Dear All,
I`m new to this forum and i`m trying to bech test the Audi A6 (4g, C7) EPS on bech. In the past i did the same with EPS for Vw Passat B6 and worked like charm, using a passat B6 gateway, the correct wiring and VCDS.
For now I`ve connected the (Audi A6, 4G - >2011)Gateway on bech and connected to it using CAN, but in gives me the following error :
0276 - FlexRay Databus
U1032 00 [009] - Initialization Failed
Reset counter: 85
Mileage: 149511 km
Date: 2018.05.24
Time: 09:44:01
Voltage terminal 30: 11.9 V
Voltage terminal 15: 11.9 V
Control Module temperature: 20 °C
System status: Terminal 15 on
IN ESP_standstill flag: no standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: On
Datenfeld: 0
Of course the EPS is connected as well, but it is connected on FlexRay pins of Gateway (Pin 24 + Flexray and Pin 8 - Flexray) ... and it`s not reacheble.
Any advice ?
I`ve triple checked the wiring and it`s correct, Maybe this EPS can be bech tested using different pins or approach, i`ve noticed the data plug has 6 pins but only 3 of them are in use. Now i`m using: Pin 2 - +12V, Pin 3 - positive Flexray (pink), Pin 5 - negative Flexray (Green) on the EPS ecu. How can i connect to this EPS on bech? I`m tired of try outs
( the EPS is 100% ok, i`ve tested it on a car not long time a go. The gateway is accesible on bech without any issues, but EPS is unreacheble. The Gateway also has optical data on it. Maybe i should loop that connection ?
Reset counter: 85
Mileage: 149511 km
Date: 2018.05.24
Time: 09:44:01
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 0
Any advice ?
