vasile76
I need your help with a problem related to the xenon adaptive headlights.
I have an A4 B9 from 2016 and, for a few weeks, the adaptive xenon headlights no longer move with the steering wheel and the cornering light are also inactive.
I think I did some coding or adaptation and the headlight settings were lost.
The problem is that I can not start the learning procedure from module 09 - Central Electric.
Every time I tried to start the procedure, after a second, appears Not Running, as can be seen from the link below.
In VCDS, in Basic Settings, at the Label File appears, NONE.
The car has no stored error.
Could you please tell me if I need an extra file for 09 module?
What can I do to start the learning procedure of the headlights?
Thank you very much.
https://imgur.com/a/Us4eVqu
Sunday,14,April,2019,13:36:16:64772
VCDS Version: 18.9.1.0
Data version: 20190215 DS296.0
VIN: WAUZZZF45GA016188 License Plate: BB14
Mileage: 79001km-49088mi Repair Order:
Chassis Type F4-AU49 (4M2)
Scan: 01 02 03 08 09 13 15 16 17 19 3C 42 44 46 52 5F 6C 81 8B A5
AC BB BC CF DE
VIN: WAUZZZF45GA016188 Mileage: 79001km-49088miles
CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
DE-Charger 1 for mobile dev -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DETA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 AD HW: 04L 907 309 L
Component: R4 2.0l TDI H33 1970
Revision: B1H33---
Coding: 0A254032236405083428
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TDI01104L906026AD 001006
ROD: EV_ECM20TDI01104L906026AD.rod
VCID: 6CEFA00A8776F32A11-8038
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 AC HW: 8W0 907 063 C
Component: BCM1 MLBevo H12 0229
Coding: 80451B42457D00CD01459754182C10F9590331000300000000 00000024001AA0274700ABC25706
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_BCM1BOSCHAU736 015005
ROD: EV_BCM1BOSCHAU736_015.rod
VCID: 7CCF904AF71663AA81-8028
Subsystem 1 - Part No SW: 8W1 955 119 HW: 8V1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS491 150926 043 0813
Serial number: 894353?0301526901192
Coding: 5BC7F7
Component: G397_RLFS H06 0004
Serial number: 60895146
Coding: 03005D
Subsystem 3 - Part No SW: 4M0 941 531 N HW: 4M0 941 531 N
Component: E1 - LDS H05 0007
Serial number: 20 08 2015 00074489
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE119101511910105
Coding: 030000
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 D HW: 8W0 947 135
Component: J528-Dachele H13 0080
Serial number: Q00014647
Subsystem 6 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H15 0010
Serial number: 2615000091884004
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 8W0 907 561 A HW: 8W0 907 561
Component: LRR4 H08 0160
Coding: 347FFF725CFFEF08949C80B6
ASAM Dataset: EV_ACCBOSCHAU49X 001016
ROD: EV_ACCBOSCHAU736.rod
VCID: 3C4F504AB796A3AAC1-8068
