8030 - Cooling Oil Valve P179D 00 [040] - Electrical Malfunction
jedyaqub
C?ID=340170
Hi All - Just had this come on my dash. Auto scan is below. Can you advise what this is? I've checked other threads but the have a slightly different code. All support is appreciated!!!!
Saturday,13,April,2019,11:28:54:32917
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
VIN: WAUZZZ4G0CN132561   License Plate: HXZ 8527
Mileage: 103332km-64207mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 30 36 3B 42 44 46 52 53 55
          56 5F 62 6C 6D 72 82
VIN: WAUZZZ4G0CN132561   Mileage: 103332km-64207miles
Address 01: Engine (J623-CLAA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 311 E    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0001
   Revision: 53H37---
   Coding: 1A254012042601020800
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114G0907311E 001001
   ROD: EV_ECM30TDI0114G0907311E.rod
   VCID: 25170D5AA5690F7FCDB-8070
5619 - Engine Off Timer Performance
          P150A 00 [032] - -
                    Mileage: 101808 km
                    Date: 2019.03.23
                    Time: 17:24:57
                    Engine speed: 0.00 /min
                    Coolant temperature: 25 C
                    Intake air temperature: 13 C
                    Voltage terminal 30: 11.220 V
                    Unlearning counter according OBD: 28
                    Shut-off timer: last engine shut-off time: 2 s
                    Shut-off timer: last ECM after-run time: 50 s
                    Time since ignition off: 2 s
                    Shut-off timer: instrum panel counter: open circuit in term 30-Bits 0-7: 0
                    Terminal 15 status-Bits 0-7: 1
   Part No SW: 4G1 927 156 C    HW: 0B5 927 156 F
   Component: 0B5 30 TDIRdW H10 0001
   Revision: --H10---    Serial number: 0000001037
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 2D07F57AFD99373F05B-8078
                    Mileage: 103330 km
                    Date: 2019.04.13
                    Time: 09:19:53
                    Engine speed: 905 /min
                    Transmission input speed: 905 /min
                    Engine torque: -8 Nm
                    Transmission fluid temperature: 3 C
                    Accelerator position: 0.0 %
                    Clutch status: Beide Kupplungen offen
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 07A68703E065E1C0DB00
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 3635DA1608CF74E7741-8062
   Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
   Component: BCM2 2.0      H31 0333
   Coding: 01BA3006000000000000
   VCID: 76B51A1648CF34E7B41-8022
   Serial number: 2312000004918002
02823 - Requirements for Locking the Steering Column Lock not met
            000 -  -  - Intermittent
                    Reset counter: 98
                    Mileage: 101804 km
                    Date: 2019.03.23
                    Time: 10:50:49
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 H    HW: 4G0 820 043 H
   Component: KLIMA 2 ZONEN H10 0064
   Serial number: 14021200040649
   Coding: 3623000830
   ASAM Dataset: EV_AirCondiBasisUDS 002040
   ROD: EV_AirCondiBasisUDS_002.rod
   VCID: 2411105EAE53F677DA5-8070
0276 - Engine Off Timer Performance
          P150A 00 [008] - -
                    Reset counter: 98
                    Mileage: 101808 km
                    Date: 2019.03.23
                    Time: 00:00:01
                    Voltage terminal 30: 11.99 V
                    Terminal 15 status: Terminal 15 on
   Part No SW: 4H0 907 063 BN    HW: 4H0 907 063 F
   Component: BCM1 2.0      H12 0111
   Revision: 20012002    Serial number: 00000001403310
   Coding: 2600201141349FE00181008380001D0CCF9DC30A27090101000004602100
   VCID: 75B71D1A55C93FFFBDB-8020
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 120116  H35 0080
   Serial number:         120125154819
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 20067978
   Coding: 02562B
   Subsystem 3 - Part No SW: 4G0 941 531 G    HW: 4G0 941 531 G
   Component: E1 - LDS  H07 0044
   Serial number: 09 02 2012  00001241
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H02 0002
   Serial number: A2088316000000000001
   Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0050
   Revision: 11001001    Serial number: 55901204001608
   Coding: 280304
   ASAM Dataset: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000_002_AU57.rod
   VCID: 3D27C53A2DF9A7BFB5B-8068
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG006ZB59
   Coding: 30314530323130303133554A305234473853
   Serial number: 3575HRB4069131GUB0QA
   Serial number: 3585HRB404R14JQMB0E-
   Serial number: 3515JRB404V0P3T4J9P9
   Serial number: 3525JRB40530P3T468PC
   Serial number: 3554VRB40570VC0K80KL
   Serial number: 3564VRB405B0VC0K1P2Q
   Part No SW: 4H0 953 568 B    HW: 4H0 953 568 B
   Component: Lenks.Modul   H07 0007
   Revision: --------    Serial number: 90815JF80001Z
   Coding: 000434
   Shop #: WSC 02311 785 00200
   VCID: 323DE606E42768C7589-8066
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 23 04 2015  E0072584
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G8 920 982 K    HW: 4G8 920 982 K
