14.27
Time: 10:38:57
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
VCID: 3449D4C2578359B8F5D
Address 47: Sound System (R12) Labels: 3T0-035-456.clb
Part No SW: 3T0 035 456 B HW: 3T0 035 456 B
Component: KonzernAmp10K H06 0362
Revision: -------- Serial number: BP225319934040
ROD: EV_AudioVerst10KanalSTT3_VW36.rod
VCID: 3041D8D26B9B6598915
End ---------------------------------------------------------------------
From: http://forums.vwvortex.com/showthread.php?4868432
NOT a VW Marine Engine :-)
https://www.youtube.com/watch?v=WSBOTSC2hAs
Tinyurl of this thread:
http://tinyurl.com/ommlump
