On a 2005 Beetle. Bought it for $400 with a transmission error.
17100 - Transmission Input Speed Sensor (G182)
P0716 - 000 - Implausible Signal - Intermittent
Took out the transmission, it was white glove clean and perfect inside, changed the sensor.
While I was in there also changed the DMF, pilot, CVs and most of the front suspension.
Rear main looked perfectly clean and dry so I left it.
Put the thing back together and the transmission error is unchanged, transmission still randomly downshifts and misses upshifts.
I assume at this point I need to change the mechatronic unit?
Is there anything else that could cause this?
Sunday,14,April,2019,18:34:00:10819
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: 3VWCR31C55M403812 License Plate: BEEBEE
Mileage: 275950km-171467mi Repair Order:
Chassis Type: 1C (1C - VW New Beetle (1998 > 2010))
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
VIN: 3VWCR31C55M403812 Mileage: 275950km-171467miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 038 906 016 P HW: 028 101 181 3
Component: R4 1,9L EDC G000DG 7000
Revision: 12345678 Serial number: VWZ5Z0D6261194
Coding: 0150038
Shop #: WSC 00066 000 00000
VCID: 211F18FF5DDB4E3FB13-5160
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
RPM: 1197 /min
Torque: 62.0 Nm
Voltage: 11.25 V
Bin. Bits: 00101100
Temperature: 5.4°C
Bin. Bits: 10110000
16512 - Coolant Thermostat Valve (N214)
P0128 - 000 - Temperature below Control Range
RPM: 1764 /min
Torque: 164.0 Nm
Speed: 49.0 km/h
Temperature: 57.6°C
Fuel Consump.: 6.80 l/h
Temperature: 32.4°C
Temperature: 32.4°C
Absolute Pres.: 1560.6 mbar
16486 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low - Intermittent
RPM: 1134 /min
Torque: 60.0 Nm
Duty Cycle: 100.6 %
Bin. Bits: 00101100
Mass Air / Rev.: 660.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Readiness: 0 1 0 0 0
Part No SW: 02E 300 041 S HW: 02E 927 770 AD
Component: GSG DSG 041 0806
Revision: 00004010 Serial number: 00000405270014
Shop #: WSC 44551 111 44551
VCID: 221D17F358DD5527A89-5160
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Coding: 0019458
VCID: 3431E1ABF229CB974A5-5160
Address 15: Airbags Labels: None
VCID: 55F77C2F5D13F29F9DB-5160
Address 17: Instruments Labels: 1C0-920-x4x.lbl
Part No: 1C0 920 951 M
Component: KOMBI+WEGFAHRS. M73 V02
Coding: 11232
Shop #: WSC 23069
VCID: 2B03FAD72A17946F1BF-4B1E
3VWCR31C55M403812 VWZ5Z0D6261194
Part No: 6N0 909 901
Component: Gateway K<->CAN V022
Coding: 00006
Shop #: WSC 00066
VCID: 70B92DBBC3B1B7B76ED-4B1E
Part No: 1C0 959 799 G
Component: 2K Komfortgerát HLO 0004
Coding: 00016
Shop #: WSC 23072
VCID: 3B23CA97DA7704EF8BF-4B1E
35-00 - -
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1C0 035 196 M
Component: RADIO DE2 0003
Coding: 06031
Shop #: WSC 00066
VCID: 290F00DF20EB867FE93-51CE
End----------(Elapsed Time: 03:49, VBatt start/end: 13.7V/13.7V)-----------