   Component: TDieGb        H79 0416
   Revision: 28460177    Serial number: 658240112596046
   Coding: 33AF00020B032600010100
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K.rod
   VCID: 3C21C83E36E3AEB7825-8068
   Part No SW: 4G0 907 468 G    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0214
   Revision: --------    Serial number: 00000000398833
   Coding: 00CD077D00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 3431E01E1EB366F74A5-8060
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790762557
   Voltage stabilizer:
   Serial number: 12032000033021200181
          U140B 00 [008] - -
          [Powermanagement active]
                    Reset counter: 110
                    Mileage: 103317 km
                    Date: 2019.04.06
                    Time: 10:56:05
                    Voltage terminal 30: 12.2 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 4 C
                    System status: Awake_Timer_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 1
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000024965
   Coding: 01010101000000000001000202
   VCID: 6491505EEE53B6771A5-8030
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000023716266
   Coding: 0078130000006001000001010101102030303232203232
   VCID: 77AB17124FC54DEFAF7-8022
   Part No SW: 4G0 907 637     HW: 4G0 907 637
   Component: SARA 3D       H02 0009
   Revision: --------    Serial number: EJ1BPA3201EF8.0
   ASAM Dataset: EV_SARA 009017
   ROD: EV_SARA_009.rod
   VCID: 6B833B62030DF90F5BF-803E
   Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
   Component: TSG FA        H05 0212
   Coding: 011F56225E21620002080402
   VCID: 42DDB6C65487D847C89-8016
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0026334100
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323DE606E4A768C7589-8066
18689 - Terminal 30
          U140A 00 [008] - Open Circuit
          [Ausfall der Versorgungsspannung (Kl30 oder Kl31) im Stillstand (unkritisch)]
                    Reset counter: 98
                    Mileage: 101808 km
                    Date: 2019.03.23
                    Write only channel
   Revision: 00002001    Serial number: 0169636652
   Coding: 013B062220B9BC8083200A04000102000000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0028
   Serial number: WA102824000000969464
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   VCID: 41DFB9CA5181C35FD13-8014
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000246117
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A0DFE66CC772007E09-807E
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 120214-0001-114
   Coding: 1123A6101000A300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C01F87EC6833E37125-8078
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109B$0C7547763
   Coding: 010103020100000001
   VCID: 2D07F57AFD19373F05B-8078
   Part No SW: 4G0 035 670 Q    HW: 4G0 035 670 A
   Component: H-BNT-EU      H48 1034
   Revision: --------    Serial number: 428BO0C7540122
   Coding: 090101040003E5FF45008B3E00000003000001000000000000
   VCID: 313FE90AE12153DF213-8064
   Subsystem 1 - Part No: 8R0 060 884 AH
   Component: EUR 2012  1308
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB9400S15H
   Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349LB4000EI
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 95
                    Mileage: 101511 km
                    Date: 2019.03.21
                    Time: 08:25:27
                    Voltage: 12.20 V
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F14224021620002080002
   VCID: 44D1B0DE4E93D677FA5-8010
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H10---    Serial number: 525 PA8JCXG01K
   Coding: 1020013
   VCID: 26150A56D4EF0467C41-8072
03006 - Back-up Camera System not calibrated
            000 -  -
                    Reset counter: 29
   Part No SW: 4G8 959 107 N    HW: 4G8 959 107 F
   Component: HDSG-Modul    H13 0039
   Revision: 11013001    Serial number: 036200345
   Coding: 0A3305C002
   ASAM Dataset: EV_HDSGAu573 001014
   ROD: EV_HDSGAu571.rod
   VCID: 40D9BCCE5A0BCA57DED-8014
   Component: TSG HR        H04 0212
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4G8 919 604 J    HW: 4G8 919 604 J
   Component: HeadUpDisplay 008 0106
   Coding: AA0000
   ASAM Dataset: EV_HUDContiC7 001020
   ROD: EV_HUDContiC7.rod
   VCID: 3A2DCE263CD79087909-806E
End----------(Elapsed Time: 02:15, VBatt start/end: 14.0V/14.7V)-----------
jedyaqub
C?ID=340170
Thanks for the response, much appreciated. Am I going to take a bath o n repair costs?
golfi_vend
Tartu, Estonia
C?ID=195131
So,
TPI is 2039534/12
You need to consult local prices, but I'm seeing prices for repairkit of 500euros, some bolts, oil quantity of 7L costing around 30e per liter.
I believe this also needs genuine ODIS before and after to run software update and determine clutch wear value.
Labor should be around 4 hours.
jedyaqub
C?ID=340170
Thanks very much for checking. Appreciated.
Stupid question but is this something I should fix immediately or wait till something fails? There are no symptoms at present except for the error message. Thanks again.
jedyaqub
C?ID=340170
Ok. Thanks. Will do!
