2004 Passat B5.5 W8 M/T
Greetings, picked up a oddball wtf 8 cylinder 1 of 11 Silverstone Gray sedan Passat and having troublesome on a few codes.
First scan when I got home, and what I've done and think I might know, or not.
03: ABS Brakes-First start the car, sometimes but not always, the ABS and Traction Control lights are on. And sometimes they don't, until after a few minute, or begin driving. I've checked connections from left front all the way to inside wheel well. ABS wheel inside rotor has light surface rust. Cleaned and inspected sensor. (doesn't mean it's good though) Checked measuring blocks and all 4 wheels are reading same mph even with lights on. Engine light comes on 10-30 min of driving which I assume is related to front left ABS fault. Vehicle speed sensor has been replaced, but throws code as shown. Also, speedo is 5 mph fast by 3 different GPS devices. OEM rims and correct tire size in place.
08: Auto HVAC-Flaps work fine to any position I put them to. Clueless to the faults.
17: Instruments, 19: CAN Gateway, 75: Telematics No label?-Throwing different faults because it's an aftermarket Kenwood DDX372BT. Not much to do about that, correct? Would rather have original Monsoon.
36: Seat Mem. Drvr - Seat(s) work fine in all positions.
55: Headlight Range - Most likely a frayed, bare wire touching inside the housing due to hotter than hell xenon and insulation age. Common VAG problem that I've yet to pull front clip and headlights to inspect and most likely heat shrink and polish lens to new.
Any advice or direction is greatly appreciated on these issues. It's a great car that got bad reviews because of the W8, but with 3" duals straight back from cats and a 6-spd m/t to boot, it's different and a blast to drive. Reviews anyways are like 1.8's and 2.8's. Everyone has one, even me.
Also, can't seem to pull up the Gateway list. It's like, not there.
Monday,25,March,2019,20:08:17:45417
VCDS Version: 18.9.1.0 (x64) HEX-NET CB: 0.4437.4
Workshop Code: 444 46561 004666
VIN: WVWKK63B84P146078 License Plate:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
VIN: WVWKK63B84P146078 Mileage: 309440km-192277miles
Address 01: Engine Labels: 07D-906-018-BDP.lbl
Part No: 07D 906 018 AP
Component: B5S-4.0L-HS-LEG 5204
Coding: 00172
Shop #: WSC 14627
VCID: 74A4DBB6460A46EAC9-513C
WVWKK63B84P146078 VWZ7Z0C8148920
16885 - Vehicle Speed Sensor
P0501 - 35-00 - Implausible Signal
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 AA
Component: ABS/ESP allrad 2329
Coding: 05395
Shop #: WSC 00028
VCID: 608CA7E6E2F2CA4ABD-51CE
00283 - ABS Wheel Speed Sensor; Front Left (G47)
30-00 - Open or Short to Plus
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B7 907 044
Component: CLIMATRONIC B5W8 0005
Coding: 27210
Shop #: WSC 05311
VCID: 6484ABF6F6EAD66A59-5184
00603 - Footwell/defroster Flap Positioning Motor (V85)
37-00 - Faulty
01271 - Positioning Motor for Temperature Flap (V68)
37-00 - Faulty
01272 - Positioning Motor for Central Flap (V70)
37-00 - Faulty
37-00 - Faulty
Part No: 1C0 909 605 C
Component: 0C AIRBAG VW61 04 0003
Coding: 12355
Shop #: WSC 00028
VCID: 2404EBF6B66A966A99-513C
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00118
Shop #: WSC 00028
VCID: 2F2E14DAEFAC253274-5160
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B7 920 949 A
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 31236
VCID: 2E1009DEE8A62C3A7F-513C
01304 - Radio
49-00 - No Communications
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00028
VCID: 70ACD7A632127ACA2D-513C
01304 - Radio
Address 36: Seat Mem. Drvr Labels: 3B1-959-760.lbl
Part No: 3B1 959 760 E
Component: °301
Shop #: WSC 00000 008 00000
VCID: 2F2E14DABFAC253274-513C
9 Faults Found:
01008 - Note; Emergency OFF Switch is Active!
00994 - Sensor for Front Height Adjustment On Drivers Seat (G215)
00995 - Sensor for Rear Height Adjustment On Drivers Seat (G216)
01009 - Sensor for Driver's Seat Position Fore/Aft (G218)
01010 - Sensor for Driver's Seat Recline (G219)
00999 - Motor for Front Height Adjustment of Driver's Seat (V29)
01000 - Motor for Rear Height Adjustment of Driver's Seat (V30)
01173 - Motor for Driver Seat Fore/Aft Adjustment (V28)
00998 - Motor for Driver's Seat Recline (V45)
Part No: 1C0 959 799 C
Component: 09 Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00028
VCID: 373E2CBA17FCEDF22C-4B00
Subsystem 1 - Part No: 1C0959801
Component: 09 Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C0959802A
Component: 09 Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811
Component: 09 Tõrsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812
Component: 09 Tõrsteuer.HR KLO 0202
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00008
Shop #: WSC 00028
VCID: 04448B7616AA766AF9-4B3C
00774 - Level Control System Sensor; Rear Left (G76)
31-00 - Open or Short to Ground
Address 58: Aux Fuel Tank Labels: 3B7-906-268.lbl
Part No: 3B7 906 268 A
Component: Kraftst. Zusatztank 0005
VCID: 2C1403D6DEBA5E2A51-513C
Address 75: Telematics Labels: None
Part No SW: 3B0 035 617 G HW: 3B0 035 617 G
Component: Telematik NAR1 0410
Coding: 0041110
Shop #: WSC 01080 444 00741
VCID: 2208EDEEFC7E985AEB-5118
01304 - Radio
01304 - Radio
End----------(Elapsed Time: 04:01, VBatt start/end: 14.1V/14.0V)-----------
